León Mk3 - BRICO - Como instalar la cámara de parking
Favoritos: JaviCG, Vampiro, J@VY, BADS, Daruma, cstrol, JorgeAnteloC, ipenalosa, MONTY DAKA, pirly, josele887, xurox, Nanox23, Carbono79, vallter, norchugo, Efremvidal, @turbina@, blankiblau, jorgee76, jliriz, Vilo, cuenxis, victir, Aras, Korath, Rasekfighter, Carrl, jdieztec, J-Frass, Tarzan, zacarias, Frannisesabe, Xperience, bronce702, sbarri, javieret69, Carlos Chea, Lotar, Alleya, miguelorly, craken, chemazz, xico, eMi1, Maverick.es
Seguidores: Linker89, car212121, franrx, davidalba, TRIBO, danieleon, Panchorin, Hecson.27, jmfcoto, aironsam14, JOTTA, MORKAS, Unaited, trekam, xandis, Jorge75016, Platanot, davidbj, Achehmg, marc.domenech.90, sadanyac, seat leon blanco, Marc.22, Peuero, er_trompe, GTI35, JoseCa, JaviCG, vigimuertos, rabazas, B.Fox, msmdraven, Tomcat7733, Txutxiysilvia, xabidh, cstrol, Carrl, El3ndil, yorky, bolche, LeoST, Diegokero, Rasekfighter, Budoka, IronTor21, marlop, xico, vanscampa, Tarzan, jorgee76, josemag, aigort, LuichiFR, SLon34, clavelstreet, nani_san, nyro, IVANIN9, rober1095, ivan0909, jose.jjg307, csabafr2013, P.carrizo.leonstfr, dookky, Edu1589, Dconnect, D83, Jeii90, inamarlo, Israel-FR, Herrdoktor, el_padrino, Kipu, aguscalderon, lebowski, juanmaroger, bailyibz, naikon_paul, Valerofr150, JAL, kennit0, Mramos1985, bronce702, kijute, juanmik, osjamil, Tonivn, Lotar, Tunnig, JaviMarquez, nitro_g4074, sergi303, ivan2017, Chema_Alvarez, ilargiman, jaumotix, sbarri, javierferriz, alcoleazgz, lecupra280, Colomer, Maikermx, luigi323, rents_80, jdiego75, Pedrost, damsolu, lead, Franr50, Dani2025, Leon pucelano, nachomart, castronight, victor david, bertoco, juan7777, Josep20, jakobitto, rr7mo, a.cuadros71, iNFeCTeD, Gendos22, VapaV, Chrohu, Ganyula, snowpluralism, victor_leon_FR, luaiabou96, Drovniak, Guillen222, leonfrrojito, justics, lopezm0, Romera, pedrorossello92, AlvaroRamlo
Re: BRICO como instalar la Camara de parking en Seat leon MK
Notapor jliriz el 06 Feb 2015, 19:19
Maestro escribió:Buenas,
Yo instale la mia (otra diferente a la del plafón) alimentándola directamente del fusible del mechero y no me hizo falta ni rele ni filtro de señal, por cierto yo no puse ningún rca, directamente crimpé los pines al cable que va al quadlock
Si va directamente al mechero, ¿Esta todo el tiempo encendida? o ¿le has puesto un interruptor?
Lo del rele es para que al meter la marcha atras detecte que se tiene que activar y coja la corriente del mechero.
Seat Leon Sc 1.6 TDI 105cv DSG Style-Itech con Faros Full Led, Techo Panorámico, Navegador, Control de velocidad con radar y asistente de frenada, Safety Pack, Alarma Volumétrica, Sensores de aparcamiento delanteros y traseros + OPS + Cámara, Cristales tintados y Rueda repuesto minimizada 16".
Febrero'15.
jliriz
Agradecido: 113 veces
Notapor Martín st el 06 Feb 2015, 20:58
Buenas noches peña, como ya comenté hoy estado hablando con mecánico por el tema de la intalacion, bueno más que un mecánico es un chispa con experiencia que controla muy bien el grupo vag.
Bueno al grano jejeje, por 120 euros la intalacion con cámara ya incluida con todo relés cables y activar la pantalla con el vagcom, la semana que bien me la instala bueno si alguien le interesa que me mande un privado y le paso el número de teléfono ahhh es en barcelona.
Martín st
Coche: Leon MK3 1.4 TSI 122cv
Agradecido: 26 veces
Notapor arlot el 07 Feb 2015, 10:53
Martín st escribió:Buenas noches peña, como ya comenté hoy estado hablando con mecánico por el tema de la intalacion, bueno más que un mecánico es un chispa con experiencia que controla muy bien el grupo vag.
