León Mk3 - BRICO - Como instalar la cámara de parking
Favoritos: JaviCG, Vampiro, J@VY, BADS, Daruma, cstrol, JorgeAnteloC, ipenalosa, MONTY DAKA, pirly, josele887, xurox, Nanox23, Carbono79, vallter, norchugo, Efremvidal, @turbina@, blankiblau, jorgee76, jliriz, Vilo, cuenxis, victir, Aras, Korath, Rasekfighter, Carrl, jdieztec, J-Frass, Tarzan, zacarias, Frannisesabe, Xperience, bronce702, sbarri, javieret69, Carlos Chea, Lotar, Alleya, miguelorly, craken, chemazz, xico, eMi1, Maverick.es
Seguidores: Linker89, car212121, franrx, davidalba, TRIBO, danieleon, Panchorin, Hecson.27, jmfcoto, aironsam14, JOTTA, MORKAS, Unaited, trekam, xandis, Jorge75016, Platanot, davidbj, Achehmg, marc.domenech.90, sadanyac, seat leon blanco, Marc.22, Peuero, er_trompe, GTI35, JoseCa, JaviCG, vigimuertos, rabazas, B.Fox, msmdraven, Tomcat7733, Txutxiysilvia, xabidh, cstrol, Carrl, El3ndil, yorky, bolche, LeoST, Diegokero, Rasekfighter, Budoka, IronTor21, marlop, xico, vanscampa, Tarzan, jorgee76, josemag, aigort, LuichiFR, SLon34, clavelstreet, nani_san, nyro, IVANIN9, rober1095, ivan0909, jose.jjg307, csabafr2013, P.carrizo.leonstfr, dookky, Edu1589, Dconnect, D83, Jeii90, inamarlo, Israel-FR, Herrdoktor, el_padrino, Kipu, aguscalderon, lebowski, juanmaroger, bailyibz, naikon_paul, Valerofr150, JAL, kennit0, Mramos1985, bronce702, kijute, juanmik, osjamil, Tonivn, Lotar, Tunnig, JaviMarquez, nitro_g4074, sergi303, ivan2017, Chema_Alvarez, ilargiman, jaumotix, sbarri, javierferriz, alcoleazgz, lecupra280, Colomer, Maikermx, luigi323, rents_80, jdiego75, Pedrost, damsolu, lead, Franr50, Dani2025, Leon pucelano, nachomart, castronight, victor david, bertoco, juan7777, Josep20, jakobitto, rr7mo, a.cuadros71, iNFeCTeD, Gendos22, VapaV, Chrohu, Ganyula, snowpluralism, victor_leon_FR, luaiabou96, Drovniak, Guillen222, leonfrrojito, justics, lopezm0, Romera, pedrorossello92, AlvaroRamlo
Re: BRICO como instalar la Camara de parking en Seat leon MK
Notapor trekam el 24 Nov 2014, 20:21
@rojas vaya pedao de brico... !!!! esta muy bien...
pero para los que nos da "repelus" toquetear tanto el coche... yo no se si me atrevere a hacerlo...
me lo voy a repasar varias veces... porque miedo me daaaa....
trekam
Coche: Leon MK3 1.5 TGI 130cv
Agradecido: 10 veces
Notapor rojas el 24 Nov 2014, 21:01
trekam escribió:@rojas vaya pedao de brico... !!!! esta muy bien...
en mi opinion es un brico para no "toquetear" apenas el coche , lo unico que he hecho es desencajar la goma pasacables del porton al techo , el plastico del maletero que sale y entra superfacil y sacar la luz de matricula ... :comediante: nivel de dificultad "3"
no he desmontado pilotos , ni paragolpes , ni moqueta del maletero ... no se , lo que mas dificultad puede entrañar es el conexionado del rca en el conector azul , dificultad "6" pero creeme que es muy sencillo todo el proceso el cableado lo he metido facilmente con la mano .
rojas
Agradecido: 1888 veces
Notapor genialsoft el 02 Dic 2014, 18:22
Una pregunta, tengo la cámara y estoy planificando la instalación y me surge una duda. Cuando sacamos el positivo de la luz del maletero no funcionaría sólo cuando se abre el porton? Perdona por si es que me pilla espeso que también puede ser. Te pongo en alerta de que no me pilla de nuevo, en mi anterior coche también le puse la cámara y con relé con lo cual ya se por donde van los tiros, pero me da la sensación que el positivo de la luz del maletero deberia estar activo sólo con el maletero abierto. Iluminame :reverencia:
genialsoft
Agradecido: 346 veces
Notapor GTI35 el 02 Dic 2014, 21:23
genialsoft escribió:Una pregunta, tengo la cámara y estoy planificando la instalación y me surge una duda. Cuando sacamos el positivo de la luz del maletero no funcionaría sólo cuando se abre el porton? Perdona por si es que me pilla espeso que también puede ser. Te pongo en alerta de que no me pilla de nuevo, en mi anterior coche también le puse la cámara y con relé con lo cual ya se por donde van los tiros, pero me da la sensación que el positivo de la luz del maletero deberia estar activo sólo con el maletero abierto. Iluminame :reverencia:
Positivo siempre tiene pero el interruptor te lo hace con masa.
