León Mk3 - BRICO - Como instalar la cámara de parking
Favoritos: JaviCG, Vampiro, J@VY, BADS, Daruma, cstrol, JorgeAnteloC, ipenalosa, MONTY DAKA, pirly, josele887, xurox, Nanox23, Carbono79, vallter, norchugo, Efremvidal, @turbina@, blankiblau, jorgee76, jliriz, Vilo, cuenxis, victir, Aras, Korath, Rasekfighter, Carrl, jdieztec, J-Frass, Tarzan, zacarias, Frannisesabe, Xperience, bronce702, sbarri, javieret69, Carlos Chea, Lotar, Alleya, miguelorly, craken, chemazz, xico, eMi1, Maverick.es
Seguidores: Linker89, car212121, franrx, davidalba, TRIBO, danieleon, Panchorin, Hecson.27, jmfcoto, aironsam14, JOTTA, MORKAS, Unaited, trekam, xandis, Jorge75016, Platanot, davidbj, Achehmg, marc.domenech.90, sadanyac, seat leon blanco, Marc.22, Peuero, er_trompe, GTI35, JoseCa, JaviCG, vigimuertos, rabazas, B.Fox, msmdraven, Tomcat7733, Txutxiysilvia, xabidh, cstrol, Carrl, El3ndil, yorky, bolche, LeoST, Diegokero, Rasekfighter, Budoka, IronTor21, marlop, xico, vanscampa, Tarzan, jorgee76, josemag, aigort, LuichiFR, SLon34, clavelstreet, nani_san, nyro, IVANIN9, rober1095, ivan0909, jose.jjg307, csabafr2013, P.carrizo.leonstfr, dookky, Edu1589, Dconnect, D83, Jeii90, inamarlo, Israel-FR, Herrdoktor, el_padrino, Kipu, aguscalderon, lebowski, juanmaroger, bailyibz, naikon_paul, Valerofr150, JAL, kennit0, Mramos1985, bronce702, kijute, juanmik, osjamil, Tonivn, Lotar, Tunnig, JaviMarquez, nitro_g4074, sergi303, ivan2017, Chema_Alvarez, ilargiman, jaumotix, sbarri, javierferriz, alcoleazgz, lecupra280, Colomer, Maikermx, luigi323, rents_80, jdiego75, Pedrost, damsolu, lead, Franr50, Dani2025, Leon pucelano, nachomart, castronight, victor david, bertoco, juan7777, Josep20, jakobitto, rr7mo, a.cuadros71, iNFeCTeD, Gendos22, VapaV, Chrohu, Ganyula, snowpluralism, victor_leon_FR, luaiabou96, Drovniak, Guillen222, leonfrrojito, justics, lopezm0, Romera, pedrorossello92, AlvaroRamlo
Re: BRICO como instalar la Camara de parking en Seat leon MK
Notapor xaacra el 03 May 2015, 22:37
dahersol escribió:Si puedo mañana envió fotos!!
ok gracias en espera.
xaacra
Agradecido: 9 veces
Notapor vallter el 03 May 2015, 22:46
Esta seria un ejemplo
en aliexpress o eBay hay mas
Leon 1.2 ITECH 110 cv
vallter
Coche: Leon MK3 1.2 TSI 105cv
Agradecido: 28 veces
Notapor Enrike_md90 el 03 May 2015, 22:53
calafat escribió:
Enrike_md90 escribió:buenas chicos tengo un problemon, tengo la camara instalada y compre el vag com nuevo, el caso esque no puedo codificarlo aunque el vag conecta con el coche y lo reconoce, no me deja hacer cambios e probado varios softwares y nada, alguien me podria ayudar o quedar para configurarmelo en madrid. un saludo
Que error te da? Metes el security access code antes de cambiar los bits?