Interesante, estaremos muuuuuuuuuuuy atentos al asunto, y si te quedas convencido y funciona OK ya te pido el telefono del chispas
Yo la cámara ya la tengo, en el armario :D
Última edición por arlot el 07 Feb 2015, 10:56, editado 1 vez en total
Vamoooooooooooooos
arlot
Agradecido: 977 veces
Notapor JoseCa el 07 Feb 2015, 10:54
Si encuentro a alguien en Coruña o alrededores que me la instale por ese precio no me lo pensaría.
Ya nos comentaras que tal queda y que tal va.
JoseCa
Agradecido: 47 veces
Notapor genialsoft el 07 Feb 2015, 19:40
Hoy he conseguido sacar algo de tiempo para intentar y reitero lo de intentar poner la cámara en marcha, indicar que como habia configurado ya la cámara lo he ido haciendo al revés, he conectado el RCA a los pins y he probado con uan cámara que tenia que se viera la imagen, hasta aquí todo bien. Como ya tenia el cable en la guantera y había prepardo una cajita con las conexiones no me he preocupado mucho de la conexión, lo he hecho al revés, es decir he ido llevando el cable de la guantera al maletero.
problemas que me he encontrado:
1.- Pasar el cable desde atrás a adelante no es fácil, me he sollado las manos bien. Para conseguir pasarlo hasta atrás he tenido que desanclar el asiento trasero ya que si no no habia manera de pasar el cable.
2.- Cuando por fin tenía el cable RCA en el maletero voy a quitar el "tetoncillo" como dices @rojas y me estaba desesperando ya que costó mucho.
3.- Cuando por fin quito el tetoncillo, me encuentro que donde debería haber un hueco hay un aislante y no es posible pasar nada por ahí.
4.- Ya desesperado no he dado a encontrar el otro punto por donde en teoría se podía pasar el RCA.
O sea que al final no he conseguido pasar el RCA ni el cable de alimentación a la cámara, teniéndolo ya todo probado y listo. :zoquete: :zoquete: :zoquete: :zoquete:
genialsoft
Agradecido: 346 veces
Notapor rojas el 07 Feb 2015, 20:19
juas!! tio q mala suerte ...
no pasa nada ... que no cunda el panico . Puse una 2ª opcion , pasar ambos cables por la esquina . Coge los cables pasalos por ahi , cuando los tengas abajo del coche quita la luz de matricula ... mete una guia hacia el lado donde estan los cables , no te canses de meter hasta que salga por algun sitio , y ya metes corriente y video con la guia hasta la luz . No te agobies , que todo tiene solucion ,sencilla y rapida ademas.
buen trabajo @genialsoft !
rojas
Coche: Leon MK3 1.5 TGI 130cv
Agradecido: 1888 veces
Notapor genialsoft el 07 Feb 2015, 21:08
rojas escribió:juas!! tio q mala suerte ...
Es que no encontré el segundo hueco, intentare mañana buscarlo a ver, hay que quitar el guarnecido de la derecha del maletero obligatoriamente, verdad?
genialsoft
Notapor rojas el 07 Feb 2015, 21:16
segun abres el maletero a la derecha , yo no quite el guarnecido , solo lo aparté , esta justo en la esquina !
rojas
Notapor genialsoft el 07 Feb 2015, 21:21
Había interpretado mal la foto.
genialsoft
Notapor arlot el 07 Feb 2015, 21:39
@genialsoft si quieres ya vendré ha ayudarte un poco :marley:
Vamoooooooooooooos
arlot
Notapor rojas el 07 Feb 2015, 21:52
:borracho: :borracho: :borracho:
rojas
Notapor genialsoft el 07 Feb 2015, 21:53
arlot escribió:@genialsoft si quieres ya vendré ha ayudarte un poco :marley:
Con eso seguro que paso el cable!
genialsoft
Notapor vallter el 07 Feb 2015, 23:18
Si necesitas ayuda aquí tienes mis manos. Solo tienes que decirme donde y cuando ir
Leon 1.2 ITECH 110 cv
vallter
Coche: Leon MK3 1.2 TSI 105cv
Agradecido: 28 veces
Notapor vallter el 07 Feb 2015, 23:23
@genialsoft si quieres que te eche una mano solo tienes que pedirlo y después unas cervecitas
vallter
Notapor Martín st el 08 Feb 2015, 12:04
Hola de nuevo peña, quiero hacer una consulta y quiero vuestra opinión sería de ayuda Gracias anticipadas.
Primera duda, elegir la cámara, luz matricula o parachoque realizando el abujero, he elegido la del parachoque ya que esta más centrada y en caso de avería es más fácil cambiarla.
Segunda duda, también he preferido no poner el relé ya que tiene un retardo en visualizar en la pantalla, pero siempre tiene alimentado la cámara de corriente, lo he comentado al instalador y me dice que no pasa nada.... Es verdad
Martín st
