León Mk3 - Actualización infotainment
Seguidores: kenny_fonseca, ncx, Lavadora, juancete, jesusFR, Hysteria, MaximusRoco, Manu1986, Jorge75016, davidbj, bIxu, miyobe, MORKAS, aironsam14, jramis, kimudj, Maikermx, Javizormo, gogua, Melonkid, Kikote8, maxinew, aigort, carlosgzlez, corderazo, Lionxp, jande, Edu1589, msmdraven, Arkan7, jeroc, inamarlo, edumachuca, Josepo79, lead, camamaleon, davidmd, carrasco13, clavelstreet, mikomiko, josele77, car212121, itz18, golf_1990, LeidenSpain, vecnte, Andy_G, csabafr2013, leonfr76, Trimmer, genialsoft, Enerts, leonfrrojito, Horus, paco_22_22, ruben88, Valerofr150, molvi_mabad, Pekee69, Dav2k6, IbiFR, il_munyo, craken, ruben91mad, papo-182, el_padrino, zeratul, kaiserssosse, lytry32.hc, sbarri, ghitus, DesmoSimon, ruli68, Mramos1985, tonielfilas, braulioT, davidalba, JaviMarquez, osjamil, egarense69, fexposru, Pedrost, Illan, chetelopez, juanacho21, cuenka16, pepeiyo69, VapaV, balbu, juan7777, mams69, Helrique, Kike77, volkov, jluis, loeches, Tom70, Dconnect, Trivi83, MilleMiglia, linxes, sergi303, hector37, D83, quiquito30lv, ElFon, DALOFER17, davidap13, kigua, JOTTA, Senuto, jd_zuri, Alvi, damsolu, Leon pucelano, javi_archi, danihd, alcoleazgz, miguel23and, xarlio, jdieztec, mitxuni, Kisszabo, Gendos22, xexpir, canijo82, Brandenor, cenkkaya, kennit0, Chelazo, bertoco, benitogomez, carlosVACA, Peje, NOECUBI1, AAAJDA, trazas, martija, borjiguez, JoseXS, ferbarroso14, Wespa, Cloud_ganora, Berbe15, Valengti, Chrohu, Atajunen, Victorzabal, jrm82, carlo13, iNFeCTeD, paralaxon, ateopoeta, pepo55, ribasxisco, Raulribarroja, ivanti, lopezm0, Rubén Flp, Warelio, Vagabundo, Rekoba, Octacon, matiaso, Alianma, Raulportela, Éugen91, Rivesgti, Mcm90, DaniR86, Gravilhas75, JuanNur78, el_Asturiano, Mr.Chuflas, albert_naga, juanfrancia, Seket, algabe, pistoleromtb, ebcuatro, [GuErRa], Mario Leon, tito68
Re: Actualización infotainment
Notapor pepeiyo69 el 27 Mar 2020, 10:54
Hay un problema con los link's, dan error d conexión.
En este mensaje, pepeiyo69 ha recibido un agradecimiento de:
Martelinko (15 Abr 2020, 21:07)
pepeiyo69
Notapor grecu_andrei el 28 Mar 2020, 20:56
hola amigos ! quen me puede ajudar con la vercion 0330 ???? porfavor
grecu_andrei
Notapor Lito69 el 07 Abr 2020, 17:37
Supongo que esta web ya la conoceis, la pongo por si acaso:
https://www.seat.at/service-zubehoer/do ... ia-updates
Lito69
Agradecido: 236 veces
Notapor Gendos22 el 07 Abr 2020, 17:41
Lito69 escribió:Supongo que esta web ya la conoceis, la pongo por si acaso:
Estos actualizaciones solo para bluetooth. Segun entiendo yo. Que dentro de los archivos solo hay metainfo y carpeta bt.
Отправлено с моего SM-N960F через Tapatalk
Gendos22
Agradecido: 82 veces
Notapor jasoriab el 08 Abr 2020, 14:46
Tiene toda la pinta que sólo actualiza la conexión bluetooth, y es para modelos antiguos de unidades multimedia.
Dentro del fichero metainfo.txt encontramos esto, que confirma que sólo es para módulos BT
Release = "BT_Package_4350"
Y el manual, aún sin saber alemán, en la tercera página también apunta al módulo bluetooth.
https://www.seat.at/media/Kwc_Basic_Dow ... tem-de.pdf
En este mensaje, jasoriab ha recibido un agradecimiento de:
pepeiyo69 (08 Abr 2020, 19:05)
jasoriab
Agradecido: 2018 veces
Notapor Mantaray el 15 Abr 2020, 14:20
Helrique escribió:Hola, puedes actualizar los links.
miceor escribió:
Mib2 - Pantalla de 6.5"
Versión de la actualización : 0330 (Beta) Instalar esta y luego la 0346. La 0330 es una Beta y tiene fallos conocidos (No asustaros si veis cosas raras) se solucionan actualizando a la 0346.
