León Mk3 - Actualización infotainment
Seguidores: kenny_fonseca, ncx, Lavadora, juancete, jesusFR, Hysteria, MaximusRoco, Manu1986, Jorge75016, davidbj, bIxu, miyobe, MORKAS, aironsam14, jramis, kimudj, Maikermx, Javizormo, gogua, Melonkid, Kikote8, maxinew, aigort, carlosgzlez, corderazo, Lionxp, jande, Edu1589, msmdraven, Arkan7, jeroc, inamarlo, edumachuca, Josepo79, lead, camamaleon, davidmd, carrasco13, clavelstreet, mikomiko, josele77, car212121, itz18, golf_1990, LeidenSpain, vecnte, Andy_G, csabafr2013, leonfr76, Trimmer, genialsoft, Enerts, leonfrrojito, Horus, paco_22_22, ruben88, Valerofr150, molvi_mabad, Pekee69, Dav2k6, IbiFR, il_munyo, craken, ruben91mad, papo-182, el_padrino, zeratul, kaiserssosse, lytry32.hc, sbarri, ghitus, DesmoSimon, ruli68, Mramos1985, tonielfilas, braulioT, davidalba, JaviMarquez, osjamil, egarense69, fexposru, Pedrost, Illan, chetelopez, juanacho21, cuenka16, pepeiyo69, VapaV, balbu, juan7777, mams69, Helrique, Kike77, volkov, jluis, loeches, Tom70, Dconnect, Trivi83, MilleMiglia, linxes, sergi303, hector37, D83, quiquito30lv, ElFon, DALOFER17, davidap13, kigua, JOTTA, Senuto, jd_zuri, Alvi, damsolu, Leon pucelano, javi_archi, danihd, alcoleazgz, miguel23and, xarlio, jdieztec, mitxuni, Kisszabo, Gendos22, xexpir, canijo82, Brandenor, cenkkaya, kennit0, Chelazo, bertoco, benitogomez, carlosVACA, Peje, NOECUBI1, AAAJDA, trazas, martija, borjiguez, JoseXS, ferbarroso14, Wespa, Cloud_ganora, Berbe15, Valengti, Chrohu, Atajunen, Victorzabal, jrm82, carlo13, iNFeCTeD, paralaxon, ateopoeta, pepo55, ribasxisco, Raulribarroja, ivanti, lopezm0, Rubén Flp, Warelio, Vagabundo, Rekoba, Octacon, matiaso, Alianma, Raulportela, Éugen91, Rivesgti, Mcm90, DaniR86, Gravilhas75, JuanNur78, el_Asturiano, Mr.Chuflas, albert_naga, juanfrancia, Seket, algabe, pistoleromtb, ebcuatro, [GuErRa], Mario Leon, tito68
Re: Actualización infotainment
Notapor craken el 17 Ago 2019, 23:41
CarlosTSi escribió:Hoy me han actualizado el software en VAG Retrofits. Ahora ya va muy bien el teléfono, antes tenía problemas (no se conectaba, había problemas con Android Auto....), ahora ya va bien. Aquí tenéis foto es la versión 1409
Me encanta leer bien de VAG Retrofits. Porque sé que en un futuro me encantaría reequipar el Leon con algo del estilo de navegador GPS y tal… y me gustaría poder tener la confianza suficiente para recurrir a ellos.
5QA035824A H30 0359
¿Afectado por los Reinicios del sistema infotainment?
Yo también, visita el siguiente enlace para más información:
https://www.clubseatleon.net/viewtopic.php?f=9&t=125535
craken
Agradecido: 31 veces
Notapor balfer1973 el 18 Ago 2019, 12:02
hola a todos.
no tengo ni idea de como cambiar el software de mi león, aunque haya leído prácticamente todo el hilo,
¿es posible hacerlo mediante usb o sd?
Numero de pieza 5QA035874
Hardware H41
Software 0472
gracias.
balfer1973
Notapor cvillajos el 18 Ago 2019, 13:16
balfer1973 escribió:hola a todos.
Hardware H41
Software 0472
gracias.
Te habrás saltado la página 41 :si: porque ahí está toda la información necesaria para las HW/SW de las que se tiene (por aquí) actualización.
cvillajos
Agradecido: 3572 veces
Notapor jasoriab el 18 Ago 2019, 13:50
Hardware H41
Software 0472
gracias.
Para la H41 no hay nada disponible de forma pública, tienes que pasar por el concesionario sí o sí. Lee las últimas páginas del hilo, donde cuento mi experiencia con una unidad similar.
