León Mk3 - Actualización infotainment
Favoritos: BADS, Daruma, ositoerik, dmesanun, YeSL, pocososinos, jasoriab, JaviMarquez, crujipoyo, Arkan7, Cristianibias, pepeiyo69, Angel J, Xaggy, edumachuca, abollao, -alberto-, Rickymax, ferre7, Pedritoleon, Rivesgti, Alleya, davidalba, Xiguito_Corito, craken, JDCLEONFR, nemura, danihd, cenkkaya, Kisszabo, castell_lkpg, pistoleromtb, Raulportela, Martelinko, albert_naga, Adrian Anton, Gravilhas75, chaiser, popez, ruli68, denniisg2000
Seguidores: kenny_fonseca, ncx, Lavadora, juancete, jesusFR, Hysteria, MaximusRoco, Manu1986, Jorge75016, davidbj, bIxu, miyobe, MORKAS, aironsam14, jramis, kimudj, Maikermx, Javizormo, gogua, Melonkid, Kikote8, maxinew, aigort, carlosgzlez, corderazo, Lionxp, jande, Edu1589, msmdraven, Arkan7, jeroc, inamarlo, edumachuca, Josepo79, lead, camamaleon, davidmd, carrasco13, clavelstreet, mikomiko, josele77, car212121, itz18, golf_1990, LeidenSpain, vecnte, Andy_G, csabafr2013, leonfr76, Trimmer, genialsoft, Enerts, leonfrrojito, Horus, paco_22_22, ruben88, Valerofr150, molvi_mabad, Pekee69, Dav2k6, IbiFR, il_munyo, craken, ruben91mad, papo-182, el_padrino, zeratul, kaiserssosse, lytry32.hc, sbarri, ghitus, DesmoSimon, ruli68, Mramos1985, tonielfilas, braulioT, davidalba, JaviMarquez, osjamil, egarense69, fexposru, Pedrost, Illan, chetelopez, juanacho21, cuenka16, pepeiyo69, VapaV, balbu, juan7777, mams69, Helrique, Kike77, volkov, jluis, loeches, Tom70, Dconnect, Trivi83, MilleMiglia, linxes, sergi303, hector37, D83, quiquito30lv, ElFon, DALOFER17, davidap13, kigua, JOTTA, Senuto, jd_zuri, Alvi, damsolu, Leon pucelano, javi_archi, danihd, alcoleazgz, miguel23and, xarlio, jdieztec, mitxuni, Kisszabo, Gendos22, xexpir, canijo82, Brandenor, cenkkaya, kennit0, Chelazo, bertoco, benitogomez, carlosVACA, Peje, NOECUBI1, AAAJDA, trazas, martija, borjiguez, JoseXS, ferbarroso14, Wespa, Cloud_ganora, Berbe15, Valengti, Chrohu, Atajunen, Victorzabal, jrm82, carlo13, iNFeCTeD, paralaxon, ateopoeta, pepo55, ribasxisco, Raulribarroja, ivanti, lopezm0, Rubén Flp, Warelio, Vagabundo, Rekoba, Octacon, matiaso, Alianma, Raulportela, Éugen91, Rivesgti, Mcm90, DaniR86, Gravilhas75, JuanNur78, el_Asturiano, Mr.Chuflas, albert_naga, juanfrancia, Seket, algabe, pistoleromtb, ebcuatro, [GuErRa], Mario Leon, tito68
Re: León Mk3 - Actualización infotainment
Notapor estudiante2003 el 13 Abr 2021, 08:40
Warelio escribió:Por favor chicos, os ruego que obreis con mucha precaución con estos temas porque puede saliros muy cara la broma si algo sale mal y no sabéis después solucionarlo.
Entiendo que intentar actualizar uno mismo estos dispositivos es un chute de autoestima y subidón de adrenalina, sobretodo cuando sale bien, lamentablemente no siempre es así y existen riesgos s que la cosa cuanto menos se complique, y pese a que no hay que ser un experto ni tener estudios superiores si que debéis empaparos bien de toda la info posible, buscar la versión correcta y estable para vuestra unidad y ante la más mínima duda es mejor estarse quieto y no actualizar nada y asegurarse antes de proceder, no por la complejidad en sí del proceso si no porque muchas veces nos venimos arriba con esto porque el "vecino" la actualizó y yo no voy a ser menos que él y después si algo falla (que puede pasar) no tenemos ningún plan B ni sabemos solucionar posibles complicaciones.
Mi consejo es que os asegureis de que sabéis hacerlo y de que sabéis solucionar posibles problemas y una vez con todas la información en vuestro poder pues entonces adelante. Y si no os veis capaces buscáis a alguien que os eche una mano que o bien lo haya hecho o tenga más experiencia al respecto.
Enviado desde mi Pixel 4 XL mediante Tapatalk
Coincido con tu comentario al 100%, podemos tener un bonito pisapapeles, yo me arriesgué tras estar una semana leyendo y releyendo constantemente.
Edito-Si el moderador lo considera oportuno, que borre lo siguiente.
