León Mk3 - Actualización infotainment
Seguidores: kenny_fonseca, ncx, Lavadora, juancete, jesusFR, Hysteria, MaximusRoco, Manu1986, Jorge75016, davidbj, bIxu, miyobe, MORKAS, aironsam14, jramis, kimudj, Maikermx, Javizormo, gogua, Melonkid, Kikote8, maxinew, aigort, carlosgzlez, corderazo, Lionxp, jande, Edu1589, msmdraven, Arkan7, jeroc, inamarlo, edumachuca, Josepo79, lead, camamaleon, davidmd, carrasco13, clavelstreet, mikomiko, josele77, car212121, itz18, golf_1990, LeidenSpain, vecnte, Andy_G, csabafr2013, leonfr76, Trimmer, genialsoft, Enerts, leonfrrojito, Horus, paco_22_22, ruben88, Valerofr150, molvi_mabad, Pekee69, Dav2k6, IbiFR, il_munyo, craken, ruben91mad, papo-182, el_padrino, zeratul, kaiserssosse, lytry32.hc, sbarri, ghitus, DesmoSimon, ruli68, Mramos1985, tonielfilas, braulioT, davidalba, JaviMarquez, osjamil, egarense69, fexposru, Pedrost, Illan, chetelopez, juanacho21, cuenka16, pepeiyo69, VapaV, balbu, juan7777, mams69, Helrique, Kike77, volkov, jluis, loeches, Tom70, Dconnect, Trivi83, MilleMiglia, linxes, sergi303, hector37, D83, quiquito30lv, ElFon, DALOFER17, davidap13, kigua, JOTTA, Senuto, jd_zuri, Alvi, damsolu, Leon pucelano, javi_archi, danihd, alcoleazgz, miguel23and, xarlio, jdieztec, mitxuni, Kisszabo, Gendos22, xexpir, canijo82, Brandenor, cenkkaya, kennit0, Chelazo, bertoco, benitogomez, carlosVACA, Peje, NOECUBI1, AAAJDA, trazas, martija, borjiguez, JoseXS, ferbarroso14, Wespa, Cloud_ganora, Berbe15, Valengti, Chrohu, Atajunen, Victorzabal, jrm82, carlo13, iNFeCTeD, paralaxon, ateopoeta, pepo55, ribasxisco, Raulribarroja, ivanti, lopezm0, Rubén Flp, Warelio, Vagabundo, Rekoba, Octacon, matiaso, Alianma, Raulportela, Éugen91, Rivesgti, Mcm90, DaniR86, Gravilhas75, JuanNur78, el_Asturiano, Mr.Chuflas, albert_naga, juanfrancia, Seket, algabe, pistoleromtb, ebcuatro, [GuErRa], Mario Leon, tito68
Re: Actualización infotainment
Notapor Lito69 el 28 Ene 2020, 11:57
napoda escribió:Hola,
Yo tengo el mismo problema. Con la actualización de firmware me sale el mismo nombre en todas las emisoras configuradas. Cuando estoy en el navegador i cambio la radio seleccionada, me sale siempre el mismo nombre i al cabo de unos 3 segundos se actualiza al nombre correcto.
Como decis, he probado borrar todas las emisoras i volver a instalarlas, pero sigue pasando.
Adjunto fotos con el problema y la versión instalada.
Alguna solución?
Gracias!!
IbiFR escribió:
kenzozo50 escribió:Buenos dias,
Desde la actualización, tengo un error. Cuando cambio la radio se actualiza el nombre de la radio. ver video gracias
[ Video ]
Borra las emisoras memorizadas y luego vuelve a probar
Enviado desde mi Nexus 6 mediante Tapatalk
Las que creas nuevas también? Quizá haciendo un reset...
Lito69
Agradecido: 236 veces
Notapor Bertio el 28 Ene 2020, 16:20
Tengo un MY16 FR y revisé mi software y es H30 0351
Intenté volver a leer este hilo, pero no puedo ver qué archivos necesito para una actualización.
¿Alguien puede ayudar por PM o por respuesta? Gracias
Bertio
Notapor pepeiyo69 el 31 Ene 2020, 20:19
Tengo un FR del 2015, el sistema de navegacion es el Navi System Plus, con disco duro, supongo es el MK3 o MIB2, la verdad que no se como identificarlo bien.
