León Mk3 - BRICO - Como instalar la cámara de parking
Favoritos: JaviCG, Vampiro, J@VY, BADS, Daruma, cstrol, JorgeAnteloC, ipenalosa, MONTY DAKA, pirly, josele887, xurox, Nanox23, Carbono79, vallter, norchugo, Efremvidal, @turbina@, blankiblau, jorgee76, jliriz, Vilo, cuenxis, victir, Aras, Korath, Rasekfighter, Carrl, jdieztec, J-Frass, Tarzan, zacarias, Frannisesabe, Xperience, bronce702, sbarri, javieret69, Carlos Chea, Lotar, Alleya, miguelorly, craken, chemazz, xico, eMi1, Maverick.es
Seguidores: Linker89, car212121, franrx, davidalba, TRIBO, danieleon, Panchorin, Hecson.27, jmfcoto, aironsam14, JOTTA, MORKAS, Unaited, trekam, xandis, Jorge75016, Platanot, davidbj, Achehmg, marc.domenech.90, sadanyac, seat leon blanco, Marc.22, Peuero, er_trompe, GTI35, JoseCa, JaviCG, vigimuertos, rabazas, B.Fox, msmdraven, Tomcat7733, Txutxiysilvia, xabidh, cstrol, Carrl, El3ndil, yorky, bolche, LeoST, Diegokero, Rasekfighter, Budoka, IronTor21, marlop, xico, vanscampa, Tarzan, jorgee76, josemag, aigort, LuichiFR, SLon34, clavelstreet, nani_san, nyro, IVANIN9, rober1095, ivan0909, jose.jjg307, csabafr2013, P.carrizo.leonstfr, dookky, Edu1589, Dconnect, D83, Jeii90, inamarlo, Israel-FR, Herrdoktor, el_padrino, Kipu, aguscalderon, lebowski, juanmaroger, bailyibz, naikon_paul, Valerofr150, JAL, kennit0, Mramos1985, bronce702, kijute, juanmik, osjamil, Tonivn, Lotar, Tunnig, JaviMarquez, nitro_g4074, sergi303, ivan2017, Chema_Alvarez, ilargiman, jaumotix, sbarri, javierferriz, alcoleazgz, lecupra280, Colomer, Maikermx, luigi323, rents_80, jdiego75, Pedrost, damsolu, lead, Franr50, Dani2025, Leon pucelano, nachomart, castronight, victor david, bertoco, juan7777, Josep20, jakobitto, rr7mo, a.cuadros71, iNFeCTeD, Gendos22, VapaV, Chrohu, Ganyula, snowpluralism, victor_leon_FR, luaiabou96, Drovniak, Guillen222, leonfrrojito, justics, lopezm0, Romera, pedrorossello92, AlvaroRamlo
Re: BRICO como instalar la Camara de parking en Seat leon MK
Notapor guajarenho el 11 Feb 2015, 18:57
genialsoft escribió:
guajarenho escribió:Hay algo que no me queda claro del todo. ¿Porque coges los 12V de la luz del maletero para alimentar tu cámara? Se supone que aquí sólo llegan los 12V cuando esta luz esta encendida, esto es, cuando el maletero esta abierto...
je je esa duda también la tuve yo, pero es que el porton del maletero corta en negativo, no en positivo.
Y supongo que ese positivo es limpio... ¿o va por pulsos?
Si todo está bajo control es que no vas lo suficientemente rápido
R135
_246
guajarenho
Coche: Leon MK3 1.2 TSI 110cv
Agradecido: 36 veces
Notapor genialsoft el 11 Feb 2015, 19:27
Va por pulsos por eso lo del condensador creo recordar.
genialsoft
Agradecido: 346 veces
Notapor B.Fox el 11 Feb 2015, 19:59
No entiendo mucho de electricidad, solo he seguido los pasos del hilo, y viendo que a otros compañeros les ha funcionado he hecho un "copy and paste", así dejo un poco más ilustrativo el post para los que vengan detrás, pero en cuanto al por qué de coger la luz del maletero supongo que por lo que dice genialsoft.
La verdad... no teeeengo ni idea, al principio del post vi que era fácil (robar corriente de aquí y de allá) pero cuando metió condensadores,reles, soldar... me dio el bajón por eso lo del esquema, creo que ayuda mucho.
B.Fox
Coche: Leon MK3 1.0 TSI 115cv
Notapor guajarenho el 11 Feb 2015, 20:35
:? Algo no me cuadra. El condensador es para eliminar parásitos. En ese caso para que traer 12V del la luz del maletero con un rele si te todas formas hay que traer un cable de la luz de marcha atrás. Para eso traemos positivo y negativo del piloto de marcha atrás hacia la cámara e intercalamos el condensador. Nos ahorramos caja, rele...
¿Tu lo tienes así @genialsoft?
