León Mk3 - BRICO - Como instalar la cámara de parking
Favoritos: JaviCG, Vampiro, J@VY, BADS, Daruma, cstrol, JorgeAnteloC, ipenalosa, MONTY DAKA, pirly, josele887, xurox, Nanox23, Carbono79, vallter, norchugo, Efremvidal, @turbina@, blankiblau, jorgee76, jliriz, Vilo, cuenxis, victir, Aras, Korath, Rasekfighter, Carrl, jdieztec, J-Frass, Tarzan, zacarias, Frannisesabe, Xperience, bronce702, sbarri, javieret69, Carlos Chea, Lotar, Alleya, miguelorly, craken, chemazz, xico, eMi1, Maverick.es
Seguidores: Linker89, car212121, franrx, davidalba, TRIBO, danieleon, Panchorin, Hecson.27, jmfcoto, aironsam14, JOTTA, MORKAS, Unaited, trekam, xandis, Jorge75016, Platanot, davidbj, Achehmg, marc.domenech.90, sadanyac, seat leon blanco, Marc.22, Peuero, er_trompe, GTI35, JoseCa, JaviCG, vigimuertos, rabazas, B.Fox, msmdraven, Tomcat7733, Txutxiysilvia, xabidh, cstrol, Carrl, El3ndil, yorky, bolche, LeoST, Diegokero, Rasekfighter, Budoka, IronTor21, marlop, xico, vanscampa, Tarzan, jorgee76, josemag, aigort, LuichiFR, SLon34, clavelstreet, nani_san, nyro, IVANIN9, rober1095, ivan0909, jose.jjg307, csabafr2013, P.carrizo.leonstfr, dookky, Edu1589, Dconnect, D83, Jeii90, inamarlo, Israel-FR, Herrdoktor, el_padrino, Kipu, aguscalderon, lebowski, juanmaroger, bailyibz, naikon_paul, Valerofr150, JAL, kennit0, Mramos1985, bronce702, kijute, juanmik, osjamil, Tonivn, Lotar, Tunnig, JaviMarquez, nitro_g4074, sergi303, ivan2017, Chema_Alvarez, ilargiman, jaumotix, sbarri, javierferriz, alcoleazgz, lecupra280, Colomer, Maikermx, luigi323, rents_80, jdiego75, Pedrost, damsolu, lead, Franr50, Dani2025, Leon pucelano, nachomart, castronight, victor david, bertoco, juan7777, Josep20, jakobitto, rr7mo, a.cuadros71, iNFeCTeD, Gendos22, VapaV, Chrohu, Ganyula, snowpluralism, victor_leon_FR, luaiabou96, Drovniak, Guillen222, leonfrrojito, justics, lopezm0, Romera, pedrorossello92, AlvaroRamlo
Re: BRICO como instalar la Camara de parking en Seat leon MK
Notapor weide el 03 Feb 2015, 20:03
Yo ya tengo todos los materiales y estoy viendo la posibilidad de ponerme con ello, pero me surge la duda, entiendo que con el cable de alimentación que va al fusible no necesito relé, o si? A ver si me echáis una mano, porque esto es más complicado de lo que pensaba en un principio. Esto es lo que tengo
weide
Notapor rojas el 04 Feb 2015, 00:17
weide escribió:Yo ya tengo todos los materiales y estoy viendo la posibilidad de ponerme con ello, pero me surge la duda, entiendo que con el cable de alimentación que va al fusible no necesito relé, o si? A ver si me echáis una mano, porque esto es más complicado de lo que pensaba en un principio. Esto es lo que tengo
hola @weide ...
a ver , yo te recomiendo ponerlo , si no lo haces la camara estara alimentada constantemente , la instalacion es muy sencilla , 4 patillas:
1 positivo ( luz marcha atras )
1 negativo
1 entra corriente ( mechero )
1 sale a la camara
en el mismo rele , viene un esquema
por otro lado necesitas un cable RCA hembra para conectarlo al quadlock y conectar tu cable ... a no ser que le cortes la punta y lo conectes directamente
rojas
Coche: Leon MK3 1.5 TGI 130cv
Agradecido: 1888 veces
Notapor oliver1124 el 04 Feb 2015, 08:57
Impresionante brico, ya tengo pedida la cámara a ver cuando llega. :banana:
oliver1124
Notapor weide el 04 Feb 2015, 14:07
Gracias Rojas. Entiendo que tambien necesitaré el condensador para el relé no?
weide
Notapor vallter el 04 Feb 2015, 18:58
genialsoft escribió:
Martín st escribió:Por faltar me falta todo, pero lo primero que estado haciendo es encotrar al alguien que lo quisiera hacer pero solo ponen pegas que si no tiene la salida de vídeo, que no entran en el vag com solo eran problemas, joder y yo me veo incapaz de hacerlo por eso no compre nada hasta que tuviera alguien que me lo.montará, te tomo la.palabra, gracias tio, que peña más buena hay en este foro ole y ole
Tu ves pidiendo el material que quedamos un dia 2 o 3 y nos lo curramos en un momento! Que yo no lo he montado por no tener la escusa de hacerlo, que ahora ya lo tengo todo y sólo tengo que hacer las conexiones.
