León Mk3 - Actualización infotainment
Favoritos: BADS, Daruma, ositoerik, dmesanun, YeSL, pocososinos, jasoriab, JaviMarquez, crujipoyo, Arkan7, Cristianibias, pepeiyo69, Angel J, Xaggy, edumachuca, abollao, -alberto-, Rickymax, ferre7, Pedritoleon, Rivesgti, Alleya, davidalba, Xiguito_Corito, craken, JDCLEONFR, nemura, danihd, cenkkaya, Kisszabo, castell_lkpg, pistoleromtb, Raulportela, Martelinko, albert_naga, Adrian Anton, Gravilhas75, chaiser, popez, ruli68, denniisg2000, LeonFR80bsv
Seguidores: kenny_fonseca, ncx, Lavadora, barris31, juancete, ivantxe, jesusFR, Hysteria, MaximusRoco, Manu1986, Jorge75016, davidbj, bIxu, miyobe, MORKAS, gorkansr, aironsam14, jramis, kimudj, Maikermx, Javizormo, gogua, Melonkid, Kikote8, danirodrigueze30, maxinew, aigort, carlosgzlez, corderazo, Lionxp, jande, Edu1589, msmdraven, Arkan7, inamarlo, edumachuca, Josepo79, lead, camamaleon, davidmd, carrasco13, clavelstreet, mikomiko, josele77, car212121, itz18, golf_1990, LeidenSpain, vecnte, Andy_G, csabafr2013, leonfr76, Trimmer, genialsoft, Enerts, leonfrrojito, Horus, paco_22_22, ruben88, Valerofr150, molvi_mabad, Pekee69, Dav2k6, IbiFR, il_munyo, craken, ruben91mad, papo-182, el_padrino, zeratul, kaiserssosse, lytry32.hc, sbarri, ghitus, DesmoSimon, ruli68, Mramos1985, tonielfilas, braulioT, davidalba, JaviMarquez, osjamil, egarense69, fexposru, Pedrost, Illan, chetelopez, juanacho21, cuenka16, pepeiyo69, VapaV, AlvaroPM13, balbu, juan7777, mams69, Helrique, Kike77, volkov, jluis, loeches, Tom70, Dconnect, Trivi83, MilleMiglia, linxes, sergi303, hector37, D83, quiquito30lv, ElFon, DALOFER17, davidap13, kigua, JOTTA, Senuto, jd_zuri, Alvi, damsolu, Leon pucelano, javi_archi, danihd, alcoleazgz, miguel23and, xarlio, jdieztec, mitxuni, Kisszabo, Gendos22, xexpir, canijo82, Brandenor, cenkkaya, kennit0, Chelazo, bertoco, benitogomez, carlosVACA, Peje, NOECUBI1, AAAJDA, trazas, martija, borjiguez, JoseXS, ferbarroso14, Wespa, Cloud_ganora, Berbe15, Valengti, Chrohu, Atajunen, Victorzabal, jrm82, carlo13, iNFeCTeD, paralaxon, ateopoeta, pepo55, ribasxisco, Raulribarroja, ivanti, Jansel, lopezm0, Rubén Flp, Warelio, Vagabundo, Rekoba, Octacon, matiaso, Alianma, Raulportela, Éugen91, Rivesgti, Mcm90, DaniR86, Gravilhas75, JuanNur78, el_Asturiano, Mr.Chuflas, albert_naga, juanfrancia, Seket, algabe, pistoleromtb, ebcuatro, [GuErRa], Mario Leon, tito68
Re: León Mk3 - Actualización infotainment
Notapor Éugen91 el 28 Oct 2021, 20:08
pistoleromtb escribió:
Éugen91 escribió:
pistoleromtb escribió:bueno ya encontrado las versiones 0330 y la 0346 en la pag.164 lo hares estos dias .... y de la version 0346 a la 0516 cuantas versiones hay de por medio? o se salta directamente? gracias de nuevo
Se hace directamente , pero tienes que modificar el swdownload , y tienes que modificar el metainfo2 de la 0515 para que la acepte la h24. Si no, no hay tú tía que la acepte. Yo siempre recomiendo que una h24 con nav. Pase a la 0515. Por que el cambio es abismal . Ganas sobre todo rapidez
gracias¡¡ estoy leyendo el mensaje de como instalarlo de miceor de la pag.41 y me surge alguna duda, en caso de que me saldria algun fallo de los mencionados al actualizar a la 0330 debo arreglarlos antes de volver actualizar a la 0346? y respecto a la version que mencionas merece la pena? porque me da ya respeto el meterme acutalizarlo... como para hacer esos dos pasos mas que comentas, que ya no se ni lo que es, gracias de nuevo a todos por la labor que se hace en el foro de forma altruista ok¡¡
En teoría no debería salirte , y si te salen metele la 0346 y ya está. Ya que la 0330 dicen que tiene lags y que normal que tenga fallos ya que es una beta. Si no me equivoco. Si es así que me corrija los compis.
