León Mk3 - Actualización infotainment
Favoritos: BADS, Daruma, ositoerik, dmesanun, YeSL, pocososinos, jasoriab, JaviMarquez, crujipoyo, Arkan7, Cristianibias, pepeiyo69, Angel J, Xaggy, edumachuca, abollao, -alberto-, Rickymax, ferre7, Pedritoleon, Rivesgti, Alleya, davidalba, Xiguito_Corito, craken, JDCLEONFR, nemura, danihd, cenkkaya, Kisszabo, castell_lkpg, pistoleromtb, Raulportela, Martelinko, albert_naga, Adrian Anton, Gravilhas75, chaiser, popez, ruli68, denniisg2000, LeonFR80bsv
Seguidores: kenny_fonseca, ncx, Lavadora, barris31, juancete, ivantxe, jesusFR, Hysteria, MaximusRoco, Manu1986, Jorge75016, davidbj, bIxu, miyobe, MORKAS, gorkansr, aironsam14, jramis, kimudj, Maikermx, Javizormo, gogua, Melonkid, Kikote8, danirodrigueze30, maxinew, aigort, carlosgzlez, corderazo, Lionxp, jande, Edu1589, msmdraven, Arkan7, inamarlo, edumachuca, Josepo79, lead, camamaleon, davidmd, carrasco13, clavelstreet, mikomiko, josele77, car212121, itz18, golf_1990, LeidenSpain, vecnte, Andy_G, csabafr2013, leonfr76, Trimmer, genialsoft, Enerts, leonfrrojito, Horus, paco_22_22, ruben88, Valerofr150, molvi_mabad, Pekee69, Dav2k6, IbiFR, il_munyo, craken, ruben91mad, papo-182, el_padrino, zeratul, kaiserssosse, lytry32.hc, sbarri, ghitus, DesmoSimon, ruli68, Mramos1985, tonielfilas, braulioT, davidalba, JaviMarquez, osjamil, egarense69, fexposru, Pedrost, Illan, chetelopez, juanacho21, cuenka16, pepeiyo69, VapaV, AlvaroPM13, balbu, juan7777, mams69, Helrique, Kike77, volkov, jluis, loeches, Tom70, Dconnect, Trivi83, MilleMiglia, linxes, sergi303, hector37, D83, quiquito30lv, ElFon, DALOFER17, davidap13, kigua, JOTTA, Senuto, jd_zuri, Alvi, damsolu, Leon pucelano, javi_archi, danihd, alcoleazgz, miguel23and, xarlio, jdieztec, mitxuni, Kisszabo, Gendos22, xexpir, canijo82, Brandenor, cenkkaya, kennit0, Chelazo, bertoco, benitogomez, carlosVACA, Peje, NOECUBI1, AAAJDA, trazas, martija, borjiguez, JoseXS, ferbarroso14, Wespa, Cloud_ganora, Berbe15, Valengti, Chrohu, Atajunen, Victorzabal, jrm82, carlo13, iNFeCTeD, paralaxon, ateopoeta, pepo55, ribasxisco, Raulribarroja, ivanti, Jansel, lopezm0, Rubén Flp, Warelio, Vagabundo, Rekoba, Octacon, matiaso, Alianma, Raulportela, Éugen91, Rivesgti, Mcm90, DaniR86, Gravilhas75, JuanNur78, el_Asturiano, Mr.Chuflas, albert_naga, juanfrancia, Seket, algabe, pistoleromtb, ebcuatro, [GuErRa], Mario Leon, tito68
Re: León Mk3 - Actualización infotainment
Notapor sinparedes el 10 Oct 2021, 10:30
Lito69 escribió:
Chiner23 escribió:Hola buenas, me gustaría saber si alguien tiene todavía la actualización 0480 para MIB1 (5F003846A) HW:041 y puede proporcionarla de nuevo como descarga, no hago más que buscar por el foro y los enlaces que mandaron hace 4 años se borraron. Si alguien puede proporcionar esa actualización seria de gran ayuda, y con la explicación de como hacerlo claro, espero que podais ayudarme! Un saludo
Creo que es un mib2, y la última es la 479 creo también.