Venga yo tambien me apunto. Voy a recopilar la lista de material necesario y la voy a ir pidiendo a ver si cuando os juntéis ya lo tengo todo. Y si no, pues igualmente iré para ver como lo hacéis y empaparme. Y como no, conoceros a los que no conozca porque a genialsoft lo conocí este domingo pasado. Fue una gran quedada y lo pasamos de P... M....
Hasta pronto compis.
Leon 1.2 ITECH 110 cv
vallter
Coche: Leon MK3 1.2 TSI 105cv
Agradecido: 28 veces
Notapor vallter el 04 Feb 2015, 19:29
Martín st escribió:Buenas peña, ya he conseguido que en concesionario me realicen la intalacion para no perder la garantía eso sí tengo que llevar la cámara yo ya que ellos no las tienen en accesorios, ya os contare
Donde tienes que ir, te han dicho lo que te cobraran?
vallter
Notapor rojas el 04 Feb 2015, 20:05
weide escribió:Gracias Rojas. Entiendo que tambien necesitaré el condensador para el relé no?
si la corriente la sacas de corriente limpia ... prueba a no ponerlo , para ponerlo siempre hay tiempo .... a ver q tal se ve
rojas
Notapor fati33 el 04 Feb 2015, 20:12
rojas escribió:
Achehmg escribió:Buenas noches lo primero, grandisimo briko rojas, un maquina.
Lo siguiente mi duda: que equipo multimedia soporta cámara trasera? Se puede montar en cualquier equipo touch/colour/plus/nav.
Perdón si no es apropiada la pregunta o ya está solventada anteriormente es que ando un poco pez
se puede montar en cualquier pantalla a color
Buenas, lo primero darte las gracias por este pedazo de brico, y ahora mis duda, mi hermano tiene el modelo de radio inferior al nuestro es decir no tiene navegador , la sd va en el aparato y en la guantera no tiene las conexiones no? ,que estarían detrás de la pantalla? y serian igual que las nuestras de estar ahi?
Gracias de nuevo y un saludo.
Seat Leon 1.4Tsi 125cv
Seat Alhambra Tdi 130cv
Seat Leon Mk1 FR Tdi 150cv
fati33
Notapor arlot el 04 Feb 2015, 22:27
@Martin st
Ya nos diras cuando funcione, donde has ido para que te lo hagan, porque a mi, realmente me da una pereza de narices.
Vamoooooooooooooos
arlot
Agradecido: 977 veces
Notapor Maestro el 04 Feb 2015, 22:41
Yo instale la mia (otra diferente a la del plafón) alimentándola directamente del fusible del mechero y no me hizo falta ni rele ni filtro de señal, por cierto yo no puse ningún rca, directamente crimpé los pines al cable que va al quadlock
Viajar no es desplazarse, es sentir el camino
Maestro
Agradecido: 25 veces
Notapor alvaro leon fr st el 04 Feb 2015, 23:39
Tenéis algún enlace donde comprar una cámara en el logó de seat?
alvaro leon fr st
Agradecido: 16 veces
Notapor Martín st el 05 Feb 2015, 00:17
Buenas peña leonera, al final en concesionario se hecharon para atrás el jefe de taller me dijo que no podía ser el motivo ufff no se termino haciendo una oferta de los sensores trasero por 500 euros de nada la madre que lo.parió jejeje.
Al final he encotrado un taller en cornella (barcelona) que me cobra 90 euros y 30 por la cámara, me comenta que el cableado y pasar por vagcom también, el viernes tengo que hablar en persona con el, ya diré como queda la historia por si alguien le interesa
Martín st
Coche: Leon MK3 1.4 TSI 122cv
Agradecido: 26 veces
Notapor arlot el 05 Feb 2015, 08:20
Martín st escribió:Buenas peña leonera, al final en concesionario se hecharon para atrás el jefe de taller me dijo que no podía ser el motivo ufff no se termino haciendo una oferta de los sensores trasero por 500 euros de nada la madre que lo.parió jejeje.
Estaremos pendiente de ese intercambio de impresiones que tengas el viernes con el pollo del taller
Vamoooooooooooooos
arlot
Notapor Javierh el 05 Feb 2015, 11:40
Antes de nada dar las gracias a rojas por tremendo aporte.
Quizás sea un poco oportuno, pero el hilo se está llenando de post y hay comentarios muy interesantes bastante desperdigados. ¿Podéis poner una lista con todos los materiales necesarios para la instalación? tanto los obligatorios como los recomendados, para que así principiantes como yo tengamos todo lo necesario sin miedo a equivocarnos.
Veo que hay bastante cámaras en el mercado: ¿algún enlace web directo con algunas de las mejores? Muchas gracias.
Javierh
Agradecido: 15 veces
Notapor halfy el 06 Feb 2015, 17:00
rojas escribió:en una tienda de electronica o repuestos de automocion
o aki uno como este
http://www.ebay.es/itm/On-Off-4-Pin-Rel ... 5653d9f875
Muchas gracias, he cogido uno de 5 pines.
Seat Leon ST 184CV FR
halfy