R135
_246
guajarenho
Notapor genialsoft el 11 Feb 2015, 20:44
En teoría comentó Rojas que subiendo la intensidad de la luz de matrícula te podias ahorra el relé, no se si el condensador. En cualquier caso yo tengo el pack completo, relé+condensador, + de maletero y +/- de matrícula, lo probé en casa simulando el + de marcha atrás y funcionaba de coña, fue conectarlo y a la primera y con una calidad mas que sobresaliente. No tenia ganas de hacer pruebas en el coche.
genialsoft
Notapor guajarenho el 11 Feb 2015, 20:59
genialsoft escribió:En teoría comentó Rojas que subiendo la intensidad de la luz de matrícula te podias ahorra el relé, no se si el condensador. En cualquier caso yo tengo el pack completo, relé+condensador, + de maletero y +/- de matrícula, lo probé en casa simulando el + de marcha atrás y funcionaba de coña, fue conectarlo y a la primera y con una calidad mas que sobresaliente. No tenia ganas de hacer pruebas en el coche.
:ok:
R135
_246
guajarenho
Notapor vallter el 11 Feb 2015, 21:24
Yo lo voy a hacer como dice @genialsoft, de echo creo que ya me esta preparando mi "cajita"
Leon 1.2 ITECH 110 cv
vallter
Coche: Leon MK3 1.2 TSI 105cv
Agradecido: 28 veces
Notapor genialsoft el 11 Feb 2015, 21:31
vallter escribió:Yo lo voy a hacer como dice @genialsoft, de echo creo que ya me esta preparando mi "cajita"
Si ya tengo un par en marcha... :yea:
genialsoft
Notapor guajarenho el 11 Feb 2015, 21:33
Es una opción. A mi no me ha echo falta ni rele ni condensador. He alimentado la cámara directamente de la marcha atrás, aumentando eso si, la intensidad del piloto.
R135
_246
guajarenho
Notapor rojas el 11 Feb 2015, 22:53
el motivo de sacarlo de la luz del maletero era un punto cercano de corriente , por aquel entonces no tenia la toma de mechero en el maletero . Como esta luz va por pulsos , de ahi que haya que poner el condensador . si la corriente es del mechero que da 12v continuos no seria necesario el condensador .
@guajarenho ha estado muy habil aumentando la intensidad , un buen aporte compañero !
rojas
Coche: Leon MK3 1.5 TGI 130cv
Agradecido: 1888 veces
Notapor Sergicm el 11 Feb 2015, 23:08
Tengo ganas de echarle mano al asunto, sólo me falta el coche y un relé... Paciencia :cafe:
Genialsoft, no se si la segunda cajita tiene dueño, si no la adoptaría con su manutención y régimen de visitas correspondiente ;)
Galería León X-Perience 184cv DSG viewtopic.php?f=43&t=109411
Sergicm
Agradecido: 15 veces
Notapor Marc.22 el 15 Feb 2015, 14:47
Que os parece esta? http://es.aliexpress.com/item/HD-CCD-wi ... 81310.html
Viernes pedí el leon y ya me estoy liando a pedirlo todo para tenerlo listo cuando llegue.
Marc.22
Notapor B.Fox el 15 Feb 2015, 15:27
Otro más con la cámara!! :banana:
Esta muy bien, se ve nítido y claro.
Gracias a todos y en especial a rojas por el brico !!!
Lo próximo, en un momento no muy lejano, el altavoz central (solo tengo 6)
B.Fox
Notapor er_trompe el 15 Feb 2015, 17:11
Marc.22 escribió:Que os parece esta? http://es.aliexpress.com/item/HD-CCD-wi ... 81310.html
Compañero, desde mi modesta opinión hay en este hilo varios enlaces que han posteado otros usuarios de las que han comprado ellos, y de las cuales ya tienes opiniones. Aparte de eso, no se si sabes que esa cámara, los 4 leds que tiene se encienden y a parte de la luz de marcha atrás, vas a tener 4 luces encendidas alrededor de la cámara. Yo no pondría esa, con el sensor CCD se consigue muy buena imagen con poca iluminación, por lo que con la luz de marcha atrás del coche es mas que suficiente.
Yo por ejemplo, he pillado esta http://www.aliexpress.com/snapshot/6439889560.html?orderId=65347448209971, es la mas pequeña que he encontrado y no modifico la luz de matrícula. Cuestión de gustos.
Es de bien nacido ser agradecido. Si te ha resultado útil este mensaje, dale al botoncito de gracias ;)
Antes de preguntar, escribe tu duda aqui, posiblemente ahorres tiempo y nos lo ahorres a los demás.
er_trompe
Agradecido: 124 veces
Notapor Marc.22 el 15 Feb 2015, 17:23
Hola, he visto algunos enlacesnde otros compañeros pero no he logrado encontrar opiniones sl respecto! Ahora mismo no se pueden hacer pedidos en ebay ya que china esta de vacaciones por el año nuevo asi que tendré que esperar unos días... Sobre la que tu comentas, donde la colocas?
Marc.22
