León Mk3 - Actualización infotainment
Favoritos: BADS, Daruma, ositoerik, dmesanun, YeSL, pocososinos, jasoriab, JaviMarquez, crujipoyo, Arkan7, Cristianibias, pepeiyo69, Angel J, Xaggy, edumachuca, abollao, -alberto-, Rickymax, ferre7, Pedritoleon, Rivesgti, Alleya, davidalba, Xiguito_Corito, craken, JDCLEONFR, nemura, danihd, cenkkaya, Kisszabo, castell_lkpg, pistoleromtb, Raulportela, Martelinko, albert_naga, Adrian Anton, Gravilhas75, chaiser, popez, ruli68, denniisg2000, LeonFR80bsv
Seguidores: kenny_fonseca, ncx, Lavadora, barris31, juancete, ivantxe, jesusFR, Hysteria, MaximusRoco, Manu1986, Jorge75016, davidbj, bIxu, miyobe, MORKAS, gorkansr, aironsam14, jramis, kimudj, Maikermx, Javizormo, gogua, Melonkid, Kikote8, danirodrigueze30, maxinew, aigort, carlosgzlez, corderazo, Lionxp, jande, Edu1589, msmdraven, Arkan7, inamarlo, edumachuca, Josepo79, lead, camamaleon, davidmd, carrasco13, clavelstreet, mikomiko, josele77, car212121, itz18, golf_1990, LeidenSpain, vecnte, Andy_G, csabafr2013, leonfr76, Trimmer, genialsoft, Enerts, leonfrrojito, Horus, paco_22_22, ruben88, Valerofr150, molvi_mabad, Pekee69, Dav2k6, IbiFR, il_munyo, craken, ruben91mad, papo-182, el_padrino, zeratul, kaiserssosse, lytry32.hc, sbarri, ghitus, DesmoSimon, ruli68, Mramos1985, tonielfilas, braulioT, davidalba, JaviMarquez, osjamil, egarense69, fexposru, Pedrost, Illan, chetelopez, juanacho21, cuenka16, pepeiyo69, VapaV, AlvaroPM13, balbu, juan7777, mams69, Helrique, Kike77, volkov, jluis, loeches, Tom70, Dconnect, Trivi83, MilleMiglia, linxes, sergi303, hector37, D83, quiquito30lv, ElFon, DALOFER17, davidap13, kigua, JOTTA, Senuto, jd_zuri, Alvi, damsolu, Leon pucelano, javi_archi, danihd, alcoleazgz, miguel23and, xarlio, jdieztec, mitxuni, Kisszabo, Gendos22, xexpir, canijo82, Brandenor, cenkkaya, kennit0, Chelazo, bertoco, benitogomez, carlosVACA, Peje, NOECUBI1, AAAJDA, trazas, martija, borjiguez, JoseXS, ferbarroso14, Wespa, Cloud_ganora, Berbe15, Valengti, Chrohu, Atajunen, Victorzabal, jrm82, carlo13, iNFeCTeD, paralaxon, ateopoeta, pepo55, ribasxisco, Raulribarroja, ivanti, Jansel, lopezm0, Rubén Flp, Warelio, Vagabundo, Rekoba, Octacon, matiaso, Alianma, Raulportela, Éugen91, Rivesgti, Mcm90, DaniR86, Gravilhas75, JuanNur78, el_Asturiano, Mr.Chuflas, albert_naga, juanfrancia, Seket, algabe, pistoleromtb, ebcuatro, [GuErRa], Mario Leon, tito68
Re: Actualización infotainment
Notapor aprietatuercas1974 el 18 Jul 2016, 21:43
Buenas
tengo ya pruebas realizas y avances,he conseguido actualizar una unidad std desde la 0245 hasta la 0346,tengo la 0351 y la 0355 para ponerla pero primero necesito la 0349 para poder instalar la 0351.
Con respecto a las High ,tengo varios archvios pero necesitaria si puiderais colgarme la version ,referencia y hardware y software que tienen,porque no se si sera posible un salto tan grande.
No se si me he explicado pero bueno si podeis pasadme las versiones de las high
aprietatuercas1974
Agradecido: 358 veces
Notapor LeonCup el 18 Jul 2016, 21:46
aprietatuercas1974 escribió:Buenas
Por lo que das a entender tienes el archivo no? Que necesitas de lo mío? Es un cupra my16 con navegador normal.
LeonCup
Usuario baneado
Agradecido: 23 veces
Notapor MORKAS el 18 Jul 2016, 21:51
Hola...esas pruebas..no seran para la pantalla de 5.8"...?..por casualidad
Mi leon llevo la 5.8".con navegador..si necesitas algo. Te envio
MORKAS
Agradecido: 369 veces
Notapor MORKAS el 18 Jul 2016, 21:52
Desde el menu ingeniero no habra nada qye hacer?
MORKAS
Notapor carlosgzlez el 18 Jul 2016, 21:56
Navi High MY2015. Matriculado el 1-abril-2015. Pantalla de 6.5" con DVD, disco duro, wifi, mirrorkink, ... y sin fullink. A ver que se puede hacer
Tienes suficiente para la version con la foto?
Gracias por adelantado por cualquier aportación
Enviado desde mi ALE-L21 mediante Tapatalk
carlosgzlez
Agradecido: 51 veces
Notapor stewei el 18 Jul 2016, 22:54
Sino lo pone nadie antes, mañana te digo de un Navi Plus de 6,5.