La version del hardware es la H50 y la del software la 0319, la cartografia es la 0175.
Intente actualizar pero ya se me han cumplido los 4 años de actualizaciones, el otro dia me baje de este link que colgasteis en un hilo: Mapa para Navi System Plus (Discovery High VW) - versión P184 - Europa Occidental
http://vw-mapscdn.tdd.adacorcdn.com/P18 ... IBH3_EU.7z, pero no me ha funcionado, dice que no hay software para actualizar.
Por favor, me podriais indicar o decir domde puedo obtener la ultima actualizacion para Infotainment y para la cartografia ultima?
Por otro lado no se si es necesario hackear la unidad, es posible? y como lo puedo hacer?
Muchas gracias.
pepeiyo69
Notapor jasoriab el 01 Feb 2020, 12:51
pepeiyo69 escribió:Hola,
Muchas gracias.
Hola @pepeiyo69
Tienes un NaviSystem Plus (por la versión de la cartografía que indicas), al que le vale también los mapas de la Discovery Pro de VW.
El grupo VAG saca generalmente dos actualizaciones de mapas al año, una por mayo y otra por noviembre. Si la última no te ha funcionado, tendrás que ir atras probando versiones 6 meses más antiguas... En este subforo hay un hilo por cada una de ellas, con los enlaces, así que te tocaría probar la de mayo 2019, si no la de noviembre 2018, etc. Usa el buscador, o miras las primeras páginas de este subforo y encontrarás dichos hilos.
Respecto a la actualización del software del infotainment, te lo tienen que hacer en un concesionario oficial SEAT, que tienen acceso a las últimas versiones compatibles con tu hardware, o consultar en las empresas que realizan retrofits por si lo pueden hacer ellos.
jasoriab
Agradecido: 2019 veces
Notapor paralaxon el 04 Feb 2020, 10:10
Is there any Firmware available fpr 5F0 035 877? My latest Firmware is 0514. Is there any possibility to update the firmware by my self?
paralaxon
Coche: Leon MK3 2.0 TSI 190cv
Notapor jasoriab el 04 Feb 2020, 10:40
paralaxon escribió:Is there any Firmware available fpr 5F0 035 877? My latest Firmware is 0514. Is there any possibility to update the firmware by my self?
No, at the moment, the firmware for the 5F0 035 877 units is not publicly available.
The only possibility now is through an authorised SEAT dealer.
Regards,
En este mensaje, jasoriab ha recibido un agradecimiento de:
paralaxon (04 Feb 2020, 10:42)
jasoriab
Notapor Bertio el 04 Feb 2020, 10:45
Just in case it was missed, is there an update for my 2016 FR
H30 0351
It was rebooting frequently on Android Auto recently but seems whatever update AA or Samsung did recently it sort of stopped but seeing as I've never updated the Firmware since purchasing in 2016 it would be nice to see if there is a newer version.
Thanks in advance
En caso de que se haya perdido, ¿hay una actualización para mi FR 2016?
H30 0351
Recientemente se reiniciaba con frecuencia en Android Auto, pero parece que cualquier actualización que AA o Samsung hayan hecho recientemente se detuvo, pero dado que nunca he actualizado el firmware desde la compra en 2016, sería bueno ver si hay una versión más nueva.
Gracias por adelantado
Bertio
Notapor Davi_TGI el 07 Feb 2020, 21:14
Buenas, me sale esto en Obdeleven, sabéis algo?
Davi_TGI
Agradecido: 153 veces
Notapor Gendos22 el 07 Feb 2020, 21:33
Davi_TGI escribió:Buenas, me sale esto en Obdeleven, sabéis algo?
Significa que hay actualización nueva para el modulo. Peeero. Si vas a seat no te lo van a actualizar si no tiene fallos y no hay campañas. A lo mejor si tines amigos en seat quizas te lo actualizan. Un saludo
Отправлено с моего SM-N960F через Tapatalk
Gendos22
Agradecido: 82 veces
Notapor aprietatuercas1974 el 08 Feb 2020, 08:06
Buenos dias,creo que esto de las actualizaciones en Seat se debe de aclarar un poco,porque creo que existe un mal entendido general.
