este es mi sensor
El hilo de VAGCOM y opciones/mods para MK3
- Seguidores: 251
- Favoritos: 101
- Vistas: 998.042
Favoritos: El-Santo, J@VY, neraka, comodisimo, nhaxo, guirimg, Maestro, José R, JorgeAnteloC, gark81, Monilloxd, LeonST, josele887, Guitarrero18, Garfu, pttzarzadilla, reyes83, jicarriches, Raulin87, Leon pucelano, pocososinos, pintalberto, dani90, Mario1307, Albert87, genialsoft, Javigt, crcrodrigo, blankiblau, trekam, lobezno13, Morientes, Josito3, jorgee76, jliriz, Albino, seat leon fr 46, francesito, khris, Agonza86, clavelstreet, ocsido, acidheart, Korath, JPeraza, marcosgumiel, Josele., itsAdriaan96, cvillajos, ertate, LU1S3N_LE, Ludovicum, migcc, Vasmurcia, Charly24Fr, Jerjeskan, Javata, adrinek8, Paliciu, Samueleitor, Sdocid, Tomcat7733, ismacom, KaZaK, m170280, GaiteFRmklll, Mate, kijute, Kete32, los, javieret69, Alberto85, dranaco, joelsm, fre_19, Koltrix, franandas, Alleya, Juanquique, AiramTuning, chetelopez, little bastard, fur, mk3CAT, Juantxu, voxyman, Peje, javimacuo, JDCLEONFR, barrosdepor, steve_mad, Matias92, LordNelson, Elpuma7788, Revi, lopezm0, tuthankamenn, Miguelespino14, rock_ero, jordy, albertolop91
Seguidores: sarge, dsorribes, Elpuma7788, fonsi008, genialsoft, Mario1307, P.carrizo.leonstfr, trumangs, robereto, rikirpa, champinet, Miguelespino14, Besaygf, El3ndil, gogua, Pitufo_fr, crisFR, hectorcanu, Budoka, janfri, ixorreta, josele887, Jorge75016, jjimene89, cstrol, volkov, easyridergs, jmofcb, crcrodrigo, TeteFR, Dandy_gsi, Marc.22, Youkiler, iMonje, delko, dUeNdEr, Aegnorazo, marlop, pttzarzadilla, Platanot, berserk, Canary_280, La_jungla, davidbj, vigimuertos, Osky1983, chemacrown77, juanmaroger, sadanyac, Lionxp, coxmox, maxinew, nhaxo, Hecson.27, Valerofr150, Arcangel_89, edumachuca, daniel_44, JoseCa, kadettero, pablomus85, Mate, Albino, chuki_gcg, trekam, Ribers, FranGonzalez, Txutxiysilvia, César C., odelot, loeches, LeoST, jmfcoto, msmdraven, antelo85, kurbak, JPeraza, Diegokero, Robert_gti, chichopaco, Unaited, J.COSTA, jbaste, ertate, Javigt, Iosu21, Raul_22_, Daruma, kijute, LuichiFR, TITO CORUÑA, golf_1990, pitc3c14, lazandury_sur, iazofra, khris, Peje, Digon, car212121, Charly24Fr, Rasekfighter, aigort, Vasmurcia, Trivi83, Jeii90, MORKAS, Cantona, picard14, fbmxx, Zenobya, pirulo79, IRO, dookky, alonsodsg, carrasco13, Edu1589, elbirlo.dmm, bailyibz, Aluisdr26, aironsam14, franrx, Joseibz, elluna, hectordrums, chetelopez, llobet112, Kikote8, zenkun, Tomcat7733, djcastle, STFR, Sdocid, jninomo, albertpg, neraka, joke2joke, Miguelpfdez94, Kete32, chisyelamos, molvi_mabad, alejandro_javier, borgio, carlosgzlez, Frekiyo, manupuente92, garrafa2, papo-182, pipaxy, joelsm, morpheusgt, leonfrsaha, joscasaster, bronce702, Dconnect, Agobo, DBS83, Luko, Leon pucelano, davics07, naikon_paul, Juanquique, abollao, Hovig, teltronik, oldaqgonzalez04, ivanmonty, jasoriab, undernok, Mramos1985, braulioT, JoseDel, DiegoR, KoToRRo, Gsclosada, Tunnig, João Ramos, cristian_l.m, ilargiman, Gus_Fring, jluis, francisco.gamiz, sisma_eltrigo, VapaV, csabafr2013, guille771, cocorolito, artur.bp, sergi303, portela84, barret, Alba Morales, davidalba, JDCLEONFR, Luiggi7, dukaty, Maikermx, nitro_g4074, Senuto, yoflipo, damsolu, Mobi2004@gmail.com, josutdm, xexpir, cucci, Xabaco, fexposru, DJGrincho, chifli, MartinLeon, sgnwill, trazas, davidap13, ncx, Thor, ivanvidal, LordNelson, David_GT, vicius, javigomezserrano, josemag, iNFeCTeD, sistrax, manu5, galelir, Juanmidv, Chrohu, alex1, davidvilao, yurkli, carlo13, carloslmfr, lopezm0, jose.a.llamas, Gisbigas, Drovniak, diepecu2, JaquetónST, alrodri, ginyu 83, Ivanbustelo, Def89, Fisio, SantiPMI, Lata8, estudiante2003, talanito, wilsugar, perikolu, pedrorossello92, AlvaroRamlo, ebcuatro
Re: El hilo de VAGCOM y opciones/mods para MK3
rojas - Gurú de los leones
- Agradecido: 1884 veces
Eso son seis captadores @rojas?
