León Mk3 - BRICO - Como instalar la cámara de parking
Favoritos: JaviCG, Vampiro, J@VY, BADS, Daruma, cstrol, JorgeAnteloC, ipenalosa, MONTY DAKA, pirly, josele887, xurox, Nanox23, Carbono79, vallter, norchugo, Efremvidal, @turbina@, blankiblau, jorgee76, jliriz, Vilo, cuenxis, victir, Aras, Korath, Rasekfighter, Carrl, jdieztec, J-Frass, Tarzan, zacarias, Frannisesabe, Xperience, bronce702, sbarri, javieret69, Carlos Chea, Lotar, Alleya, miguelorly, craken, chemazz, xico, eMi1, Maverick.es
Seguidores: Linker89, car212121, franrx, davidalba, TRIBO, danieleon, Panchorin, Hecson.27, jmfcoto, aironsam14, JOTTA, MORKAS, Unaited, trekam, xandis, Jorge75016, Platanot, davidbj, Achehmg, marc.domenech.90, sadanyac, seat leon blanco, Marc.22, Peuero, er_trompe, GTI35, JoseCa, JaviCG, vigimuertos, rabazas, B.Fox, msmdraven, Tomcat7733, Txutxiysilvia, xabidh, cstrol, Carrl, El3ndil, yorky, bolche, LeoST, Diegokero, Rasekfighter, Budoka, IronTor21, marlop, xico, vanscampa, Tarzan, jorgee76, josemag, aigort, LuichiFR, SLon34, clavelstreet, nani_san, nyro, IVANIN9, rober1095, ivan0909, jose.jjg307, csabafr2013, P.carrizo.leonstfr, dookky, Edu1589, Dconnect, D83, Jeii90, inamarlo, Israel-FR, Herrdoktor, el_padrino, Kipu, aguscalderon, lebowski, juanmaroger, bailyibz, naikon_paul, Valerofr150, JAL, kennit0, Mramos1985, bronce702, kijute, juanmik, osjamil, Tonivn, Lotar, Tunnig, JaviMarquez, nitro_g4074, sergi303, ivan2017, Chema_Alvarez, ilargiman, jaumotix, sbarri, javierferriz, alcoleazgz, lecupra280, Colomer, Maikermx, luigi323, rents_80, jdiego75, Pedrost, damsolu, lead, Franr50, Dani2025, Leon pucelano, nachomart, castronight, victor david, bertoco, juan7777, Josep20, jakobitto, rr7mo, a.cuadros71, iNFeCTeD, Gendos22, VapaV, Chrohu, Ganyula, snowpluralism, victor_leon_FR, luaiabou96, Drovniak, Guillen222, leonfrrojito, justics, lopezm0, Romera, pedrorossello92, AlvaroRamlo
Re: BRICO como instalar la Camara de parking en Seat leon MK
Notapor genialsoft el 24 Mar 2015, 11:55
dahersol escribió:Ya me ha llegado la cámara!!!!!!! y tambien los pedales!!!!!!
Este finde empiezo a ponerla y cuando lo tenga casi todo pego un toque a Genialsoft para que me ayude con el tema informático y conexiones finales!!!! ( Gracias de antemano :aplauso: )
Al final es curioso pero la cámara que me ha llegado es compatible con NTC/PAL , mejor!!
Un saludo a todos y ya os iré contanto!!
:banana:
Bricoquedada? :yea:
genialsoft
Agradecido: 346 veces
Notapor vallter el 24 Mar 2015, 19:08
:banana:
Bricoquedada? :yea:
Me apunto :comediante: :comediante: :comediante:
Leon 1.2 ITECH 110 cv
vallter
Coche: Leon MK3 1.2 TSI 105cv
Agradecido: 28 veces
Notapor alfbriga el 24 Mar 2015, 19:55
calafat escribió:Una cosa, los fastons que ya vienen aislados como se grimpan?
El otro día los compré y hoy empezaba a preparar todo el material y sin romper dicho plástico duro no le veo la forma de armar el cable dentro.. O mejor comprar las hembras metálicas sueltas y con termoretractil sellarlo una vez puesto?
Hay una "tenaza"/"alicate"/"máquina" específicos para crimpar los terminales preaislados de ese tipo:
http://www.palcoelectronica.es/conector ... img/43.png
Pero costarán como unos 35 a 50 €.
Como te ha dicho Rojas, puedes utilizar la zona de corte de unos alicates universales o unos de corte, si compras unos baratos, y los limas de manera que cerrados a tope los cortes queden separados unos dos milímetros, minimizas bastante el riesgo de cortar los terminales completamente al crimparlos. Las maquinas de crimpar hacen dos cierres paralelos en el cuello del terminal, uno coge el cable sin aislante y hace el contacto eléctrico con el terminal, y el otro coge la parte aislada para darle mayor resistencia mecánica a la conexión.
alfbriga
Coche: Leon MK3 1.5 TGI 130cv
Notapor psxlab el 25 Mar 2015, 10:19
Hola, tengo una cámara y cableado original de VW que a ver si puedo sacar tiempo para instalar, ya que esta cámara es de las que hay que desmontar el paragolpes para instalarlo. El cableado que trae de alimentación es de 3 hilos: alimentación, masa y un tercer hilo para conectar a marcha atrás. El problema que tengo es con el terminal del cable de video, ya que lleva un conector de 26 pines. Lo he desmontado y realmente tiene 5 pines útiles, de los cuales se supone que tengo utilizar 2 pines para conectar al quadlock. ¿Hay alguna forma de averiguar cuáles de esos 2 pines son los válidos?
