Metelo con un espacio entre medias. XX XX.
Luego acepta y borra los fallos.
SAludos
León Mk3 - Actualización infotainment
- Seguidores: 188
- Favoritos: 42
- Vistas: 660.740
Favoritos: BADS, Daruma, ositoerik, dmesanun, YeSL, pocososinos, jasoriab, JaviMarquez, crujipoyo, Arkan7, Cristianibias, pepeiyo69, Angel J, Xaggy, edumachuca, abollao, -alberto-, Rickymax, ferre7, Pedritoleon, Rivesgti, Alleya, davidalba, Xiguito_Corito, craken, JDCLEONFR, nemura, danihd, cenkkaya, Kisszabo, castell_lkpg, pistoleromtb, Raulportela, Martelinko, albert_naga, Adrian Anton, Gravilhas75, chaiser, popez, ruli68, denniisg2000, LeonFR80bsv
Seguidores: kenny_fonseca, ncx, Lavadora, barris31, juancete, ivantxe, jesusFR, Hysteria, MaximusRoco, Manu1986, Jorge75016, davidbj, bIxu, miyobe, MORKAS, gorkansr, aironsam14, jramis, kimudj, Maikermx, Javizormo, gogua, Melonkid, Kikote8, danirodrigueze30, maxinew, aigort, carlosgzlez, corderazo, Lionxp, jande, Edu1589, msmdraven, Arkan7, inamarlo, edumachuca, Josepo79, lead, camamaleon, davidmd, carrasco13, clavelstreet, mikomiko, josele77, car212121, itz18, golf_1990, LeidenSpain, vecnte, Andy_G, csabafr2013, leonfr76, Trimmer, genialsoft, Enerts, leonfrrojito, Horus, paco_22_22, ruben88, Valerofr150, molvi_mabad, Pekee69, Dav2k6, IbiFR, il_munyo, craken, ruben91mad, papo-182, el_padrino, zeratul, kaiserssosse, lytry32.hc, sbarri, ghitus, DesmoSimon, ruli68, Mramos1985, tonielfilas, braulioT, davidalba, JaviMarquez, osjamil, egarense69, fexposru, Pedrost, Illan, chetelopez, juanacho21, cuenka16, pepeiyo69, VapaV, AlvaroPM13, balbu, juan7777, mams69, Helrique, Kike77, volkov, jluis, loeches, Tom70, Dconnect, Trivi83, MilleMiglia, linxes, sergi303, hector37, D83, quiquito30lv, ElFon, DALOFER17, davidap13, kigua, JOTTA, Senuto, jd_zuri, Alvi, damsolu, Leon pucelano, javi_archi, danihd, alcoleazgz, miguel23and, xarlio, jdieztec, mitxuni, Kisszabo, Gendos22, xexpir, canijo82, Brandenor, cenkkaya, kennit0, Chelazo, bertoco, benitogomez, carlosVACA, Peje, NOECUBI1, AAAJDA, trazas, martija, borjiguez, JoseXS, ferbarroso14, Wespa, Cloud_ganora, Berbe15, Valengti, Chrohu, Atajunen, Victorzabal, jrm82, carlo13, iNFeCTeD, paralaxon, ateopoeta, pepo55, ribasxisco, Raulribarroja, ivanti, Jansel, lopezm0, Rubén Flp, Warelio, Vagabundo, Rekoba, Octacon, matiaso, Alianma, Raulportela, Éugen91, Rivesgti, Mcm90, DaniR86, Gravilhas75, JuanNur78, el_Asturiano, Mr.Chuflas, albert_naga, juanfrancia, Seket, algabe, pistoleromtb, ebcuatro, [GuErRa], Mario Leon, tito68
Re: Actualización infotainment
miceor - Leoner@ mayor del reino
- Agradecido: 1259 veces
Lo he hecho y me pone error mi vag con es 16.8
JUANILLO101976 - Aun con la L
- Agradecido: 10 veces
Me puedes ayudar gracias
Tienes un MP
Hola miceor yo tengo esta versión que me dices vale la pena actualizar me funciona bien y tiene mirrolink
csabafr2013 - Asidu@ en la selva
- Agradecido: 13 veces
JUANILLO101976 escribió:Lo he hecho y me pone error mi vag con es 16.8
Segundo caso que conozco que no le va con un 16.8
Mira a ver si encuentras a alguien con otra versión de VagCom o VCP u OBDeleven cerca de tu zona...
- Agradecido: 3613 veces
Ya está solucionado.
Fué un error mio al escribir con el movil y se me coló una letra antes de tiempo.
