León Mk3 - Actualización infotainment
Favoritos: BADS, Daruma, ositoerik, dmesanun, YeSL, pocososinos, jasoriab, JaviMarquez, crujipoyo, Arkan7, Cristianibias, pepeiyo69, Angel J, Xaggy, edumachuca, abollao, -alberto-, Rickymax, ferre7, Pedritoleon, Rivesgti, Alleya, davidalba, Xiguito_Corito, craken, JDCLEONFR, nemura, danihd, cenkkaya, Kisszabo, castell_lkpg, pistoleromtb, Raulportela, Martelinko, albert_naga, Adrian Anton, Gravilhas75, chaiser, popez, ruli68, denniisg2000, LeonFR80bsv
Seguidores: kenny_fonseca, ncx, Lavadora, barris31, juancete, ivantxe, jesusFR, Hysteria, MaximusRoco, Manu1986, Jorge75016, davidbj, bIxu, miyobe, MORKAS, gorkansr, aironsam14, jramis, kimudj, Maikermx, Javizormo, gogua, Melonkid, Kikote8, danirodrigueze30, maxinew, aigort, carlosgzlez, corderazo, Lionxp, jande, Edu1589, msmdraven, Arkan7, inamarlo, edumachuca, Josepo79, lead, camamaleon, davidmd, carrasco13, clavelstreet, mikomiko, josele77, car212121, itz18, golf_1990, LeidenSpain, vecnte, Andy_G, csabafr2013, leonfr76, Trimmer, genialsoft, Enerts, leonfrrojito, Horus, paco_22_22, ruben88, Valerofr150, molvi_mabad, Pekee69, Dav2k6, IbiFR, il_munyo, craken, ruben91mad, papo-182, el_padrino, zeratul, kaiserssosse, lytry32.hc, sbarri, ghitus, DesmoSimon, ruli68, Mramos1985, tonielfilas, braulioT, davidalba, JaviMarquez, osjamil, egarense69, fexposru, Pedrost, Illan, chetelopez, juanacho21, cuenka16, pepeiyo69, VapaV, AlvaroPM13, balbu, juan7777, mams69, Helrique, Kike77, volkov, jluis, loeches, Tom70, Dconnect, Trivi83, MilleMiglia, linxes, sergi303, hector37, D83, quiquito30lv, ElFon, DALOFER17, davidap13, kigua, JOTTA, Senuto, jd_zuri, Alvi, damsolu, Leon pucelano, javi_archi, danihd, alcoleazgz, miguel23and, xarlio, jdieztec, mitxuni, Kisszabo, Gendos22, xexpir, canijo82, Brandenor, cenkkaya, kennit0, Chelazo, bertoco, benitogomez, carlosVACA, Peje, NOECUBI1, AAAJDA, trazas, martija, borjiguez, JoseXS, ferbarroso14, Wespa, Cloud_ganora, Berbe15, Valengti, Chrohu, Atajunen, Victorzabal, jrm82, carlo13, iNFeCTeD, paralaxon, ateopoeta, pepo55, ribasxisco, Raulribarroja, ivanti, Jansel, lopezm0, Rubén Flp, Warelio, Vagabundo, Rekoba, Octacon, matiaso, Alianma, Raulportela, Éugen91, Rivesgti, Mcm90, DaniR86, Gravilhas75, JuanNur78, el_Asturiano, Mr.Chuflas, albert_naga, juanfrancia, Seket, algabe, pistoleromtb, ebcuatro, [GuErRa], Mario Leon, tito68
Re: Actualización infotainment
Notapor artek90 el 27 Nov 2016, 12:32
Sotolui escribió:Yo si que he podido actualizar mi 5.8 h041 S0425 my15 pero haciendo como pone en la explicación manteniendo el botón de menú apretado unos segundos, si simplemente vas a menú información del sistema y das a actualizar no te deja. La he probado un poco y va bien.
no te sale error como a los otros compañeros que comentan ? quiero hacerlo bien y que no salga nada.