Con el parche para esta versión, instale full link. Acto seguido como no se mostraba, mediante vagcom active mirror link, android auto y CarPlay.
Como tengo un huawei p20 pro ya sabia que solo funcionaría correctamente android auto. El problema es CarPlay con un iPhone 6s y 11, no conecta de ninguna manera.
Este mk3 de final del 2015 solo lleva una toma usb entre salpicadero y palanca de cambio.
1- Puede ser que le falta otro usb más?
2 un error de software?, si es así como corregirlo?
Todo bajo mi cuenta y riesgo
Gracias y saludos.
Última edición por jasoriab el 13 Abr 2021, 09:31, editado 1 vez en total
Razón: Editado para corregir la cita.
estudiante2003
Notapor Warelio el 20 Abr 2021, 08:13
Gracias y saludos.
Doy por hecho que estás usando un cable de datos para la conexión de los móviles, parecerá una tontería pero en muchos casos el no usar un cable de datos y usar el típico cable solamente de carga puede hacer que no se conecte el móvil ni a tiros. Si usas el cable de datos y no te conecta quizás sea ya tema Hardware por la versión de firmware de tu unidad de guantera tenga algún tipo de conflicto con la versión de software que instalaste. Y si no te quedaría o bien reinstalar de nuevo el software (pero no creo que sea solución ya que te conecta) o revisar la activación que hiciste de Full Link a ver si te saltaste algún paso.
Warelio
Moderador de Racing
Agradecido: 1144 veces
Notapor Éugen91 el 20 Abr 2021, 08:28
Gracias y saludos.
Buenos días. Respecto a los iPhone no te conecta. Es por la clavija usb ( si no la cambiaste). La que viene de serie en los leones que no trae full link. Solo sirve para android auto. Para tener CarPlay tienes que poner la doble o la simple pero para apta para eso. 5q0035726E. Aunque últimamente ha subido el precio bastante.
Respecto a la actualización de software no tiene por qué ir mal si todo lo hiciste bien. Ya que eso te desbloquea todo y si has activado con vag com debería ir 100%. Otra cosa que tengas que activar los códigos swap manualmente. Pero yendo el android auto es por la clavija seguramente. Un saludo
Éugen91
Agradecido: 28 veces
Notapor estudiante2003 el 20 Abr 2021, 09:40
Gracias y saludos.
Gracias a todos por las respuestas.
La clavija que lleva tiene encima un minijack.
1- Entiendo que visualmente son similares pero que internamente hay algun chip o hardware que ya permitiría realizar carplay y mirror link?, si es así, solo pieza que incluye usb o tambien cableado?, me recomiendas algunos vendedores ya sea aquí o en Aliexpress?
2 -¿Algún manual para cuando tenga el nuevo usb?
3- ¿Manual para torpes para activar códigos swap ?
Gracias nuevamente y saludos.
estudiante2003
Notapor jasoriab el 20 Abr 2021, 09:49
Un aviso a todos. No se permite tratar públicamente en el foro la activación de códigos SWAP sin pasar por concesionario y pagar la correspondiente licencia, ya que nos podría acarrear problemas legales al foro con SEAT o el grupo VAG.
Cualquier mensaje que haga referencia a este punto, será editado y/o borrado completamente.
jasoriab
Agradecido: 2021 veces
Notapor Lito69 el 20 Abr 2021, 15:34
estudiante2003 escribió:Hola, alguien en Barcelona para eliminar errores de actualización en mk3, desapareció el icono de full link, es para editar lo que sale en página 41 y que vuelva a mostrarse este icono y tener acceso al full link, gracias.
Hay una carpeta de magaupload de un foro alemán operativa para bajar todo el firmware y parches.
El error de comprobacion de software no tiene nada que ver con tu full link, busca en adaptaciones o codificación extendida full link que seguramente se te ha quitado
Lito69
Agradecido: 237 veces
Notapor Victorrafales el 25 Abr 2021, 11:26
Buenasss, tengo un leon st fr my16 y quiero actualizar el infotaiment, a ver si me podeis ayudar un poco, soy un negado para esto jaja, la version de software que lleva es la 0245, el hardware es un H24, gracias de antemano.
Victorrafales
Notapor el_Asturiano el 29 Abr 2021, 05:01
Warelio escribió:Muy complicado que en Seat actualicen el Infotainment si no hay pruebas evidentes de que falla constantemente y tiene fallos demostrables. Es cierto que hay algunos modelos de móviles que puede generar conflictos más que otras marcas. Xiaomi o Huawei tienen unos protocolos en el tema de ahorro de batería bastante estrictos y eso muchas veces genera conflictos de compatibilidad. Echa un vistazo en este hilo a ver si existe una versión de Firmware para tu unidad.
Saludos,.