Pol escribió:miceor escribió:Entiendo que deberia solucionarse entrando en Modo Ingeniero y seguir los pasos del video hasta llegar a la opcion Mirrorlink.
Marcarla como activa y salir del modo ingeniero.
Resetear el infotainment y deberia de salir.
Aqui podeis ver los pasos en el video de Rojas.
https://www.youtube.com/watch?v=3NP_XStsTQg
Para entrar en modo ingeniero , usad el buscador.
Mañana lo intento y comento si se soluciona.
Nada... activo el mirrorlink en el modo ingeniero, reseteo pero al volver al modo ingeniero veo que no está marcado como activo.
Pol - Aun con la L
- Agradecido: 12 veces
Pol escribió:Pol escribió:miceor escribió:Entiendo que deberia solucionarse entrando en Modo Ingeniero y seguir los pasos del video hasta llegar a la opcion Mirrorlink.
Yo lo he probado hace un rato también y me pasa lo mismo que a tí.
Lo que no puedo probar es a conectar directamente un móvil con mirrorlink ya q mi móvil no es compatible, pero lo mismo conectándolo funciona aunque no salga el menú...
Sent from my Nexus 5 using Tapatalk
tevaadarelsol - Aqui + que con la novi@
- Agradecido: 200 veces
No, tengo un z2 que conectaba y ahora sólo puedo con Android auto
Pol - Aun con la L
Yo no puedo probar porque a mi me apareció desde el primer momento, al tenerlo operativo no puedo realizar pruebas para determinar cual es la activación, sin embargo he visto que @Rojas ha subido un video que muestra como se activa partiendo de la pantallla con Android Auto y Carplay igual que la captura que puso el primero al que le pasó.
Podeis verlo aqui : https://www.youtube.com/watch?v=gtr4uSaFDYY
Igual @Rojas puede explicarnos alguna cosa al respecto.
Pues esperemos, me ha pasado lo mismo, con vim desbloqueado
corderazo - Primeros Pasos
golf_1990 - Asidu@ en la selva
La otra opción, como ya dije en su momento:
Por tanto yo haría lo siguiente:
Con OBDeleven :
Modulo 5F
- Vehicle configuration -- Opciones
----- Mirror_link -- (Function off_HMI off - Fucntion on_HMI on - Function on_HMI off)
Yo lo tengo en Function off_HMI off
Si no os deja cambiarlo, entrad a Cambiar sesión dentro de la 5F y elegid Modo desarrollador y hacedlo como desarrolladores.
Asi deberia funcionar.
Con VAgCom
Modulo 5F
Adaptations menu
Vehicle Configuration
Buscar Mirrorlink y cambiar el valor de 0 a 1
En VagCom no sé si me he saltado algo, lo estoy poniendo de memoria(Poned los pasos si lo haceis alguno)
Reportad resultados
miceor escribió:Cristianibias escribió:Bueno despues de actualizarlo todo ha salido bien lo unico que me ha desaparecido la opcion de conectar por mirrolink si alguien puede echarme una mano
He estado dandole vueltas al tema de que desaparezca el Mirrorlink en al menos un caso que conocemos.
Me gustaria saber si antes de la actualización llevaba el VIM+Mirrorlink desactivado, no sea que al llevarlo así la actualización interprete que no está disponible y lo deja fuera.
Se me ocurre probar en ese caso en concreto a entrar en el menú de ingeniero y Activarlo desde el menú y ver que ocurre. Si lo haces, luego salte del menú de ingeniero y reinicia el infotainment a ver si aparece de nuevo el Mirrorlink.
Tambien puedes comprobar estos valores:
En la 5F, entra en Vehicle configuration y abajo del todo mira esto -----Mirror_link -- (Function off_HMI off).
Si lo cambias de valor, Reinicia el Infotainment.
Comprueba que esté como se indica.
Con OBDeleven :
Modulo 5F
Con VAgCom
Modulo 5F
Adaptations menu
Reportad resultados
Incidencias varias nuevo Seat Leon Foro: Leon IV - Mecánica / Electricidad / Electrónica Autor: ma.cantero Respuestas: 364 |
Pastillas freno Seat León 1,5Tsi FR 130cv Foro: Leon IV - Mecánica / Electricidad / Electrónica Autor: Ervijandro Respuestas: 10 |
Seat León 5F – Fallo del aire acondicionado/ven Foro: Leon III - Mecánica / Electricidad / Electrónica Autor: Babytricks Respuestas: 0 |
Nuevo Leon en el foro Foro: Presentaciones Autor: tony_mlg Respuestas: 5 |
Hilo del León mkIV e-hybrid Foro: General Autor: vkr84 Respuestas: 667 |
