León Mk3 - BRICO - Como instalar la cámara de parking
Favoritos: JaviCG, Vampiro, J@VY, BADS, Daruma, cstrol, JorgeAnteloC, ipenalosa, MONTY DAKA, pirly, josele887, xurox, Nanox23, Carbono79, vallter, norchugo, Efremvidal, @turbina@, blankiblau, jorgee76, jliriz, Vilo, cuenxis, victir, Aras, Korath, Rasekfighter, Carrl, jdieztec, J-Frass, Tarzan, zacarias, Frannisesabe, Xperience, bronce702, sbarri, javieret69, Carlos Chea, Lotar, Alleya, miguelorly, craken, chemazz, xico, eMi1, Maverick.es
Seguidores: Linker89, car212121, franrx, davidalba, TRIBO, danieleon, Panchorin, Hecson.27, jmfcoto, aironsam14, JOTTA, MORKAS, Unaited, trekam, xandis, Jorge75016, Platanot, davidbj, Achehmg, marc.domenech.90, sadanyac, seat leon blanco, Marc.22, Peuero, er_trompe, GTI35, JoseCa, JaviCG, vigimuertos, rabazas, B.Fox, msmdraven, Tomcat7733, Txutxiysilvia, xabidh, cstrol, Carrl, El3ndil, yorky, bolche, LeoST, Diegokero, Rasekfighter, Budoka, IronTor21, marlop, xico, vanscampa, Tarzan, jorgee76, josemag, aigort, LuichiFR, SLon34, clavelstreet, nani_san, nyro, IVANIN9, rober1095, ivan0909, jose.jjg307, csabafr2013, P.carrizo.leonstfr, dookky, Edu1589, Dconnect, D83, Jeii90, inamarlo, Israel-FR, Herrdoktor, el_padrino, Kipu, aguscalderon, lebowski, juanmaroger, bailyibz, naikon_paul, Valerofr150, JAL, kennit0, Mramos1985, bronce702, kijute, juanmik, osjamil, Tonivn, Lotar, Tunnig, JaviMarquez, nitro_g4074, sergi303, ivan2017, Chema_Alvarez, ilargiman, jaumotix, sbarri, javierferriz, alcoleazgz, lecupra280, Colomer, Maikermx, luigi323, rents_80, jdiego75, Pedrost, damsolu, lead, Franr50, Dani2025, Leon pucelano, nachomart, castronight, victor david, bertoco, juan7777, Josep20, jakobitto, rr7mo, a.cuadros71, iNFeCTeD, Gendos22, VapaV, Chrohu, Ganyula, snowpluralism, victor_leon_FR, luaiabou96, Drovniak, Guillen222, leonfrrojito, justics, lopezm0, Romera, pedrorossello92, AlvaroRamlo
Re: BRICO como instalar la Camara de parking en Seat leon MK
Notapor dahersol el 13 Abr 2015, 17:02
Si que parece del Rele, pero el que tenga 5 patillas es para tener otro circuito trabajando cuando esta abierto, no deberia dar problemas. Lo que no se si la bobina se mantiene excitada al recibir la tensión de la luz de la marcha atras por pulsos. Es posible que esta funcíon solo los tengan los reles de automoción.
Yo tambien he colocado un rele de 5 patillas pero aún no lo he podido probar porque me falta la codificación, espero en breve tenerlo y te digo algo.
dahersol
Agradecido: 44 veces
Notapor Kampedtre el 13 Abr 2015, 17:15
dahersol escribió:Si que parece del Rele, pero el que tenga 5 patillas es para tener otro circuito trabajando cuando esta abierto, no deberia dar problemas. Lo que no se si la bobina se mantiene excitada al recibir la tensión de la luz de la marcha atras por pulsos. Es posible que esta funcíon solo los tengan los reles de automoción.
Puede ser que sea porque tengo cojido el positivo de la luz de maletero y al no ser 12v puros corte la alimentación? Esque me parece raro
Kampedtre
Coche: Leon MK3 1.2 TSI 105cv
Agradecido: 28 veces
Notapor genialsoft el 13 Abr 2015, 17:30
Si lees el post inicial de @rojas veras que le pasaba igual y fue cuando puso el condensador. Ya sabes condensador o directo a la Luz de marcha atrás codificado para que de mas chicha
genialsoft
Agradecido: 346 veces
Notapor dahersol el 13 Abr 2015, 22:10
Ya tengo la cámara instalada!!!!! Muchas gracias Genialsoft por tu ayuda!!!!