Como bien ha dicho @Lito69, la última versión disponible para unidades MIB2 H41 es la 0479. La 0480 no existe.
Enviado desde mi Pixel 4 XL mediante Tapatalk
Lito69 y Warelio , creo que se refiere a la que aparece en el enlace que puse un poco mas arriba , yo la tengo instalada en mi unidad MIB1 H40 5,8", aunque en su momento se puso como indicada para las unidades MIB1 H41 5,8" , yo me "arriesgue" y me funciona sin problemas , seria la misma descarga que ya no esta disponible en el enlace original que comenta el compañero fritzy_hh , pero luego el compañero jeroc la volvio a subir y esta en el enlace a la pagina 169 que pongo en mi anterior post, y sigo recomendando leer antes los problemas que puede dar como el error 1555 y como solucionarlo.
sinparedes escribió:
Andreja escribió:Hello guys,
I have Leon mk3 1.2 tsi with infotaiment photo in link.Is there any update for this unit?
https://photos.app.goo.gl/QF1Gv8ngD8QZH1iz8
Echale un vistazo al enlace que hay una que es posible que te valga:
viewtopic.php?f=9&t=118140&start=2520
Pero mira antes este enlace, ahi te pone como realizar la actualizacion y problemas que te puede dar:
viewtopic.php?f=9&t=118140&p=1928908#p1928908
Saludos..
sinparedes
Agradecido: 129 veces
Notapor jasoriab el 11 Oct 2021, 08:37
A ver, hay que tener cuidado, que estamos mezclando dos generaciones de infotainments, aunque ambas aparezca H41.
La H41 con referencia 5F0035824A es una MIB1 y la H41 con referencia 5F0035846A es una MIB2 (NaviSystem estándar). No se puede usar ni el firmware o los mapas de una en la otra, y viceversa.
La verdad es que SEAT (o el grupo VAG) tenía que haber estado algo más espabilado, para no usar el mismo Id. de Hw en ambas generaciones, pero se pueden diferenciar unívocamente por el nº de referencia que indico más arriba.
Para la H41 MIB1 la última versión de la que tenemos constancia es la 480, y para la H41 MIB2, la última oficial SEAT es la 479 (aunque se puede actualizar hasta la 516 con firmware modificado).
jasoriab
Agradecido: 2053 veces
Notapor fran6120 el 27 Oct 2021, 18:08
La unidad de mi MY16 es H30 y de serie traía la versión 0351 pero rebuscando por ahí he encontrado un repositorio en el que aparecen varias versiones de firmware para las unidades, y entre otras cosas, herramientas para parchear unidades por lo que no pongo el link para no incumplir normas del foro.
No tendría problema en poner el link si algún moderador me autoriza.
Dejo aquí el enlace a la 0368 para hardware H30
Total que he actualizado mi H30 0351T a la 0368T que es la última que hay para SEAT y que varios compis aquí en este hilo tienen de fábrica.
A ver si desaparecen los problemillas que tenia en la anterior, como que de vez en cuando al encender empieza por la primera carpeta de canciones en vez de continuar por que iba antes, también el bug de que solo suena el altavoz central y subwoofer y por último que en android auto, cuando tengo maps a veces no me baja el sonido de la música mientras da una instrucción de voz
Última edición por fran6120 el 28 Oct 2021, 18:42, editado 1 vez en total
La música es el arte más directo, entra por el oído y va al corazón :yea:
fran6120
Notapor Octacon el 27 Oct 2021, 18:11
fran6120 escribió:La unidad de mi MY16 es H30 y de serie traía la versión 0351 pero rebuscando por ahí he encontrado un repositorio en el que aparecen varias versiones de firmware para las unidades, y entre otras cosas, herramientas para parchear unidades por lo que no pongo el link para no incumplir normas del foro.
Si has encontrado el manual veras que puedes actualizar hasta la 516
Octacon
Agradecido: 95 veces
Notapor fran6120 el 27 Oct 2021, 19:35
Ahí ya me pierdo, el repositorio es muy grande y si que hay PDF explicando cosillas pero se me hacen complicadas...
