León Mk3 - BRICO - Como instalar la cámara de parking
- Seguidores: 136
- Favoritos: 46
- Vistas: 603.583
Favoritos: JaviCG, Vampiro, J@VY, BADS, Daruma, cstrol, JorgeAnteloC, ipenalosa, MONTY DAKA, pirly, josele887, xurox, Nanox23, Carbono79, vallter, norchugo, Efremvidal, @turbina@, blankiblau, jorgee76, jliriz, Vilo, cuenxis, victir, Aras, Korath, Rasekfighter, Carrl, jdieztec, J-Frass, Tarzan, zacarias, Frannisesabe, Xperience, bronce702, sbarri, javieret69, Carlos Chea, Lotar, Alleya, miguelorly, craken, chemazz, xico, eMi1, Maverick.es
Seguidores: Linker89, car212121, franrx, davidalba, TRIBO, danieleon, Panchorin, Hecson.27, jmfcoto, aironsam14, JOTTA, MORKAS, Unaited, trekam, xandis, Jorge75016, Platanot, davidbj, Achehmg, marc.domenech.90, sadanyac, seat leon blanco, Marc.22, Peuero, er_trompe, GTI35, JoseCa, JaviCG, vigimuertos, rabazas, B.Fox, msmdraven, Tomcat7733, Txutxiysilvia, xabidh, cstrol, Carrl, El3ndil, yorky, bolche, LeoST, Diegokero, Rasekfighter, Budoka, IronTor21, marlop, xico, vanscampa, Tarzan, jorgee76, josemag, aigort, LuichiFR, SLon34, clavelstreet, nani_san, nyro, IVANIN9, rober1095, ivan0909, jose.jjg307, csabafr2013, P.carrizo.leonstfr, dookky, Edu1589, Dconnect, D83, Jeii90, inamarlo, Israel-FR, Herrdoktor, el_padrino, Kipu, aguscalderon, lebowski, juanmaroger, bailyibz, naikon_paul, Valerofr150, JAL, kennit0, Mramos1985, bronce702, kijute, juanmik, osjamil, Tonivn, Lotar, Tunnig, JaviMarquez, nitro_g4074, sergi303, ivan2017, Chema_Alvarez, ilargiman, jaumotix, sbarri, javierferriz, alcoleazgz, lecupra280, Colomer, Maikermx, luigi323, rents_80, jdiego75, Pedrost, damsolu, lead, Franr50, Dani2025, Leon pucelano, nachomart, castronight, victor david, bertoco, juan7777, Josep20, jakobitto, rr7mo, a.cuadros71, iNFeCTeD, Gendos22, VapaV, Chrohu, Ganyula, snowpluralism, victor_leon_FR, luaiabou96, Drovniak, Guillen222, leonfrrojito, justics, lopezm0, Romera, pedrorossello92, AlvaroRamlo
Re: BRICO como instalar la Camara de parking en Seat leon MK
Opsss, fallo! No se encuentra el archivo!!
RuJe - Asidu@ en la selva
- Agradecido: 27 veces
Vale, esto ya me imagino que habras mirado tu @rojas y habras visto que no se ve nada de lo que se busca, ahora, si se saca el mapa de un coche que si tenga la camara de serie con el mismo navi, un golf 7 o un skoda?? No se que modelos lo traeran de serie y no se como funciona elsa asiq alumbrarme y seguiremos buscando
Hay muchos pines vacios en los que no marca ni que posibilidades tienen
Cuando pienses que estas al limite, estaras a un 50% de llegar al mismo.
IvanMc2 - Leoner@ habitual
- Agradecido: 129 veces
RuJe escribió:Opsss, fallo! No se encuentra el archivo!!
