El hilo de VAGCOM y opciones/mods para MK3
Favoritos: El-Santo, J@VY, neraka, comodisimo, nhaxo, guirimg, Maestro, José R, JorgeAnteloC, gark81, Monilloxd, LeonST, josele887, Guitarrero18, Garfu, pttzarzadilla, reyes83, jicarriches, Raulin87, Leon pucelano, pocososinos, pintalberto, dani90, Mario1307, Albert87, genialsoft, Javigt, crcrodrigo, blankiblau, trekam, lobezno13, Morientes, Josito3, jorgee76, jliriz, Albino, seat leon fr 46, francesito, khris, Agonza86, clavelstreet, ocsido, acidheart, Korath, JPeraza, marcosgumiel, Josele., itsAdriaan96, cvillajos, ertate, LU1S3N_LE, Ludovicum, migcc, Vasmurcia, Charly24Fr, Jerjeskan, Javata, adrinek8, Paliciu, Samueleitor, Sdocid, Tomcat7733, ismacom, KaZaK, m170280, GaiteFRmklll, Mate, kijute, Kete32, los, javieret69, Alberto85, dranaco, joelsm, fre_19, Koltrix, franandas, Alleya, Juanquique, AiramTuning, chetelopez, little bastard, fur, mk3CAT, Juantxu, voxyman, Peje, javimacuo, JDCLEONFR, barrosdepor, steve_mad, Matias92, LordNelson, Elpuma7788, Revi, lopezm0, tuthankamenn, Miguelespino14, rock_ero, jordy, albertolop91
Seguidores: sarge, dsorribes, Elpuma7788, fonsi008, genialsoft, Mario1307, P.carrizo.leonstfr, trumangs, robereto, rikirpa, champinet, Miguelespino14, Besaygf, El3ndil, gogua, Pitufo_fr, crisFR, hectorcanu, Budoka, janfri, ixorreta, josele887, Jorge75016, jjimene89, cstrol, volkov, easyridergs, jmofcb, crcrodrigo, TeteFR, Dandy_gsi, Marc.22, Youkiler, iMonje, delko, dUeNdEr, Aegnorazo, marlop, pttzarzadilla, Platanot, berserk, Canary_280, La_jungla, davidbj, vigimuertos, Osky1983, chemacrown77, juanmaroger, sadanyac, Lionxp, coxmox, maxinew, nhaxo, Hecson.27, Valerofr150, Arcangel_89, edumachuca, daniel_44, JoseCa, kadettero, pablomus85, Mate, Albino, chuki_gcg, trekam, Ribers, FranGonzalez, Txutxiysilvia, César C., odelot, loeches, LeoST, jmfcoto, msmdraven, antelo85, kurbak, JPeraza, Diegokero, Robert_gti, chichopaco, Unaited, J.COSTA, jbaste, ertate, Javigt, Iosu21, Raul_22_, Daruma, kijute, LuichiFR, TITO CORUÑA, golf_1990, pitc3c14, lazandury_sur, iazofra, khris, Peje, Digon, car212121, Charly24Fr, Rasekfighter, aigort, Vasmurcia, Trivi83, Jeii90, MORKAS, Cantona, picard14, fbmxx, Zenobya, pirulo79, IRO, dookky, alonsodsg, carrasco13, Edu1589, elbirlo.dmm, bailyibz, Aluisdr26, aironsam14, franrx, Joseibz, elluna, hectordrums, chetelopez, llobet112, Kikote8, zenkun, Tomcat7733, djcastle, STFR, Sdocid, jninomo, albertpg, neraka, joke2joke, Miguelpfdez94, Kete32, chisyelamos, molvi_mabad, alejandro_javier, borgio, carlosgzlez, Frekiyo, manupuente92, garrafa2, papo-182, pipaxy, joelsm, morpheusgt, leonfrsaha, joscasaster, bronce702, Dconnect, Agobo, DBS83, Luko, Leon pucelano, davics07, naikon_paul, Juanquique, abollao, Hovig, teltronik, oldaqgonzalez04, ivanmonty, jasoriab, undernok, Mramos1985, braulioT, JoseDel, DiegoR, KoToRRo, Gsclosada, Tunnig, João Ramos, cristian_l.m, ilargiman, Gus_Fring, eyebee, jluis, francisco.gamiz, sisma_eltrigo, VapaV, csabafr2013, guille771, cocorolito, artur.bp, sergi303, portela84, barret, Alba Morales, davidalba, JDCLEONFR, Luiggi7, dukaty, Maikermx, nitro_g4074, Senuto, yoflipo, damsolu, Mobi2004@gmail.com, josutdm, xexpir, cucci, Xabaco, fexposru, DJGrincho, chifli, MartinLeon, sgnwill, trazas, davidap13, ncx, Thor, ivanvidal, LordNelson, David_GT, vicius, javigomezserrano, josemag, iNFeCTeD, sistrax, manu5, galelir, Juanmidv, Chrohu, alex1, davidvilao, yurkli, carlo13, carloslmfr, lopezm0, jose.a.llamas, Gisbigas, Drovniak, diepecu2, JaquetónST, alrodri, ginyu 83, Ivanbustelo, Def89, Fisio, SantiPMI, Lata8, estudiante2003, talanito, wilsugar, perikolu, pedrorossello92, AlvaroRamlo, ebcuatro
Re: El hilo de VAGCOM y opciones/mods para MK3
Notapor Qarl el 09 Oct 2015, 13:52
He ido a hacer el Mod del FIS de carbono pero me he encontrado que mi coche (Style) ya tiene seleccionado el valor 2, sin embargo el FIS sale normal. Si trato de seleccionar el valor 3 me da error de "out range".
