León Mk3 - Actualización infotainment
Favoritos: BADS, Daruma, ositoerik, dmesanun, YeSL, pocososinos, jasoriab, JaviMarquez, crujipoyo, Arkan7, Cristianibias, pepeiyo69, Angel J, Xaggy, edumachuca, abollao, -alberto-, Rickymax, ferre7, Pedritoleon, Rivesgti, Alleya, davidalba, Xiguito_Corito, craken, JDCLEONFR, nemura, danihd, cenkkaya, Kisszabo, castell_lkpg, pistoleromtb, Raulportela, Martelinko, albert_naga, Adrian Anton, Gravilhas75, chaiser, popez, ruli68, denniisg2000, LeonFR80bsv
Seguidores: kenny_fonseca, ncx, Lavadora, barris31, juancete, ivantxe, jesusFR, Hysteria, MaximusRoco, Manu1986, Jorge75016, davidbj, bIxu, miyobe, MORKAS, gorkansr, aironsam14, jramis, kimudj, Maikermx, Javizormo, gogua, Melonkid, Kikote8, danirodrigueze30, maxinew, aigort, carlosgzlez, corderazo, Lionxp, jande, Edu1589, msmdraven, Arkan7, inamarlo, edumachuca, Josepo79, lead, camamaleon, davidmd, carrasco13, clavelstreet, mikomiko, josele77, car212121, itz18, golf_1990, LeidenSpain, vecnte, Andy_G, csabafr2013, leonfr76, Trimmer, genialsoft, Enerts, leonfrrojito, Horus, paco_22_22, ruben88, Valerofr150, molvi_mabad, Pekee69, Dav2k6, IbiFR, il_munyo, craken, ruben91mad, papo-182, el_padrino, zeratul, kaiserssosse, lytry32.hc, sbarri, ghitus, DesmoSimon, ruli68, Mramos1985, tonielfilas, braulioT, davidalba, JaviMarquez, osjamil, egarense69, fexposru, Pedrost, Illan, chetelopez, juanacho21, cuenka16, pepeiyo69, VapaV, AlvaroPM13, balbu, juan7777, mams69, Helrique, Kike77, volkov, jluis, loeches, Tom70, Dconnect, Trivi83, MilleMiglia, linxes, sergi303, hector37, D83, quiquito30lv, ElFon, DALOFER17, davidap13, kigua, JOTTA, Senuto, jd_zuri, Alvi, damsolu, Leon pucelano, javi_archi, danihd, alcoleazgz, miguel23and, xarlio, jdieztec, mitxuni, Kisszabo, Gendos22, xexpir, canijo82, Brandenor, cenkkaya, kennit0, Chelazo, bertoco, benitogomez, carlosVACA, Peje, NOECUBI1, AAAJDA, trazas, martija, borjiguez, JoseXS, ferbarroso14, Wespa, Cloud_ganora, Berbe15, Valengti, Chrohu, Atajunen, Victorzabal, jrm82, carlo13, iNFeCTeD, paralaxon, ateopoeta, pepo55, ribasxisco, Raulribarroja, ivanti, Jansel, lopezm0, Rubén Flp, Warelio, Vagabundo, Rekoba, Octacon, matiaso, Alianma, Raulportela, Éugen91, Rivesgti, Mcm90, DaniR86, Gravilhas75, JuanNur78, el_Asturiano, Mr.Chuflas, albert_naga, juanfrancia, Seket, algabe, pistoleromtb, ebcuatro, [GuErRa], Mario Leon, tito68
Re: Actualización infotainment
Notapor Eluryh el 12 Jul 2016, 09:25
Moonlight escribió:
Lo que me he fijado que en vehículo aparece dentro del contorno tipo app creo que un Ateca, supongo que después en el apartado consumo saldrá la silueta del acabado del Leon que tenga uno.
Si te refieres a la imagen del icono Vehiculo, es un Leon. El Ateca tiene la luz diurna LED diferente.
Eluryh
Agradecido: 107 veces
Notapor Moonlight el 12 Jul 2016, 11:21
Pues será que la del Ateca es de un León o desde la distancia induce a error, ya me fijaré en vivo.
Leon MK3 Cupra ST 300 DSG PP
Moonlight
Agradecido: 129 veces
Notapor sonxav el 12 Jul 2016, 11:45
Yo veo claramente las luces full led de un leon ST.....
sonxav
Agradecido: 526 veces
Notapor Moonlight el 12 Jul 2016, 11:53
Arriba es un fotograba de un vídeo del Ateca, por eso de no haberme fijado en el contorno de la luz diurna y parecerme el mismo vehículo en ambas interfaz.
Moonlight
Notapor FR184 el 12 Jul 2016, 12:21
Esto significa que mi FR PLUS MY16 tiene "derecho" a actualizar el interfaz o me dirán que no es posible? Lo llevo dentro de 1 semana a revisión de los 20,000
FR184
Agradecido: 42 veces
Notapor Eluryh el 12 Jul 2016, 12:31
Seguro que si @FR184.
A ver si @aprietatuercas1974 puede aportarnos luz al tema pronto para el resto.
