León Mk3 - Actualización infotainment
Favoritos: BADS, Daruma, ositoerik, dmesanun, YeSL, pocososinos, jasoriab, JaviMarquez, crujipoyo, Arkan7, Cristianibias, pepeiyo69, Angel J, Xaggy, edumachuca, abollao, -alberto-, Rickymax, ferre7, Pedritoleon, Rivesgti, Alleya, davidalba, Xiguito_Corito, craken, JDCLEONFR, nemura, danihd, cenkkaya, Kisszabo, castell_lkpg, pistoleromtb, Raulportela, Martelinko, albert_naga, Adrian Anton, Gravilhas75, chaiser, popez, ruli68, denniisg2000, LeonFR80bsv
Seguidores: kenny_fonseca, ncx, Lavadora, barris31, juancete, ivantxe, jesusFR, Hysteria, MaximusRoco, Manu1986, Jorge75016, davidbj, bIxu, miyobe, MORKAS, gorkansr, aironsam14, jramis, kimudj, Maikermx, Javizormo, gogua, Melonkid, Kikote8, danirodrigueze30, maxinew, aigort, carlosgzlez, corderazo, Lionxp, jande, Edu1589, msmdraven, Arkan7, inamarlo, edumachuca, Josepo79, lead, camamaleon, davidmd, carrasco13, clavelstreet, mikomiko, josele77, car212121, itz18, golf_1990, LeidenSpain, vecnte, Andy_G, csabafr2013, leonfr76, Trimmer, genialsoft, Enerts, leonfrrojito, Horus, paco_22_22, ruben88, Valerofr150, molvi_mabad, Pekee69, Dav2k6, IbiFR, il_munyo, craken, ruben91mad, papo-182, el_padrino, zeratul, kaiserssosse, lytry32.hc, sbarri, ghitus, DesmoSimon, ruli68, Mramos1985, tonielfilas, braulioT, davidalba, JaviMarquez, osjamil, egarense69, fexposru, Pedrost, Illan, chetelopez, juanacho21, cuenka16, pepeiyo69, VapaV, AlvaroPM13, balbu, juan7777, mams69, Helrique, Kike77, volkov, jluis, loeches, Tom70, Dconnect, Trivi83, MilleMiglia, linxes, sergi303, hector37, D83, quiquito30lv, ElFon, DALOFER17, davidap13, kigua, JOTTA, Senuto, jd_zuri, Alvi, damsolu, Leon pucelano, javi_archi, danihd, alcoleazgz, miguel23and, xarlio, jdieztec, mitxuni, Kisszabo, Gendos22, xexpir, canijo82, Brandenor, cenkkaya, kennit0, Chelazo, bertoco, benitogomez, carlosVACA, Peje, NOECUBI1, AAAJDA, trazas, martija, borjiguez, JoseXS, ferbarroso14, Wespa, Cloud_ganora, Berbe15, Valengti, Chrohu, Atajunen, Victorzabal, jrm82, carlo13, iNFeCTeD, paralaxon, ateopoeta, pepo55, ribasxisco, Raulribarroja, ivanti, Jansel, lopezm0, Rubén Flp, Warelio, Vagabundo, Rekoba, Octacon, matiaso, Alianma, Raulportela, Éugen91, Rivesgti, Mcm90, DaniR86, Gravilhas75, JuanNur78, el_Asturiano, Mr.Chuflas, albert_naga, juanfrancia, Seket, algabe, pistoleromtb, ebcuatro, [GuErRa], Mario Leon, tito68
Re: Actualización infotainment
Notapor MORKAS el 27 Nov 2016, 15:27
MORKAS escribió:
aprietatuercas1974 escribió:si con odis se hace,yo lo hago asi
Seria posible indicar como?...tengo service y enginering....gracias
O tiene que ser online?..con usuario de concesionario?..
MORKAS
Agradecido: 369 veces
Notapor artek90 el 27 Nov 2016, 15:37
Imagen acabo de actualizar todo mapas tambien. Pero como quitar fallo 15555 que con manual de audi no encuentro canal 15.