Leon 1.6 tdi i-tech ----> http://www.clubseatleon.net/viewtopic.php?f=43&t=111717
Imagen Leon ST FR 1.8 TSI --->Imagen
artek90
Agradecido: 187 veces
Notapor artek90 el 27 Nov 2016, 12:42
Destino escribió:ACTUALIZADO!!!!
5.8 h041 S0425 my15 //1.2itech
Ahora es 480.
Menos de media hora con micro sd 8gb + adaptador SD.
Mucha mas fluidez al cambiar de menus, y al poner y quitar marcha atras tambien se nota que es mas rapido.
Fallos: Tras actualizar , y probarlo, todo ok, saque la llave volvi a poner contacto: fallo Airbag frontal :plas:
Saque y volvi a poner la llave y todo ok :rey:
Ya con el mosqueo le he metido un scan con OBD, resultado : 5 fallos, 2 de ellos permanentes.
Aunque todo funciona perfecto, al menos en la hora o asi que he trasteado. Los fallos permanentes que marca OBD son los siguientes:
5f Comprobacion gestion de la version de software.
Interfaz de diagnosis de datos .Reproductor de media en posición 1 no hay comunicacion.
Tambien probe (ya que estaba con el OBD enchufado) poner el modo offroad, y el modo autoescuela, a ver si con la 480 chutaba, y nada :o
Aun asi, contentisimo de la rapidez con la que fluye ahora el inotaiment..
Gracias por sacar a la luz esta actualizacion!!!
Editado: Sique dando el error si tienes el mod de señales de trafico, seguro que mas de uno se lo pregunta :D
pero los dos errores permanentes los has conseguido quitar ?
artek90
Notapor Cristianibias el 27 Nov 2016, 12:49
miceor escribió:
Cristianibias escribió:Bueno despues de actualizarlo todo ha salido bien lo unico que me ha desaparecido la opcion de conectar por mirrolink si alguien puede echarme una mano
Haz un reset al infotainment. Ya sabes botón de encendido pulsado hasta que reinicie.
Supongo que deberá solucionarse así, tiene que volver a cargar el software en el arranque.
La he reiniciado y tambien restableci los ajustes de fabrica del full link y nada sigue sin aparecer. El android auto y appel va perfecto igual que todo lo demas
Cristianibias
Notapor MORKAS el 27 Nov 2016, 12:54
Ahora es 480.
A mi solo me queda el 1555.....los demas se borraron sin problemas
MORKAS
Agradecido: 369 veces
Notapor miceor el 27 Nov 2016, 12:54
tevaadarelsol escribió:Bueno pues yo acabo de actualizar mi MIB2 a la 0346 pasando por la 0330 como se indica, y en principio todo ok salvo por un error permanente que se ha quedado en el móduclo 5F y que aunque borre sigue saliendo:
1 Fault Found:
1555 - Check Software Version Management
B201A 00 [009] - -
Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Status: 00000001
Fault Priority: 6
Fault Frequency: 1
Reset counter: 4
Mileage: 20465 km
Date: 2016.11.27
Time: 12:01:34
La semana que viene tengo que llevar el coche a revisión y son MUY tocapelotas en ese conce, con lo que no quiero llevarlo con ese error y que se agarren a un clavo ardiendo para anular garantía.
@miceor, @aprietatuercas1974, ¿sabéis cómo eliminar este error?
Gracias!
Hasta donde yo sé el codigo de error 1555 - Check Software Version Management .
Este código se establece una vez que se detecta un cambio de software o hardware, que no se refiere a ningún tipo de incompatibilidad.
No hay ningún problema de funcionamiento una vez que el código se almacena.
