León Mk3 - BRICO - Como instalar la cámara de parking
Favoritos: JaviCG, Vampiro, J@VY, BADS, Daruma, cstrol, JorgeAnteloC, ipenalosa, MONTY DAKA, pirly, josele887, xurox, Nanox23, Carbono79, vallter, norchugo, Efremvidal, @turbina@, blankiblau, jorgee76, jliriz, Vilo, cuenxis, victir, Aras, Korath, Rasekfighter, Carrl, jdieztec, J-Frass, Tarzan, zacarias, Frannisesabe, Xperience, bronce702, sbarri, javieret69, Carlos Chea, Lotar, Alleya, miguelorly, craken, chemazz, xico, eMi1, Maverick.es
Seguidores: Linker89, car212121, franrx, davidalba, TRIBO, danieleon, Panchorin, Hecson.27, jmfcoto, aironsam14, JOTTA, MORKAS, Unaited, trekam, xandis, Jorge75016, Platanot, davidbj, Achehmg, marc.domenech.90, sadanyac, seat leon blanco, Marc.22, Peuero, er_trompe, GTI35, JoseCa, JaviCG, vigimuertos, rabazas, B.Fox, msmdraven, Tomcat7733, Txutxiysilvia, xabidh, cstrol, Carrl, El3ndil, yorky, bolche, LeoST, Diegokero, Rasekfighter, Budoka, IronTor21, marlop, xico, vanscampa, Tarzan, jorgee76, josemag, aigort, LuichiFR, SLon34, clavelstreet, nani_san, nyro, IVANIN9, rober1095, ivan0909, jose.jjg307, csabafr2013, P.carrizo.leonstfr, dookky, Edu1589, Dconnect, D83, Jeii90, inamarlo, Israel-FR, Herrdoktor, el_padrino, Kipu, aguscalderon, lebowski, juanmaroger, bailyibz, naikon_paul, Valerofr150, JAL, kennit0, Mramos1985, bronce702, kijute, juanmik, osjamil, Tonivn, Lotar, Tunnig, JaviMarquez, nitro_g4074, sergi303, ivan2017, Chema_Alvarez, ilargiman, jaumotix, sbarri, javierferriz, alcoleazgz, lecupra280, Colomer, Maikermx, luigi323, rents_80, jdiego75, Pedrost, damsolu, lead, Franr50, Dani2025, Leon pucelano, nachomart, castronight, victor david, bertoco, juan7777, Josep20, jakobitto, rr7mo, a.cuadros71, iNFeCTeD, Gendos22, VapaV, Chrohu, Ganyula, snowpluralism, victor_leon_FR, luaiabou96, Drovniak, Guillen222, leonfrrojito, justics, lopezm0, Romera, pedrorossello92, AlvaroRamlo
Re: BRICO como instalar la Camara de parking en Seat leon MK
Notapor rojas el 22 Mar 2015, 19:36
jliriz escribió:
rojas escribió:
jliriz escribió:A ver si es verdad que alguien me ayuda que llevo 2 semanas pidiendolo y yo ayudo al que me lo pide y al que no me lo pide.
@jliriz yo lo tengo asi , byt 18 y 19 marcado el bite 4 , el valor se queda 10 en ambos
Gracias rojas.
Si la cosa es que el marco no desaparece y el coche no se integra en la pantalla. Las otras casillas que tengo marcadas las tienes tambien marcadas? Es por confirmar tambien que las otras casillas tambien las teneis marcadas y no estan marcadas por error involuntario o venian asi de fabrica.
Cuando vaya al coche lo miro ... pero si marcando el bite 4 en el byte 18 y 19 el valor es 10 ... esta correcto , sino te daría otro valor
rojas
Coche: Leon MK3 1.5 TGI 130cv
Agradecido: 1888 veces
Notapor javijave el 22 Mar 2015, 20:03
genialsoft escribió:
javijave escribió:Muchas gracias rojas por tu ayuda. Me da a mi q se va a quedar sin cámara el coche.
Me he perdido algo de la conversación? Por que tu preguntabas por usar una cámara de norauto y rojas te ha contestado por los sensores de aparcamiento...
Osea, q puedo montar una cámara trasera y ver la imagen en la pantalla del coche?
javijave
Coche: Leon MK3 2.0 TSI 190cv
Agradecido: 264 veces
Notapor rojas el 22 Mar 2015, 20:28
si , claro
por cierto yo tb me he perdido un poco con lo del norauto :shock:
rojas
Notapor javijave el 22 Mar 2015, 21:42
@rojas, como el post se llama instalar la cámara trasera, por ahí iba mi mensaje. En Norauto te instalan una pero viene con una pantalla y yo si se puede me gustaría instalarla pero ver la imagen en la pantalla de 5,8" del coche, y preguntaba si eso era posible.
javijave
Notapor rojas el 22 Mar 2015, 21:51
javijave escribió:@rojas, como el post se llama instalar la cámara trasera, por ahí iba mi mensaje. En Norauto te instalan una pero viene con una pantalla y yo si se puede me gustaría instalarla pero ver la imagen en la pantalla de 5,8" del coche, y preguntaba si eso era posible.