Seat Leon ST FR TSI 1.4 ACT 150cv DSG
psxlab
Notapor genialsoft el 25 Mar 2015, 10:56
psxlab escribió:Hola, tengo una cámara y cableado original de VW que a ver si puedo sacar tiempo para instalar, ya que esta cámara es de las que hay que desmontar el paragolpes para instalarlo. El cableado que trae de alimentación es de 3 hilos: alimentación, masa y un tercer hilo para conectar a marcha atrás. El problema que tengo es con el terminal del cable de video, ya que lleva un conector de 26 pines. Lo he desmontado y realmente tiene 5 pines útiles, de los cuales se supone que tengo utilizar 2 pines para conectar al quadlock. ¿Hay alguna forma de averiguar cuáles de esos 2 pines son los válidos?
Con un multimetro (tester) en posición de medir la resistencia podrías verificar los que la resitencia = 0 entre el cable a comprobar y el RCA o conector de video de la cámara.
genialsoft
Notapor psxlab el 25 Mar 2015, 13:41
Buf, ni idea de cómo hacerlo... el extremo del cable termina en un conector como el de la foto que adjunto (no se ven los cables de colores)
psxlab
Notapor calafat el 25 Mar 2015, 14:42
Gracias por la explicación @alfbriga! Al final lo que he hecho como son muy baratos es comprarlos "pelados" y los sellaré yo con termoretráctil..
Si tuviera cientos a crimpar sí, pero por 4 ó 5 no vale la pena..
calafat
Agradecido: 22 veces
Notapor rojas el 25 Mar 2015, 15:04
a ver si puedes sacar foto del interior del conector .... de todas formas a ver si tengo tiempo de mirarlo antes de viajar esta noche
rojas
Agradecido: 1888 veces
Notapor calafat el 25 Mar 2015, 15:15
rojas escribió:ahora vamos a alimentar los led de la camara , para ello he vuelto a usar dos robacorrientes para poner en paralelo la luz , por el momento y para que no me de fallo de luz fundida , lo que he hecho es meter el piloto dentro del paragolpes , seguramente en un futuro lo reubique y le de utilidad al piloto , como hay unos 15 cm hasta el interior del maletero , ponga ese piloto en el plastico que hemos quitado de forma que tenga una luz adicional en el maletero.
@rojas, una duda.. Al final llegaste a dejar el piloto dentro? O lo sacaste?
Yo creo que al llevar full led miraré de quitar el piloto original ya que si por VAG está codificado con que no de fallo si es led, no debería saltar el error..
Sería coger el positivo del led de la cámara al marron/gris y el negativo al marrón que alimentan el piloto original, no?
Gracias!
calafat
Notapor psxlab el 25 Mar 2015, 15:23
Te mando foto del interior del conector. intentaré desmontar de alguna manera el conector, aunque es complicado...
La referencia del cable es 1K8980551
psxlab
Notapor rojas el 25 Mar 2015, 15:42
calafat escribió:[ Imagen ]
Gracias!
Sí . Así es ... tal y como ves en la foto ... yo tengo el piloto original dentro del hueco ... pero cuando tenga un ratin lo voy a poner dentro del maletero ... me parece poca luz y encima amarilla
rojas
Notapor jliriz el 25 Mar 2015, 15:58
Gracias!
Yo quité el piloto original y lo he montado en el maletero al lado contrario para iluminarlo mas. No te da fallo de bombilla el led que viene con la cámara.
Si cambias los antinieblas tampoco te da fallo.
Seat Leon Sc 1.6 TDI 105cv DSG Style-Itech con Faros Full Led, Techo Panorámico, Navegador, Control de velocidad con radar y asistente de frenada, Safety Pack, Alarma Volumétrica, Sensores de aparcamiento delanteros y traseros + OPS + Cámara, Cristales tintados y Rueda repuesto minimizada 16".
Febrero'15.
jliriz
Agradecido: 113 veces
Notapor pirly el 25 Mar 2015, 16:10
Hola gente, hoy por fin me ha llegado la cámara y he comprado el cable pero no he encontrado de 1mm ni de 0.5mm. El caso es que he visto uno que ponía HIFI de 0.75 mm , este me valdría para el brico o lo cambio ?.
pirly
Agradecido: 304 veces
Notapor jliriz el 25 Mar 2015, 16:50
pirly escribió:Hola gente, hoy por fin me ha llegado la cámara y he comprado el cable pero no he encontrado de 1mm ni de 0.5mm. El caso es que he visto uno que ponía HIFI de 0.75 mm , este me valdría para el brico o lo cambio ?.
Si el cable es para positivo y masa no tendrás problema. Si es para imagen te digo que usé al principio un cable con mas grosor y no iba la imagen. Pregunte a un instalador de CCTV y me dijo que tenia que ser del grosor especifico, que no te se decir ahora mismo, pero que es finísimo el cable. Como el que lleva la cámara que has comprado.
Febrero'15.
jliriz
Notapor pirly el 25 Mar 2015, 17:18
El cable es para la alimentación, para el vídeo la cámara trae uno de unos 6 metros aproximadamente. Luego le tiro una foto al cable de la camará.
pirly
Usuarios navegando por este Foro: AhrefsBot, Anthropic y 6 invitados
