León Mk3 - Actualización infotainment
Favoritos: BADS, Daruma, ositoerik, dmesanun, YeSL, pocososinos, jasoriab, JaviMarquez, crujipoyo, Arkan7, Cristianibias, pepeiyo69, Angel J, Xaggy, edumachuca, abollao, -alberto-, Rickymax, ferre7, Pedritoleon, Rivesgti, Alleya, davidalba, Xiguito_Corito, craken, JDCLEONFR, nemura, danihd, cenkkaya, Kisszabo, castell_lkpg, pistoleromtb, Raulportela, Martelinko, albert_naga, Adrian Anton, Gravilhas75, chaiser, popez, ruli68, denniisg2000, LeonFR80bsv
Seguidores: kenny_fonseca, ncx, Lavadora, barris31, juancete, ivantxe, jesusFR, Hysteria, MaximusRoco, Manu1986, Jorge75016, davidbj, bIxu, miyobe, MORKAS, gorkansr, aironsam14, jramis, kimudj, Maikermx, Javizormo, gogua, Melonkid, Kikote8, danirodrigueze30, maxinew, aigort, carlosgzlez, corderazo, Lionxp, jande, Edu1589, msmdraven, Arkan7, inamarlo, edumachuca, Josepo79, lead, camamaleon, davidmd, carrasco13, clavelstreet, mikomiko, josele77, car212121, itz18, golf_1990, LeidenSpain, vecnte, Andy_G, csabafr2013, leonfr76, Trimmer, genialsoft, Enerts, leonfrrojito, Horus, paco_22_22, ruben88, Valerofr150, molvi_mabad, Pekee69, Dav2k6, IbiFR, il_munyo, craken, ruben91mad, papo-182, el_padrino, zeratul, kaiserssosse, lytry32.hc, sbarri, ghitus, DesmoSimon, ruli68, Mramos1985, tonielfilas, braulioT, davidalba, JaviMarquez, osjamil, egarense69, fexposru, Pedrost, Illan, chetelopez, juanacho21, cuenka16, pepeiyo69, VapaV, AlvaroPM13, balbu, juan7777, mams69, Helrique, Kike77, volkov, jluis, loeches, Tom70, Dconnect, Trivi83, MilleMiglia, linxes, sergi303, hector37, D83, quiquito30lv, ElFon, DALOFER17, davidap13, kigua, JOTTA, Senuto, jd_zuri, Alvi, damsolu, Leon pucelano, javi_archi, danihd, alcoleazgz, miguel23and, xarlio, jdieztec, mitxuni, Kisszabo, Gendos22, xexpir, canijo82, Brandenor, cenkkaya, kennit0, Chelazo, bertoco, benitogomez, carlosVACA, Peje, NOECUBI1, AAAJDA, trazas, martija, borjiguez, JoseXS, ferbarroso14, Wespa, Cloud_ganora, Berbe15, Valengti, Chrohu, Atajunen, Victorzabal, jrm82, carlo13, iNFeCTeD, paralaxon, ateopoeta, pepo55, ribasxisco, Raulribarroja, ivanti, Jansel, lopezm0, Rubén Flp, Warelio, Vagabundo, Rekoba, Octacon, matiaso, Alianma, Raulportela, Éugen91, Rivesgti, Mcm90, DaniR86, Gravilhas75, JuanNur78, el_Asturiano, Mr.Chuflas, albert_naga, juanfrancia, Seket, algabe, pistoleromtb, ebcuatro, [GuErRa], Mario Leon, tito68
Re: León Mk3 - Actualización infotainment
Notapor nogard el 04 Mar 2023, 12:49
Octacon escribió:
nogard escribió:Buenas noches.una duda sobre actualizar info-entertaiment: tengo actualmente la version MST2_EU_SE_ZR_P0346T
y he visto en mibsolution la version 497T.
Sabeis si se puede actualizar? si se puede saltar directamente de una a otra?
Enviado desde mi Pixel 7 mediante Tapatalk
Tienes navegador?
No
- Seat Leon MK1 - FR TDI 150cv (2005)
- Seat Leon MK3 - X-Perience TDI 150cv (MY16)
nogard
Agradecido: 34 veces
Notapor Silguer el 07 Mar 2023, 20:56
Muy buenas tardes, en la imagen aparece cual es mi version, después de leerme mas o menos 100 pag me surgen algunas dudas:
Cuando hablamos del error, es visible en el uso , o sea te aparece en alguna parte.(no tengo obdeleven)
La tarjeta sd debe ser sin adaptador o una clase 10 con adaptador funcionaria.
Yo tenia el navegador con los mapas actualizadles se supone que para siempre, por lo que veo nunca se me han actualizado, entiendo que esto debería hacerlo la seat directamente no?