Tienes un link de la cámara de Norauto? ...
rojas
Notapor javijave el 23 Mar 2015, 06:37
javijave
Notapor calafat el 23 Mar 2015, 14:51
rojas escribió:La idea es tener un cable positivo que mande corriente a la camara cuando accione la marcha atras ,cada
patilla del rele tiene una numeracion ( 30 , 85 , 86 y 87 ), para ello conectamos el positivo de la luz de
maletero al 87 , el rojo de la camara al 30 , la masa con el negro de la camara al 85 y el positivo de la
marcha atras al 86.
@rojas, una duda. Para montar las conexiones al relé si hacemos el de la toma de mechero+usb más el de la cámara la configuración sería:
El positivo que viene desde la caja de fusibles al 87.
El rojo de la cámara al 30.
El negro de la cámara + la masa desde el tornillo al 85.
El cable azul/negro de 0,5mm de arriba (positivo marcha atrás) al 86.
Es correcto?
Gracias!
calafat
Agradecido: 22 veces
Notapor rojas el 23 Mar 2015, 20:51
javijave escribió:http://www.norauto.es/producto/sensor-beep-park-valeo-parkvision-camara-display_354518.html
@rojas ese es.
vale , a ver ...
con esa pantalla no ves la imagen sino una representacion de un coche con rallas como si se tratase del pdc pero mas cutre.
yo montaria una camara como la que ponemos en el brico ...
rojas
Notapor rojas el 23 Mar 2015, 20:54
marcha atras al 86.
Es correcto?
Gracias!
es correcto ! :comediante:
mira , aqui se ve facilmente :
rojas
Notapor calafat el 23 Mar 2015, 22:54
marcha atras al 86.
Es correcto?
Gracias!
Perfecto, es para no cagarla que con eso no es cuestión de enchufar cosas mal y cagarla...jeje
Una cosa, los fastons que ya vienen aislados como se grimpan?
El otro día los compré y hoy empezaba a preparar todo el material y sin romper dicho plástico duro no le veo la forma de armar el cable dentro.. O mejor comprar las hembras metálicas sueltas y con termoretractil sellarlo una vez puesto?
calafat
Notapor rojas el 23 Mar 2015, 22:57
marcha atras al 86.
Es correcto?
Gracias!
se grimpan con un alicate , yo le presiono con un universal y luego le presiono sin pasarme con la parte que corta , asegurate que pillas hierro :si: o lo cortaras :plas:
rojas
Notapor javijave el 24 Mar 2015, 06:45
@rojas ese es.
vale , a ver ...
Te entiendo. El problema es q yo la cámara ni en 100 años seria capaz de montarla. A ver si me entero de algo aquí en Sevilla.
Muchas gracias por todo.
javijave
@rojas ese es.
vale , a ver ...
javijave
Notapor calafat el 24 Mar 2015, 09:01
rojas escribió:se grimpan con un alicate , yo le presiono con un universal y luego le presiono sin pasarme con la parte que corta , asegurate que pillas hierro :si: o lo cortaras :plas:
Jajaja, vale vale..
Es que creía que era como si fuera una faston hembra que la abrazadera está "abierta" colocas el cable, y luego cierras dichas abrazaderas, una por lado.. Con éstos entonces es "grimpar" a ciegas, ya que le tienes que meter el cable por abajo, y asegurarte que coges hierro, pero por lo que entiendo no te queda tan sujeto como si pillas hembras abiertas (si suena mal, pero es así :risa3: ) las grimpas y luego con funda termoretractil las cierras, viene a ser lo mismo pero más seguro por lo que veo!
Gracias maestro! :beso_mano:
calafat
Notapor dahersol el 24 Mar 2015, 10:08
Ya me ha llegado la cámara!!!!!!! y tambien los pedales!!!!!!
Este finde empiezo a ponerla y cuando lo tenga casi todo pego un toque a Genialsoft para que me ayude con el tema informático y conexiones finales!!!! ( Gracias de antemano :aplauso: )
Al final es curioso pero la cámara que me ha llegado es compatible con NTC/PAL , mejor!!
Un saludo a todos y ya os iré contanto!!
:banana:
dahersol
Agradecido: 44 veces
Usuarios navegando por este Foro: Anthropic, Semrush, SentiBot y 5 invitados
