León Mk3 - BRICO - Como instalar la cámara de parking
Favoritos: JaviCG, Vampiro, J@VY, BADS, Daruma, cstrol, JorgeAnteloC, ipenalosa, MONTY DAKA, pirly, josele887, xurox, Nanox23, Carbono79, vallter, norchugo, Efremvidal, @turbina@, blankiblau, jorgee76, jliriz, Vilo, cuenxis, victir, Aras, Korath, Rasekfighter, Carrl, jdieztec, J-Frass, Tarzan, zacarias, Frannisesabe, Xperience, bronce702, sbarri, javieret69, Carlos Chea, Lotar, Alleya, miguelorly, craken, chemazz, xico, eMi1, Maverick.es
Seguidores: Linker89, car212121, franrx, davidalba, TRIBO, danieleon, Panchorin, Hecson.27, jmfcoto, aironsam14, JOTTA, MORKAS, Unaited, trekam, xandis, Jorge75016, Platanot, davidbj, Achehmg, marc.domenech.90, sadanyac, seat leon blanco, Marc.22, Peuero, er_trompe, GTI35, JoseCa, JaviCG, vigimuertos, rabazas, B.Fox, msmdraven, Tomcat7733, Txutxiysilvia, xabidh, cstrol, Carrl, El3ndil, yorky, bolche, LeoST, Diegokero, Rasekfighter, Budoka, IronTor21, marlop, xico, vanscampa, Tarzan, jorgee76, josemag, aigort, LuichiFR, SLon34, clavelstreet, nani_san, nyro, IVANIN9, rober1095, ivan0909, jose.jjg307, csabafr2013, P.carrizo.leonstfr, dookky, Edu1589, Dconnect, D83, Jeii90, inamarlo, Israel-FR, Herrdoktor, el_padrino, Kipu, aguscalderon, lebowski, juanmaroger, bailyibz, naikon_paul, Valerofr150, JAL, kennit0, Mramos1985, bronce702, kijute, juanmik, osjamil, Tonivn, Lotar, Tunnig, JaviMarquez, nitro_g4074, sergi303, ivan2017, Chema_Alvarez, ilargiman, jaumotix, sbarri, javierferriz, alcoleazgz, lecupra280, Colomer, Maikermx, luigi323, rents_80, jdiego75, Pedrost, damsolu, lead, Franr50, Dani2025, Leon pucelano, nachomart, castronight, victor david, bertoco, juan7777, Josep20, jakobitto, rr7mo, a.cuadros71, iNFeCTeD, Gendos22, VapaV, Chrohu, Ganyula, snowpluralism, victor_leon_FR, luaiabou96, Drovniak, Guillen222, leonfrrojito, justics, lopezm0, Romera, pedrorossello92, AlvaroRamlo
Re: BRICO como instalar la Camara de parking en Seat leon MK
Notapor lgilm el 10 Nov 2014, 18:21
Entiendo que evitó el problema de las interferencias si cojo un positivo puro de la caja de fusibles en lugar de pillarlo de la red cambus no? Algo tipo mechero o algún servicio parecido, algo tiene que haber ahí atrás o en la guantera donde se puedan sacar 12v bajo contacto que sean puros.
lgilm
Agradecido: 53 veces
Notapor rojas el 10 Nov 2014, 18:35
lgilm escribió:
rojas escribió:
lgilm escribió:
rojas escribió:
Stealnick escribió:Ya lo había dicho antes pero lo repito....eres un crak.....se me amontonan tus bricos y me condeno porque no tengo tiempo de hacerlos....tengo pendiente el de los altavoces ya lo he comprado y ahora traes este. Pues nada a comprar más cosas y ya las instalaré aunque sea en Navidades.
Felicidades tio, te lo curras genial.
ajaja gracias compañero , este brico es super barato , 15€ la camara y 1€ el condensador si no se viera correctamente
Buenas, hay una cosa que no entiendo y puede que me lo aclares rápidamente, si es el software del coche a través de canbus el que se encarga de activar la cámara, que problema habría en dejar la cámara siempre con tensión bajo contacto, de esta manera la cámara al poner contacto ya tendría tensión y creo seria mas rápida y funcional que no estar alimentando y dejando de alimentar cada vez que metemos marcha atrás. De esa forma no habría que ir a la bisagra del maletero a coger la señal y se podría coger de cualquier sitio cercano a la matricula, algo habrá por ahí que lleve tensión fija y estable.
Por duración de la cámara no creo que hubiera problema y si tiene una vida útil de tres o cuatro años por lo que vale tampoco sería problemático.
Saludos y gracias.
supongo que la vida util de la camara se acortaria al estar con tension permanentemente sin contar el desgaste de bateria , ahora la bateria es nueva y no le hace ni cosquillas , pero cuando ya ande un poco cascailla quizas le sobre ese consumo de tension continuado , pero recuerda si coges el positivo de cualquier positivo mandado por la red de abordo tendrias el problema de que no se viera o almenos no correctamente.Particularmente prefiero que se active solo al engranar la marcha atras , he tardadado mas en subir las fotos del brico que hacer la instalacion.Quizas parezca mas de lo que es , pero se hace en un pispas.
saludos amigo
Pero el consumo seria solo con contacto y estamos hablando de mili amperios, no se, yo no le veo problema y me ahorro roba cables y pelar instalación original del coche. Si funcionalmente tu no le ves problema yo voy a probar, no pierdo nada y creo que facilita la instalación.
Así hago también de conejillo.
