León Mk3 - Actualización infotainment
Favoritos: BADS, Daruma, ositoerik, dmesanun, YeSL, pocososinos, jasoriab, JaviMarquez, crujipoyo, Arkan7, Cristianibias, pepeiyo69, Angel J, Xaggy, edumachuca, abollao, -alberto-, Rickymax, ferre7, Pedritoleon, Rivesgti, Alleya, davidalba, Xiguito_Corito, craken, JDCLEONFR, nemura, danihd, cenkkaya, Kisszabo, castell_lkpg, pistoleromtb, Raulportela, Martelinko, albert_naga, Adrian Anton, Gravilhas75, chaiser, popez, ruli68, denniisg2000, LeonFR80bsv
Seguidores: kenny_fonseca, ncx, Lavadora, barris31, juancete, ivantxe, jesusFR, Hysteria, MaximusRoco, Manu1986, Jorge75016, davidbj, bIxu, miyobe, MORKAS, gorkansr, aironsam14, jramis, kimudj, Maikermx, Javizormo, gogua, Melonkid, Kikote8, danirodrigueze30, maxinew, aigort, carlosgzlez, corderazo, Lionxp, jande, Edu1589, msmdraven, Arkan7, inamarlo, edumachuca, Josepo79, lead, camamaleon, davidmd, carrasco13, clavelstreet, mikomiko, josele77, car212121, itz18, golf_1990, LeidenSpain, vecnte, Andy_G, csabafr2013, leonfr76, Trimmer, genialsoft, Enerts, leonfrrojito, Horus, paco_22_22, ruben88, Valerofr150, molvi_mabad, Pekee69, Dav2k6, IbiFR, il_munyo, craken, ruben91mad, papo-182, el_padrino, zeratul, kaiserssosse, lytry32.hc, sbarri, ghitus, DesmoSimon, ruli68, Mramos1985, tonielfilas, braulioT, davidalba, JaviMarquez, osjamil, egarense69, fexposru, Pedrost, Illan, chetelopez, juanacho21, cuenka16, pepeiyo69, VapaV, AlvaroPM13, balbu, juan7777, mams69, Helrique, Kike77, volkov, jluis, loeches, Tom70, Dconnect, Trivi83, MilleMiglia, linxes, sergi303, hector37, D83, quiquito30lv, ElFon, DALOFER17, davidap13, kigua, JOTTA, Senuto, jd_zuri, Alvi, damsolu, Leon pucelano, javi_archi, danihd, alcoleazgz, miguel23and, xarlio, jdieztec, mitxuni, Kisszabo, Gendos22, xexpir, canijo82, Brandenor, cenkkaya, kennit0, Chelazo, bertoco, benitogomez, carlosVACA, Peje, NOECUBI1, AAAJDA, trazas, martija, borjiguez, JoseXS, ferbarroso14, Wespa, Cloud_ganora, Berbe15, Valengti, Chrohu, Atajunen, Victorzabal, jrm82, carlo13, iNFeCTeD, paralaxon, ateopoeta, pepo55, ribasxisco, Raulribarroja, ivanti, Jansel, lopezm0, Rubén Flp, Warelio, Vagabundo, Rekoba, Octacon, matiaso, Alianma, Raulportela, Éugen91, Rivesgti, Mcm90, DaniR86, Gravilhas75, JuanNur78, el_Asturiano, Mr.Chuflas, albert_naga, juanfrancia, Seket, algabe, pistoleromtb, ebcuatro, [GuErRa], Mario Leon, tito68
Re: León Mk3 - Actualización infotainment
Notapor el_Asturiano el 04 May 2021, 16:50
el_Asturiano escribió:
jasoriab escribió:Las unidades H42 son unidades high (Navisystem Plus) por lo que la nomenclatura de las versiones es distinta a las unidades estándar, donde si se cumple que coincide el dígito de la decena de la versión hardware con el dígito de la centena de la versión software.
@el_Asturiano ¿Es esta la referencia de tu unidad?, viewtopic.php?f=9&t=118140&start=2505
Las high creo que iban por la 1409 ó 1447 (no sé si habrá salido de las betas esta última versión o no)
Te paso una imagen que creo que viene la referencia de la unidad, sino me dices donde puedo mirarlo.
Viendo la versión que tengo ¿hasta donde pueden actualizarlo? ¿voy a notar mucha diferencia respecto a lo que tengo?
