León Mk3 - BRICO - cambio de 5.8" a 6,5"
Favoritos: BADS, hectorcanu, gerarbcn, marlop, pocososinos, centicol, crcrodrigo, marcosgumiel, arracho, bronce702, manugl, Triple R, maki26, craken, Borjuyze, Jean-car, chemazz, rossirossa
Seguidores: Triera, Lionxp, Rumafr, crcrodrigo, Jorge75016, culofino880, gorkansr, inamarlo, davidbj, clavelstreet, saxisaac, picard14, msmdraven, gianry, danifusi, Kikote8, Kravwallace, javinho10, arracho, LeoST, JoseCa, kijute, centicol, Edu1589, aigort, webon14, pocososinos, jairin13, Txutxiysilvia, MORKAS, Triple R, mananipons, chisyelamos, CarlosTSi, Rayback, loeches, Montydaka, Taim5f, exedj, cocorolito, sergi303, sisma_eltrigo, Valdes084, Leon pucelano, Yeiem93, juanbb, miaguicam, Pedrost, Xoti, Maikermx, pasola80, PuertoLeon, Éugen91, leonfrrojito, Antoniolopez92
Re: BRICO - cambio de 5.8" a 6,5"
Notapor rojas el 24 May 2016, 02:05
gianry escribió:Hi to all,
I've got a GOLF 7 2015 with composition media 5.8" MIB1 but I'd like to install a MIB II system with 6.5" display
do you think there is a way to remove CP from it ? I've found some units and displays on Ebay
thanks
yes , is correct but ...
not bt
not sds
not navy
not fullink
rojas
Coche: Leon MK3 1.5 TGI 130cv
Agradecido: 1889 veces
Notapor gianry el 24 May 2016, 10:24
thanks
not bt
not sds
not navy
not fullink
I don't understand. what is it correct ? the VW system has the fulllink function (aPPCONNECT) AS OPTIONAL
gianry
Notapor aprietatuercas1974 el 24 May 2016, 20:59
la gente investigando y con nuevos avances,sois grandes
Última edición por aprietatuercas1974 el 05 Nov 2016, 15:43, editado 1 vez en total
aprietatuercas1974
Agradecido: 358 veces
Notapor gianry el 24 May 2016, 21:06
¿podría decirnos lo que haya instalado y cómo se quitó la protección de los componentes ?
gracias
could you tell us what you have installed and how you removed the component protection?
thank you
gianry
Notapor Eluryh el 24 May 2016, 21:51
alguna información acerca de si es posible poner full link a los mirrorlink? o qué habría que cambiar?
Eluryh
Agradecido: 107 veces
Notapor aprietatuercas1974 el 25 May 2016, 06:28
Eluryh escribió:alguna información acerca de si es posible poner full link a los mirrorlink? o qué habría que cambiar?
Última edición por aprietatuercas1974 el 05 Nov 2016, 15:44, editado 1 vez en total
aprietatuercas1974
Notapor Eluryh el 25 May 2016, 08:24
Pues no lo entiendo...
En el primer post @rojas ha puesto que se necesita esto y yo con mirrorlink tengo los marcados en negrita:
5,8" :
5F0035824 sin gps
5F0035846 con gps
5F0035858 con gps y DAB
6,5":
5QA035824 sin gps
5QA035846 con gps
5QA035858 con gps y DAB
6,5" HDD:
5F0035020 <<< tengo esta referencia en mi MIB con mirrorlink
5F0035043/46
pantalla de 6,5":
5F0919604 A <<< entiendo que todas las de 6.5 son la misma referencia
entonces no es hardware sino software?
Última edición por Eluryh el 05 Nov 2016, 16:07, editado 1 vez en total
Eluryh
Notapor PACO07.FBR el 25 May 2016, 08:58
Hola buenos días, soy nuevo en el foro me llamo Paco y soy de Madrid, he estado siguiendo este brico y me hice con una unidad de 6.5'' con navegador de segunda mano, decir que de serie tengo la unidad de 5.8'' y navegador, la he instalado y le he quitado la protección de componentes en la seat, pero no han sido capaces de configurarla y eso que ya he ido a dos.
No me funciona el control por voz me dice que tengo que ir al concesionario a que lo activen, el full link lo mismo, el bluetooth me dice que no esta disponible y no detecta ningun movil, decir que estas funciones funcionaban antes de darle al contacto y que saltara la protección. Alguien podria echarme una mano porque estoy a punto de darme por vencido, gracias de antemano.
PACO07.FBR
Notapor rojas el 25 May 2016, 12:37
PACO07.FBR escribió:Hola buenos días, soy nuevo en el foro me llamo Paco y soy de Madrid, he estado siguiendo este brico y me hice con una unidad de 6.5'' con navegador de segunda mano, decir que de serie tengo la unidad de 5.8'' y navegador, la he instalado y le he quitado la protección de componentes en la seat, pero no han sido capaces de configurarla y eso que ya he ido a dos.
Ya lo he comentado en varias ocasiones , como mucho podras recuperar el SDS y el BT ... olvidae del navy y del fullink
en el momento que le das al contacto todas las opciones que precisan licencia ( codigos SWAP ) son bloqueadas ya que no coincide tu bastidor . En mi caso bajamos todas mis activaciones y se cargaron en la unidad con lo cual he recuperado de momento el BT y el SDS .
Habla con @aprietatuercas1974 que seguro podras ayudarte
rojas
Notapor PACO07.FBR el 25 May 2016, 12:50
Gracias por la respuesta intentare hablar con @aprietatuercas1974.
PACO07.FBR
Notapor gianry el 25 May 2016, 13:20
I'd like to fit a composition media mibII instead the MIB 1 version.
I understand it is possible . IS IT CORRECT ? who could help me to remove CP ?
gianry
Notapor Eluryh el 26 May 2016, 17:39
pero tu no lograste ponerte full link y tal? no te sigo..
Eluryh
Notapor aprietatuercas1974 el 31 May 2016, 20:52
buenas tardes
Última edición por aprietatuercas1974 el 05 Nov 2016, 15:45, editado 1 vez en total
aprietatuercas1974
Notapor rojas el 31 May 2016, 21:02
Oleee oleee de quien será ;)
Muchas gracias y buen trabajo !
Enviado desde mi SM-G925F mediante Tapatalk
rojas
Notapor Eluryh el 31 May 2016, 23:08
@rojas que codigo de unidad de guantera has montado?
Eluryh
Usuarios navegando por este Foro: Anthropic, SentiBot y 4 invitados
