León Mk3 - BRICO - Como instalar la cámara de parking
Favoritos: JaviCG, Vampiro, J@VY, BADS, Daruma, cstrol, JorgeAnteloC, ipenalosa, MONTY DAKA, pirly, josele887, xurox, Nanox23, Carbono79, vallter, norchugo, Efremvidal, @turbina@, blankiblau, jorgee76, jliriz, Vilo, cuenxis, victir, Aras, Korath, Rasekfighter, Carrl, jdieztec, J-Frass, Tarzan, zacarias, Frannisesabe, Xperience, bronce702, sbarri, javieret69, Carlos Chea, Lotar, Alleya, miguelorly, craken, chemazz, xico, eMi1, Maverick.es
Seguidores: Linker89, car212121, franrx, davidalba, TRIBO, danieleon, Panchorin, Hecson.27, jmfcoto, aironsam14, JOTTA, MORKAS, Unaited, trekam, xandis, Jorge75016, Platanot, davidbj, Achehmg, marc.domenech.90, sadanyac, seat leon blanco, Marc.22, Peuero, er_trompe, GTI35, JoseCa, JaviCG, vigimuertos, rabazas, B.Fox, msmdraven, Tomcat7733, Txutxiysilvia, xabidh, cstrol, Carrl, El3ndil, yorky, bolche, LeoST, Diegokero, Rasekfighter, Budoka, IronTor21, marlop, xico, vanscampa, Tarzan, jorgee76, josemag, aigort, LuichiFR, SLon34, clavelstreet, nani_san, nyro, IVANIN9, rober1095, ivan0909, jose.jjg307, csabafr2013, P.carrizo.leonstfr, dookky, Edu1589, Dconnect, D83, Jeii90, inamarlo, Israel-FR, Herrdoktor, el_padrino, Kipu, aguscalderon, lebowski, juanmaroger, bailyibz, naikon_paul, Valerofr150, JAL, kennit0, Mramos1985, bronce702, kijute, juanmik, osjamil, Tonivn, Lotar, Tunnig, JaviMarquez, nitro_g4074, sergi303, ivan2017, Chema_Alvarez, ilargiman, jaumotix, sbarri, javierferriz, alcoleazgz, lecupra280, Colomer, Maikermx, luigi323, rents_80, jdiego75, Pedrost, damsolu, lead, Franr50, Dani2025, Leon pucelano, nachomart, castronight, victor david, bertoco, juan7777, Josep20, jakobitto, rr7mo, a.cuadros71, iNFeCTeD, Gendos22, VapaV, Chrohu, Ganyula, snowpluralism, victor_leon_FR, luaiabou96, Drovniak, Guillen222, leonfrrojito, justics, lopezm0, Romera, pedrorossello92, AlvaroRamlo
Re: BRICO como instalar la Camara de parking en Seat leon MK
Notapor Kaisen el 05 May 2015, 19:19
dahersol escribió:Así me quedó a mi. Es de las que se puede ajustar 360°
¿Tu cámara era NTSC,no? yo pedi un modelo distinto a todos los que habéis montado y la pedi PAL y veo la imagen en blanco y negro y un poco mal en la parte alta,la cámara seria esta.
http://es.aliexpress.com/item/wire-wire ... 50593.html
A ver si el coche acepta NTSC en vez de PAL.... he mirado por foros y gente monta la Ampire que pone que es NTSC,la que pone todo el mundo no me queda claro que sea PAL realmente y tal vez sea NTSC también.
A ver si alguien me puede aclarar algo no vaya a ser que pida otra y este en las mismas.
Kaisen
Agradecido: 380 veces
Notapor jliriz el 05 May 2015, 20:21
Intenta probar en tu coche la camara de alguien que le funcione en color para salir de dudas.
Seat Leon Sc 1.6 TDI 105cv DSG Style-Itech con Faros Full Led, Techo Panorámico, Navegador, Control de velocidad con radar y asistente de frenada, Safety Pack, Alarma Volumétrica, Sensores de aparcamiento delanteros y traseros + OPS + Cámara, Cristales tintados y Rueda repuesto minimizada 16".
Febrero'15.
jliriz
Agradecido: 113 veces
Notapor dahersol el 06 May 2015, 10:20
Mi cámara aunque en la web ponga NTCS luego en la caja indica que acepta los dos formatos Pal y Ntcs. Además casi todos se han puesto Pal. Si tu cámara provando en una tv se ve a color yo revisaria bien las soltaduras a ver di hay algo haciendo un contacto que no deba o incluso el cable RCA.
Suerte.
dahersol
Agradecido: 44 veces
Notapor calafat el 06 May 2015, 15:28
Yo cuando tuve un problema de conexión al positivo de arriba del portón, fuí probando donde fallaba. Y lo hice con una cámara digital, y al lado de la guantera se veía en blanco y negro. Detrás también. Fué encontrar el fallo de conexión y la cámara del coche se veía en color en su lugar de instalación. Con eso quiero decir que dependerá de la cámara creo, no de la conexión ya que lo que me pasó a mí lo deja claro, una cámara en B/N y la del coche en color en el mismo sitio.
calafat
Agradecido: 22 veces
Notapor Kaisen el 06 May 2015, 20:35
calafat escribió:Yo cuando tuve un problema de conexión al positivo de arriba del portón, fuí probando donde fallaba. Y lo hice con una cámara digital, y al lado de la guantera se veía en blanco y negro. Detrás también. Fué encontrar el fallo de conexión y la cámara del coche se veía en color en su lugar de instalación. Con eso quiero decir que dependerá de la cámara creo, no de la conexión ya que lo que me pasó a mí lo deja claro, una cámara en B/N y la del coche en color en el mismo sitio.