Por ejemplo en los Audi dan el mismo error pero con otro codigo (03276 - Please Check Software Version Management)
Aqui podeis ver como lo solucionan:
http://audienthusiasts.com/Application_SVMError.html
He leido mucho al respecto de las Actualizaciones en todos los modelos de la rama Vag pero la verdad es que unicamente he actualizado el mio Mib2 HW:024 Fw:245 sin navi y con Full Link hasta la versión 0346 y sin problemas.
Actualicé primero a la 0330, quité contacto, puse contacto y reinicié el infotainment y me puse a chumetear a ver si veia los fallos que se conocian de esa versión, me metí en todas las funciones y cuando vi todo actualicé a la 0346 y seguí los mismo pasos que con la 0330, quité contacto, puse contacto, reinicié el infotainment y todo correcto.
Luego un Scan y quité varios fallos que salian, Airbag, ESC y alguno más y hasta la fecha sin problemas.
miceor
Agradecido: 1259 veces
Notapor golf_1990 el 27 Nov 2016, 13:01
1 Fault Found:
B201A 00 [009] - -
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 4
Mileage: 20465 km
Date: 2016.11.27
Time: 12:01:34
Gracias!
Tienes la misma pantalla que yo, o sea que te funciona todo correcto.
No debería tener ningún problema pues... Que desaparezca el mirrorlink la verdad es que me la trae floja, pero el android auto si que me importa...
Pero si OS funciona con la h24 esta tarde lo actualizo.
Otra cosa, se puede hacer con el coche encendido ? Le daré el contacto y cuando lleve 20 min o así lo puedo encender ? Por la batería...
Enviado desde mi MI 5 mediante Tapatalk
golf_1990
Notapor hagiwara2002 el 27 Nov 2016, 13:12
Una pregunta, tengo la 5,8" y cuando apreto al boton fisico del menu me aparece un nuevo meno, selecciona la primera opción.
Pero luego me aparece esta:
Tengo que cambiar algo o le doy a iniciar y listos?
hagiwara2002
Notapor aprietatuercas1974 el 27 Nov 2016, 13:22
ya comente que desaparecian cosas y que despues se deben de activar de nuevo.
el error es facil de quitar con odis
aprietatuercas1974
Agradecido: 358 veces
Notapor artek90 el 27 Nov 2016, 13:44
ahora probare. primero actualizo las mapas, despues mirare con vag com si esta todo limpio y pasare a actualizar de 0425 a 0480 y si sale error lo quitare segun manual de audi que puso compi
artek90
Notapor MORKAS el 27 Nov 2016, 13:56
aprietatuercas1974 escribió:ya comente que desaparecian cosas y que despues se deben de activar de nuevo.
Con odis?..he probado y el 1555 no se borra..
MORKAS
Notapor Destino el 27 Nov 2016, 14:53
Ahora es 480.
Ayer despues de borrar los errores volvian a salir, pues eran fijos asi que la respuesta es NO.
En un rato probare la solucion que a puesto un compañero para el error de version de software, y os comento si se va.
¿Alguna idea de como quitar el otro error?(.Reproductor de media en posición 1 no hay comunicacion.)
Destino
Notapor lafu1988 el 27 Nov 2016, 15:09
Estaría bien hacer una tabla con modelo de infotaiment y como ha salido la actualización.
lafu1988
Agradecido: 217 veces
Notapor hagiwara2002 el 27 Nov 2016, 15:16
hagiwara2002 escribió:Una pregunta, tengo la 5,8" y cuando apreto al boton fisico del menu me aparece un nuevo meno, selecciona la primera opción.
Podrías decirme sobre esto por favor?
hagiwara2002
Notapor aprietatuercas1974 el 27 Nov 2016, 15:23
si con odis se hace,yo lo hago asi
aprietatuercas1974
Notapor MORKAS el 27 Nov 2016, 15:26
aprietatuercas1974 escribió:si con odis se hace,yo lo hago asi
Seria posible indicar como?...tengo service y enginering....gracias
MORKAS