El mío marca 00095D antes de codificar con long Coding helper y 06095D después pero no me funciona. Supongo que será de los que no se puede hacer el mod de cerrar ventanas con lluvia.
O no se puede con VAG-COM pero con el del concesionario si?
Albino - Leoner@ avanzad@
- Agradecido: 61 veces
@rojas..gracias...el mio solo iluminan 2, el de arriba y el de abajo...que rabia...es facil de cambiar?..o es posible activar los demas con vag?.. seria la leche!!
- Agradecido: 368 veces
No se puede activar con vag ... todo el que tenga 95 en su codificacion no lo puede hacer . Hay que cambiar el sensor que estoy seguro que es muy sencillo
Hola gente!!
Tengo mi Leon des de abril'15 y tal como me lo dieron le active lo de las señales de trafico por vagcom, que como bien sabreis cada vez que enciendes te da la alerta de "faltan datos". Sabeis si se ha podido hacer algo al respecto para que no salga?
Saludos y gracias!
Saludos y gracias!
Ruinolt nunca mais... Esperando mi MK3 FR 1.8
rul3s - Aun con la L
- Agradecido: 10 veces
rul3s escribió:Hola gente!!
Saludos y gracias!
nop
Buenas , queria comentar , el otro dia active un par de cosas con el vagcom , una de ellas , el cronometro en el fis , lo activo en el vagcom sin problemas asi como lo pone la primera pagina.
Pero no me llega a salir en el fis , mi fis no es a color es el basico , se trata de un loen 1.8 Tsi 180 cv.
El vagcom es 12.12 puede ser por eso?
Tambien quise hacer unos logs y no me dava opcion a clickar en el apartado para hacer logs....
Haber si alguien me puede ayudar , saludos y gracias.
puertas91 - Asidu@ en la selva
- Agradecido: 8 veces
puertas91 escribió:Buenas , queria comentar , el otro dia active un par de cosas con el vagcom , una de ellas , el cronometro en el fis , lo activo en el vagcom sin problemas asi como lo pone la primera pagina.
Yo lo tengo todo igual color de fis, vag 12.12 y pude activar el cronometro. Algo has hecho mal.
Seat Leon 2.0 tdi 222,2cv by REVO
joangp - Leoner@ habitual
- Agradecido: 50 veces
Vete a los ajustes del Easy Connect donde se seleccionan las opciones a mostrar en el FIS y activa el cronometro. Al hacer el mod te aparece en este menu, pero no directamente en el FIS
- Agradecido: 346 veces
A mi el cronómetro me sale directamente en fis ... en el menu multifuncion de la pantalla no me sale
Hola compañeros!
No sé si os pasa lo mismo... cuando abro el techo solar con el interruptor no se me abre completamente si no que tengo que volver a girar y mantener girado el commutador para que se acabe de abrir del todo. ¿Habría algún mod que permitiese abrir el techo entero de golpe?
davicinn - Leoner@ habitual
- Agradecido: 65 veces
davicinn escribió:Hola compañeros!
A mi el techo me funciona igual que a ti y recuerdo haber leído que funcionaba así. Lo que no se es si con el vag se podrá hacer algo...
MI LEONCETE viewtopic.php?f=43&t=111988#p1800461
inamarlo - Leoner@ avanzad@
- Agradecido: 88 veces
sonxav - Gurú de los leones
- Agradecido: 526 veces
sonxav escribió:
Yo juraría que el mío sólo tiene 2...
¿Es posible?
@sonxav es posible, por que el mío también tiene sólo 2.... Por eso nos podemos olvidar de activar lo del cierre por lluvia acaso que no cambiemos el sensor por el de seis....
Cupra R 300 DSG
- Agradecido: 938 veces
Si, @homersimpson nos quedamos con las ganas.....
Alguien sabe la referencia y precio del sensor de 6? @rojas
¿Porqué seat cambia continuamente de componentes? De verdad que no lo entiendo, unos llevan asidero con tapa, otros no, unos llevan sensor de 2 luces, otros de 6, unos llevan una centralita, otros otra.... Cuando las diferencias entre un coche y otro son inexistentes. ¿No sería más práctico usar el mismo componente para todos los que llevan line assist ?
Terminales o pines de fusilera. Foro: Leon III - Mecánica / Electricidad / Electrónica Autor: Dav2k6 Respuestas: 2 |
Luz de bateria fija Foro: Leon I - Mecánica / Electricidad / Electrónica Autor: t0rr3s.tdi Respuestas: 2 |
Usuarios navegando por este Foro: jlbpmr, Majestic-12 [Bot] y 7 invitados