Éugen91
Agradecido: 29 veces
Notapor pistoleromtb el 29 Oct 2021, 12:40
pues ya esta actualizado y todo correcto¡¡ muchas gracias¡¡ ahora solo me queda el buscar como se cambia la configuracion de la pantalla para que salgan los 10 recuadros y cambiar el modelo de coche que me sale un leon normal y el mio es un st se que lo he visto pero no recuerdo la pag. pero vaya en un rato todo ok¡¡ muchas gracias¡¡
pistoleromtb
Notapor pistoleromtb el 29 Oct 2021, 16:49
pues me revisado el hilo entero.... se me ha tenido que pasar el video donde se ve como se ajusta la pantalla..... alguien sabe por donde puede estar..... luego sino lo buscare de nuevo ya es lo unico que me falta, bueno ya lo tengo hecho tambien¡¡
pistoleromtb
Notapor agonbus el 30 Oct 2021, 13:31
Buenas tardes tengo un seat león de finales del 2019 con acabado xcellence y la versión de software que pongo en la foto. Tengo que llevarlo a la revisión de los dos años y quería saber si existe alguna actualización para pedirla en el taller. Muchas gracias.
Última edición por agonbus el 11 Ene 2022, 15:55, editado 1 vez en total
agonbus
Notapor Lito69 el 30 Oct 2021, 16:28
pistoleromtb escribió:pues ya esta actualizado y todo correcto¡¡ muchas gracias¡¡ ahora solo me queda el buscar como se cambia la configuracion de la pantalla para que salgan los 10 recuadros y cambiar el modelo de coche que me sale un leon normal y el mio es un st se que lo he visto pero no recuerdo la pag. pero vaya en un rato todo ok¡¡ muchas gracias¡¡
Eso estaba en skin, dejando el botón menu apretado sale un menu, busca skin.
Lito69
Agradecido: 240 veces
Notapor jasoriab el 30 Oct 2021, 16:46
agonbus escribió:Buenas tardes tengo un seat león de finales del 2019 con acabado xcellence y la versión de software que pongo en la foto. Tengo que llevarlo a la revisión de los dos años y quería saber si existe alguna actualización para pedirla en el taller. Muchas gracias.
@agonbus no has subido al la foto que comentas...
jasoriab
Agradecido: 2055 veces
Notapor Warelio el 30 Oct 2021, 16:49
Si no tienes ningún problema demostrable y te funciona todo correctamente vas a tener difícil que te actualicen la versión de Infotainment así como así. Son bastante por no decir muy reacios a actualizar nada si no tiene fallos la unidad.