En Seat por desgracia al contrario de lo que pensais no tenemos los sw de las unidades MIB que salen de fabrica,solo podemos poner los sw que se ha realizado alguna mejorapor algun fallo conocido y se ha sacado una TPI con dicho fallo.Entonces es cuando nosotros podemos sacra ese sw y poder instalalro en las unidades que tengan dicho fallo.
No es cierto que en Seat ni en Vw se tenga todos los sw de las unidades,y si existe un coche que disponga de una version de hw y sw mas antiguo,y decidan por cualquier motivo sacar la misma version de hw pero con un sw mas moderno,ese no lo vamos a tener por desgracia,puesto que son sw de fabrica.
No es lo mismo esto que las actualizaciones de las unidades de motor,cambio,puertas etc,que pesan muchisimo menos y esas si que disponemos de ellas,aunque no siempre es posible actualizar en servicio oficial.
Espero que quede un poquito mas claro el tema de las actualizaciones MIB.
Una cosa es que exista una version mas moderna(como indica el OBD11 ,que compara las versiones de usuarios y sabe si existen versiones mas modernas)y que podamos tenerlas y otra es que el servicio oficial aun sabiendo que existe un fallo y existe una actualizacion no os la quiera hacer.
En este mensaje, aprietatuercas1974 ha recibido 2 agradecimientos de:
gymnos (03 Mar 2020, 20:40), jasoriab (08 Feb 2020, 10:23)
aprietatuercas1974
Agradecido: 356 veces
Notapor Gendos22 el 08 Feb 2020, 08:10
aprietatuercas1974 escribió:Buenos dias,creo que esto de las actualizaciones en Seat se debe de aclarar un poco,porque creo que existe un mal entendido general.
Gracias por aclarar todo. Espero que usuarios vean tu post y entiendan lo que has explicado.
Gendos22
Notapor carlosgzlez el 01 Mar 2020, 09:44
bojlihal escribió:Hola ,
Tengo un auto Leon X-perience 2015 con 6,5 "y esta información y entretenimiento
Como lo sé, es una versión MIB 2 High.
Alguien sabe si hay una actualización para esta versión y puede compartir conmigo?
Gracias!
Buenos días,
Yo tengo la misma unidad. El jueves al ir a pedir hora para la revisión de 90.000km me dijeron que hay un campaña para actualizar el firmware de la pantalla. Creo recordar que a versión 0397 o similar. Solo recuerdo que enpezaba 03. Ya sabes, en la próxima revisión puede que te la actualicen.
Enviado desde mi SM-A202F mediante Tapatalk
En este mensaje, carlosgzlez ha recibido un agradecimiento de:
pepeiyo69 (02 Mar 2020, 11:49)
carlosgzlez
Agradecido: 51 veces
Notapor LuTe. el 02 Mar 2020, 20:58
Yo tengo una duda me dice un compañero que primero se actualiza una carpeta y después la otra, esto hablo en la 5,8 no se pueden actualizar las dos ala vez gracias
LuTe.
Notapor LuTe. el 03 Mar 2020, 18:26
Alguno ha actualizado la pantalla de 5,8 porque yo la he actualizado y no ha cambiado nada yo la veo igual visualmente
LuTe.
Notapor Helrique el 25 Mar 2020, 21:20
Hola, puedes actualizar los links.
miceor escribió:
Mib2 - Pantalla de 6.5"
Versión de la actualización : 0330 (Beta) Instalar esta y luego la 0346. La 0330 es una Beta y tiene fallos conocidos (No asustaros si veis cosas raras) se solucionan actualizando a la 0346.
Equipos compatibles con estas actualizaciones : MIB 2GEN 6,5" HW:024 FW:0245
Descargar el archivo desde:
Drive--- https://drive.google.com/open?id=0BxJGz ... mw0UHNfejg
Versión de la actualización : 0346 (Ultima versión compatible con el dispositivo)(Instalar previamente la 0330)
Equipos compatibles con estas actualizaciones : MIB 2GEN 6,5" HW:024 FW:0245 y logicamente HW:024 FW:0330 (Si existiese alguno)
Drive--- https://drive.google.com/open?id=0BxJGznK3NRXVTU1nbXN5UjlCbDA
En este mensaje, Helrique ha recibido 2 agradecimientos de:
jp23 (10 Abr 2020, 19:25), yokin (26 Abr 2020, 18:12)
Helrique
Usuarios navegando por este Foro: No hay usuarios registrados visitando el Foro y 10 invitados
