León Mk3 - Actualización infotainment
Favoritos: BADS, Daruma, ositoerik, dmesanun, YeSL, pocososinos, jasoriab, JaviMarquez, crujipoyo, Arkan7, Cristianibias, pepeiyo69, Angel J, Xaggy, edumachuca, abollao, -alberto-, Rickymax, ferre7, Pedritoleon, Rivesgti, Alleya, davidalba, Xiguito_Corito, craken, JDCLEONFR, nemura, danihd, cenkkaya, Kisszabo, castell_lkpg, pistoleromtb, Raulportela, Martelinko, albert_naga, Adrian Anton, Gravilhas75, chaiser, popez, ruli68, denniisg2000, LeonFR80bsv
Seguidores: kenny_fonseca, ncx, Lavadora, barris31, juancete, ivantxe, jesusFR, Hysteria, MaximusRoco, Manu1986, Jorge75016, davidbj, bIxu, miyobe, MORKAS, gorkansr, aironsam14, jramis, kimudj, Maikermx, Javizormo, gogua, Melonkid, Kikote8, danirodrigueze30, maxinew, aigort, carlosgzlez, corderazo, Lionxp, jande, Edu1589, msmdraven, Arkan7, inamarlo, edumachuca, Josepo79, lead, camamaleon, davidmd, carrasco13, clavelstreet, mikomiko, josele77, car212121, itz18, golf_1990, LeidenSpain, vecnte, Andy_G, csabafr2013, leonfr76, Trimmer, genialsoft, Enerts, leonfrrojito, Horus, paco_22_22, ruben88, Valerofr150, molvi_mabad, Pekee69, Dav2k6, IbiFR, il_munyo, craken, ruben91mad, papo-182, el_padrino, zeratul, kaiserssosse, lytry32.hc, sbarri, ghitus, DesmoSimon, ruli68, Mramos1985, tonielfilas, braulioT, davidalba, JaviMarquez, osjamil, egarense69, fexposru, Pedrost, Illan, chetelopez, juanacho21, cuenka16, pepeiyo69, VapaV, AlvaroPM13, balbu, juan7777, mams69, Helrique, Kike77, volkov, jluis, loeches, Tom70, Dconnect, Trivi83, MilleMiglia, linxes, sergi303, hector37, D83, quiquito30lv, ElFon, DALOFER17, davidap13, kigua, JOTTA, Senuto, jd_zuri, Alvi, damsolu, Leon pucelano, javi_archi, danihd, alcoleazgz, miguel23and, xarlio, jdieztec, mitxuni, Kisszabo, Gendos22, xexpir, canijo82, Brandenor, cenkkaya, kennit0, Chelazo, bertoco, benitogomez, carlosVACA, Peje, NOECUBI1, AAAJDA, trazas, martija, borjiguez, JoseXS, ferbarroso14, Wespa, Cloud_ganora, Berbe15, Valengti, Chrohu, Atajunen, Victorzabal, jrm82, carlo13, iNFeCTeD, paralaxon, ateopoeta, pepo55, ribasxisco, Raulribarroja, ivanti, Jansel, lopezm0, Rubén Flp, Warelio, Vagabundo, Rekoba, Octacon, matiaso, Alianma, Raulportela, Éugen91, Rivesgti, Mcm90, DaniR86, Gravilhas75, JuanNur78, el_Asturiano, Mr.Chuflas, albert_naga, juanfrancia, Seket, algabe, pistoleromtb, ebcuatro, [GuErRa], Mario Leon, tito68
Re: Actualización infotainment
Notapor cvillajos el 28 Nov 2016, 12:50
miceor escribió:Alguien ha probado simplemente a confirmar el valor original directamente sin cambiarlo?
Puede que simplemente haya que confirmarlo.
Cristianibias escribió:Bueno despues de actualizarlo todo ha salido bien lo unico que me ha desaparecido la opcion de conectar por mirrolink si alguien puede echarme una mano
He estado dandole vueltas al tema de que desaparezca el Mirrorlink en al menos un caso que conocemos.
Me gustaria saber si antes de la actualización llevaba el VIM+Mirrorlink desactivado, no sea que al llevarlo así la actualización interprete que no está disponible y lo deja fuera.
Se me ocurre probar en ese caso en concreto a entrar en el menú de ingeniero y Activarlo desde el menú y ver que ocurre. Si lo haces, luego salte del menú de ingeniero y reinicia el infotainment a ver si aparece de nuevo el Mirrorlink.
Tambien puedes comprobar estos valores:
En la 5F, entra en Vehicle configuration y abajo del todo mira esto -----Mirror_link -- (Function off_HMI off).
Si lo cambias de valor, Reinicia el Infotainment.
Comprueba que esté como se indica.
¿Puedes poner una foto de ese submenú del menú ingeniero @miceor ?