Tu lo tienes hecho?
fran6120
Notapor pistoleromtb el 27 Oct 2021, 21:49
Hola, Buenas me ando leyendo casi todo el hilo... pero me sobrepasa.... demasiada info los hijos revolotenando alreedor.... y apenas saco algo en claro haber si me podeis echar una mano que hardware y sofware necesito para actualizar partiendo de un hardware H24 y sofware 0245
decir que es un leon my16, muchas gracias de ante mano y agradecer el curro que le echais¡¡¡
pistoleromtb
Notapor Éugen91 el 27 Oct 2021, 21:52
Tu lo tienes hecho?
Si tú unidad es con nav , se hace sin problemas. Ahora si no tiene nav. Olvídate ya que hay que abrir. Y solo para actualizar a una versión superior. No merece la pena desde mi punto de vista. Solo en caso de activar funcionar. Full link. Menú sport. Etc
Éugen91
Agradecido: 29 veces
Notapor Éugen91 el 27 Oct 2021, 21:56
pistoleromtb escribió:Hola, Buenas me ando leyendo casi todo el hilo... pero me sobrepasa.... demasiada info los hijos revolotenando alreedor.... y apenas saco algo en claro haber si me podeis echar una mano que hardware y sofware necesito para actualizar partiendo de un hardware H24 y sofware 0245
En tu caso digo lo mismo si es con nav. Lo puedes hacer mediante sd hasta la 0516 como dice el compi. Si no ñ, lo que puedes hacer actualizar primero a la 0330 y después a la 0346. Que allí ganas el menú moderno (mosaico) que tienen ahora las unidades.
Éugen91
Notapor fran6120 el 27 Oct 2021, 22:25
Tu lo tienes hecho?
No tengo navy y el full link lo tengo de serie...
El menú sport no se ni que es
fran6120
Notapor jasoriab el 28 Oct 2021, 09:04
Hola @fran6120
Si compartes únicamente las actualizaciones de firmware de las unidades de infotainment no hay ningún problema en publicar el enlace en el hilo , pero si también hay ahí herramientas para hackear las unidades no se puede publicar, para evitar posibles problemas legales con SEAT.
jasoriab
Notapor pistoleromtb el 28 Oct 2021, 13:45
ok¡¡ muchas gracias y a puestos... pero al comienzo del hil los enlaces ya no estan.... y voy leyendo por la 100 y poco donde puedo encotrar los enlaces? muchas gracias y perdon por ser tan torpe de no encontrarlo
pistoleromtb
Notapor pistoleromtb el 28 Oct 2021, 15:19
bueno ya encontrado las versiones 0330 y la 0346 en la pag.164 lo hares estos dias .... y de la version 0346 a la 0516 cuantas versiones hay de por medio? o se salta directamente? gracias de nuevo
pistoleromtb
Notapor fran6120 el 28 Oct 2021, 18:43
Hola @fran6120
Post editado con enlace de descarga
fran6120
Notapor Éugen91 el 28 Oct 2021, 19:32
pistoleromtb escribió:bueno ya encontrado las versiones 0330 y la 0346 en la pag.164 lo hares estos dias .... y de la version 0346 a la 0516 cuantas versiones hay de por medio? o se salta directamente? gracias de nuevo
Se hace directamente , pero tienes que modificar el swdownload , y tienes que modificar el metainfo2 de la 0515 para que la acepte la h24. Si no, no hay tú tía que la acepte. Yo siempre recomiendo que una h24 con nav. Pase a la 0515. Por que el cambio es abismal . Ganas sobre todo rapidez
Éugen91
Notapor pistoleromtb el 28 Oct 2021, 19:58
gracias¡¡ estoy leyendo el mensaje de como instalarlo de miceor de la pag.41 y me surge alguna duda, en caso de que me saldria algun fallo de los mencionados al actualizar a la 0330 debo arreglarlos antes de volver actualizar a la 0346? y respecto a la version que mencionas merece la pena? porque me da ya respeto el meterme acutalizarlo... como para hacer esos dos pasos mas que comentas, que ya no se ni lo que es, gracias de nuevo a todos por la labor que se hace en el foro de forma altruista ok¡¡
pistoleromtb