Eluryh
Notapor lupen el 12 Jul 2016, 14:01
Hola @aprietatuercas1974 me puedes informar si esta actualizacion valdria para infotaiment navy high mib2 6,5 el acabado en 43 con hdd y mirrorlink hasta mayo 2015 y precio sd de sw actualizacion?saludos.
lupen
Notapor javigody el 12 Jul 2016, 18:21
En la SEAT me han dicho que no es posible cambiar la versión del sw, a no ser que el coche presente alguna anomalía con la que trae de fabrica, y me han empezado a contar una milonga de que si los pr hay que cambiarlos y que si se cambian pierde la garantía y tal. A ver si se encuentra por algún lado el archivo y nos lo actualizamos nosotros.
SEAT León MK3 FR 1.4 TSI 150CV ACT
Instalador en Málaga -> VIM, bricos MK3, tempomat MK1 y más
--- ¡Colabora con nosotros y con la comunidad con tus backups de OBDeleven/Vagcom/VCDS en el siguiente enlace!: viewtopic.php?f=8&t=120732 ¡Gracias!---
javigody
Agradecido: 274 veces
Notapor miceor el 12 Jul 2016, 19:17
En la SEAT lo que hay es mucho charlatán que no tiene ni idea de lo que tienen entre manos.
Siempre se tiran a lo facil (Es la unica salida que les queda ante su incopetencia)
El otro dia estuve yo para un problemilla que ya comenté y verguenza les tenia que dar la imagen que dan al publico.
Les cuentas el problema y les suena a chino, llaman al listo de la cuadrilla y me cuenta una pelicula de indios que a poco me meo encima.
¿Pero que me estás contando chavalote?
Como si no supiese yo cual es el problema, lo que hay que hacer y como hay que hacerlo.
Pero me tuve que callar para evitar males mayores.
Que lo llevé porque no me da la realisima gana de arreglarlo yo porque para eso está en garantia.
Me citan para otro dia diciendome que hacen notificación a Barcelona.
Vuelvo el dia que me han citado y hacen exactamente lo mismo y me dicen que se ha jodido una pieza o que hay algo mal pero que no saben que es.
Que van a llamar a Barcelona para notificarles el caso.
¿Pues no se lo habian notificado ya?
Y llevo un mes y pico esperando a que me llamen a ver si se han enterado que es lo que tienen que hacer.
De verdad lo digo, el dia que me llamen para llevarlo, lo arreglo delante de sus morros para que se les caiga la cara de verguenza.
Les pregunto por el interruptor antiarranque para el coche y me dicen que eso ya no se lleva y que además anula la garantia porque puede desconfigurar la centralita.
Es para darles una hostia con la mano abierta y marcarles los cinco dedos.
Que capacidad de inventiva tienen estos tios. Preguntes lo que preguntes, te pase lo que te pase, siempre hay un pero o una excusa inventada.
Con lo facil que es decir en cualquiera de los casos... Mira no sé de que me hablas porque no tengo suficiente formación al respecto... pero te lo miro y vemos que hacemos.
Y me voy tan contento.
miceor
Agradecido: 1259 veces
Notapor LeonCup el 13 Jul 2016, 00:34
A ver yo tengo mucha mano en la Seat, esto ze hace vía online o sólo por sd? Porque tengo que ir la semana que viene a por mi documentación y quiero hacerlo.
LeonCup
Usuario baneado
Agradecido: 23 veces
Notapor sonxav el 13 Jul 2016, 21:13
miceor escribió:Con lo facil que es decir en cualquiera de los casos... Mira no sé de que me hablas porque no tengo suficiente formación al respecto... pero te lo miro y vemos que hacemos.
En pocas seat te encuentras con gente así, las hay, yo agradezco mucho más una verdad que las medias mentiras (o enteras) que cuentan algunos.... :plas:
En fin, yo al menos a la seat que yo voy no me cuentan milongas, o saben o no saben, pero al menos te lo dicen a la cara....
sonxav
Notapor bigbywolf85 el 14 Jul 2016, 22:55
seat leon navi high 5,5 2014. seria muxo pedir q funcionase para este modelo?
Enviado desde mi D6603 mediante Tapatalk
bigbywolf85
Coche: Leon MK3 1.5 TGI 130cv
Notapor Eluryh el 14 Jul 2016, 23:01
bigbywolf85 escribió:seat leon navi high 5,5 2014. seria muxo pedir q funcionase para este modelo?
estamos a la espera de que @aprietatuercas1974 nos diga algo, compañero. Los MY16 seguro que podrán, los MY15, si alguno pudiese, serían los Navi High de 6.5'' (ya que también son MIB2) pero no está confirmado que se vaya a poder.
Eluryh
Notapor MORKAS el 15 Jul 2016, 12:43
sonxav escribió:Esto aún me da más rabia.... Con los infotaiments de los MY2014 y MY2015 ni una mísera actualización en el tiempo que lleva en el mercado (y ni se la espera) vaya panda de sinverguenzas están hechos! :mosqueao: :mosqueao: :enfurecido: :enfurecido:
Bueno, es lo que hay......
Si...cierto....es una pena....podrian molestarse...
MORKAS
Agradecido: 369 veces
Notapor FR184 el 15 Jul 2016, 14:14
Acabo de mandar un mail a Seat Responde a ver si es posible actualizar y que modelos están disponibles.
No creo q me vayan a responder pero hay que intentarlo
FR184