¿Alguna sugerencia?
Qarl
Agradecido: 83 veces
Notapor CarlosTSi el 09 Oct 2015, 14:16
Adikubens escribió:
Homersimpson escribió:
Adikubens escribió:
Qarl escribió:
Adikubens escribió:hola, este lo he intentado hacer pero al pinchar en el long coding me dice que mi ECU no tiene acceso a esto y no me sale el menu para poder ir al byte 4 y seguir con el resto de la configuración :( :(
Tienes el contacto puesto??
si, siempre hago el mismo proceder, enchufo el cable al coche, luego al ordenador, abro el VCDS y doy contacto, de hecho tengo el portátil enchufado a la corriente del coche porque la bateria me dura un suspiro y sino esta el contacto dado no da corriente la toma de 12v y no puedo hacer nada porque se me apaga el portátil. No se porqué me pasará eso :(
@Adikubens nunca, pero nunca enchufes el ordenador al mechero del coche directamente te puedes cargar el cable y más sí es el "pirata".... Pon un transformador de 12 a 220/230V y lo enchufas al transformador
Hola Homersimpson, tengo un transformador ufff que suste me has dado al leerlo de primeras no había reparado que me decías lo del transformador. primero enchufo el transformador al mechero y éste al portatil, mi portatil trabaja a 19v entonces el transformador tiene un selector de voltaje y tu ya pones el que te convenga según el voltaje que trabaje tu máquina. mira es este:
un saludo ;)
Perfecto @Adikubens
Cupra R 300 DSG
CarlosTSi
Agradecido: 938 veces
Notapor joangp el 09 Oct 2015, 19:59
Adikubens escribió:
Albino escribió:
Adikubens escribió:Buenas compañeros, alguien me podría decir si ha probado este mod y si le funciona o hace lo que dice que es??
activar los antinieblas delanteros al dar marcha atras
1. 09 central electric
2. 16 security access Unlock code 31347
3. 10 adaptations From drop down
4. select - (1) static AFS light-bei Rueckwaertsfahrt Set value to Double Sided from OFF
5. Do It
yo lo he hecho tal y como dice, se hace todo correcto, se graba la nueva configuración pero luego cuando doy marcha atrás no se encienden los antinieblas. Tengo activado que al echar las ráfagas se enciendan antinieblas y eso si me funciona, no se si al tener eso activo es incompatible con este mod que quiero activar. a ver si alguien me arroja algo de "luz" porque o yo estoy activando algo que no se que es y para que sirve o a mi no me hace nada.
un saludo!!
Yo llevo ese mod pero sin haberlo hecho especificmente. Me explico, al hacer el mod del cornering ya va incluido o al menos en mi caso
que curioso, yo active el mod de cornering y me funcionaba bien pero lo quite porque al llevar luces LED no me gustaba como se veía la mezcla de blanco led con el amarillo halógeno, pensé que algún día le cambiaria la lámpara al antiniebla y quité el mod. Lo que no me fijé es si al dar marcha atrás se activaban los antinieblas, pero se te activan los dos? o es porque al dar marcha atras giras el volante y se enciende el antiniebla del lado que giras?
saludos y gracias por tu respuesta
A mi también se me activaron al activar los cornering.
pd habéis visto este mod https://www.youtube.com/watch?v=JQcpNBQmN0Y
Seat Leon 2.0 tdi 222,2cv by REVO
joangp
Agradecido: 50 veces
Notapor Qarl el 09 Oct 2015, 20:17
LLevo media hora buscando la opción en VAG-COM para que las ventanillas suban y bajen aunque estén las puertas abiertas, me refiero a este mod:
http://www.stemei.de/pages/coding/seat- ... chlauf.php
¿Alquien me puede decir más o menos por la altura que se encuentra esta opción? He ido mirando todas pero nada, no hay manera de encontrarla, he ido buscando todos los (13) y ninguno coincidía...