De todas formas, la tienes prácticamente a la última, la última versión para esa unidad de la que tengamos conocimiento es la 0475.
En este mensaje, jasoriab ha recibido un agradecimiento de:
balfer1973 (19 Ago 2019, 22:03)
jasoriab
Agradecido: 2019 veces
Notapor balfer1973 el 19 Ago 2019, 22:04
Hardware H41
Software 0472
gracias.
balfer1973
Notapor ferbarroso14 el 20 Ago 2019, 17:30
Buenos días,
Me he comprado un León 2019 y el infotainment me va bastante lento. ¿Sabéis cuál es la última versión de firmware que hay disponible? Igual es que no está actualizada...
A vosotros os va lento?
Gracias!
ferbarroso14
Notapor jasoriab el 21 Ago 2019, 08:38
ferbarroso14 escribió:Buenos días,
Gracias!
Hola @ferbarroso14 lo primero bienvenido al foro.
Si el coche es nuevo, deberías pasar por el concesionario e informar de ello, ya que podría ser un problema de la unidad infotainment que han montado en tu coche. La garantía está para eso.
Por otro lado, en función de la opción escogida, hay distintos modelos de unidades, cada una con sus versiones de HW y SW diferentes. Habría que saber la referencia de tu unidad.
Dicha información es accesible a través del icono de ajustes (el de las ruedas dentadas)/Información del sistema. Ahí aparecerá la referencia de tu unidad, así como las versiones hardware y software de ella.
jasoriab
Notapor ferbarroso14 el 21 Ago 2019, 19:22
Gracias!
Gracias por la bienvenida.
El número de pieza del dispositivo es: 5F0035877
Hardware: H50
Software: 0514
Enviado desde mi GM1913 mediante Tapatalk
ferbarroso14
Notapor jasoriab el 22 Ago 2019, 09:51
Gracias!
Hardware: H50
Software: 0514
Para ese H50 nadie ha informado que le haya llegado una versión superior del software de la 0514 que monta tu unidad. Antes salían con la 0512, pero desde hace unos meses, vienen con la 0514.
De todas formas, en el concesionario pueden comprobar si hay alguna nueva versión de software aplicable para ella, aunque normalmente son bastantes reacios a actualizar, tal como se ha explicado numerosamente en este hilo. Pero si está en garantía, y puedes demostrarles que va lento (comparando con otro coche que tengan allí con similar unidad de guantera) te lo tendrían que solucionar.
Por cierto, y adelantándome a una posible cuestión, la referencia que tienes no es compatible con los POIs personalizados, como los que subimos de radares al foro. La explicación está en el hilo al respecto.
jasoriab
Notapor carlo13 el 25 Ago 2019, 18:06
muy buenas yo me acabo de pillar mi leoncete pero no tengo ni idea de si esta actualizado o no esta es la version que tengo.
https://ibb.co/FmDsG3d
carlo13
Agradecido: 9 veces
Notapor jramis el 26 Ago 2019, 08:06
carlo13 escribió:muy buenas yo me acabo de pillar mi leoncete pero no tengo ni idea de si esta actualizado o no esta es la version que tengo.
Sólo tienes que leer unos milímetros más arriba...
Mi fiera: http://www.clubseatleon.net/viewtopic.php?f=43&t=113244
En este mensaje, jramis ha recibido un agradecimiento de:
jasoriab (26 Ago 2019, 08:27)
jramis
Agradecido: 16 veces
Notapor bojlihal el 27 Ago 2019, 16:15
Hola ,
Tengo un auto Leon X-perience 2015 con 6,5 "y esta información y entretenimiento
Como lo sé, es una versión MIB 2 High.
Alguien sabe si hay una actualización para esta versión y puede compartir conmigo?
Gracias!
bojlihal
Notapor ivanti el 02 Sep 2019, 21:31
Hace 2 meses que tengo un León y me pregunto si es normal estas lineas en la pantalla cuando está apagada
ivanti
Notapor tevaadarelsol el 02 Sep 2019, 22:02
ivanti escribió:Hola,
Sí, son normales, el fondo es así
Enviado desde mi ONEPLUS A6003 mediante Tapatalk
tevaadarelsol
Agradecido: 199 veces
Notapor ivanti el 02 Sep 2019, 22:21
Ok gracias. Parece que la pantalla tenga un problema
ivanti
Usuarios navegando por este Foro: No hay usuarios registrados visitando el Foro y 12 invitados