Con el relé de 5 patillas perfecto!!!!
dahersol
Notapor pirly el 13 Abr 2015, 22:13
:ayuda:
Bueno chicos ya si que tengo la instalación completa, con el condensador (10.000uF 35V - no habia de menos) incluido pero me he dado cuenta que tarda mucho en cortar la imagen y hace como un pequeño extraño la imagen antes de cortar. Además, como puse el otro día misteriosamente han desaparecido las lineas que te guian , alguien sabe que puede estar pasando?
pirly
Agradecido: 304 veces
Notapor Kampedtre el 13 Abr 2015, 22:35
Ya estaaaaa!! Solucionado, e quitado el cable que venia del plafón del maletero y e cojido positivo de el enchufe para mechero del maletero, y todo perfecto!! Sin condensador ni nada!!
Kampedtre
Notapor magan_124 el 14 Abr 2015, 17:55
Hola buenas tardes, quería saber si se podría convalidar los sensores delanteros y traseros con la cámara, y supongo que al activar la cámara se quitaria el dibujo del recorrido ruedas/obstáculos que aparece en la pantalla verdad? Gracias de antemano y muy buen trabajo!!
magan_124
Notapor genialsoft el 15 Abr 2015, 16:51
dahersol escribió:Ya tengo la cámara instalada!!!!! Muchas gracias Genialsoft por tu ayuda!!!!
De nada, pero el trabajo duro lo hiciste tú (ahora, acuerdate del tester :maruja: )
genialsoft
Notapor genialsoft el 15 Abr 2015, 16:52
magan_124 escribió:Hola buenas tardes, quería saber si se podría convalidar los sensores delanteros y traseros con la cámara, y supongo que al activar la cámara se quitaria el dibujo del recorrido ruedas/obstáculos que aparece en la pantalla verdad? Gracias de antemano y muy buen trabajo!!
Si te refieres a si funcionan ambas cosas a la vez, si no pierdes nada ni el dibujo (que aparecerá a la izquierda) ni por supuesto los sensores. Puedes verlo en mi firma
genialsoft
Notapor carlos_mk3 el 16 Abr 2015, 00:04
hola. a lo mejor ya lo habréis comentado pero he visto que el hilo tiene 45 paginas y no me lo he leído entero la verdad. mi pregunta es sobre si se puede ver la imagen de la cámara si tienes el modelo de radio inferior al que se muestra en el brico. yo no tengo la toma cd y eso en la guantera y mi pantalla es la que viene en el acabado style. gracias
carlos_mk3
Coche: Leon MK3 1.2 TSI 86cv
Notapor magan_124 el 16 Abr 2015, 06:21
Es verdad jooh que caña de mod!! Muchas gracias tío! Me voy a poner manos al coche pero ya! Voy a pedir el cable para empezar, todos esas mod lo as llevado a cabo con vag com 12.12 o 12.12.3? Y la tapa del porta vasos con el logo de seat? Lo venden o te lo has currado tu? Muchas gracias soys unos jefes! :aplauso: :aplauso:
magan_124
Notapor genialsoft el 16 Abr 2015, 15:16
magan_124 escribió:Es verdad jooh que caña de mod!! Muchas gracias tío! Me voy a poner manos al coche pero ya! Voy a pedir el cable para empezar, todos esas mod lo as llevado a cabo con vag com 12.12 o 12.12.3? Y la tapa del porta vasos con el logo de seat? Lo venden o te lo has currado tu? Muchas gracias soys unos jefes! :aplauso: :aplauso:
Con el cable 12.12
y la tapa me la he currado yo para integrar el mando del garaje
genialsoft
Notapor magan_124 el 17 Abr 2015, 01:29
Muchas gracias tío! Eres un jefazo eeeh! Mil gracias por todo y perdón por las molestias jeje
magan_124
Notapor pirly el 17 Abr 2015, 13:53
Alguien sabe si existen para automóvil relé con temporizador para que cuando corte mantenga unos segundos mas y así quitar el efecto que hace de pantalla en negro ???
pirly
Notapor Kampedtre el 17 Abr 2015, 13:59
pirly escribió:Alguien sabe si existen para automóvil relé con temporizador para que cuando corte mantenga unos segundos mas y así quitar el efecto que hace de pantalla en negro ???
+1 me interesa y mucho!! Porque da rabia que al quitar la marcha desaparezca, par aparcar es un poco rollo
Kampedtre
Usuarios navegando por este Foro: Anthropic, Semrush y 3 invitados