Equipos compatibles con estas actualizaciones : MIB 2GEN 6,5" HW:024 FW:0245
Descargar el archivo desde:
Drive--- https://drive.google.com/open?id=0BxJGz ... mw0UHNfejg
Versión de la actualización : 0346 (Ultima versión compatible con el dispositivo)(Instalar previamente la 0330)
Equipos compatibles con estas actualizaciones : MIB 2GEN 6,5" HW:024 FW:0245 y logicamente HW:024 FW:0330 (Si existiese alguno)
Drive--- https://drive.google.com/open?id=0BxJGznK3NRXVTU1nbXN5UjlCbDA
no van los enlaces
En este mensaje, Mantaray ha recibido un agradecimiento de:
yokin (26 Abr 2020, 18:12)
Mantaray
Agradecido: 93 veces
Notapor Martelinko el 15 Abr 2020, 21:09
pepeiyo69 escribió:Hay un problema con los link's, dan error d conexión.
Have any update files for mib1 480? If yes, could by update new link for this, i can update my mib 1 from h041 s 425.
Thx for fast reply bro s.
Martelinko
Notapor e2tk el 22 Abr 2020, 18:35
miceor escribió:Bueno, pues os pongo algunas actualizaciones QUE HE ENCONTRADO DE CASUALIDAD para Mib1 y Mib2.
Mib1 - Pantalla de 5.8"
Versión de la actualización : 0480 (Ultima versión compatible con el dispositivo)
Equipos compatibles con esta actualización : MIB 1GEN 5,8" con HW:041 FW:0425
Drive--- https://drive.google.com/open?id=0BxJGznK3NRXVRGRFWlJwaDhjNlU
Descomprimir el archivo. La estructura final debe quedar de la siguiente forma:
Carpeta: SEAT_NAV_SSB
Carpeta: SEAT_PLUS_SSB
Archivo: metainfo2.txt
Copiar las dos carpetas y el archivo en una tarjeta SD Class 10 de 8 GB (Si usais una tarjeta lenta, la actualización se puede eternizar, con la Class 10 tarda unos 40 minutos)
links are broken can you upload again I need actual version 0480 thank you
e2tk
Notapor javiaupi el 23 Abr 2020, 10:19
Buenos dias! Estoy interesado en realizar la actualización y he estado leyendo que, en principio, si que podría realizarla.
En mi león tengo el Hardware H24 y el Software 0245, tal y como se puede observar en la imagen.
He intentado descargar los documentos del drive que se subieron hace tiempo pero el ordenador me marca que no encuentra el URL de descarga. Supongo que será porque con el tiempo se habrán quitado.
¿Sería posible que alguien me los pudieran volver a pasar? Creo que varios han comentado ya que los links no les funcionaba...
Gracias![im
Adjuntos
En este mensaje, javiaupi ha recibido un agradecimiento de:
javiaupi
Notapor yokin el 26 Abr 2020, 16:43
¿Podrías actualizar los enlaces de Drive para Mib2 - Pantalla de 6.5"? Muchas gracias
Última edición por jasoriab el 26 Abr 2020, 18:33, editado 1 vez en total
Razón: Editado para corregir la cita innecesaria al primer mensaje del hilo
yokin
Coche: Leon MK3 1.2 TSI 105cv
Notapor miceor el 26 Abr 2020, 22:03
Los links están caidos porque la cuenta que usaba de drive ya no existe. De momento no puedo subir los archivos hasta que no empecemos a currar. Los tengo en un disco portatil en el trabajo.
Buscarlos por otro lado, me consta que en el foro hay gente que los tiene.
En este mensaje, miceor ha recibido 4 agradecimientos de:
elchia12 (03 May 2020, 01:31), jasoriab (26 Abr 2020, 22:52), Warelio (27 Abr 2020, 09:50), yokin (03 May 2020, 17:55)
miceor
Agradecido: 1256 veces
Notapor elchia12 el 03 May 2020, 01:33
miceor escribió:Los links están caidos porque la cuenta que usaba de drive ya no existe. De momento no puedo subir los archivos hasta que no empecemos a currar. Los tengo en un disco portatil en el trabajo.
podría ponerlos? no los encuentro por ningun lado. y ya pregunto. si lo actualizo no me hace falta utilizar el obdeleven no? soy nuevo. y tengo una pantalla 6,5" con navegador H24 sw 241 y me gustaría actulizarla y reproducir videos en ella
elchia12
Notapor jasoriab el 06 May 2020, 12:04
Ya ha comentado @miceor que no los tiene disponibles actualmente.
Por favor, un poquito de paciencia...
jasoriab
Notapor Ivanfrweiss el 06 May 2020, 13:40
Hola buenas,
A mi tambien me interesa la actualizacion 330 y 386 para la H24 mib 2 de 6,5". Los he buscado por todas partes pero no hay manera.
Si alguien fuese tan amable de compartirlos, estaria agradecido.
Gracias!!
Ivanfrweiss
Notapor Radi el 06 May 2020, 18:10
hola buenas ,
tengo un seat león mk3 del 2013 estoy un poco perdido con el tema de las actualizaciones cual me serviría? hasta cual podría actualizar ?
agradezco cualquier ayuda que me podríais darme
muchas gracias un saludo.
Radi
Coche: Leon MK3 1.4 TSI 140cv
Usuarios navegando por este Foro: hsalvarado y 4 invitados