Leon 1.6 tdi i-tech ----> http://www.clubseatleon.net/viewtopic.php?f=43&t=111717
Imagen Leon ST FR 1.8 TSI --->Imagen
artek90
Agradecido: 187 veces
Notapor Arkan7 el 27 Nov 2016, 15:53
aprietatuercas1974 escribió:los que teneis la mib2 high este firmware no es y se pueden actualizar desde la version 0123 y tener la opcion full link,tener la opcion otra cosa es habilitar la funcion
supongo que pueda pasar como con las std y segun que hw no se pueda instalar la ultima version pero en uno con firmware 0123 no se exactamente que hw era creo que 41 o 42 le puse la version 0674 y esa es con apariencia de ateca y posibilidad de full link
@aprietatuercas1974 lo siento pero no te acabo de entender... mib2 high HW H41 con SW 0123, podemos instalar 0330 y luego 0346? o debemos esperar a otras actualizaciones que nos lleven hasta la 0674?
Lo siento por volver a preguntar pero es que esto es un poco confuso...
Aprovecho y pregunto, que significa std?
:banana:
Arkan7
Notapor artek90 el 27 Nov 2016, 15:54
hagiwara2002 escribió:Una pregunta, tengo la 5,8" y cuando apreto al boton fisico del menu me aparece un nuevo meno, selecciona la primera opción.
Pero luego me aparece esta:
Tengo que cambiar algo o le doy a iniciar y listos?
alli no hay que tocar nada. solo te especifica que modulos se van a actualizar, algunos llevan mismo software y por eso pone no. donde pone parcial se actualiza solo una parte, pero como detecta todas versiones automaticamente no hay que tocar nada. 40 minutos y listo.
artek90
Notapor cvillajos el 27 Nov 2016, 16:03
El error de SW management no se quita con el procedimiento que hacen los de Audi... Sus 5F MMI son muy distintasa nuestras MIB y la gestión de los canales difieren.
El canal de adaptación que origina el fallo es "Confirmation of installation change", pero no sé qué valor hay que meter en cada caso (quizá alguien con la 480 puesta en concesionario pueda indicar su valor).
@aprietatuercas1974 , qué procedimiento hay que seguir con ODIS para quitar el error?
cvillajos
Agradecido: 3613 veces
Notapor aprietatuercas1974 el 27 Nov 2016, 16:04
estas que se han colhado son std=standard la tuya es la high y el firmware no es el mismo por lo tanto no puedes poner estos
aprietatuercas1974
Agradecido: 358 veces
Notapor artek90 el 27 Nov 2016, 16:13
cvillajos escribió:El error de SW management no se quita con el procedimiento que hacen los de Audi... Sus 5F MMI son muy distintasa nuestras MIB y la gestión de los canales difieren.
a ver si lo descubrimos. y la calculadora que hay en pagina de audi no vale para calcular valor nuevo ?
artek90
Notapor cvillajos el 27 Nov 2016, 16:21
Yo ya estuve probando con un compi hace tiempo que le salió el mismo error, pero no lo conseguimos. En esa calculadora se meten números aparentemente decimales, pero nosotros en el canal mencionado antes de installation change tenemos hexadecimales...
Probamos a meter el mío, el suyo, convertir ambos a decimal -> calcular con la herramienta Audi -> convertir de nuevo a hexadecimal...
Nada de nada. A ver si @aprietatuercas1974 comenta algo más de cómo se hace por ODIS e intentamos extrapolar a otras interfaces (si es que se puede).
cvillajos
Notapor artek90 el 27 Nov 2016, 16:25
Ahora la pregunta es si en concesionario me dicen algo? Se enteraran? Seguramente si por el fallo pero si les dire que no he tocado nada? Podran quitar el fallo?
artek90
Notapor MORKAS el 27 Nov 2016, 16:46
En el conce si pueden quitar el fallo..de hecho al acabar la actualizacion..precisamente te ordena la infotaiment meter la diagnosis
Ahora...si quieren o no ya es cuestion de cortesia por su parte...y si...claro que te ven el error..y sabran que has hecho la update...pero de sobra saben que no has hecho nada malo..ni que afecte al coche...
