León Mk3 - Actualización infotainment
Favoritos: BADS, Daruma, ositoerik, dmesanun, YeSL, pocososinos, jasoriab, JaviMarquez, crujipoyo, Arkan7, Cristianibias, pepeiyo69, Angel J, Xaggy, edumachuca, abollao, -alberto-, Rickymax, ferre7, Pedritoleon, Rivesgti, Alleya, davidalba, Xiguito_Corito, craken, JDCLEONFR, nemura, danihd, cenkkaya, Kisszabo, castell_lkpg, pistoleromtb, Raulportela, Martelinko, albert_naga, Adrian Anton, Gravilhas75, chaiser, popez, ruli68, denniisg2000, LeonFR80bsv
Seguidores: kenny_fonseca, ncx, Lavadora, barris31, juancete, ivantxe, jesusFR, Hysteria, MaximusRoco, Manu1986, Jorge75016, davidbj, bIxu, miyobe, MORKAS, gorkansr, aironsam14, jramis, kimudj, Maikermx, Javizormo, gogua, Melonkid, Kikote8, danirodrigueze30, maxinew, aigort, carlosgzlez, corderazo, Lionxp, jande, Edu1589, msmdraven, Arkan7, inamarlo, edumachuca, Josepo79, lead, camamaleon, davidmd, carrasco13, clavelstreet, mikomiko, josele77, car212121, itz18, golf_1990, LeidenSpain, vecnte, Andy_G, csabafr2013, leonfr76, Trimmer, genialsoft, Enerts, leonfrrojito, Horus, paco_22_22, ruben88, Valerofr150, molvi_mabad, Pekee69, Dav2k6, IbiFR, il_munyo, craken, ruben91mad, papo-182, el_padrino, zeratul, kaiserssosse, lytry32.hc, sbarri, ghitus, DesmoSimon, ruli68, Mramos1985, tonielfilas, braulioT, davidalba, JaviMarquez, osjamil, egarense69, fexposru, Pedrost, Illan, chetelopez, juanacho21, cuenka16, pepeiyo69, VapaV, AlvaroPM13, balbu, juan7777, mams69, Helrique, Kike77, volkov, jluis, loeches, Tom70, Dconnect, Trivi83, MilleMiglia, linxes, sergi303, hector37, D83, quiquito30lv, ElFon, DALOFER17, davidap13, kigua, JOTTA, Senuto, jd_zuri, Alvi, damsolu, Leon pucelano, javi_archi, danihd, alcoleazgz, miguel23and, xarlio, jdieztec, mitxuni, Kisszabo, Gendos22, xexpir, canijo82, Brandenor, cenkkaya, kennit0, Chelazo, bertoco, benitogomez, carlosVACA, Peje, NOECUBI1, AAAJDA, trazas, martija, borjiguez, JoseXS, ferbarroso14, Wespa, Cloud_ganora, Berbe15, Valengti, Chrohu, Atajunen, Victorzabal, jrm82, carlo13, iNFeCTeD, paralaxon, ateopoeta, pepo55, ribasxisco, Raulribarroja, ivanti, Jansel, lopezm0, Rubén Flp, Warelio, Vagabundo, Rekoba, Octacon, matiaso, Alianma, Raulportela, Éugen91, Rivesgti, Mcm90, DaniR86, Gravilhas75, JuanNur78, el_Asturiano, Mr.Chuflas, albert_naga, juanfrancia, Seket, algabe, pistoleromtb, ebcuatro, [GuErRa], Mario Leon, tito68
Re: Actualización infotainment
Notapor miceor el 01 Dic 2016, 11:22
Lo tienes todo en la pagina 41.
miceor
Agradecido: 1259 veces
Notapor csabafr2013 el 01 Dic 2016, 11:24
Gracias miceor aver si lo hago bien
csabafr2013
Notapor arlot el 01 Dic 2016, 11:33
miceor escribió:...Yo no perderia el tiempo con un USB. Las tarjetas de 8 Gb cuestan cuatro reales.
Reales? jeje esa es una expresión es muy muy antigua
Vamoooooooooooooos
arlot
Agradecido: 977 veces
Notapor JordS el 01 Dic 2016, 12:49
Buenas, tengo esta version pero en la pagina 41 no veo que haya actualizacion para mi version
Alguien podria decirme si puedo actualizar ?
JordS
Agradecido: 9 veces
Notapor Davido2790 el 01 Dic 2016, 13:17
He probado en la pantalla de 6,5" quitar el fallo (1555) con el método que decís y no hay manera...