A mi me llamaron ayer de la seat para decirme que mi coche esta en una campaña para actualizar el infotainment. La comercial que me llamo no me supo explicar más que necesito dejar el coche de un día para otro, que tienen que cambiar una pieza, y que puedo perder la actualización de los mapas del navegador que yo mismo actualicé. Y que si no hago la campaña podría tener problemas en un futuro con el infotainment :plas:
Hardware: H42
Software: 0319
Esos son mis datos. ¿alguien sabe algo? Porque estoy bastante mosqueado con el tema. Decir que a mi jamás me ha dado un solo problema ni la pantalla ni nada relacionado con el infotainment. Me va perfecto todo.
¿Si me actualizan el infotaiment que ventajas puedo tener respecto a la version de origen que tengo? ó ¿sabeis si la version que tengo ha dado algun problema y por eso necesita actualización?
Gracias por la info chicos :ok:
el_Asturiano
Agradecido: 110 veces
Notapor craken el 29 Abr 2021, 07:24
Saludos,.
Hardware: H42
Software: 0319
Gracias por informar. No sé qué implicaciones puede tener, la verdad. Que cambirían, la unidad?
5QA035824A H30 0359
¿Afectado por los Reinicios del sistema infotainment?
Yo también, visita el siguiente enlace para más información:
https://www.clubseatleon.net/viewtopic.php?f=9&t=125535
craken
Agradecido: 31 veces
Notapor Warelio el 29 Abr 2021, 07:24
Saludos,.
Hardware: H42
Software: 0319
Vale, te respondí en el otro post que has publicado sin ver este... Viendo tu versión de Hardware H42 es extraño que lleves una versión 03XX, ya que normalmente las versiones de software suelen empezar por el mismo n° que la versión de Hardware, es decir si tú tienes una H42 la versión de software debería ser 04XX. Posiblemente en Seat te actualizarán a la versión 0479, que es la versión más reciente para unidades H04X si no estoy equivocado. Las mejoras no sean funcionales, en tu caso ganarás estabilidad y rapidez de funcionamiento, visualmente o funcionalmente no creo que haya diferencias más allá de algún detalle.
Warelio
Moderador de Racing
Notapor jasoriab el 29 Abr 2021, 08:48
Las unidades H42 son unidades high (Navisystem Plus) por lo que la nomenclatura de las versiones es distinta a las unidades estándar, donde si se cumple que coincide el dígito de la decena de la versión hardware con el dígito de la centena de la versión software.
@el_Asturiano ¿Es esta la referencia de tu unidad?, viewtopic.php?f=9&t=118140&start=2505
Las high creo que iban por la 1409 ó 1447 (no sé si habrá salido de las betas esta última versión o no)
Última edición por jasoriab el 29 Abr 2021, 08:50, editado 1 vez en total
Razón: Editado para corregir número de versión firmware
jasoriab
Notapor Warelio el 29 Abr 2021, 08:51
jasoriab escribió:Las unidades H42 son unidades high (Navisystem Plus) por lo que la nomenclatura de las versiones es distinta a las unidades estándar, donde si se cumple que coincide el dígito de la decena de la versión hardware con el dígito de la centena de la versión software.
Gracias por la aclaración acerca de la versión de unidades.
Warelio
Moderador de Racing
Notapor Octacon el 29 Abr 2021, 09:51
Saludos,.
Hardware: H42
Software: 0319
Esta unidad tiene pinta que sea de las primeras que salieron, las acabadas en A, unidad high. Esto se puede actualizar hasta la 1447, nose si actualmente tienes full link etc.. pero que sepas que lo puedes tener.
Octacon
Agradecido: 89 veces
Notapor el_Asturiano el 30 Abr 2021, 00:06
Te paso una imagen que creo que viene la referencia de la unidad, sino me dices donde puedo mirarlo.
Viendo la versión que tengo ¿hasta donde pueden actualizarlo? ¿voy a notar mucha diferencia respecto a lo que tengo?
El martes que dejo el coche intentaré enterarme de lo máximo posible y lo comparto con vosotros :comediante: Por eso también ahora os estoy leyendo, para aprendertodo lo que pueda sobre este tema y el martes hacer las preguntas correctas y sacar el máximo posible de información.
Saludos,.
Hardware: H42
Software: 0319
Si tengo full link y lo he usado. Gracias por la info compi :ok:
el_Asturiano
Notapor jasoriab el 30 Abr 2021, 08:57
@el_Asturiano para las últimas referencias de las unidades High, las versiones son la v1409 ó v1447 si SEAT ya la considerase como estable.
Como te dice @Octacon se puede llegar a la v1447 modificando algunos ficheros del firmware. Pero SEAT no se va a complicar la vida en eso, y te actualizarán hasta la última que ellos tengan para tu referencia de unidad como válida en sus servidores.
Respecto a novedades de la nueva versión, difícil saberlo ya que SEAT no publica los cambios que introduce entre versiones, por lo que se supone que serán correcciones de errores y mejoras de rendimiento (lo típico, vamos...)
Si no te importa, cuando te lo actualicen, nos comentas la nueva versión a la que te hayan actualizado, que seguro servirá de ayudas para otros compañeros que tengan esa unidad.
jasoriab