A mi me abre el pdf estupendamente en varios equipos ... vuelve a intentarlo , ahi esta todo el pineado y conexiones del easy connect en guantera
si te gusta ... agradece el post !!
rojas - Gurú de los leones
- Agradecido: 1888 veces
Toma, mira a ver si puedes desde aki
https://www.dropbox.com/s/pwsvwa4f7f1hy ... .docx?dl=0
Si no dejame tu correo por mp
Otra cámara instalada. Formato NTSC y codificada la intensidad del piloto trasero izquierdo.
Ah! Y esta vez en un golf
https://www.dropbox.com/s/o3w3486rw64ly ... 0.jpg?dl=0
zamapo - Aun con la L
- Coche: Otro modelo SEAT
Martín st escribió:Buenas, a mi me quedo asín la que va en el centro del vehículo
Hola! Te queda genial! Me podrías decir el modelo de cámara que compraste y donde la compraste? Si tienes a mano el listado de las demás cosas que necesitas te para hacer el bricolaje tampoco estaría mal que la pusieras!
musisol - Nuev@ por aqui
Buenas!! Este finde he podido hacer este brico y el del seat sound system... al final el +12v lo queria sacar del mechero pero me ayudo un colega que es mecanico y al final lo puso justo debajo de la guantera hay una tapa con 3 tornillos y una grapa de plastico... pues sacó esa tapa y esta el positivo del ventilador del aire... pues ahy lo pusimos y durante todo el finde ha ido perfecto ni un problema.
El unico problema que veo es que me sale la imagen de los sensores en negro y me ocupa la mitad... y hay que ocultarla para que se vea bien la cam... hay alguna opcion para que salga transparente como a @rojas ?? ya que tambien he leido por aqui que a los pocos segundo se transparenta... pero no es mi caso... alguna ayuda?
Gracias de nuevo @rojas por tu trabajo
Monilloxd - Primeros Pasos
- Agradecido: 10 veces
Buenas tardes.
Después del palizón de leerme todos los comentarios (57 páginas), me queda una duda. La cámara tiene que ser en formato NTSC, pero todos los enlaces han caducado.
Alguién que los tenga, o sepa donde están. Me refiero a las cámaras que van en el hueco de la luz de la matrícula y con las líneas de refencia.
Gracias, un saludo.
Gracias, un saludo.
- Agradecido: 269 veces
Stealnick escribió:Buenas tardes.
Gracias, un saludo.
Creo que esta es la que monto rojas.
http://www.ebay.es/itm/Coche-camara-de- ... 5418d0d464
- Agradecido: 380 veces
No me queda claro de cuanto es el condensador... paginas atrás he visto que alguien decía 10000mF osea 10F lo cual lo veo muy grande y otros dicen 10000uF lo que serían 10mF ¿Cual es de los dos?
davicinn - Leoner@ habitual
- Agradecido: 65 veces
Yo puse 2 de 2000uF uno en la entrada activadora del rele y el otro a la salida y antes de montar rele puse uno de 2000uF conectado a positivo y negativo de la camara
Chicos una pregunta, tengo la instalación de la cámara hecha con todas las conexiones, la codificación como el resto de compañeros pero cuando engrano la marcha atrás la pantalla no hace nada, se queda tal cual. Llevo toda la tarde intentándolo y no lo consigo. Alguien que me pueda ayudar poorfa!!
Tengo instalada la pantalla media system touch colour de 5 pulgadas.
josele887 - Primeros Pasos
- Agradecido: 7 veces
Muchas gracias compañero! Más que nada era saber el orden de magnitud de la capacidad.
Gracias y saludos!
Encuesta - Que tipo de Gasoil utilizais Foro: General Autor: pirly Respuestas: 291 |
Cupra leon VZ 300 restyling Foro: General Autor: Artichoke Respuestas: 1 |
León Mk4 - Actualización mapas MIB3 SEAT 2021 Foro: AudioCar y MultimediaCar Autor: jasoriab Respuestas: 122 |
el leon tdi 150cv tiene estabilizadora atras o no?? Foro: Leon I - Mecánica / Electricidad / Electrónica Autor: cordobitax Respuestas: 4 |