Enviado desde mi Mi-4c mediante Tapatalk
Davido2790
Agradecido: 81 veces
Notapor miceor el 01 Dic 2016, 13:24
Si lo hace con Vag com deja un espacio entre los dos primeros digitos y los dos segundos XX XX
miceor
Notapor golf_1990 el 01 Dic 2016, 18:14
miceor escribió:Si lo hace con Vag com deja un espacio entre los dos primeros digitos y los dos segundos XX XX
Para los que nunca hemos usado vag com... es complicado hacer el escaner y borrar los fallos ? Borra todos de golpe o están por categorías ? :ayuda: :ayuda:
golf_1990
Notapor Pol el 01 Dic 2016, 21:53
Bueno, 6,5" actualizada con exito y borrados los fallos peeero.... me desapareció el mirrorlink. No lo uso, pero me gustaría solucionarlo. Leí que a otro usuario le pasó lo mismo. ¿ Se conoce alguna solución? Yo tenía el VIM desbloqueado y por si sirve de algo, la actualización a la versión beta la hice sin el contacto puesto.
Pol
Notapor miceor el 01 Dic 2016, 22:00
Entiendo que deberia solucionarse entrando en Modo Ingeniero y seguir los pasos del video hasta llegar a la opcion Mirrorlink.
Marcarla como activa y salir del modo ingeniero.
Resetear el infotainment y deberia de salir.
Aqui podeis ver los pasos en el video de Rojas.
https://www.youtube.com/watch?v=3NP_XStsTQg
Para entrar en modo ingeniero , usad el buscador.
miceor
Notapor Pol el 01 Dic 2016, 22:06
miceor escribió:Entiendo que deberia solucionarse entrando en Modo Ingeniero y seguir los pasos del video hasta llegar a la opcion Mirrorlink.
Mañana lo intento y comento si se soluciona.
Pol
Notapor Monilloxd el 02 Dic 2016, 09:06
miceor escribió:Perdón por la demora, pero se me ha ido de madre el tiempo de cocción.
Bueno, pues os pongo algunas actualizaciones QUE HE ENCONTRADO DE CASUALIDAD para Mib1 y Mib2.
Mib1 - Pantalla de 5.8"
Versión de la actualización : 0480 (Ultima versión compatible con el dispositivo)
Equipos compatibles con esta actualización : MIB 1GEN 5,8" con HW:041 FW:0425
Descargar el archivo desde:
Mega--- https://mega.nz/#!e9RzCbzC!cSZlpTtHBVJrc-oqXia5rFqUj0tbBxjvQujO2PhtrD4
Drive--- https://drive.google.com/open?id=0BxJGznK3NRXVRGRFWlJwaDhjNlU
Descomprimir el archivo. La estructura final debe quedar de la siguiente forma:
Carpeta: SEAT_NAV_SSB
Carpeta: SEAT_PLUS_SSB
Archivo: metainfo2.txt
Copiar las dos carpetas y el archivo en una tarjeta SD Class 10 de 8 GB (Si usais una tarjeta lenta, la actualización se puede eternizar, con la Class 10 tarda unos 40 minutos)
Mib2 - Pantalla de 6.5"
Versión de la actualización : 0330 (Beta) Instalar esta y luego la 0346. La 0330 es una Beta y tiene fallos conocidos (No asustaros si veis cosas raras) se solucionan actualizando a la 0346.
Equipos compatibles con estas actualizaciones : MIB 2GEN 6,5" HW:024 FW:0245
Mega--- https://mega.nz/#!GxgAkYSK!Ht3zUeOG03iamefZbC0pyMWMz8hQbhQWFweVvgxEE-U
Drive--- https://drive.google.com/open?id=0BxJGz ... mw0UHNfejg
Carpeta: powerc
Carpeta: mainplus
Carpeta: main
Carpeta: DUW014
Carpeta: DUW013
Carpeta: DUE410
Carpeta: DUE409
Carpeta: DUE406
Carpeta: DUE405
Carpeta: cpuplus
Carpeta: cpu
Carpeta: bluetooth
Copiar las carpetas y el archivo en una tarjeta SD Class 10 de 8 GB (Si usais una tarjeta lenta, la actualización se puede eternizar, con la Class 10 tarda unos 40 minutos)
Versión de la actualización : 0346 (Ultima versión compatible con el dispositivo)(Instalar previamente la 0330)
Equipos compatibles con estas actualizaciones : MIB 2GEN 6,5" HW:024 FW:0245 y logicamente HW:024 FW:0330 (Si existiese alguno)
Mega--- https://mega.nz/#!H0g3XbzC!OYwx6oPDZSHab_5Rl0iMUnfbPIQwv0fSb8sQU6hJtNk
Drive--- https://drive.google.com/open?id=0BxJGznK3NRXVTU1nbXN5UjlCbDA
Carpeta: powerc
Carpeta: mainplus
Carpeta: main
Carpeta: DUW070
Carpeta: DUW069
Carpeta: DUW013
Carpeta: DUW014
Carpeta: DUE410
Carpeta: DUE409
Carpeta: DUE406
Carpeta: DUE405
Carpeta: cpuplus
Carpeta: cpu
Carpeta: bluetooth
Método de actualización MIB1 5.8"
COMPROBADO Y CON SOLUCIÓN A LOS ERRORES PRESENTADOS
1) Utilizar una SD de 8GB como mínimo y a poder ser Class 10 (Es mucho más rápida)
2) Formatear la tarjeta SD en FAT32
3) Copiar los datos en la tarjeta SD (Todas las carpetas y el archivo TXT deben quedar en el raiz de la tarjeta)
4) Introducir la tarjeta SD en el Alojamiento SD1 del reproductor de la guantera.