El martes que dejo el coche intentaré enterarme de lo máximo posible y lo comparto con vosotros :comediante: Por eso también ahora os estoy leyendo, para aprendertodo lo que pueda sobre este tema y el martes hacer las preguntas correctas y sacar el máximo posible de información.
Warelio escribió:Muy complicado que en Seat actualicen el Infotainment si no hay pruebas evidentes de que falla constantemente y tiene fallos demostrables. Es cierto que hay algunos modelos de móviles que puede generar conflictos más que otras marcas. Xiaomi o Huawei tienen unos protocolos en el tema de ahorro de batería bastante estrictos y eso muchas veces genera conflictos de compatibilidad. Echa un vistazo en este hilo a ver si existe una versión de Firmware para tu unidad.
Saludos,.
Enviado desde mi Pixel 4 XL mediante Tapatalk
A mi me llamaron ayer de la seat para decirme que mi coche esta en una campaña para actualizar el infotainment. La comercial que me llamo no me supo explicar más que necesito dejar el coche de un día para otro, que tienen que cambiar una pieza, y que puedo perder la actualización de los mapas del navegador que yo mismo actualicé. Y que si no hago la campaña podría tener problemas en un futuro con el infotainment :plas:
Hardware: H42
Software: 0319
Esos son mis datos. ¿alguien sabe algo? Porque estoy bastante mosqueado con el tema. Decir que a mi jamás me ha dado un solo problema ni la pantalla ni nada relacionado con el infotainment. Me va perfecto todo.
¿Si me actualizan el infotaiment que ventajas puedo tener respecto a la version de origen que tengo? ó ¿sabeis si la version que tengo ha dado algun problema y por eso necesita actualización?
Gracias por la info chicos :ok:
Esta unidad tiene pinta que sea de las primeras que salieron, las acabadas en A, unidad high. Esto se puede actualizar hasta la 1447, nose si actualmente tienes full link etc.. pero que sepas que lo puedes tener.
Si tengo full link y lo he usado. Gracias por la info compi :ok:
Ya tengo el coche. Dejo fotos del número de campaña que me han aplicado y de la versión que me han actualizado, creo que solo cambia la última letra.
Decir que deje el coche a las 8 y a las 12 ya lo tenía. Y que no me quisieron contar. Solo que es una actualización para que en un futuro no de problemas la versión que tenía.
A ver si sabiendo el número de campaña alguien puede aportar más datos. Yo no he notado ninguna diferencia, ni he perdido ninguna modificación, todo correcto.
Pd: lo único que me ha dejado de funcionar ha sido el automático de la ventanilla delantera izquierda. Estoy bastante cabreado, porque cuando lo dejé funcionaba, y he estado intentando volver a configurarla y no hay manera. Y creo que es problema mecánico ya que la tecla no baja a la posición dos, se queda en la uno por muy fuerte que la expulse. Pero bueno indagare en el foro a ver como puedo solucionarlo. En principio actualizar infotainment no tiene nada que ver con la programación de las ventanillas no?
Gracias chicosImagenImagen
Enviado desde mi SM-G975F mediante Tapatalk
el_Asturiano
Agradecido: 110 veces
Notapor Octacon el 04 May 2021, 16:56
Saludos,.
Hardware: H42
Software: 0319
Puedes colgar la version que tienes de sw? Ostia que cosa mas rara, tienes el mismo sw pero tienes el hardware acabado en Y
Octacon
Agradecido: 95 veces
Notapor el_Asturiano el 04 May 2021, 18:33
Saludos,.
Hardware: H42
Software: 0319
Es 0319 no?
Lo que me ha cambiado es el número de pieza de dispositivo, que ahora acaba en Y y antes acababa en A. Que diferencia hay?Imagen
el_Asturiano
Notapor Octacon el 04 May 2021, 20:07
Saludos,.
Hardware: H42
Software: 0319
Es 0319 no?
Nose pero es muy raro eso x lo menos por lo que yo he visto, por ejemplo yo tenia una acabada en C y al actualizar el sw a la ultima version la letra cambio a K, pero Y??
Octacon
Notapor jasoriab el 05 May 2021, 09:28
La verdad es que no hay mucha información sobre la campaña 91U4 para el León Mk3, aunque al menos tiene ya un año.