A ver , como factible es factible ... en 15 min todo listo ! :mrgreen: , yo he preferido hacerlo como indica el manual que he hecho , pero cada uno es libre de hacerlo como le parezca mejor.
rojas
Coche: Leon MK3 1.5 TGI 130cv
Agradecido: 1889 veces
Notapor rojas el 10 Nov 2014, 18:37
lgilm escribió:Entiendo que evitó el problema de las interferencias si cojo un positivo puro de la caja de fusibles en lugar de pillarlo de la red cambus no? Algo tipo mechero o algún servicio parecido, algo tiene que haber ahí atrás o en la guantera donde se puedan sacar 12v bajo contacto que sean puros.
de la caja de fusibles o del mechero es perfecto y valida 100%
rojas
Notapor guajarenho el 10 Nov 2014, 19:01
Otra idea...
Con un cámara genérica alimentada por la luz de marcha atrás, hay que reprogramar la configuración del piloto par eliminar los posibles parásitos.
Para ello:
[09 - Cent. Elect]=> [Security Access - 16]=> Codigo de seguridad 31347 => [Adaptation - 10]
(6)-Leuchte29RFL RA64-Dimmwert AB 29 introducir el valor 127 en lugar de 100
Nuestro piloto de marcha atrás, eso si, a partir de ahora se encenderá con más intensidad.
No se si funciona o no... habra que probarlo. :cafe:
Si todo está bajo control es que no vas lo suficientemente rápido
R135
_246
guajarenho
Coche: Leon MK3 1.2 TSI 110cv
Agradecido: 36 veces
Notapor Kampedtre el 10 Nov 2014, 19:03
Bufff... Cuando ya empezamos que sí reles que sí cojo de aquí, paso por aquí y lo meto por allá...yo envez de meter x aki lo meto por allá y a tomar viento la garantía y una semana sin coche fijo!! Jajajajajaj
Kampedtre
Coche: Leon MK3 1.2 TSI 105cv
Agradecido: 28 veces
Notapor GTI35 el 10 Nov 2014, 19:26
Yo al tener una toma de 12V en el maletero lo podría coger directamente de allí no? Aunque claro la cámara estaría siempre encendida...
Seat Leon ST FR 2.0 TDI 184CV
GTI35
Coche: Leon MK3 1.4 TSI 140cv
Agradecido: 90 veces
Notapor rojas el 10 Nov 2014, 19:33
GTI35 escribió:Yo al tener una toma de 12V en el maletero lo podría coger directamente de allí no? Aunque claro la cámara estaría siempre encendida...
Si . Asi es
rojas
Notapor norchugo el 10 Nov 2014, 19:40
Enhorabuena por el post, me lo guardo en favoritos. Un 10, si señor
Seat leon mk3 1.8 fsi dsg
norchugo
Agradecido: 54 veces
Notapor rojas el 10 Nov 2014, 20:02
norchugo escribió:Enhorabuena por el post, me lo guardo en favoritos. Un 10, si señor
gracias ! :ok:
rojas
Notapor Achehmg el 10 Nov 2014, 23:56
Buenas noches lo primero, grandisimo briko rojas, un maquina.
Lo siguiente mi duda: que equipo multimedia soporta cámara trasera? Se puede montar en cualquier equipo touch/colour/plus/nav.
Perdón si no es apropiada la pregunta o ya está solventada anteriormente es que ando un poco pez
Leon Mk3 1.6TDI 105 s/s reference plus
Achehmg
Notapor jorge77237 el 11 Nov 2014, 11:55
Simplemente felicitarte por el peazo de post que hiciste, y lo bien explicado que esta enhorabuena rojas.
Ayer recogí el león del conce y tengo pensado ponerle la cámara pero me surge un par de dudas , mi coche no tiene sensores de aparcamiento, ni delante ni detrás,
se podrá poner igualmente??? si, tiene la pantalla 5,8.
y la otra duda, donde va cipotillo ese de 1€ que hace de filtro??
muchas gracias
haber si me da tiempo y subo unas fotillos de la maquina
jorge77237
Notapor rojas el 11 Nov 2014, 12:15
jorge77237 escribió:Simplemente felicitarte por el peazo de post que hiciste, y lo bien explicado que esta enhorabuena rojas.
muchas gracias
Claro q si. Solo q no se codifica el bite 18 . Solo el 19 "bit 4 activar"
El condensador tiene 2 patillas largas una + y otra - ... respeta la polaridad.
si pones una clema en el cable de alimentacion de la camara .... metes en la clema con los cables la patilla + con el rojo y la - con el negro. Tb la.puedes soldar a los dos cables si no pones clema rojo y negro
rojas
Notapor alesitox el 11 Nov 2014, 13:36
Excelente brico!!! Mil gracias!! Tengo pedida ya la cámara para ponerme a ello.
Pero me surge una pregunta... Como quitas la unidad de la guantera? necesitas un útil especial?
Un saludo y y te reitero mi agradecimiento!!!
alesitox
Agradecido: 18 veces
Notapor rojas el 11 Nov 2014, 15:33
Achehmg escribió:Buenas noches lo primero, grandisimo briko rojas, un maquina.
se puede montar en cualquier pantalla a color
rojas
Notapor rojas el 11 Nov 2014, 15:43
alesitox escribió:Excelente brico!!! Mil gracias!! Tengo pedida ya la cámara para ponerme a ello.
necesitas 2 llaves como estas
http://www.ebay.es/itm/Car-Stereo-Radio ... 3cb2cb5bd2
rojas
Usuarios navegando por este Foro: Anthropic, joangp y 7 invitados
