León Mk3 - Actualización infotainment
Favoritos: BADS, Daruma, ositoerik, dmesanun, YeSL, pocososinos, jasoriab, JaviMarquez, crujipoyo, Arkan7, Cristianibias, pepeiyo69, Angel J, Xaggy, edumachuca, abollao, -alberto-, Rickymax, ferre7, Pedritoleon, Rivesgti, Alleya, davidalba, Xiguito_Corito, craken, JDCLEONFR, nemura, danihd, cenkkaya, Kisszabo, castell_lkpg, pistoleromtb, Raulportela, Martelinko, albert_naga, Adrian Anton, Gravilhas75, chaiser, popez, ruli68, denniisg2000, LeonFR80bsv
Seguidores: kenny_fonseca, ncx, Lavadora, barris31, juancete, ivantxe, jesusFR, Hysteria, MaximusRoco, Manu1986, Jorge75016, davidbj, bIxu, miyobe, MORKAS, gorkansr, aironsam14, jramis, kimudj, Maikermx, Javizormo, gogua, Melonkid, Kikote8, danirodrigueze30, maxinew, aigort, carlosgzlez, corderazo, Lionxp, jande, Edu1589, msmdraven, Arkan7, inamarlo, edumachuca, Josepo79, lead, camamaleon, davidmd, carrasco13, clavelstreet, mikomiko, josele77, car212121, itz18, golf_1990, LeidenSpain, vecnte, Andy_G, csabafr2013, leonfr76, Trimmer, genialsoft, Enerts, leonfrrojito, Horus, paco_22_22, ruben88, Valerofr150, molvi_mabad, Pekee69, Dav2k6, IbiFR, il_munyo, craken, ruben91mad, papo-182, el_padrino, zeratul, kaiserssosse, lytry32.hc, sbarri, ghitus, DesmoSimon, ruli68, Mramos1985, tonielfilas, braulioT, davidalba, JaviMarquez, osjamil, egarense69, fexposru, Pedrost, Illan, chetelopez, juanacho21, cuenka16, pepeiyo69, VapaV, AlvaroPM13, balbu, juan7777, mams69, Helrique, Kike77, volkov, jluis, loeches, Tom70, Dconnect, Trivi83, MilleMiglia, linxes, sergi303, hector37, D83, quiquito30lv, ElFon, DALOFER17, davidap13, kigua, JOTTA, Senuto, jd_zuri, Alvi, damsolu, Leon pucelano, javi_archi, danihd, alcoleazgz, miguel23and, xarlio, jdieztec, mitxuni, Kisszabo, Gendos22, xexpir, canijo82, Brandenor, cenkkaya, kennit0, Chelazo, bertoco, benitogomez, carlosVACA, Peje, NOECUBI1, AAAJDA, trazas, martija, borjiguez, JoseXS, ferbarroso14, Wespa, Cloud_ganora, Berbe15, Valengti, Chrohu, Atajunen, Victorzabal, jrm82, carlo13, iNFeCTeD, paralaxon, ateopoeta, pepo55, ribasxisco, Raulribarroja, ivanti, Jansel, lopezm0, Rubén Flp, Warelio, Vagabundo, Rekoba, Octacon, matiaso, Alianma, Raulportela, Éugen91, Rivesgti, Mcm90, DaniR86, Gravilhas75, JuanNur78, el_Asturiano, Mr.Chuflas, albert_naga, juanfrancia, Seket, algabe, pistoleromtb, ebcuatro, [GuErRa], Mario Leon, tito68
Re: León Mk3 - Actualización infotainment
Notapor Éugen91 el 10 Feb 2021, 21:41
noe mrtel escribió:no es la h41 eso es lo extraño en version de sofware me aparece lo siguiente en el video se ve pero te lo escribo pone
Vercion del sofware H29.319.58STD2 PLUS EU eso es lo que pone asique interpreto que no es la h41 ? entonces no creo que pueda actualizarlo con ese no?
Por lo que veo tienes la 0472. La siguiente que tienes que actualizar es la que te puso el compañero. Y el MEGA que te pase. Para estar seguro. Vete a ajustes, información de sistema. Allí te viene la versión y el firmware que tienes instalado. Un saludo
Éugen91
Agradecido: 29 veces
Notapor Warelio el 10 Feb 2021, 21:46
Lo que me parece extraño es que teniendo una unidad H29, el firmware que lleva instalado sea un 0462, por lógica debería empezar por 02XX
Enviado desde mi Pixel 4 XL mediante Tapatalk
Warelio
Moderador de Racing
Agradecido: 1182 veces
Notapor noe mrtel el 10 Feb 2021, 21:59
https://ibb.co/3By93YK
https://ibb.co/nrQQPVj
que raro en un lado pone h29 y en otro h41 escribi una cosa en la pagina anterior por si quieres chequearla y otra duda que me surge es tengo que extraer los archivos y copiarlos ala sd ? o directamente meto el zip y el coche los extrae ?
noe mrtel
Notapor Éugen91 el 10 Feb 2021, 22:05
Tienes la h41 con la 0472. Tienes que actualizar a la 0479. Tienes qje extraer y copiar todo los archivos a la sd sin ninguna carpeta de por medio.
