León Mk3 - BRICO - Como instalar la cámara de parking
Favoritos: JaviCG, Vampiro, J@VY, BADS, Daruma, cstrol, JorgeAnteloC, ipenalosa, MONTY DAKA, pirly, josele887, xurox, Nanox23, Carbono79, vallter, norchugo, Efremvidal, @turbina@, blankiblau, jorgee76, jliriz, Vilo, cuenxis, victir, Aras, Korath, Rasekfighter, Carrl, jdieztec, J-Frass, Tarzan, zacarias, Frannisesabe, Xperience, bronce702, sbarri, javieret69, Carlos Chea, Lotar, Alleya, miguelorly, craken, chemazz, xico, eMi1, Maverick.es
Seguidores: Linker89, car212121, franrx, davidalba, TRIBO, danieleon, Panchorin, Hecson.27, jmfcoto, aironsam14, JOTTA, MORKAS, Unaited, trekam, xandis, Jorge75016, Platanot, davidbj, Achehmg, marc.domenech.90, sadanyac, seat leon blanco, Marc.22, Peuero, er_trompe, GTI35, JoseCa, JaviCG, vigimuertos, rabazas, B.Fox, msmdraven, Tomcat7733, Txutxiysilvia, xabidh, cstrol, Carrl, El3ndil, yorky, bolche, LeoST, Diegokero, Rasekfighter, Budoka, IronTor21, marlop, xico, vanscampa, Tarzan, jorgee76, josemag, aigort, LuichiFR, SLon34, clavelstreet, nani_san, nyro, IVANIN9, rober1095, ivan0909, jose.jjg307, csabafr2013, P.carrizo.leonstfr, dookky, Edu1589, Dconnect, D83, Jeii90, inamarlo, Israel-FR, Herrdoktor, el_padrino, Kipu, aguscalderon, lebowski, juanmaroger, bailyibz, naikon_paul, Valerofr150, JAL, kennit0, Mramos1985, bronce702, kijute, juanmik, osjamil, Tonivn, Lotar, Tunnig, JaviMarquez, nitro_g4074, sergi303, ivan2017, Chema_Alvarez, ilargiman, jaumotix, sbarri, javierferriz, alcoleazgz, lecupra280, Colomer, Maikermx, luigi323, rents_80, jdiego75, Pedrost, damsolu, lead, Franr50, Dani2025, Leon pucelano, nachomart, castronight, victor david, bertoco, juan7777, Josep20, jakobitto, rr7mo, a.cuadros71, iNFeCTeD, Gendos22, VapaV, Chrohu, Ganyula, snowpluralism, victor_leon_FR, luaiabou96, Drovniak, Guillen222, leonfrrojito, justics, lopezm0, Romera, pedrorossello92, AlvaroRamlo
Re: BRICO como instalar la Camara de parking en Seat leon MK
Notapor er_trompe el 17 Abr 2015, 15:32
Kampedtre escribió:
pirly escribió:Alguien sabe si existen para automóvil relé con temporizador para que cuando corte mantenga unos segundos mas y así quitar el efecto que hace de pantalla en negro ???
+1 me interesa y mucho!! Porque da rabia que al quitar la marcha desaparezca, par aparcar es un poco rollo
:zoquete: :zoquete: :zoquete: Hay dios!!!! Que fácil es buscar y que díficil se les hace a algunos...
https://www.google.es/webhp?sourceid=chrome-instant&ion=1&espv=2&ie=UTF-8#q=rele%20temporizador%2012v
San google, "rele temporizador 12v " :plas: Y te lo pongo mas fácil y así no te hace falta ni buscarlo, los hay con un tiempo definido fijo, 5 seg, 10 seg, etc, o con una ruleta que según las vueltas que le des, pues tu regulas el tiempo.
