León Mk3 - BRICO - Como instalar la cámara de parking
Favoritos: JaviCG, Vampiro, J@VY, BADS, Daruma, cstrol, JorgeAnteloC, ipenalosa, MONTY DAKA, pirly, josele887, xurox, Nanox23, Carbono79, vallter, norchugo, Efremvidal, @turbina@, blankiblau, jorgee76, jliriz, Vilo, cuenxis, victir, Aras, Korath, Rasekfighter, Carrl, jdieztec, J-Frass, Tarzan, zacarias, Frannisesabe, Xperience, bronce702, sbarri, javieret69, Carlos Chea, Lotar, Alleya, miguelorly, craken, chemazz, xico, eMi1, Maverick.es
Seguidores: Linker89, car212121, franrx, davidalba, TRIBO, danieleon, Panchorin, Hecson.27, jmfcoto, aironsam14, JOTTA, MORKAS, Unaited, trekam, xandis, Jorge75016, Platanot, davidbj, Achehmg, marc.domenech.90, sadanyac, seat leon blanco, Marc.22, Peuero, er_trompe, GTI35, JoseCa, JaviCG, vigimuertos, rabazas, B.Fox, msmdraven, Tomcat7733, Txutxiysilvia, xabidh, cstrol, Carrl, El3ndil, yorky, bolche, LeoST, Diegokero, Rasekfighter, Budoka, IronTor21, marlop, xico, vanscampa, Tarzan, jorgee76, josemag, aigort, LuichiFR, SLon34, clavelstreet, nani_san, nyro, IVANIN9, rober1095, ivan0909, jose.jjg307, csabafr2013, P.carrizo.leonstfr, dookky, Edu1589, Dconnect, D83, Jeii90, inamarlo, Israel-FR, Herrdoktor, el_padrino, Kipu, aguscalderon, lebowski, juanmaroger, bailyibz, naikon_paul, Valerofr150, JAL, kennit0, Mramos1985, bronce702, kijute, juanmik, osjamil, Tonivn, Lotar, Tunnig, JaviMarquez, nitro_g4074, sergi303, ivan2017, Chema_Alvarez, ilargiman, jaumotix, sbarri, javierferriz, alcoleazgz, lecupra280, Colomer, Maikermx, luigi323, rents_80, jdiego75, Pedrost, damsolu, lead, Franr50, Dani2025, Leon pucelano, nachomart, castronight, victor david, bertoco, juan7777, Josep20, jakobitto, rr7mo, a.cuadros71, iNFeCTeD, Gendos22, VapaV, Chrohu, Ganyula, snowpluralism, victor_leon_FR, luaiabou96, Drovniak, Guillen222, leonfrrojito, justics, lopezm0, Romera, pedrorossello92, AlvaroRamlo
Re: BRICO como instalar la Camara de parking en Seat leon MK
Notapor vallter el 25 Feb 2015, 22:37
weide escribió:A ver si me podéis echar una mano, ya la tengo montada, he hecho todo pero cuando meto marcha atrás se queda la pantalla en negro. He comprobado la cámara con una TV en el coche y funciona bien pero en la pantalla del coche no se ve. Sabéis por qué puede ser?
Le has echo el vag com?
Leon 1.2 ITECH 110 cv
vallter
Coche: Leon MK3 1.2 TSI 105cv
Agradecido: 28 veces
Notapor fati33 el 25 Feb 2015, 22:41
Te has fijado bien si hace contacto los cables en el pin 6 y 12 a mi me paso, hay que meterlos hasta el fondo levantando las pestañas de la clavija.
Seat Leon 1.4Tsi 125cv
Seat Alhambra Tdi 130cv
Seat Leon Mk1 FR Tdi 150cv
fati33
Notapor weide el 25 Feb 2015, 23:00
Claro que se lo he hecho, cuando meto marcha atrás se queda en negro, y pone lo de compruebe la trayectoria. Lo único que entiendo que puede ser es el cable rca. A ver si a alguien más le ha pasado y me dice como arreglarlo
weide
Notapor arlot el 26 Feb 2015, 09:30
genialsoft escribió:A ver quien se apunta, se que @gti35 tenia todo el material y no se si @arlot también. O cualquiera de bcn que quiera quedar un sábado o domingo por la mañana.
Edito: también podéis venir como observadores que así nos reiremos más.
Contad conmigo, si no he dicho nada antes es que estoy de baja por trancazo gastrico :mosqueao:
@genialsoft gracias por la cajita mágica, que parece que haya pasado de ti.
Vamoooooooooooooos
arlot
Agradecido: 977 veces
Notapor B.Fox el 26 Feb 2015, 09:54
weide escribió:Claro que se lo he hecho, cuando meto marcha atrás se queda en negro, y pone lo de compruebe la trayectoria. Lo único que entiendo que puede ser es el cable rca. A ver si a alguien más le ha pasado y me dice como arreglarlo
A mí me ocurrió lo mismo, se veía en negro, probé la cámara y funcionaba, al final era que los robacorrientes no cortaron bien el plástico que recubre el cable y no llegaba corriente porque un cable era mas gordo que otro y solo llegaba a cortar uno, así que apreté bien los robacorrientes con un alicate para ayudarles... y funcionó.