Éugen91
Notapor noe mrtel el 10 Feb 2021, 22:13
muchas gracias fenomeno te lo agradesco para no saturar el tema te escribi un mensaje privado que un amigo tiene el cupra y quisiera actualizarlo el tambien si quieres puedes mirar el mensaje privado y me contestas por ayi muchas gracias por tu dedicacion
noe mrtel
Notapor Éugen91 el 10 Feb 2021, 22:14
noe mrtel escribió:muchas gracias fenomeno te lo agradesco para no saturar el tema te escribi un mensaje privado que un amigo tiene el cupra y quisiera actualizarlo el tambien si quieres puedes mirar el mensaje privado y me contestas por ayi muchas gracias por tu dedicacion
Te acabo de contestar , mira a ver si te ha llegado
Éugen91
Notapor noe mrtel el 10 Feb 2021, 22:15
y sin niunguna carpeta por medio te refieres a cojer los archivos ke estan dentro de la carpeta ? osea la carpeta tiene el nombre mst2... ect le das y dentro aparece un monton de carpetas mas, bluetoo mainplus ect ect todas esas las pongo en la tarjeta sd ? eso entendi,
noe mrtel
Notapor Lito69 el 11 Feb 2021, 10:08
Éugen91 escribió:Tienes la h41 con la 0472. Tienes que actualizar a la 0479. Tienes qje extraer y copiar todo los archivos a la sd sin ninguna carpeta de por medio.
Se refiere todo a la raiz de la sd, sin estar dentro de ninguna carpeta.
Lito69
Agradecido: 240 veces
Notapor Oscargarciag el 12 Feb 2021, 18:00
Alguien tendría, por casualidad, la versión 0368 (la última publicada para el hardware H30)? Gracias de antemano!
Oscargarciag
Notapor DaniR86 el 13 Feb 2021, 20:36
Buenas tardes compiss, creo que me voy a aventurar a instalar la 479 en un h41, en principio 186 paginas despues creo que lo tengo claro todo el proceso, obviamente conozco los riesgos, no es que me gusten pero... :( , pero lo que me deja mal sabor de boca es lo del fallo 1555 que eso no me llega a gustar mucho, leí en otro post quien habia en cada provincia y con que dispositivo, lo digo para despues contactar y que se quite el fallo.
Como lo veis?? Le tiro pa adelante o me quedo como estoy??
Gracias Leoneros un saludo
Última edición por DaniR86 el 14 Feb 2021, 20:29, editado 1 vez en total
Leon ST 2.0 TDI 150CV Rojo Desire :enamorado:
DaniR86
Notapor simon.piwecki el 14 Feb 2021, 15:03
Hola juntos,
Tengo el siguiente sistema de infoentretenimiento:
Dispositivo P / N: 5F0035043V
Hardware: H41
Software: 0123
Versión de SW Train instalada: MHI2_ER_SEG11_S0257
Hasta donde yo sé, puedo realizar los siguientes pasos:
0123 -> 0674 -> 0818 -> 1447
Alguien puede confirmar eso?
Y la pregunta más importante es, ¿dónde puedo conseguir estos firmwares?
Gracias por adelantado!
simon.piwecki
Notapor leonfrrojito el 14 Feb 2021, 19:46
DaniR86 escribió:Buenas tardes compiss, creo que me voy a aventurar a instalar la 479 en un h41, en principio 186 paginas despues creo que lo tengo claro todo el proceso, obviamente conozco los riesgos, no es que me gusten pero... :( , pero lo que me deja mal ssbor de voca es lo del fallo 1555 que eso no me llega a gustar mucho, leí en otro post quien habia en cada provincia y con que dispositivo, lo digo para despues contactar y que se quite el fallo.
Puedes hacerlo sin problemas el XOR con OBDeleven o Vagcom lo puedes solucionar , aunque tengas el error te va a funcionar todo correctamente .
leonfrrojito
Agradecido: 178 veces
Notapor DaniR86 el 14 Feb 2021, 20:42
leonfrrojito escribió:
DaniR86 escribió:Buenas tardes compiss, creo que me voy a aventurar a instalar la 479 en un h41, en principio 186 paginas despues creo que lo tengo claro todo el proceso, obviamente conozco los riesgos, no es que me gusten pero... :( , pero lo que me deja mal sabor de boca es lo del fallo 1555 que eso no me llega a gustar mucho, leí en otro post quien habia en cada provincia y con que dispositivo, lo digo para despues contactar y que se quite el fallo.
Gracias @leonfrrojito
En estos días intentaré actualizarlo y buscaré a alguien para que me elimine el error por mi zona ya que no tengo ni Obd ni vagcom :shock: en fin haber como queda la cosa, soy de Graná alguien de por aquí para ayudar :lol:
Saludos y gracias jeje
DaniR86
Notapor AlberMC el 16 Feb 2021, 11:50
Buenos días gente! una pregunta rápida:
Tengo mi león mk3 desde enero 2020, no he actualizado nunca.
La cuestión es... cambia mucho con actualización? no sé, cambian muchas cosas o hay alguna mejora en algo?
Me caga un poco el actualizarlo la verdad...
No gana el que más corre, gana el que menos frena.
AlberMC
Agradecido: 134 veces
Notapor Warelio el 16 Feb 2021, 12:15
En general las actualizaciones del Firmware no suelen llevar cambios drásticos más allá de optimización de tiempo de respuesta o de arreglo de algún cuelgue inesperado de la misma unidad, estética o funcionalmente apenas suelen haber cambios y salvo que tu unidad actual funcione mal o de muchos fallos y lo puedas demostrar en la casa no te la van a actualizar. Puedes buscar aquí si existe un firmware actualizado para tu unidad, siendo tu coche de 2020 es posible que ya tenga la versión más reciente instalada pero puedes comprobarlo a ver. Actualizar firmware de fábrica es sencillo y no conlleva ningún problema si se siguen los pasos.
Warelio
Moderador de Racing