El tema no es el relé, el tema es que al parecer es la pantalla la que lo hace, aunque la cámara este encendida, sino, prueba primero a poner la camara con corriente fija, siempre encendida, y verás como sigue haciéndolo (hablo según l o que he leído aquí al respecto)
Es de bien nacido ser agradecido. Si te ha resultado útil este mensaje, dale al botoncito de gracias ;)
Antes de preguntar, escribe tu duda aqui, posiblemente ahorres tiempo y nos lo ahorres a los demás.
er_trompe
Coche: Leon MK3 1.5 TGI 130cv
Agradecido: 124 veces
Notapor Kampedtre el 17 Abr 2015, 15:45
+1 amen!! Y esto se podría modificar por VAG COM?
Kampedtre
Coche: Leon MK3 1.2 TSI 105cv
Agradecido: 28 veces
Notapor er_trompe el 17 Abr 2015, 15:55
@Kampedtre de momento por aquí no se ha hablado nada de eso. S
Se me ocurren tres opciones.
Primera, es la centralita la que controla el tema, y si, se puede modificar con vagcom.
Segunda, el propio modulo multimedia o "radio" es el que corta la imagen cuando se saca la marcha atrás, y por mucho vídeo que esté enviando la cámara se ve la pantalla negra, por lo que posiblemente, habría alguna opción de poner un relé temporizado a la señal que va de la marcha atrás a la radio y así "engañarla.
Tercera, quizás eso lo haga porque con esa radio, se puedan conectar dos cámaras, trasera y delantera, y cuando se ve negro, realmente lo que está haciendo es abrir paso a la cámara frontal, por lo que, y esto habría que investigarlo bien, se podría meter la misma señal de la cámara trasera por las dos entradas de vídeo, y cuando haga el cambio a la delantera, siga reproduciendo la trasera.
er_trompe
Notapor genialsoft el 17 Abr 2015, 16:06
A mi me sale asi, engranada y al desengranar sin ninguna pantalla negra en medio. O sea que lo de una segunda cámara no puede ser y como digo no hay espera entre la imagen de la camara y la pantalla de los Sensores.
genialsoft
Agradecido: 346 veces
Notapor er_trompe el 17 Abr 2015, 16:22
Descartada tercera opción, ya solo quedan 2 para bingo! :lol: :lol:
Yo cogería encantado el polímetro y me pondría a medir tensión uno a uno en todos los cables que llegan a la radio metiendo y sacando la marcha atrás, pero no tengo el coche :cry:
er_trompe
Notapor Kampedtre el 17 Abr 2015, 17:22
er_trompe escribió:@Kampedtre de momento por aquí no se ha hablado nada de eso. S
Me acabo de saturar!! Jajajaja enserio, mas o menos lo entiendo, pero del grupo VAG hay algún modelo que lleve cámara frontal? Porque si es así se podría poner!! Vamos @rojas, tu puede!! :)
Kampedtre
Notapor pirly el 17 Abr 2015, 21:11
No te ofendas, pero creo que se buscar por Internet , soy programador informático .... El problema es que de esos temas estoy pegado. primero no se si el relé corta antes o después de recibir la señal y segundo que relé con temporizadores de 40 Amperios no los he visto, he visto de 10,20 y no se si da poco más, lo mismo si me tiro un rato más los veo pero si la gente de por aquí sabe de estos temas, seguro nos dirá que podremos comprar.
Por otro lado, ahora mismo la llevo sin relé y el efecto de pantalla en negro ha desaparecido totalmente. Aun así, me gustaría conectar un relé para que no este siempre activa.
Un saludo compañero
pirly
Agradecido: 304 veces
Notapor rojas el 18 Abr 2015, 09:37
Yo aun no entiendo para que un relé con temporizador ... se trata que solo se vea la parte trasera cuando tengas la marcha atrás y al poner primera se vea el gráfico con sensores en grande ....
Pero allá cada uno ;)
rojas
Agradecido: 1889 veces
Notapor genialsoft el 18 Abr 2015, 09:58
rojas escribió:Yo aun no entiendo para que un relé con temporizador ... se trata que solo se vea la parte trasera cuando tengas la marcha atrás y al poner primera se vea el gráfico con sensores en grande ....
