León Mk3 - Actualización infotainment
- Seguidores: 188
- Favoritos: 42
- Vistas: 653.502
Favoritos: BADS, Daruma, ositoerik, dmesanun, YeSL, pocososinos, jasoriab, JaviMarquez, crujipoyo, Arkan7, Cristianibias, pepeiyo69, Angel J, Xaggy, edumachuca, abollao, -alberto-, Rickymax, ferre7, Pedritoleon, Rivesgti, Alleya, davidalba, Xiguito_Corito, craken, JDCLEONFR, nemura, danihd, cenkkaya, Kisszabo, castell_lkpg, pistoleromtb, Raulportela, Martelinko, albert_naga, Adrian Anton, Gravilhas75, chaiser, popez, ruli68, denniisg2000, LeonFR80bsv
Seguidores: kenny_fonseca, ncx, Lavadora, barris31, juancete, ivantxe, jesusFR, Hysteria, MaximusRoco, Manu1986, Jorge75016, davidbj, bIxu, miyobe, MORKAS, gorkansr, aironsam14, jramis, kimudj, Maikermx, Javizormo, gogua, Melonkid, Kikote8, danirodrigueze30, maxinew, aigort, carlosgzlez, corderazo, Lionxp, jande, Edu1589, msmdraven, Arkan7, inamarlo, edumachuca, Josepo79, lead, camamaleon, davidmd, carrasco13, clavelstreet, mikomiko, josele77, car212121, itz18, golf_1990, LeidenSpain, vecnte, Andy_G, csabafr2013, leonfr76, Trimmer, genialsoft, Enerts, leonfrrojito, Horus, paco_22_22, ruben88, Valerofr150, molvi_mabad, Pekee69, Dav2k6, IbiFR, il_munyo, craken, ruben91mad, papo-182, el_padrino, zeratul, kaiserssosse, lytry32.hc, sbarri, ghitus, DesmoSimon, ruli68, Mramos1985, tonielfilas, braulioT, davidalba, JaviMarquez, osjamil, egarense69, fexposru, Pedrost, Illan, chetelopez, juanacho21, cuenka16, pepeiyo69, VapaV, AlvaroPM13, balbu, juan7777, mams69, Helrique, Kike77, volkov, jluis, loeches, Tom70, Dconnect, Trivi83, MilleMiglia, linxes, sergi303, hector37, D83, quiquito30lv, ElFon, DALOFER17, davidap13, kigua, JOTTA, Senuto, jd_zuri, Alvi, damsolu, Leon pucelano, javi_archi, danihd, alcoleazgz, miguel23and, xarlio, jdieztec, mitxuni, Kisszabo, Gendos22, xexpir, canijo82, Brandenor, cenkkaya, kennit0, Chelazo, bertoco, benitogomez, carlosVACA, Peje, NOECUBI1, AAAJDA, trazas, martija, borjiguez, JoseXS, ferbarroso14, Wespa, Cloud_ganora, Berbe15, Valengti, Chrohu, Atajunen, Victorzabal, jrm82, carlo13, iNFeCTeD, paralaxon, ateopoeta, pepo55, ribasxisco, Raulribarroja, ivanti, Jansel, lopezm0, Rubén Flp, Warelio, Vagabundo, Rekoba, Octacon, matiaso, Alianma, Raulportela, Éugen91, Rivesgti, Mcm90, DaniR86, Gravilhas75, JuanNur78, el_Asturiano, Mr.Chuflas, albert_naga, juanfrancia, Seket, algabe, pistoleromtb, ebcuatro, [GuErRa], Mario Leon, tito68
Re: León Mk3 - Actualización infotainment
Hola Buenos días , tengo un Leon MK3 FR Plus de Octubre del 2015 , sabéis si hay alguna actualización del infotainment, tengo la versión que venía cuando la compre y algún amigo me ha comentado que cree que hay alguna actualización pero no está seguro , alguien sabe algo y en caso de existir te la puedan instalar en el concesionario, gracias
AMGM - Nuev@ por aqui
- Agradecido: 9 veces
En el concesionario va a ser complicado por no decir imposible, a no ser que tu unidad tenga fallos graves demostrables no actualizan nada. Una unidad de 2015 es ya bastante antigua, tendrías que indicar tu versión actual de firmware y hardware para ver si aquí existe algún archivo de actualización y lo más entendidos en la materia puedan ayudarte.
