@al_jandrox Necesitas el cable y hacer este mod.
León Mk3 - BRICO - Como instalar la cámara de parking
- Seguidores: 136
- Favoritos: 46
- Vistas: 545.926
Favoritos: JaviCG, Vampiro, J@VY, BADS, Daruma, cstrol, JorgeAnteloC, ipenalosa, MONTY DAKA, pirly, josele887, xurox, Nanox23, Carbono79, vallter, norchugo, Efremvidal, @turbina@, blankiblau, jorgee76, jliriz, Vilo, cuenxis, victir, Aras, Korath, Rasekfighter, Carrl, jdieztec, J-Frass, Tarzan, zacarias, Frannisesabe, Xperience, bronce702, sbarri, javieret69, Carlos Chea, Lotar, Alleya, miguelorly, craken, chemazz, xico, eMi1, Maverick.es
Seguidores: Linker89, car212121, franrx, davidalba, TRIBO, danieleon, Panchorin, Hecson.27, jmfcoto, aironsam14, JOTTA, MORKAS, Unaited, trekam, xandis, Jorge75016, Platanot, davidbj, Achehmg, marc.domenech.90, sadanyac, seat leon blanco, Marc.22, Peuero, er_trompe, GTI35, JoseCa, JaviCG, vigimuertos, rabazas, B.Fox, msmdraven, Tomcat7733, Txutxiysilvia, xabidh, cstrol, Carrl, El3ndil, yorky, bolche, LeoST, Diegokero, Rasekfighter, Budoka, IronTor21, marlop, xico, vanscampa, Tarzan, jorgee76, josemag, aigort, LuichiFR, SLon34, clavelstreet, nani_san, nyro, IVANIN9, rober1095, ivan0909, jose.jjg307, csabafr2013, P.carrizo.leonstfr, dookky, Edu1589, Dconnect, D83, Jeii90, inamarlo, Israel-FR, Herrdoktor, el_padrino, Kipu, aguscalderon, lebowski, juanmaroger, bailyibz, naikon_paul, Valerofr150, JAL, kennit0, Mramos1985, bronce702, kijute, juanmik, osjamil, Tonivn, Lotar, Tunnig, JaviMarquez, nitro_g4074, sergi303, ivan2017, Chema_Alvarez, ilargiman, jaumotix, sbarri, javierferriz, alcoleazgz, lecupra280, Colomer, Maikermx, luigi323, rents_80, jdiego75, Pedrost, damsolu, lead, Franr50, Dani2025, Leon pucelano, nachomart, castronight, victor david, bertoco, juan7777, Josep20, jakobitto, rr7mo, a.cuadros71, iNFeCTeD, Gendos22, VapaV, Chrohu, Ganyula, snowpluralism, victor_leon_FR, luaiabou96, Drovniak, Guillen222, leonfrrojito, justics, lopezm0, Romera, pedrorossello92, AlvaroRamlo
arlot - Gurú de los leones
- Agradecido: 975 veces
Re: BRICO como instalar la Camara de parking en Seat leon MK
Buenas tardes. @vicasgon y @josele887 habéis avanzado algo??? Cómo va la cosa???
- Agradecido: 268 veces
Para los interesados, hay otra opción de cámara que va en el porta matrículas bien centradita, el problema quizás es que vaya mas expuesta que en el parachoques
http://www.asturxenon.com/equipos-multi ... 340-detail
XoXe - Leoner@ habitual
- Agradecido: 59 veces
Stealnick escribió:Buenas tardes. @vicasgon y @josele887 habéis avanzado algo??? Cómo va la cosa???
Buenas tardes, yo sigo igual, no he avanzado nada. El problema fundamental es la codificación que no es la misma que en las pantallas más grandes que llevan el navegador.
josele887 - Primeros Pasos
- Agradecido: 7 veces
como he dicho en anteriores posts, sigo esperando la versión de SEAT introducida en los MY16, aunque en el ETKA sigue sin rastro...
Eluryh - Leoner@ avanzad@
- Agradecido: 107 veces
al_jandrox escribió:Hola amigos!!
Voy a montar la camara trasera con nuestro crack "rojas", pero tengo una duda.
Yo llevo luces alogenas en la matricula y la cámara del plafon lleva led. Mi pregunta es como se puede solucionar sin que te de error . Yo le intente cambiar a la luz de la matricula por led y me dan siempre fallo.
cuando instale la cámara me dará fallo tambien?
Gracias!!!!1
Hay camaras sin plafon compañero, pero tendrias que hacer un pequeño agujer entre las dos luces y sacar el paragolpes para mo tarlo, equivale a 20 o 30min. mas de trabajo
Cuando pienses que estas al limite, estaras a un 50% de llegar al mismo.