Muchas gracias de antemano.
Silguer
Notapor jasoriab el 08 Mar 2023, 08:39
Silguer escribió:Muy buenas tardes, en la imagen aparece cual es mi version, después de leerme mas o menos 100 pag me surgen algunas dudas:
Hola @Silguer
* Si te refieres al error de Xor, no es visible en el uso normál del coche, sólo queda registrada la avería en la unidad del infotainment, pero la puedes usar sin problemas.
* SD cuanto más rápida mejor, lo que es indiferente es si es SD o microSD+adaptador, pero si tienes SD mejor úsala, para evitar tener que usar el adaptador en un proceso tan delicado como es la actualización.
* Los mapas hay que actualizarlos manualmente, bajándolos de la web de SEAT o VW. Lee el hilo de la última actualización de cartografía disponible, noviembre 2022, en este mismo subforo. En la SEAT también te lo pueden hacer, pero te cobrarían por ello, como es natural.
jasoriab
Agradecido: 2055 veces
Notapor fullanchelo el 09 Mar 2023, 22:55
hola tengo el leon de 2017 el que tiene la pantalla de 3 botones a cada lado tengo dos preguntas existe actualizaciones de esa pantalla
version software 7305
version bluetooth d460
version harware 052
y que pantalla recomendarias para cambiar que no sea muy cara gracias por adelantado
fullanchelo
Coche: Leon MK3 1.2 TSI 110cv
Notapor Berma09 el 12 Mar 2023, 20:21
Buenas:
Mi primera consulta en el foro. Soy reciente propietario de un Leon Cupra ST Mk3 de 2020, supongo que de los últimos en fabricarse. Pues bien, llevo unos días a vueltas con actualizar los mapas pero no hay forma.
He conseguido que detecte que hay una actualización al meter una tarjeta pero al final siempre me da el mismo error : "no hay datos disponibles. Introduzca una fuente con datos para actualizar el software o compruebe la fuente".
He leído que con menos de 3 años podrían estar incluidas las actualizaciones, pero no sé si me lo harán en concesionario, tengo pendiente pasarme. También tengo la duda de si los últimos no es posible actualizarlos sin "hackear". Entre actualizar el infortaiment, los mapas y los POIs (estos también me reconoció que había algo en la tarjeta pero luego dió error), y los diferentes hilo que hay ya no sé por donde tirar para actualizarlo todo.
¿Alguien podría darme un poco de luz? Estoy intentando usar la actualización de la página para Navi Sistem Plus.
Adjunto info del sistema y del navegador:
Información del sistema:
Número de pieza del dispositivo: 5F0035020j
Hardware: H55
Software: 1409
Base de datos de la navegación: V03959802PL0177 ECE
2019/2020
Berma09
Notapor jasoriab el 13 Mar 2023, 16:32
Hola @Berma09 lo primero bienvenido al foro.
La duda que realizas sobre como actualizar la cartografía deberías haberla hecha en el hilo sobre las actualizaciones de mapas, este es el hilo más reciente, viewtopic.php?f=9&t=138217
Pero te doy una pista, estás usando la versión del mapa que no se corresponde a tu navegador. Por las versiones de HW y SW que indicas, tienes un Navisystem estándar, no el plus.
Si te bajas la versión correspondiente a tu Navisystem, podrás actualizar sin ningún problema copiándola en la tarjeta SD original SEAT.
Respecto a los POIs de radares, hay un par de hilos, uno general y otro con los enlaces a las últimas versiones disponibles.
viewtopic.php?f=9&t=101511
viewtopic.php?f=9&t=128650
Lee el hilo que te indico, y si tienes más dudas, realízalas en él, por favor.
Última edición por jasoriab el 13 Mar 2023, 19:34, editado 4 veces en total
Razón: Tachar información incorrecta
jasoriab
Notapor Berma09 el 13 Mar 2023, 17:55
Gracias Jasoriab. No lleva SD con los mapas. Tiene memoria, dvd, etc. Entiendo que tiene que ser el Plus. Había intentado seguir esos hilos pero siempre tengo la sensación de no estar siguiendo ninguno que sea exactamente igual.
Berma09
Notapor jasoriab el 13 Mar 2023, 19:37
Cierto, me ha despistado la versión de SW 1409 interpretándola como la versión de la cartografría, que en el NaviSystem estándar son 4 dígitos actualemte, por tres dígitos en el Navisystem Plus, disculpa @Berma09
En tu caso, el último mapa tiene como número de versión 310, viewtopic.php?f=9&t=138217
Para ver si te ha caducado el MapCare haz lo siguiente. Deja pulsado el botón físico de menú (el que está en la zona izquierda de la pantalla) hasta que aparezca un nuevo menú con varias opciones, y entra en la opción de FEC.