me da error de licencia, el caso que cuendo entro me sale activada pero cuando voy a modificar algo me da un error de que ya no la tengo activada lo miro y asi es pone que no esta registrada. el security access que es?? gracias
Enrike_md90
Notapor Martín st el 04 May 2015, 00:20
Buenas, a mi me quedo asín la que va en el centro del vehículo
Martín st
Coche: Leon MK3 1.4 TSI 122cv
Agradecido: 26 veces
Notapor xaacra el 04 May 2015, 00:28
Martín st escribió:Buenas, a mi me quedo asín la que va en el centro del vehículo
Hola cual es el modelo de camara no tiene lineas
xaacra
Agradecido: 9 veces
Notapor tokedj1989 el 04 May 2015, 00:47
Y si pudieras decir como es el montaje te lo agradeceria jejejeje. Un saludo
tokedj1989
Agradecido: 25 veces
Notapor dasi658 el 04 May 2015, 13:55
Esta es mi codificación, el problema es que no se me vuelve transparente el ops pasados unos segundos.¿Alguien sabe cual puede ser el motivo?Saludos
dasi658
Agradecido: 37 veces
Notapor rojas el 04 May 2015, 13:59
dasi658 escribió:Esta es mi codificación, el problema es que no se me vuelve transparente el ops pasados unos segundos.¿Alguien sabe cual puede ser el motivo?Saludos
en el modulo 5F esta correcto como se ve en la foto , creo mas bien que el tema está en la centralita de pdc
postea las fotos de cada byte del modulo 10
rojas
Coche: Leon MK3 1.5 TGI 130cv
Agradecido: 1888 veces
Notapor dahersol el 04 May 2015, 14:04
Así me quedó a mi. Es de las que se puede ajustar 360°
dahersol
Agradecido: 44 veces
Notapor ocsido el 04 May 2015, 14:34
dahersol escribió:Así me quedó a mi. Es de las que se puede ajustar 360°
hola dahersol.
Queda genial. Yo tengo puesta la que lleva la mayoria y no me gusta mucho, se ve bastante y aunque tiene las líneas, nunca la imagen es fiel ya que está en un lado y tampoco tengo la referencia de donde acaba el parachoques.
¿la tuya se puede enfocar de manera que veas el parachoques?
¿podrías pasar el link?
gracias!!!
SEAT LEON X-PERIENCE 1.8 TSI 180CV
SEAT TOLEDO MK2 1.9 TDI 130CV
ocsido
Agradecido: 33 veces
Notapor genialsoft el 04 May 2015, 15:04
hola dahersol.
gracias!!!
que me corrija @Dahersol, pero tal y como la tiene puesta es imposible que se vea el parachoques. Si la montases arriba entre las luces de la matrícula si se podría, pero piensalo un poco. Yo tengo la cámara como tú entiendo, lo que tienes que hacer es tomar medida a las rayas que te salen, yo por ejemplo sé perfectamente que si dejo la raya roja alineada por ejemplo con la zona azúl el coche está clavado. Si la enfocas para que veas la referencia del parachoques perderás mucho ángulo de visión y la principal utilidad que yo le veo a la cámara no es tanto el aparcar si no salir de los aparcamientos en bateria o semi-bateria marcha atrás, ves perfectamente si vienen coches o no. Cuanto más cierres el ángulo más vision pierdes.
genialsoft
Agradecido: 346 veces
Notapor dasi658 el 04 May 2015, 16:24
Ahí va el modulo 10
dasi658
Notapor dahersol el 04 May 2015, 18:44
Al tenerla por debajo del parachoques no se puede ver. La otra opción es donde el compañero en medio de los plafones, pero comí dice @genialsoft perderás mas ángulo de visión y va muy bien para salir marcha atrás de los aparcamientos. Yo la tengo para eso y para tener referencia de cuando acaba una plaza de pk.
Luego busco el link de mi cámara y la pongo.
dahersol
Notapor dahersol el 04 May 2015, 22:53
dahersol
Notapor calafat el 04 May 2015, 23:16
El security access es el código que debes insertar antes de hacer algún cambio, sino te dará error, está como botón al lado de coding. Eso te error de licencia, actualizaste la aplicación o conectaste el cable con internet activo?
calafat
Agradecido: 22 veces