Enviado desde mi Pixel 4 XL mediante Tapatalk
Warelio - Moderador de Racing
- Agradecido: 1181 veces
Para saber si hay actualizacion, tendrias que mandar una foto de la version que llevas y el num de ref del infotaimentAMGM escribió:Hola Buenos días , tengo un Leon MK3 FR Plus de Octubre del 2015 , sabéis si hay alguna actualización del infotainment, tengo la versión que venía cuando la compre y algún amigo me ha comentado que cree que hay alguna actualización pero no está seguro , alguien sabe algo y en caso de existir te la puedan instalar en el concesionario, gracias
Octacon - Leoner@ avanzad@
- Agradecido: 95 veces
albert_naga escribió:Buenas, he estado leyendo el hilo, pero no lo he visto.
La actualización es gratuita? Es decir, llamas a la SEAT diciendo que lo quieres actualizar y te lo hacen sin más? O debes de tener algún problema para que te lo hagan?
A mi desde que lo compré me da problemas con el full link, se me desconecta del móvil cada 2x3. Eso se puede solucionar actualizando?
Muchas gracias!
Hola
Si está en garantía, si debe ser gratuita la actualización, pero eso sí, tienes que justificar que tienes un problema, demostrándoselo mejor en vivo en el mismo taller.
Muchos concesionarios son muy reacios a actualizar unidades, y te pondrán mil y una pegas para no hacértelo.
Respecto a las desconexiones de FullLink, la mayoría de los problemas se debe a la mala calidad del cable USB, o que se termina ropiendo de tanto conectarlo y desconectarlo. ¿Has probado con otros cables distintos?
- Agradecido: 2046 veces
una pregunta de novato en estas lides....
¿Cómo sabéis que versión es compatible con tu equipo?, por ejemplo, mi hw es el H41 y sw 0479 y la pieza de dispositivo es la 5QA035874.
Veo que en post anteriores, habeis subido al mega la versión MST2_EU_SE_ZR_P0516T_MU0516 .7z
¿cómo identificais que la versión del fw es compatible?
Muchas gracias por adelantado!
Edito: para ver el train version hay que pulsar el boton menú durante 3 segundos y luego entrar en software update/versions. Viendo las versiones que tengo instaladas, el año pasado en la revisión me actualizaron el infotainment
Vista mi versión, si meto la versión en una sd, desde el mismo menú que saqué la información se podría actualizar sin problemas, verdad?
Gracias!
Gracias!
Mr.Chuflas - Leoner@ mayor del reino
- Agradecido: 257 veces
Mr.Chuflas escribió:una pregunta de novato en estas lides....
Edito: para ver el train version hay que pulsar el boton menú durante 3 segundos y luego entrar en software update/versions. Viendo las versiones que tengo instaladas, el año pasado en la revisión me actualizaron el infotainment![]()
Gracias!
Lamentablemente no puedes pasar de 04xx a 05xx tal cual y sin modificar nada, los infotainment que vienen de serie con las versiones 05xx tienen HW5x (a diferencia de tu y yo que tenemos HW4x), que tiene una versión diferente de cpu que hace que necesitemos parchear nuestra unidad para que se crea que tiene cpu compatible con HW5x y nos deje instalar una versión de firmware de la familia 05xx. Para parchear la unidad necesitas tener activado el GEM (o Green Engineering Menu) y los archivos para parchear. En este hilo puedes encontrar (y aquí: https://mega.nz/folder/209x3IQJ#lBMtI1Bb6HGWIIjtOSFcHg) todos esos archivos para actualizar a la 0515 con HW41 (pero no se si se puede a la 0516)
lucky_38 - Nuev@ por aqui
- Agradecido: 14 veces
Buenas tardes, tengo un problema, quiero poner la pantalla de 8 pulgadas a mi Seat León con pantalla de 5".
Tengo la pantalla, el cableado, la guantera y demás, pero me han dicho que tengo que quitar el sistema de protección de componentes y luego codificarla.
He visto por ahí que tengo que hablar con aprietatuercas. Si me podéis echar una mano, por favor.
tiran2000 - Nuev@ por aqui
Holaaaa buenas noches a todos!