Lo único que he encontrado es esto, en el foro alemán del León, https://www.seat-leon.de/forum/threads/ ... 05.122401/
En el último mensaje se comenta que parece que se ha solucionado un problema con el volumen del subwoofer.
Según Google Translate sería esto:
Además del trabajo de garantía adicional, también se llevó a cabo la acción de servicio 91U4 en mi Seat Leon FR 1.8 (BJ 03/2016) y se llevó a cabo una actualización del MIB2 (Navi Plus).
Antes de eso, mi Navi Plus siempre tenía este molesto error en el subwoofer en relación con el sistema de sonido del asiento.
Después de reiniciar el motor, la potencia del subwoofer establecida en el menú de sonido ya no correspondía al valor establecido en el menú.
El subwoofer era entonces significativamente más débil o más silencioso. Restablecer a un nivel más bajo resultó en un sonido de subwoofer significativamente más fuerte.
Siempre tengo el subwoofer en el nivel 6 y creo que este molesto error finalmente se ha solucionado con la actualización actual o se ha reducido considerablemente.
Desafortunadamente, no tengo información más detallada sobre el alcance de esta actualización. Pero estoy muy satisfecho con el resultado
jasoriab
Agradecido: 2051 veces
Notapor pacoooooo el 25 May 2021, 14:59
Hola chicos
quiero actualizar mi infotaiment y tengo la version SW train instalada MHI2_ER_SEG11_P4517 y he encontrado esta otra MHI2_ER_SEG11_P4709_MU1447 , seria compatible con la mia? es que no vaya actualizarlo y lo fria.
pacoooooo
Agradecido: 41 veces
Notapor Lito69 el 02 Jun 2021, 16:05
pacoooooo escribió:Hola chicos
Sí, esa es la última, la que llevo yo
Lito69
Agradecido: 240 veces
Notapor pacoooooo el 05 Jun 2021, 13:22
Y te salió álgun fallo despues de la actualización? es que si puedo mañana domingo me pondré con ello.
pacoooooo
Notapor Octacon el 05 Jun 2021, 14:14
Última edición por Octacon el 05 Jun 2021, 14:15, editado 1 vez en total
Octacon
Notapor Octacon el 05 Jun 2021, 14:15
Tu unidad es OEM?
Octacon
Notapor pacoooooo el 05 Jun 2021, 20:32
Tu unidad es OEM?
La unidad que yo llevo es la original que viene con el coche, no esta hackeada ni nada.
pacoooooo
Notapor Alexroll el 05 Jul 2021, 13:49
Buenas, soy nuevo y me gustaría actualizar el sistema de infotainment de mi coche pero por mas que veo en internet solo encuentro el software para mi coche en el portal de software del ateca. Mi pregunta es si ¿puedo actualizar con dicho software, o tendría que buscar la actualización que fuera exclusivamente para Seat Leon?. Me gustaria que siguiera apareciendo el modelo de mi coche y no que cambiara a un ateca.
Hardware:H50
Mi Unidad: 5F0035877
Mi Software: MST2_EU_SE_ZR_P0514T
Actualizar a: MST2_EU_SE_ZR_P0515T
Saludos y muchas gracias de antemano.
Alexroll
Notapor Lito69 el 06 Jul 2021, 03:01
Alexroll escribió:Buenas, soy nuevo y me gustaría actualizar el sistema de infotainment de mi coche pero por mas que veo en internet solo encuentro el software para mi coche en el portal de software del ateca. Mi pregunta es si ¿puedo actualizar con dicho software, o tendría que buscar la actualización que fuera exclusivamente para Seat Leon?. Me gustaria que siguiera apareciendo el modelo de mi coche y no que cambiara a un ateca.
Hardware:H50
Sí, y a la 516 si la encuentras
Lito69
Notapor jasoriab el 06 Jul 2021, 09:27
Hola @Lito69
¿Ha sacado SEAT una nueva versión para los Navisystem estándar?
Si es así, buena noticia, que sigan actualizando las unidades, aunque ya hayan sido sustituidas por las MIB3 en los modelos nuevos, esperemos que dure...
jasoriab
Notapor Lito69 el 06 Jul 2021, 18:16
jasoriab escribió:Hola @Lito69
La tengo en mi pc sí, parece que corrige algo del full link, si me pasas un enlace donde lo pueda subir lo subo.
Lito69