¿Pero la cámara digital que usabas era en color y se veía en blanco y negro?
Yo he conseguido una cámara de video digital para hacer pruebas,a ver si se ve bien con esta,la masa la tengo cogida del propio tornillo de masa del maletero lado izquierdo y el positivo del mechero (que por cierto al poner el duplicador de fusible no cierra la tapa del portaobjetos porque tiene una pestaña que justo pilla esa zona) tuve que cambiarlo al del limpia trasero que esta algo mas bajo.
El cable de señal es raro que este mal porque lo probe y estaba bien antes de meterlo,le puse cinta de tela a todos los cables en todo su recorrido,no creo que afecte en nada al de señal,no?
Este finde intentare hacer pruebas a ver que pasa con la otra cámara,lo raro es que gente monte la NTSC y se vea bien porque esa cámara Ampire pone claramente que es NTSC,a ver si doy con el fallo :shock:
http://www.ampire.de/Parking-Solutions/ ... 06&p=23206
Kaisen
Notapor calafat el 06 May 2015, 21:55
Kaisen escribió:¿Pero la cámara digital que usabas era en color y se veía en blanco y negro?
Claro, si fuera blanco y negro y me saca la imagen en color ya sería la ostia!
calafat
Notapor Kaisen el 06 May 2015, 22:13
A ver si entiendo bien,la cámara digital es en color pero se veía en blanco y negro,localizaste algún fallo y ya se vio en color? o esa cámara siempre se vio en blanco y negro y la del coche es la que se vio en color?
¿Sabes si esa cámara digital eral PAL?
No se como estos chinos no marcan si es PAL o NTSC,vaya tela marinera.... :maruja: el chino me dice que es PAL pero vete a saber....
Kaisen
Notapor calafat el 06 May 2015, 23:24
Kaisen escribió:A ver si entiendo bien,la cámara digital es en color pero se veía en blanco y negro,localizaste algún fallo y ya se vio en color? o esa cámara siempre se vio en blanco y negro y la del coche es la que se vio en color?
Exacto, la digital nunca se vió a color, y la del coche sí.
Kaisen escribió:¿Sabes si esa cámara digital eral PAL?
Te lo miraré, ahora no la tengo a mano, cuando pueda te lo miro.
calafat
Notapor dasi658 el 07 May 2015, 16:40
dasi658 escribió:Esta es mi codificación, el problema es que no se me vuelve transparente el ops pasados unos segundos.¿Alguien sabe cual puede ser el motivo?Saludos
dasi658
Coche: Leon MK3 1.4 TSI 122cv
Agradecido: 37 veces
Notapor dasi658 el 07 May 2015, 18:12
Buenas no consigo averiguar el motivo pero no se me pone el ops en transparente. Primero está en gris los botones y luego a los pocos segundos cuando se supone que cambia a transparente los iconos de la derecha desaparecen y el ops en la izquierda se queda con el fondo y las teclas en negro tapando media pantalla en vez de transparente . Lo que e conseguido es quitar el ops y sale la cámara entera y los pitidos de los sensores pero ahí cuando quito marcha atrás se queda un par de segundos en negro hasta que aparece lo que teníamos anteriormente Y con el ops activado no me pasa quito la marcha y sale el dibujo del ops en grande y seguidamente pasa a la pantalla anterior. Saludos y gracias a todos.
dasi658
Notapor larax el 08 May 2015, 12:15
Me acabo de registrar y acabo de ver este pedazo brico. La boca agua.
Estoy esperando mi Leon, sabeis si esto mismo se puede realizar en la otra pantalla que es un poco mas pequeña de 5 pulgadas tambien a color?
Un saludo a todos!
larax
Coche: Leon MK3 1.2 TSI 86cv
Agradecido: 16 veces
Notapor tokedj1989 el 08 May 2015, 13:53
larax escribió:Me acabo de registrar y acabo de ver este pedazo brico. La boca agua.
Un saludo a todos!
En el fis? La que hay entre el velocimetro y el cuentarevoluciones???? No creo que se pueda ahi pero seria un puntazo
tokedj1989
Coche: Leon MK3 1.2 TSI 105cv
Agradecido: 25 veces
Notapor pirly el 08 May 2015, 13:56
Un saludo a todos!
Si, lo único que las conexiones en lugar de estar en la guantera están detrás de la pantalla.
pirly
Agradecido: 304 veces
Notapor larax el 08 May 2015, 13:57
Un saludo a todos!
Hola, me referia a la pantalla "Media System Touch/Colour" que es de solo 5 pulgadas en vez de 5,8 como he visto a todos los que han realizado el brico. Es otra versión inferior de pantalla
Veo que ya me ha contestado otro compañero. Muchas gracias, mirare para hacerlo!
larax
Notapor ocsido el 08 May 2015, 15:21
pues sería un puntazo verlo en el fis...
SEAT LEON X-PERIENCE 1.8 TSI 180CV
SEAT TOLEDO MK2 1.9 TDI 130CV
ocsido
Agradecido: 33 veces