Enviado desde mi Pixel 4 XL mediante Tapatalk
Warelio
Moderador de Racing
Agradecido: 1183 veces
Notapor juanfrancia el 06 Nov 2021, 11:39
Buenos días a todos y muchas gracias por todos los consejos. Juan Carlos y vivo en francia. Me leí todas las paginas y pasé de la versión 0425 a la 0480 sin problemas. Pero al otro día me di cuenta que el dibujo del coche cuando meto la reversa desapareció ( mirar la foto) alguien encontró el mismo problema? Se puedo devolver a la otra versión? Muchas gracias de antemano.
juanfrancia
Coche: Leon MK3 1.2 TSI 110cv
Notapor juanfrancia el 07 Nov 2021, 19:40
Con la foto es mejorImagen
Envoyé de mon SM-G996B en utilisant Tapatalk
juanfrancia
Notapor Huguito18 el 09 Nov 2021, 07:16
Buenas a todos, es el segundo dia que me doy cuenta que mi Full linck “falla” hace unos dias llamó por telefono solo a un numero que tengo en favoritos y hoy m cambiaba de emisora de radio solo... y entraba ajustes de sonido sin yo tocar nada! Sabeis que le puede pasar?
Huguito18
Notapor andy.arbeit92 el 14 Nov 2021, 16:48
fran6120 escribió:La unidad de mi MY16 es H30 y de serie traía la versión 0351 pero rebuscando por ahí he encontrado un repositorio en el que aparecen varias versiones de firmware para las unidades, y entre otras cosas, herramientas para parchear unidades por lo que no pongo el link para no incumplir normas del foro.
No tendría problema en poner el link si algún moderador me autoriza.
Dejo aquí el enlace a la 0368 para hardware H30
Total que he actualizado mi H30 0351T a la 0368T que es la última que hay para SEAT y que varios compis aquí en este hilo tienen de fábrica.
A ver si desaparecen los problemillas que tenia en la anterior, como que de vez en cuando al encender empieza por la primera carpeta de canciones en vez de continuar por que iba antes, también el bug de que solo suena el altavoz central y subwoofer y por último que en android auto, cuando tengo maps a veces no me baja el sonido de la música mientras da una instrucción de voz
Hello together,
sorry for asking in english but I'm from Germany and do not speak any spanish.
I own a Seat Leon Mk3 from 2017 and I want to update my infotainment system. I read a lot of articles in different forums. Where do I get the files for updating the system?
my specs:
system number: 5QA035834A
hardware: H30
software: 0359
My Seat doesnt have the navigation system. I want to update the infotainment system.
Can I use the file posted here few days ago?
best regards
Andy
andy.arbeit92
Notapor jasoriab el 15 Nov 2021, 13:07
Huguito18 escribió:Buenas a todos, es el segundo dia que me doy cuenta que mi Full linck “falla” hace unos dias llamó por telefono solo a un numero que tengo en favoritos y hoy m cambiaba de emisora de radio solo... y entraba ajustes de sonido sin yo tocar nada! Sabeis que le puede pasar?
Te acabo de contestar aquí, viewtopic.php?f=9&t=136828
jasoriab
Notapor Chiner23 el 20 Nov 2021, 17:40
Hola buenas, he estado leyendo y algunos me decís que la actualización que sería es la MIB2 479, ya que es la última, perdonar si digo algo mal porque no me aclaro mucho con esto, como se puede confirmar que esa es la última y que es la que me serviría a mi? Tambien me gustaría saber si esa actualización me la puede proporcionar alguien y guiarme de como poder instalarmela yo, porque como os digo voy algo perdido en esto, perdonar. Espero que alguien pueda ayudarme, muchas gracias a todos, os lo agradezco!
Chiner23
Notapor Sabido el 22 Nov 2021, 18:09
El otro día descargue una actualización de Software a un amigo en su Seat Leon FR MY16, y tenia el SW 236 y el HW H24, y le puse la SW 346. La cuestión es; Me dice que le saltan las llamadas ahora y a veces le peta el audio. Esto a que se debe? Y sabéis si hay alguna solución?
Sabido
Notapor victor1990mk3 el 25 Nov 2021, 07:47
Hola @aprietatuercas1974 tengo esta unidad de 6,5 con esta version dejo foto, es posible que me la actualizaras de manera oficial para tener el aspecto de ateca o leones de 2017 en adelante ? Soy de Barcelona. Tengo que ir a tu concesionario o prefieres que quede contigo personalmente?. Queria mandarte un mensaje privado pero no me deja al ser miembro nuevo. Espero que puedas ayudarme, muchas gracias.
victor1990mk3