5) Poner el contacto del coche (No arrancar el motor bajo ningún concepto ni apagar el Infotainment)
6) Presionar el botón Menú del Infotainment y mantener pulsado hasta que salga el menú de servicio.
7) Seleccionar Actualización SW y pulsar en Actualizar.
8) Esperar a que el sistema nos dé un mensaje de Actualización Realizada y confirmamos.
9) Conectamos el dispositivo de diagnosis (Vagcom, OBDeleven, etc) y hacemos un Scan.
10) Borramos todos los fallos.
ERRORES QUE NO SE BORRAN AL BORRAR FALLOS
1) Normalmente después de las actualizaciones hay que validar el SVM (Software Version Manager)
El sistema arrojará un error : 1555 - Check Software Version Management que es permanente y no se borra.
Para solucionarlo seguir estos pasos del video de @Morkas : https://www.youtube.com/watch?v=wuo_oR6nbeM
Una vez realizado, resetear el infotainment y volver a hacer el Scan y borrar el fallo definitivamente.
2) Error Reproductor de media en posición 1 no hay comunicacion. Se puede quitar el error siguiendo estos pasos descritos por el Compañero @Destino :
con obdeleven ->interfaz diagnóstico de datos 19->adaptación->lista de montaje montaje teórico y ahí desactivas el reproductor media 1.
Luego borrar el fallo indefinidamente.
Método de actualización MIB2 6.5"
COMPROBADO Y CON SOLUCIÓN A LOS ERRORES PRESENTADOS QUEDANDO PENDIENTE UN CASO CON LA DESAPARICION DEL MIRRORLINK EN PANTALLA
Hemos detectado al menos un caso en el que después de actualizar el Mirrorlink ha desaparecido de la pantalla.
Estamos investigando cuando se produce y como reactivarlo.
Como ya se ha explicado, para actualizar la MIB2 desde la 0245 hasta la 0346 hay que actualizar previamente a la 0330.
Por tanto, realizar primero la 0330 siguiendo todos los pasos descritos aqui abajo y luego la 0346 y otra vez los mismos pasos y evitaremos sorpresas desagradables.
Las actualizaciones vienen tardando en torno a los 40 minutos cada una si la tarjeta SD es Class 10, en tarjetas mas antiguas tardará bastante más.
IMPORTANTE
Si al intentar actualizar te da error de datos, algo has hecho mal. Formatea de nuevo la tarjeta o cambia de tarjeta.
Durante la actualización:
No quitar el contacto del coche, ni apagar el Infotainment.
No arrancar el motor durante la Actualización.
Si consideras que no quieres arriesgarte a quedarte bajo de bateria, conecta un cargador de bateria antes de iniciar el proceso y mantenlo encendido
hasta que finalice.
Ojo a como conectais el cargador: Positivo del cargador al borne positivo de la bateria y pinza negativa del cargador a la pletina que hay encima de la bateria atornillada al chasis (NO CONECTAR AL BORNE NEGATIVO O TE CARGAS EL CONTROLADOR DE CARGA DE LA BATERIA)
No me hago responsable del mal uso de estos archivos, cada cual que considere si quiere, si debe realizar las actualizaciones bajo su responsabilidad.
Todo está explicado:
Miras tu versión en tu infotainment y miras en este post si es compatible con las actualizaciones.
Las descargas van a estar disponibles durante un tiempo prudencial, el suficiente para que se puedan descargar con tranquilidad y no tenga sentido comerciar con ellas.
Aquellos que hagais las actualizaciones podeis reportar los cambios apreciables, rapidez, comportamiento, solución de errores anteriores, etc, etc para que sirvan de guia a los que vengan empujando.
Este post se irá actualizando con los resultados que vayamos obteniendo y las soluciones que se encuentren en cada caso.
Buenos días!!
Lo primero agradecerte el trabajo realizado! de pm! ahora te cuento, me he leido todo y no veo lo que voy a preguntar, mi navegador 5.8" del año 2013 tiene versión de hardware 039 y de soft 0132 podria meterle la actualización que has publicado??
Muchas gracias!!
Monilloxd
Agradecido: 10 veces
Notapor miceor el 02 Dic 2016, 09:51
Me temo que no
miceor
Notapor JUANILLO101976 el 02 Dic 2016, 13:31
Me lo podéis calcular código para borrarlo vag con el código que tengo es 12 99
JUANILLO101976
Notapor miceor el 02 Dic 2016, 13:35
El codigo es DB 4B
Última edición por miceor el 02 Dic 2016, 13:46, editado 1 vez en total
miceor
Notapor JUANILLO101976 el 02 Dic 2016, 13:38
Lo he metido vag con y no me deja borrarlo que hago
JUANILLO101976
