León Mk3 - Actualización infotainment
Favoritos: BADS, Daruma, ositoerik, dmesanun, YeSL, pocososinos, jasoriab, JaviMarquez, crujipoyo, Arkan7, Cristianibias, pepeiyo69, Angel J, Xaggy, edumachuca, abollao, -alberto-, Rickymax, ferre7, Pedritoleon, Rivesgti, Alleya, davidalba, Xiguito_Corito, craken, JDCLEONFR, nemura, danihd, cenkkaya, Kisszabo, castell_lkpg, pistoleromtb, Raulportela, Martelinko, albert_naga, Adrian Anton, Gravilhas75, chaiser, popez, ruli68, denniisg2000, LeonFR80bsv
Seguidores: kenny_fonseca, ncx, Lavadora, barris31, juancete, ivantxe, jesusFR, Hysteria, MaximusRoco, Manu1986, Jorge75016, davidbj, bIxu, miyobe, MORKAS, gorkansr, aironsam14, jramis, kimudj, Maikermx, Javizormo, gogua, Melonkid, Kikote8, danirodrigueze30, maxinew, aigort, carlosgzlez, corderazo, Lionxp, jande, Edu1589, msmdraven, Arkan7, inamarlo, edumachuca, Josepo79, lead, camamaleon, davidmd, carrasco13, clavelstreet, mikomiko, josele77, car212121, itz18, golf_1990, LeidenSpain, vecnte, Andy_G, csabafr2013, leonfr76, Trimmer, genialsoft, Enerts, leonfrrojito, Horus, paco_22_22, ruben88, Valerofr150, molvi_mabad, Pekee69, Dav2k6, IbiFR, il_munyo, craken, ruben91mad, papo-182, el_padrino, zeratul, kaiserssosse, lytry32.hc, sbarri, ghitus, DesmoSimon, ruli68, Mramos1985, tonielfilas, braulioT, davidalba, JaviMarquez, osjamil, egarense69, fexposru, Pedrost, Illan, chetelopez, juanacho21, cuenka16, pepeiyo69, VapaV, AlvaroPM13, balbu, juan7777, mams69, Helrique, Kike77, volkov, jluis, loeches, Tom70, Dconnect, Trivi83, MilleMiglia, linxes, sergi303, hector37, D83, quiquito30lv, ElFon, DALOFER17, davidap13, kigua, JOTTA, Senuto, jd_zuri, Alvi, damsolu, Leon pucelano, javi_archi, danihd, alcoleazgz, miguel23and, xarlio, jdieztec, mitxuni, Kisszabo, Gendos22, xexpir, canijo82, Brandenor, cenkkaya, kennit0, Chelazo, bertoco, benitogomez, carlosVACA, Peje, NOECUBI1, AAAJDA, trazas, martija, borjiguez, JoseXS, ferbarroso14, Wespa, Cloud_ganora, Berbe15, Valengti, Chrohu, Atajunen, Victorzabal, jrm82, carlo13, iNFeCTeD, paralaxon, ateopoeta, pepo55, ribasxisco, Raulribarroja, ivanti, Jansel, lopezm0, Rubén Flp, Warelio, Vagabundo, Rekoba, Octacon, matiaso, Alianma, Raulportela, Éugen91, Rivesgti, Mcm90, DaniR86, Gravilhas75, JuanNur78, el_Asturiano, Mr.Chuflas, albert_naga, juanfrancia, Seket, algabe, pistoleromtb, ebcuatro, [GuErRa], Mario Leon, tito68
Re: León Mk3 - Actualización infotainment
Notapor Termi84 el 23 Sep 2023, 14:38
Hola buenas compañeros, me voy a liar la manta a la cabeza y quiero actualizar mi equipo, pero por más que leo y leo estoy perdido de donde descargar los archivos y los pasos que hacer.
Mi equipo es este :
Número de pieza del dispositivo: 50A035824
Hardware: H24
Software: 0245
SOUND
CAR
Códec de Media: 2101.0.0.10
A ver si me pudierais ayudar.