Yo tengo 5,8" MIB gen1 y con ella (lógicamente) no le puedo ver.
cvillajos
Agradecido: 3612 veces
Notapor cvillajos el 28 Nov 2016, 12:53
MORKAS escribió:Una pregunta...a parte de esa calculadora XOR online...como se calcularia con una aplicacion de calculadora....estoy buscando y no consigo esos valores..
Tienes que irte a la vista de calculadora "Programador":
P.D.: A la izquierda seleccionar "HEXA".
cvillajos
Notapor artek90 el 28 Nov 2016, 13:15
Imagen yo hice asi.
Leon 1.6 tdi i-tech ----> http://www.clubseatleon.net/viewtopic.php?f=43&t=111717
Imagen Leon ST FR 1.8 TSI --->Imagen
artek90
Agradecido: 187 veces
Notapor miceor el 28 Nov 2016, 13:30
cvillajos escribió:¿Puedes poner una foto de ese submenú del menú ingeniero @miceor ?
Lo tienes en este video de @Rojas https://www.youtube.com/watch?v=3NP_XStsTQg
miceor
Agradecido: 1259 veces
Notapor Cristianibias el 28 Nov 2016, 14:04
Miceor no tenia desbloqueao el vim la tenia de serie completamente y antes iva todo mirare lo que dices con vagcom a ver si puedo donde me tengo que meter exactamemte? Gracias
Cristianibias
Notapor supergalvista el 28 Nov 2016, 14:26
Buenas. Me han surgido 2 dudas antes de actualizar. Tengo la MIB1 de 5,8" con el software 421. Por lo que tengo entendido ¿habría que actualizar primero a la 425 y luego a la 480, o se puede actualizar directamente? Y la otro pregunta es que tengo activado el SSS y el VIM a posteriori, ¿al actualizar se perderán esas funciones o seguirán? Muchas gracias.
supergalvista
Notapor lafu1988 el 28 Nov 2016, 14:45
Que diferencia hay entre 5QA035824A a la 5QA035824? Las dos son 6,5 mib2 con full link sin Nav
lafu1988
Agradecido: 217 veces
Notapor cvillajos el 28 Nov 2016, 14:55
Ese vídeo es cuando la de @rojas era de 5,8". Ese menú le tengo yo y no hace nada (crea un icono de "MirrorLink"en el menú pero no es funcional).
Yo creí que te referías a otro menú en las 6,5".
cvillajos
Notapor miceor el 28 Nov 2016, 15:23
En las 6.5" sale exactamente igual.
Crea el menú del Mirrorlink, funcional si te desapareció despues de actualizar supongo.
Logicamente si no lo tienes de serie no sirve de nada.
miceor
Notapor sinparedes el 28 Nov 2016, 16:06
Estoy en el coche, me sale el valor 52 C1, me podéis calcular el valor para borrar el fallo a través del Vagcom, no me aclaro con la calculadora.
Saludos..
sinparedes
Agradecido: 129 veces
Notapor artek90 el 28 Nov 2016, 16:24
sinparedes escribió:Estoy en el coche, me sale el valor 52 C1, me podéis calcular el valor para borrar el fallo a través del Vagcom, no me aclaro con la calculadora.
Saludos..
9B 13 hay que meterlo con espacio
artek90
Notapor miceor el 28 Nov 2016, 16:31
Saludos..
Prueba primero a validarlo tal cual sin cambiarlo y mira si borra los fallos
Seria interesante saberlo
miceor
Notapor Agonza86 el 28 Nov 2016, 16:42
Otro con duda de novato que no se termina de aclarar.
Con este equipo 5,8 con Navy de marzo de 2015 puedo cargar directamente la actualización que has colgado @miceor??
Gracias de antemano!!
Agonza86
Agradecido: 409 veces
Notapor tevaadarelsol el 28 Nov 2016, 18:03
Bueno pues ya he podido borrar el fallo. A tener en cuenta:
- No me ha cambiado el valor del canal tras meter el código nuevo. Tanto antes como despues de meterlo, tengo el mismo valor.
- @miceor Si pruebo simplemente a aceptar el valor que ya viene puesto, me sale "funcion no disponible"
tevaadarelsol
Agradecido: 200 veces
Notapor ATA-RACING el 28 Nov 2016, 18:18
Agonza86 escribió:Otro con duda de novato que no se termina de aclarar.
@Agonza86 en la pajina 41 de este mismo post explica @miceor como realizar la operacion de actualizacion de la 5.8 mib-1 navi y sin navi tengo la misma version pero hasta que no este del todo claro yo quietecito y leer todo muy bien para que luego no alla arrepintimientos dar las gracias a @miceor por explicarlo y subir los firw y link muchas gracias compañero. :ok:
Última edición por ATA-RACING el 28 Nov 2016, 18:37, editado 3 veces en total
SEAT LEON FR-1.4-TSI-ACT 150CV 5 PUERTAS :rey:
si te gusta conducir,conduce un seat leon mk3 A-TUMBA-ABIERTA. :comediante: :cuñao:
ATA-RACING
Agradecido: 375 veces
Usuarios navegando por este Foro: AhrefsBot, Anthropic y 5 invitados