Yo creo que lo que pasa es que no tienen sensores o el firmware es mas viejo, por que el funcionamiento es el que dices y no hay ninguna pantalla negra. El otro dia montando la cámara de @dahersol si que a el se le quedaba en negro pero es porque no lleva la centralita de los sensores, si lleva sensores pero sin representación en pantalla ni botón para desactivarlos, e igual pasa lo mismo.
genialsoft
Notapor ocsido el 18 Abr 2015, 10:02
Hola. yo creo que es debido a que los que no tenemos sensores, solo nos sale la pantalla negra unos segundos más al quitar la marcha atrás y queda fea, de allí lo de alagar la señal de video que creo que la corta el relé, la pantalla la mantiene unos segundos, creo...
Y sí, ayer a las 3 de la mañana terminé de instalarla y quiero agradecer a @rojas especialmente y todos los demás el gran brico. gracias crack!!!
SEAT LEON X-PERIENCE 1.8 TSI 180CV
SEAT TOLEDO MK2 1.9 TDI 130CV
ocsido
Agradecido: 33 veces
Notapor er_trompe el 18 Abr 2015, 10:07
@pirly no me ofendo hombre, sino que tal y como has planteado la pregunta, la respuesta es si, existen, y puedes comprobarlo simplemente buscando en Google, si ya te refieres a detalles en concreto como tiempo o amperaje máximo de carga, normalmente abierto o normalmente cerrado... es otra cosa.
En cuanto a los amperios, da igual el que pongas siempre y cuando sea mayor de 5, la cámara en si no consume ni uno. De todos modos, ya se ha demostrado que ni con el relé se consigue evitar la imagen en negro así que no lo compres que va a ser para nada.
@rojas yo estoy contigo, pero se supone que la gente quiere evitar la pantalla en negro, y aún más, si no tienen sensores de parking
er_trompe
Notapor pirly el 18 Abr 2015, 10:31
er_trompe escribió:@pirly no me ofendo hombre, sino que tal y como has planteado la pregunta, la respuesta es si, existen, y puedes comprobarlo simplemente buscando en Google, si ya te refieres a detalles en concreto como tiempo o amperaje máximo de carga, normalmente abierto o normalmente cerrado... es otra cosa.
Yo la pantalla en negro lo he solucionado quitando el relé, luego si tengo tiempo subo un video a youtube y vereis el antes y después.
@rojas cuando veas el vídeo de con relé y sin relé veras porque quiero lo del relé con temporizador. La camara está activa mientras este la marcha atrás engranada, pero cuando metes primera/punto muerto al no tener sensores la pantalla se queda en negro 8 segundos hasta que vuelve a la radio. Al tener alimentación siempre ese efecto desaparece, entonces si hubiera algo que pudiera hacer que al cortar la marcha atrás siga alimentando la camará unos segundos más seria la solución ideal y así seguir conservando el relé evitando que la camará este todo el día activa.
Vuelvo a poner el video para que veaís el efecto extraño
pirly
Notapor er_trompe el 18 Abr 2015, 10:34
Tienes puesto condensador? Parece como que la cámara pierde alimentación progresivamente y por eso ese efecto "raro"
er_trompe
Notapor pirly el 18 Abr 2015, 11:16
Si lo tengo puesto, de los mismos micro faradios, sin el la imagen ni se puede ver metía mucho ruido, creo que se dice así jeje.
pirly
Notapor er_trompe el 18 Abr 2015, 14:30
Pues seguramente sea de eso, que la electricidad que almacena el condensador, una vez corta la corriente, se va gastando poco a poco y llega el momento en que no es suficiente para la cámara y hace eso, en vez de quedarse instantáneamente sin corriente y apagar la cámara
er_trompe
Usuarios navegando por este Foro: Anthropic, SentiBot y 5 invitados