Termi84
Notapor Lavadora el 29 Sep 2023, 21:43
lucky_38 escribió:Buenos días a todos! Los que tengan una MIB2 H41 (Software Train MST2_EU_SE_ZR_P04xxx) tienen disponible la versión 0480 (hasta hace poco la última era la 0479) para actualizar la 5F. Os dejo el enlace de mega donde la he subido. Instalada hace un par de días y funciona correctamente :)
https://mega.nz/file/S6ghwJyI#TheBOJTH_ ... ipEWDrxYqk
Actualizado desde MST2_EU_SE_ZR_P0479T a MST2_EU_SE_ZR_P0480T.
Muchas gracias!!
Procedure
1. Enter hidden menu and check your current SW train.
2. Find and download latest supported firmware update for your unit.
3. Use 8GB or larger SD card, format it with FAT32 file system with the smallest allocation size available.
4. Copy firmware update files to the root directory of the SD card.
5. Remove SD cards from the main unit and insert update SD into SD1 port.
6. Press and hold MENU button for 3 seconds, select "Software update/versions", "Update", "SD card", select firmware, press "Start" and "Next".
7. Wait patiently. Main unit will reboot 3 times before the new firmware is installed.
8. When the installation is complete you can press the arrow in the upper-right corner, "Cancel". Unit will reboot one final time.
9. Press and hold MENU button to confirm that the unit is running new firmware version now.
10. Use scan tool like OBDeleven or VCDS to clear the B201A fault code according to this tutorial: https://www.youtube.com/watch?v=0tpPm-ucAwc&t=0s
Lavadora
Notapor richard_11 el 06 Oct 2023, 10:22
Muchas gracias!!
Procedure
Tengo la misma unidad. Actualmente en la versión 0472 y OBD11 me dice que está disponible la 0480. ¿Has notado alguna mejora? Me estoy planteando actualizar.
PD: ¿alguien sabe dónde encontrar el "changelog" de cada firmware? Sería interesante saber qué corrige o cambia cada versión de fw.
2018 - Hoy -> Seat Leon III Style Visio 1.6TDI CR 115cv (2018)
2013 - 2018 -> Seat Leon II Reference 1.6TDI CR 105cv (2012)
2010 - 2013 -> Renault Clio Expression 1.2i 16v 75cv (2003)
richard_11
Agradecido: 57 veces
Notapor Warelio el 06 Oct 2023, 10:28
Tengo instalada la versión 0479 y no noté nada con respecto a la versión 0468 que llevaba antes instalada, si acaso algo más de rapidez en la respuesta. Deduzco que de la 0479 a la 0480 pocos o casi nulos serán los cambios... Además los Leones MK3 ya están considerados "desfasados" en cuanto a software y no creo que desarrollen actualizaciones de la 5F muy extensas más allá de arreglar algún bug.
Prueba a actualizarla y nos cuentas a ver si notaste cambios.
Enviado desde mi Pixel 6 Pro mediante Tapatalk
Warelio
Moderador de Racing
Agradecido: 1182 veces
Notapor richard_11 el 06 Oct 2023, 10:32
Warelio escribió:Tengo instalada la versión 0479 y no noté nada con respecto a la versión 0468 que llevaba antes instalada, si acaso algo más de rapidez en la respuesta. Deduzco que de la 0479 a la 0480 pocos o casi nulos serán los cambios... Además los Leones MK3 ya están considerados "desfasados" en cuanto a software y no creo que desarrollen actualizaciones de la 5F muy extensas más allá de arreglar algún bug.
Esta tarde le meto mano, en unos días os contaré impresiones. Aunque sólo sea el "efecto placebo" y lo notemos más rápido :P
¿Sólo se puede por tarjeta SD o también te deja por USB? Tengo SD, es sólo curiosidad (he visto que está la opción de USB en el menú de servicio, pero siempre se habla de SD)
richard_11
Notapor Warelio el 06 Oct 2023, 10:34
Hazlo con tarjeta SD.
Y siempre con precaución, ya sabes que con estas cosas existe un riesgo de dejar la unidad como un pisapapeles si algo sale mal...
Warelio
Moderador de Racing
Notapor Lavadora el 06 Oct 2023, 15:36
Muchas gracias!!
Procedure
No he notado nada. Quizás algo más rapido en general o quizás efecto placebo. Si he leído y comprobado que se pierden las imágenes de la radio.
¿Sabéis como instalarlas?