Tengo un Leon Cupra de Agosto 2018, con unidad normal.
Me gustaría actualizar para poder sobre todo cambiar de colores los relojes amarillos de la pestaña Vehículo.
Os dejo lo que llevo a ver si alguien me enseña la luz:
Versión SW Train : MST2_EU_SE_ZR_P0472T
Versión SW MU : 0472
Número de pieza : 5QA035874
Versión de HW : 5QA035874
Versión de SW : H29.319.58_STD2Nav_EU
Espero que alguno podáis ayudarme, muchas gracias de antemano!
aCm96 - Nuev@ por aqui
hola estoy buscando la actualización de la radio del coche versión 480 he buscado por todas partes en el foro pero no he encontrado si me la puedes dar cordialmente
Rafaa89 - Nuev@ por aqui
Rafaa89 escribió:hola estoy buscando la actualización de la radio del coche versión 480 he buscado por todas partes en el foro pero no he encontrado si me la puedes dar cordialmente
Normal que no la encuentres, la última que yo sepa es 479
- Agradecido: 240 veces
aCm96 escribió:Holaaaa buenas noches a todos!
Tiene navegación tu radio? Si no la tiene hay que abrirla y es más complicado, yo personalmente no sé hacerlo. Originalmente venía con 472?
Aquí más de uno lo ha hecho de 4xx a 515 o 516, si son tan amables que te ayuden, sinó pues si tengo tiempo te ayudo yo, pero tiene trabajillo la cosa, eso sí, gratis, y corres riesgos de los cuales nunca culpes al que te ayuda, sinó no te ayudarán jejej
Por lo que veo tú unidad tiene navegador. Entonces es fácil. Lo que más lleva es prepararte los archivos. Pero si quieres te lo hago y te lo subo en un enlace de mega.aCm96 escribió:Holaaaa buenas noches a todos!
Para actualizar a la 0515( que es la que tengo yo el metainfo2 modificado, de la 0516 no lo tengo , para poder pasar de 2xx , 3xx , 4xx a esa versión.) pero si quieres la 0515 te ayudo. Te preparo los archivos y lo haces de un momento.
Lo único me tienes que decir que número tienes entre paréntesis, metiéndote en menú 10s. Y yendo a cpuplus. Y allí te aparece y dime qué número es y te empiezo a crear todo lo necesario.
Éugen91 - Primeros Pasos
- Agradecido: 29 veces
Éugen91 escribió:Por lo que veo tú unidad tiene navegador. Entonces es fácil. Lo que más lleva es prepararte los archivos. Pero si quieres te lo hago y te lo subo en un enlace de mega.aCm96 escribió:Holaaaa buenas noches a todos!
El metainfo es el mismo que 515 creo
Hola buenas tardes!
Poseo un Leon Cupra st MY 2018, con unidad high.
Me gustaría actualizar para poder cambiar de colores los relojes amarillos de la pestaña Vehículo.
Os dejo lo que llevo:
Dispositivo: 5F0035020E
Hardware: H54
Software: 1376
Datos de navegación: V03959802PLX1776ECE 2019/2020
V03959802PL
X176
ECE
Hardware: H54
Software: 1376
V03959802PL
X176
ECE
Scant_zx6r - Nuev@ por aqui
Buenas a todos!
he leido practicamente todo el hilo y utilizado el buscador pero no encuentro informacion apenas sobre mi unidad, me gustaría saber si hay actualización para una:
5qa035846a con navegador
hardware:h30
software: 0359
shield 2016-03 (build 20)
muchas gracias!
hardware:h30
software: 0359
muchas gracias!
tajada3 - Nuev@ por aqui
Cupra leon VZ 300 restyling Foro: General Autor: Artichoke Respuestas: 1 |
León Mk4 - Actualización mapas MIB3 SEAT 2021 Foro: AudioCar y MultimediaCar Autor: jasoriab Respuestas: 121 |
el leon tdi 150cv tiene estabilizadora atras o no?? Foro: Leon I - Mecánica / Electricidad / Electrónica Autor: cordobitax Respuestas: 4 |
León Mk4 - Actualizaciones sistema de infotainment Foro: AudioCar y MultimediaCar Autor: Yundas Respuestas: 1757 |