Busca el código que empieza por 0730000xx y escribe aquí cual es. En el caso que ese código acabe en EE ó FF tendrás actualizaciones de por vida, y si es otro número, tienen fecha de caducidad.
jasoriab
Notapor Berma09 el 13 Mar 2023, 20:43
Tengo la 07300024.
Supongo que no estará caducado pero tendré que ir un dia con cita o cuando toque revisión que hoy no se pudieron parar mucho con el. Quería hacerlo yo, pero si me quito el lío al menos una vez...
Berma09
Notapor jasoriab el 13 Mar 2023, 21:05
Berma09 escribió:Tengo la 07300024.
Pues ese código indica que la última actualización que admite tu unidad es la de noviembre 2019. ¿Es una unidad española tu coche? Es que si lo fabricaron en la fecha que indicas, en España debería traer 3 años de MapCare, por lo que debería traer el código 07300034 ó 073000EE (actualizaciones de por vida útil del navegador).
Para ese tipo de unidades, sólo hay dos opciones posibles, o comprar la actualización en la SEAT, o hackear la unidad para cambiarle ese valor del FEC 073. No funciona la sustitución del fichero overall.nds como en las Navisystem estándar.
¿Cuál es la versión del mapa actual que tiene tu coche?
jasoriab
Notapor Berma09 el 13 Mar 2023, 21:43
Definitivamente mejor me lo tomo con calma entonces. Ya me descargué el manual del FEC, pero ya he trasteado bastante por el momento, como para meterme en eso antes de familiarizarme con todo.
La version es esta V03959802PL0177 ECE
2019/2020. Es alemán, fabricado entre julio y septiembre, no lo sé exactamente.
Berma09
Notapor jasoriab el 14 Mar 2023, 08:17
Berma09 escribió:Definitivamente mejor me lo tomo con calma entonces. Ya me descargué el manual del FEC, pero ya he trasteado bastante por el momento, como para meterme en eso antes de familiarizarme con todo.
Entonces ese es el motivo. Supongo que en Alemania no era obligatorio comprar MapCare al comprar el coche como sí lo era en España, por eso cuadra la caducidad de la cartografía con la fecha de fabricación aproximada del coche.
Aquí se comenta una manera de hacerlo, viewtopic.php?f=9&t=137818 pero tienes que tener en cuenta que puedes dejar inservible la unidad si lo haces mal, ya bajo tu responsabilidad si lo haces...
Dejamos ya el tema, para no desviar la temática del hilo, que trata de las actualizaciones de firmware de la 5F en el León Mk3. Si tienes más dudas, plantéalas en el hilo que te indico arriba de como cambiar el FEC si te animas a hacerlo, o en este viewtopic.php?f=9&t=138217 que trata de la última versión disponibles de mapas, a fecha de hoy.
jasoriab
Notapor Nosi el 30 Mar 2023, 15:29
Buenos días.
Tengo un style connect de noviembre del 2015 y es My16. Salía de casa con pantalla de 6,5" con full link y sin disco duro.
Me funciona correctamente Android auto pero solo con ciertos cables. Tengo amigos con modelos mas modernos a los que todos los cables usb les funciona correctamente pero mi coche no los reconoce. Solo sirven para cargar.
Será porque el módulo usb es más antiguo y sibarita con ciertos cables?
Se podría solucionar haciendo un cambio del módulo de usb por otro más actual?
Saludos y gracias por adelantado
Nosi
Notapor Sabido el 09 May 2023, 17:58
Veo que en Apps de OBD11, en los LEon de 2017-2020 (Mk3), han puesto un one-click-app, que es "CarPlay Wireless MIB3", que yo sepa nuestros Leones son MIB2, y no llevan WLAN (para poder hacer CarPlay inalámbrico), no se si hay alguna manera de subir nuestros infotainment a MIB3. Y aprovecho el comentario para preguntar cual es la ultima versión de software si mi hardware es el H50??
Sabido
Notapor jasoriab el 10 May 2023, 09:10
Sabido escribió:Buenas,
Hola @Sabido
Está claro que es un error por parte de la gente de OBDEleven, ya que las MIB3 las monta el León 4, no el León 3. De todas formas, acabo de mirarlo y no me aparece ya ese mod en la aplicación Android, lo mismo han corregido el error...
Es bastante complejo pasar a MIB3 en el León 5F, y no funcionaría todo bien, así que personalmente no merece la pena. La opción es usar un dispositivo como pueda ser AAWireless, Motorola M1 o similar para obtener Android Auto o Carplay inalámbrico en el Mk3.
Respecto a tu pregunta de última versión disponible para las H50, es la 516 si no han sacado alguna nueva recientemente...
jasoriab
Usuarios navegando por este Foro: Anthropic, Drs y 3 invitados