Un saludo :ok:
stewei
Agradecido: 465 veces
Notapor Eluryh el 19 Jul 2016, 00:58
carlosgzlez escribió:[ Imagen ]
La misma por aquí, @aprietatuercas1974
Eluryh
Agradecido: 107 veces
Notapor arlot el 19 Jul 2016, 09:39
FR184 escribió:En contestación me han solicitado una serie de datos personales míos y del coche.
Se los he enviado.
Aprovechando que mañana dejo el coche en el conce para pintar una manilla que me rayó una chica descuidada al abrir la puerta sin mirar y que me pagó en mano, aproveche para preguntarle a los del taller si me lo podían hacer.
Aquí viene lo gracioso:
Seat me deriva al concesionario.
El concesionario no tiene la mas mínima idea de si se puede o no hacer y preguntará a Seat.
Me suena a cuento de nunca acabar.
Mañana vendré con el siguiente episodio de la telenovela.
Continuará
Pues como a mi
Y como no encuentro coherente que te pidan la dirección y menos aún el DNI para dar una simple respuesta de si hay actualización disponoble para los Navi System de 5,8 les he contestado:
Última edición por arlot el 28 Sep 2016, 09:21, editado 1 vez en total
Vamoooooooooooooos
arlot
Agradecido: 977 veces
Notapor boixet el 19 Jul 2016, 11:22
Otro más con la misma configuración esperando buenas noticias
Enviado desde mi C6603 mediante Tapatalk
boixet
Agradecido: 15 veces
Notapor stewei el 19 Jul 2016, 15:37
@aprietatuercas1974 ha continuacion te pongo la imagen de mi Navi Sistem Plus de 6,5 (noviembre 2015):
Un saludo :ok:
stewei
Notapor LeonCup el 19 Jul 2016, 18:35
Acabo de llamar al supuesto concesionario y lo típico que no tienen ni idea. Que le diera mi bastidor para comprobar si hay alguna actualización osea que estoy casi fijo que se ha hecho por online. Ya que no se ha hecho aposta. O solicitado por el cliente.
He quedado que le voy a dar mi bastidor mañana y me lo miran.
LeonCup
Usuario baneado
Notapor FR184 el 19 Jul 2016, 19:05
Me han dicho en mi concesionario que los Leones serán actualizados cuando en ése conce hayan entregado las primeras unidades de Ateca. Hasta entonces no disponen del software ni de la formación para hacerlo y por tanto no tocan.
FR184
Agradecido: 42 veces
Notapor lupen el 19 Jul 2016, 19:07
Hay va otro @aprietatuercas1974 Navi High hasta MY2015. Cada uno de una madre. Pantalla de 6.5" con DVD, disco duro, mirrorkink...
lupen
Notapor LeonCup el 19 Jul 2016, 19:44
FR184 escribió:Me han dicho en mi concesionario que los Leones serán actualizados cuando en ése conce hayan entregado las primeras unidades de Ateca. Hasta entonces no disponen del software ni de la formación para hacerlo y por tanto no tocan.
Yo lo único que quiero saber si es por online o manual.
LeonCup
Usuario baneado
Notapor miceor el 19 Jul 2016, 20:17
Pues a mi me han llamado a las 18:30 más o menos para hacerme una limpieza ionica (¿?) del vehiculo de manera gratuita y hacer una actualización de software a la última versión .
Palabras textuales.
Les he preguntado si es obligatorio o no y me han dicho que no, asi que he quedado en bajar el viernes a la limpieza ionica peroooo lo de actualizar el software va a ser que no, intentaré que no lo hagan.
¿Una limpieza ionica a un coche con 5 meses que está como la patena?
Me suena a escusa barata para que lo lleves y de paso instalar lo otro y joderte vivo.
No me fio un pelo de que me lo actualicen y hayan tocorreado el software para evitar que toquemos como hasta ahora.
Hasta la fecha el nuevo software que instalan unicamente aporta un aspecto visual mejorado en el menú (Que puedo vivir sin el mucho tiempo) y mayor rapidez en la camara trasera (Que tampoco se me va la vida por tres segundos de espera)
Sin embargo no sé que cosas ocultas me podrian estar esperando.
Prefiero ser cauto a este respecto y ver en otros coches que lo tengan instalado si realmente merece la pena ponerlo o no.
Saber que mejoras aporta y que inconvenientes nuevos presenta.
EDITO
He cambiado de opinión, ni siquiera voy a bajar a lo de la limpieza.
Paso de que toquen nada en mi coche mientras yo no lo veo y que empiecen a chumetear a ver que he tocado y que no, que la unica ve que he ido con lo del Start Stop ya estaba el listo de turno venga a tocorrear en la pantalla los menús en busca de indicios de modificaciones y yo venga a decirle al tio.... Que eso no es coño, que es entrando en CAR y el tio venga a darle a los menús hasta que le di dos voces mas mosqueado que la leche.
miceor
Agradecido: 1259 veces
Problema con aire acondicionado León fr mk1 !!
Foro: Leon I - Mecánica / Electricidad / Electrónica
Autor: Paranohia
Respuestas: 33
Tengo un Leon
Foro: Presentaciones
Autor: Timoteo
Respuestas: 2
León MK4 1.5 e-Hybrid 204cv
Autor: javiernick
Respuestas: 4
Hilo del León mkIV e-hybrid
Foro: General
Autor: vkr84
Respuestas: 658
RUIDOS en el Nuevo Leon MK4
Autor: Tik0
Respuestas: 424
Usuarios navegando por este Foro: AhrefsBot, Anthropic y 3 invitados