IvanMc2 - Leoner@ habitual
- Agradecido: 129 veces
aunque os parezca un poco "chapuza " ... la opcion que hice para solucionar el fallo para mi es la mejor ... y hasta ahora ningun falllo !!
plafon dentro y listo ! no hay fallo
rojas - Gurú de los leones
- Agradecido: 1885 veces
Pues ya me ha llegado la cámara, a ver si soy capaz de hacerla funcionar. Tengo mis dudas ya que ninguno de los que tenemos la pantalla de 5'' la ha hecho funcionar (al menos que yo sepa).
Stealnick escribió:Pues ya me ha llegado la cámara, a ver si soy capaz de hacerla funcionar. Tengo mis dudas ya que ninguno de los que tenemos la pantalla de 5'' la ha hecho funcionar (al menos que yo sepa).
Si la consigues poner en marcha dinos como, porque yo estoy igual, no consigo codificarla con vagcom. Suerte!!!
Pues nada hoy me he puesto a hacer el brico... pero me sale la pantalla negra... lo cierto es que todavía no me ha llegado el condensador ¿Será por eso? Pues no tengo imagen me sale la pantalla en negro y no sé por qué... He visto también que cuando he puesto los robacorrientes en la marcha atrás en el mismo mazo pasan dos cables marrones de igual grosor (masa) ¿es igual conectar el robacorrientes en uno que en otro? @rojas imploro tu ayuda!!! Muchas gracias!
davicinn - Leoner@ habitual
- Agradecido: 65 veces
davicinn escribió:Pues nada hoy me he puesto a hacer el brico... pero me sale la pantalla negra... lo cierto es que todavía no me ha llegado el condensador ¿Será por eso? Pues no tengo imagen me sale la pantalla en negro y no sé por qué... He visto también que cuando he puesto los robacorrientes en la marcha atrás en el mismo mazo pasan dos cables marrones de igual grosor (masa) ¿es igual conectar el robacorrientes en uno que en otro? @rojas imploro tu ayuda!!! Muchas gracias!
Comprueba en la toma de la camara con un polimetro, multimetro, buscapolos o una bombilla de coche con dos cables que llega corriente que aveces los robacorriente no enganchan bien y no hacen contacto, hay que pelarlos un pokito.
De donde has cojido el positivo, de la bombilla del maletero o del mechero?
Pd. Cierra el porton si no no funciona
Estoy de vacaciones y no me he puesto a revisar la instalación, a ver si la semana que viene tengo un hueco.
El tema de codificación hice lo que me dijo rojas y no me funciona. A ver si conseguimos que le funcione a alguien que tenga la pantalla de 5 pulgadas.
vicasgon - Nuev@ por aqui
- Agradecido: 9 veces
IvanMc2 escribió:davicinn escribió:Pues nada hoy me he puesto a hacer el brico... pero me sale la pantalla negra... lo cierto es que todavía no me ha llegado el condensador ¿Será por eso? Pues no tengo imagen me sale la pantalla en negro y no sé por qué... He visto también que cuando he puesto los robacorrientes en la marcha atrás en el mismo mazo pasan dos cables marrones de igual grosor (masa) ¿es igual conectar el robacorrientes en uno que en otro? @rojas imploro tu ayuda!!! Muchas gracias!
Compañero pues lo he cogido de la marcha atrás!! El caso es que pasaban dos marrones por el mazo y he pillado uno pero no sé si el correcto puesto que los dos eran iguales... Muchas gracias por tu ayuda
Pedazo brico @rojas!!! Te lo has currado un montón, este es un extra que en su día no pude poner al coche y quería y quiero.
Intentaré saber que cuesta que te lo pongan en el taller oficial, aunque de momento no saben, por eso de no perder la garantía del coche ya que no tiene ni un año.
VilaXp - Nuev@ por aqui
- Agradecido: 5 veces
BRICO como instalar la Camara de parking en Seat leon MK3
davicinn escribió:IvanMc2 escribió:davicinn escribió:Pues nada hoy me he puesto a hacer el brico... pero me sale la pantalla negra... lo cierto es que todavía no me ha llegado el condensador ¿Será por eso? Pues no tengo imagen me sale la pantalla en negro y no sé por qué... He visto también que cuando he puesto los robacorrientes en la marcha atrás en el mismo mazo pasan dos cables marrones de igual grosor (masa) ¿es igual conectar el robacorrientes en uno que en otro? @rojas imploro tu ayuda!!! Muchas gracias!
Si lo has puesto de la bombilla marcha atras (Blanca) directo a la camara no te va a funcionar por que la bombilla blanca no entrega 12v constantes, prueba cojiendo el positivo de la luez del maletero o del mechero.
Con respecto al cable marron, yo creo que te va a dar igual de donde saques la masa, todas son iguales, yo lo tengo donde tu y cuando le puse la camara a @tokedj1989 le puse la masa en el enganche del maletero por no das vueltas
