Seat Leon FR 2015 Navigation error
Notapor martijnb23 el 27 Ene 2018, 20:11
We have a Seat Leon from 2015 with a MIB2, and we have a problem with the
navigation system. The message is: Navigation database is not available.
We have also been at dealer, but no solution.
Can i release the navigation database maybe with obd2eleven. Or another solution?
Here is a link to the error message
th23autolink_encode_start_3lwlsai4W2ltZzozbHdsc2FpNF1odHRwJiM1ODsvL2Z1bmt5aW1nJiM0Njtjb20vaS8yQkVZdSYjNDY7anBnWy9pbWc6M2x3bHNhaTRdth23autolink_encode_end_3lwlsai4
martijnb23
Re: Seat Leon FR 2015 Navigation error
Notapor LeonFR.Gz el 27 Ene 2018, 21:13
@martijnb23 te lo muevo al subforo de [AudioCar y MultimediaCar]
LeonFR.Gz
Moderador Global
Agradecido: 1173 veces
Notapor cvillajos el 27 Ene 2018, 23:04
Do you have correctly inserted the original SD Card into slot2 (and 'lock' tab set)? Had you try to upgrade database versión sometime? If yes, have you try to restore a backup from first version?
Regards!!
cvillajos
Agradecido: 3610 veces
Notapor martijnb23 el 27 Ene 2018, 23:28
I have tried both slot 1 and slot 2. and also put the sd card on lock.
The original sd card for navigation is version v2.
I have not yet upgraded the database version, how should I do that.
After removing the component protection by dealer, I received this message.
Unfortunately, I do not have a backup
martijnb23
Notapor cvillajos el 29 Ene 2018, 10:25
martijnb23 escribió:I have tried both slot 1 and slot 2. and also put the sd card on lock.
If you remove CP on your dealer that means you have changed your Infotaiment... Original SD does not work on different Infotaiment.
Regards!!
cvillajos
Notapor martijnb23 el 29 Ene 2018, 15:05
We have just been to the dealer, and they can not find them.
Get error message: fm module (no tuner error they said)
We also used the correct SD card.
Is it smart to order a new V2 card (with codes of course),
because the original has always worked.
martijnb23