MORKAS
MORKAS
Notapor vortexhacker el 27 Nov 2016, 18:04
al final formatee la tarjeta volví a meter los archivos y actualizo a la primera y sin fallos a la vista. Lo tipico de al terminar que conectes la diagnosis pero no lo he hecho se reinicio y funciona todo sin problemas. Las mismas funciones nada nuevo pero los menús cambian entre ellos mas rápido. Y sin los pequeños tirones que daban. Con la version anterior muy muy rara vez se desconectaba el bt a lo mejor a las 3 horas de viaje. pero conectaba solo instantáneamente. Ya veremos si eso se ha corregido.
Con una sd que tenia de 16gb clase 10 me tardo 30-35 min en actualizar.
vortexhacker
Agradecido: 114 veces
Notapor aprietatuercas1974 el 27 Nov 2016, 19:33
en el registro de la mismo 5f quedan grabadas las acciones que se han hecho y si la tarjeta es la que envia seat o no
aprietatuercas1974
Notapor miceor el 27 Nov 2016, 19:49
En la 5F queda el registro de las ultimas 10 modificaciones nada mas.
Eso lo estuve viendo yo en la propia SEAT.
En el proceso de Actualización, por un lado se hace el chequeo de lo que tienes, lo sobreescribe respetando las modificaciones realizadas con la fecha que se hicieron y aplica la actualización en base a la configuración actual.
Si hay alguna cosa nueva, la implementa (Vease visualización del Ateca),
Una vez actualizado, se reinicia precisamente para volver a releer todas las configuraciones.
El registro de la tarjeta como tu dices no queda en ningún lado registrado por una cuestión principal, porque la tarjeta no lleva ninguna identificación.
La orden principal de instalación así como el listado de cada elemento a actualizar y el orden del mismo se lo indica el archivo Metainfo.txt y si cualquiera que entienda un poquito de esto le echa un vistazo se dará cuenta de que no hay ninguna vinculación de la tarjeta con el sistema de instalación, asi como que es una instalación generalista no unica para cada vehiculo.
Yo he tenido las originales y las propias tarjetas no llevan ni el label.
Unicamente queda registrado en el sistema que se han realizado las actualizaciones de los modulos correspondientes, con la identificación del SW y FW correspondiente y la fecha y además luego en algunos casos que no en todos da el error 1555 que significa simplemente que no se ha validado la instalación de la actualización por el servicio oficial.
Para ello hay que validar el SVM y punto.
O sea, que si dejas pulsado el botón Menú hasta que te sale el segundo menú podrás ir viendo que modulos se han actualizado y cuando. Punto y pelota, no hay nada mas que quede registrado.
Si la tarjeta crease un registro de autentificación logicamente no sería necesaria la validación posterior de instalación.
Así que hablemos con propiedad y no liemos a la gente con cosas que no son.
Última edición por miceor el 27 Nov 2016, 19:58, editado 1 vez en total
miceor
Agradecido: 1259 veces
Notapor aprietatuercas1974 el 27 Nov 2016, 19:57
si tu lo dices sera asi, yo comento lo que me explicaron la primera vez al hacerlo en vw.
No entro en si es verdad o no
aprietatuercas1974
Hilo del León mkIV e-hybrid
Foro: General
Autor: vkr84
Respuestas: 648
Pantalla aparece más pequeña tras actualización
Autor: josedagil
Respuestas: 1
León MK4 1.5 e-Hybrid 204cv
Foro: Presentaciones
Autor: javiernick
Respuestas: 0
Impresiones León MK4 ST eTSi 150CV DSG Style Special Edition
Foro: General
Autor: jgleal
Respuestas: 6
Cubierta aislante capó MK3.
Foro: General
Autor: FR-Matt Line
Respuestas: 0