No uso la radio pero es por dejarlo bonito...
Ojalá tuviera el changelog.
Enviado desde mi SM-G991B mediante Tapatalk
Lavadora
Notapor Lavadora el 06 Oct 2023, 15:38
Yo lo hice siempre por MicroSD.
[img]https://uploads.tapatalk-cdn.com/20231006/cd744233360b37aa8ee9846219a481ec.jpg[/img][img]https://uploads.tapatalk-cdn.com/20231006/c7f6b8e1fc988f5adbf2495a9997dae0.jpg[/img]
Lavadora
Notapor Warelio el 06 Oct 2023, 15:55
¿Has notado alguna mejora con la nueva actualización?
Warelio
Moderador de Racing
Notapor richard_11 el 06 Oct 2023, 20:17
Actualizado hace un rato de 0472 a 0480 sin problemas. En estos días informo si noto algo. En principio lo que comentáis, da la impresión de que moverse por los menús es ligeramente más ágil, pero no descarto que sea efecto placebo.
richard_11
Notapor Lavadora el 06 Oct 2023, 22:20
Nada, quizás algo más rápido pero puede que sea placebo
Lavadora
Notapor algabe el 01 Nov 2023, 17:59
Saludos, este es mi primer mensaje en este grupo, me he leído, no sé si cerca cien páginas, pero no tengo claro si puedo actualizar mi unidad, tengo un Seat leon xperience 2.0 TDI del 2016 con sistema de audio full link, disco duro y navegador, aquí dejo unas imágenes, gracias.
algabe
Notapor aprietatuercas1974 el 04 Nov 2023, 12:07
algabe escribió:Saludos, este es mi primer mensaje en este grupo, me he leído, no sé si cerca cien páginas, pero no tengo claro si puedo actualizar mi unidad, tengo un Seat leon xperience 2.0 TDI del 2016 con sistema de audio full link, disco duro y navegador, aquí dejo unas imágenes, gracias.
puedes actualizar a la 1447 creo recordar
aprietatuercas1974
Agradecido: 358 veces
Notapor algabe el 08 Nov 2023, 17:30
Saludos, mi versión actual de infotainments es esta: SW Train instalada: MHI2_ER_SEG11_SG2130 y la versión SW MU instalada: 0355.
Me descargué la actualización de la página https://mibsolution.one/, la versión MHI2_ER_SEG11_P4709_MU1447.
Una vez descargada la metí en una tarjeta SD, la introduje en la ranura para su instalación y le di a actualizar, en principio parecía que todo iba correctamente actualizándose sin ningún problema, pero cuando se reinició el sistema la pantalla se quedó permanentemente en el logo de SEAT xperience y de allí ya no pasa, le he dejado así horas la pantalla para ver si finaliza la actualización sin resultado, con el coche apagado, quitado la llave y cerrado, la pantalla se queda encendida con el logo, he sacado y vuelto a poner el fusible de la radio durante un tiempo para sí ver si la instalación podría continuar sin resultado tampoco, ya no sé qué hacer más, ¿alguien sabría si hay alguna solución para este problema?, gracias.
algabe
Notapor Warelio el 17 Nov 2023, 09:07
¿Te aseguraste de que la versión que descargaste era compatible con tu unidad? ¿Actualizaste porque tu unidad fallaba o por el mero hecho de actualizar a la última versión? Creo recordar que el contacto ha de estar encendido y el motor parado durante todo el proceso de actualización (reinicios de pantalla incluidos) y vigilar que la pantalla no se apague, abriendo puertas de vez en cuando, de lo contrario se corre el riesgo de que la actualización no se implemente y/o pueda dejar frita la unidad 5F... Espero que se haya quedado en un susto y hayas posido solucionarlo. Hay que vigilar con lo que se toca y estar muy seguro en el qué y en el cómo para evitar sustos o males mayores. No son precisamente baratas las averías de estos módulos.
Si no se está seguro mejor no tocar nada y si se trastea, empaparse antes bien del proceso a seguir, y ante la más mínima duda dejarlo estar o acudir a alguien que lo tenga por la mano y sepa cómo hacerlo minimizando riesgos.
Warelio
Moderador de Racing
Usuarios navegando por este Foro: Anthropic, Semrush y 5 invitados