Suerte!!
B.Fox
Coche: Leon MK3 1.0 TSI 115cv
Notapor weide el 26 Feb 2015, 10:30
En el byte 19 tengo que seleccionar el bit 4 y quitar el bit 2 para que el valor se quede en 10 no?
Y puesto que no tengo sensor de parking el byte 18 no lo toco?
weide
Notapor fati33 el 26 Feb 2015, 13:35
weide escribió:En el byte 19 tengo que seleccionar el bit 4 y quitar el bit 2 para que el valor se quede en 10 no?
Correcto, pero vamos si cuando metes la marcha atrás se te pone la pantalla en negro significa que la programación esta bien, fíjate bien en el conector de atrás en el pin 6 y 12, yo pensaba que estaba bien y había que meterlos hasta el final
fati33
Notapor genialsoft el 26 Feb 2015, 14:24
hay que levantar bien las pestañas del conector azul y si se meten los dos pins a la vez suele ser más facil.
genialsoft
Agradecido: 346 veces
Notapor weide el 26 Feb 2015, 15:21
Gracias chicos, era eso, no habia metido los pines 6 y 12 hasta el fondo, ahora ya funciona.
Ahora me surge un nuevo problema, al momento que muevo unos metros el coche se me encienden las luces del techo sin estar la puerta abierta y en ese momento se queda en negro la camara
se quedan encendidas mas suave que cuando se encienden de verdad pero eso provoca que la camara se apague, he pensado que podría ser una derivación o algo asi? que suerte tengo, estaba ya dando botes de alegria cuando de repente pasa esto :zoquete: :zoquete:
weide
Notapor genialsoft el 26 Feb 2015, 16:06
weide escribió:Gracias chicos, era eso, no habia metido los pines 6 y 12 hasta el fondo, ahora ya funciona.
Uala! yo desenchufaba todo (menos el rca) y verificaba todo!
genialsoft
Notapor weide el 26 Feb 2015, 17:15
Pffff madre mía, es para volverse loco, lo he revisado todo, comprobado el rele, he cambiado los robacorrientes y nada. En el momento que desconecto algo de la cámara lo de la luz del techo ya no pasa pero cuando lo conecto vuelve a pasar. A ver si alguien me puede iluminar
weide
Notapor genialsoft el 26 Feb 2015, 17:27
Pon el esquema de como lo has conectado para que te podamos ayudar. Yo comprobaria sobretodo los cables que has grimpado porque igual has puesto el robacorrientes en el que no es.
Por lógica el problema debería estar en el que has conectado para alimentar la cámara porque se encienden las luces pero se apaga la cámara, pero pasa el esquema. Tienes sensores traseros y vienen de fabrica?
genialsoft
Notapor weide el 26 Feb 2015, 19:40
genialsoft escribió:Pon el esquema de como lo has conectado para que te podamos ayudar. Yo comprobaria sobretodo los cables que has grimpado porque igual has puesto el robacorrientes en el que no es.
No @genialsoft, no tengo los sensores de parking. He cambiado la posición del relé y he conseguido que no se encienda la luz interior pero en cuanto muevo un poco el coche ya se queda en negro, y hasta que no apago el contacto y enciendo no se vuelve a ver. Cambie todos los robacorrientes pero nada. La cámara se ve perfecta sin rayas ni nada, así que decidí no ponerle el condensador, podría ser por eso?
Os paso unas fotos de como he hecho las conexiones
weide
Notapor genialsoft el 26 Feb 2015, 19:41
Pon el condensador o quita el rele y conectarla directamente a la marcha atrás subiendo la intensidad con el vag com. y por cierto ahora que he visto las fotos en el ordenador los cables rojos que has conectado a la luz del maletero metelos dentro del robacorrientes o cortalos porque como toquen la chapa vas a tener más que tonterías en el coche!
genialsoft
Notapor Martín st el 26 Feb 2015, 20:24
Hola buenas noches, como ya comenté hoy he recojido el coche después de la intalacion de la cámara trasera, al fina el precio a sido 130 euros ( con todo cableado cámara, relé y vag com) la intalacion a sido más que correcta no an marcado los plásticos que yo le tenía miedo, en eso soy un poco plasta, al final me pueto la que ba centrada en el vehículo es la que hay que agujerear el choque, es muy pequeña y no se aprecia nada y la visión nocturna es buena, mañana colgaré una foto para que veáis como queda .
Para las foreros que me preguntaban donde la instalado, se llama auto-radio America, que está en la calle América número 41 el teléfono lo podéis encontrar en el Google fácil mente, ahh esta en Barcelona muy cerca del hospital de sant Pau
Martín st
Coche: Leon MK3 1.4 TSI 122cv
Agradecido: 26 veces
Usuarios navegando por este Foro: Anthropic, SentiBot y 4 invitados