Seat Leon ST FR 2.0 TDI 184CV
GTI35
Coche: Leon MK3 1.4 TSI 140cv
Agradecido: 90 veces
Notapor rojas el 02 Dic 2014, 22:57
como te indica nuestro compi nuestros coches cortan masa
rojas
Notapor trekam el 03 Dic 2014, 01:11
hola @rojas...
cuando hablas de sacar la unidad de la guantera.. para sacar el el conector quadlock...
hablas de esta unidad...
pero yo tengo esta unidad y no la q tu has puesto..
como saco esa unidad... para poder aceder al conector quadlock... si es que esta ahi...
muchas gracias...
trekam
Notapor rojas el 03 Dic 2014, 11:39
tu la tienes en la misma pantalla , el conector quadlock lo tienes detras , es el mismo procedimiento , porque ... entiendo que es una pantalla a color no? , me refiero a que no es monocromo , ya que si fuera asi no podrias visualizar la imagen
rojas
Notapor galaxis el 03 Dic 2014, 19:55
rojas escribió:como te indica nuestro compi nuestros coches cortan masa
Hola rojas
¿La tensión del positivo de la luz del maletero es continua de 12voltios o también va por pulsos como las canbus?
Si fuera continua, para alimentar la cámara se podría coger el positivo de la luz del maletero y el negativo de la luz de marcha atrás y así no haría falta el relé.
galaxis
Notapor Pinta el 04 Dic 2014, 23:02
Hola rojas!!!! Muy wapo ese brico!!! Super bien explicado, parece facil, yo tengo la pantalla de 5 pulgadas, es en color y me gustaria saber si me va a funcionar igual que en la tuya ya ke es de 5,8 y un modelo superior y otra cosilla ke se me viene a la cabeza, podrias poner una lista de las piezas con los links ke se necesitan ya que lo quiero hacer y no quiero dejarme piezas por coger!!!! Muchas graciad y enhorabuena por el brico!!!:mad:
Pinta
Notapor frestor el 04 Dic 2014, 23:41
Me descalzo ante vosotros chavales
En este caso rojas
Pero hay unos cuantos que sois unos manitas de la leche
Una pregunta, ya que funciona la camara y se ve en la pantalla, se veria tambien un dvd?,que habria que hacer para que se vea?
@rojas de donde eres? Haces estas cosillas a la gente
frestor
Agradecido: 35 veces
Notapor rojas el 05 Dic 2014, 11:32
Pinta escribió:Hola rojas!!!! Muy wapo ese brico!!! Super bien explicado, parece facil, yo tengo la pantalla de 5 pulgadas, es en color y me gustaria saber si me va a funcionar igual que en la tuya ya ke es de 5,8 y un modelo superior y otra cosilla ke se me viene a la cabeza, podrias poner una lista de las piezas con los links ke se necesitan ya que lo quiero hacer y no quiero dejarme piezas por coger!!!! Muchas graciad y enhorabuena por el brico!!!:mad:
todo esta en el manual ,
necesitas :
2 llaves para extraer la unidad de guantera
la camara con el cable de video
un rca con 20-30 cm de cable
cable paralelo 2x1 ó 2x0,5 mm , 3 mtrs de para alimentar la camara con la marcha atras
4 robacorrientes o cocodrilos
y si se ve con interferencias tienes 2 opciones :
- codificar
-poner un rele
rojas
Notapor rojas el 05 Dic 2014, 15:26
frestor escribió:Me descalzo ante vosotros chavales
En este caso rojas
soy de madrid ,
si se veria , cualquier cosa con AV ( videoconsolas , camaras , dvd , tdt , etc...) si usas el rca del brico .... solo lo verias al meter la marcha atras.
hay un cable mitsumi que he comprado , del A3 .... que permite ver audio y video
rojas
Notapor arlot el 05 Dic 2014, 17:50
Llegó. Ahora falta tener ganas y tiempo de montarla.
Vamoooooooooooooos
arlot
Agradecido: 977 veces
Notapor genialsoft el 05 Dic 2014, 17:54
A ver cuando hay un momento, je je
genialsoft
Notapor arlot el 05 Dic 2014, 17:57
@genialsoft no me esperes, ya puedes empezar sin mi :cafe:
Vamoooooooooooooos
arlot