Muchas gracias!!
Qarl
Notapor marcosbng el 10 Oct 2015, 08:56
5. Do It
un saludo!!
Como me gusta el intermitente así en el espejo, a ver si alguien nos dice algo de como se pone.
Eternamente agradecido a Rojas
marcosbng
Agradecido: 16 veces
Notapor norchugo el 10 Oct 2015, 13:08
Eso no me suena a mi a vagcom, es mas bien una modificacion de la propia tira de led mas bien
Seat leon mk3 1.8 fsi dsg
norchugo
Agradecido: 54 veces
Notapor yours3lf el 10 Oct 2015, 16:45
5. Do It
un saludo!!
Muy guapo, ojalá se pudiera con vagcom, yo lo activaria
yours3lf
Agradecido: 26 veces
Notapor alexdaoe el 11 Oct 2015, 16:30
Hola, acabo de comprarle bombillas led para el freno y la posición traseras y queria saber si alguien sabe como programar para que no den error de luz fundida? las de freno ya de por si no dan error, pero las de posición si que dan, ya en su dia cambié las de la matricula y daban error, pero con la codificación de la pagina de inicio de este tema pude cambiar de 5w a led la programación, me fije que alrededor de esa opción habia muchas mas bombillas programables, sabeis si se puede programar estas de posición? Gracias
alexdaoe
Coche: Leon MK3 1.5 TGI 130cv
Agradecido: 48 veces
Notapor GueRRe el 12 Oct 2015, 07:44
alexdaoe escribió:Hola, acabo de comprarle bombillas led para el freno y la posición traseras y queria saber si alguien sabe como programar para que no den error de luz fundida? las de freno ya de por si no dan error, pero las de posición si que dan, ya en su dia cambié las de la matricula y daban error, pero con la codificación de la pagina de inicio de este tema pude cambiar de 5w a led la programación, me fije que alrededor de esa opción habia muchas mas bombillas programables, sabeis si se puede programar estas de posición? Gracias
Echa un ojo a este hilo:
viewtopic.php?f=43&t=108737&start=45
Saludos.l
GueRRe
Notapor pitc3c14 el 12 Oct 2015, 10:42
Saludos.l
Buenas, soy el creador de ese hilo, lo tengo puesto con las resistencias y también me gustaría saber si con VagCom se puede decir a la centralita que lleva bombillas de le y que no hagan falta las resistencias.
Muchas gracias
pitc3c14
Notapor alexdaoe el 12 Oct 2015, 15:15
Mira para quitar el error de las de la matricula tienes que hacer este paso, el paso nº5 corrresponde a las luces de la matricula, pero en la lista alrededor de esta opcion hay decenas de bombillas y estoy casi seguro que si decubrimos como se llaman las de posición podremos ponerlas como LED
1. 09 control electric
2. Security access 16
3. Codigo desbloqueo 31347 - Do it
4. Adaptation 10
5. Seleccionar canal: (1)-Leuchte25KZL HA59-Lasttyp25
Stored value: 18-2* 5W
New value: 43 - Allgemeine LED
alexdaoe
Notapor Qarl el 12 Oct 2015, 15:44
Buenos dias amigos!
Después de estar varios días trasteando con las opciones de vag-com me he puesto a hacer un sencillo programita que básicamente lo que hace es volcar todos los canales que salen en los diferentes módulos a un fichero de log que genera el propio vag-com.
Después, con el fichero de log ya podemos pegar todas las lineas en el traductor y así encontrar opciones curiosas, además el log de vag-com vuelca también el valor del canal seleccionado.
El programa hace lo siguiente:
1. Mueve el cursor hacia el desplegable de los canales.
2. Hace click en el desplegable para que aparezcan las opciones.
3. Hace click en la siguiente opción.
4. Hace click sobre el botón "Add to Log".
Este mismo proceso le repite las veces que quiera a una velocidad bastante rápida.
Acaba de volcar todas las opciones del módulo 09-Cent. Elect mientras escribía este mensaje jejeje. Unas 2500 opciones que tiene el dichoso desplegable.
A ver si me puedo currar un poco más el programa esta tarde y lo subo aquí al foro con una breve explicación para que cada uno pueda explotar bien el maravilloso vag-com jejeje.
Qarl
Notapor stewei el 12 Oct 2015, 17:04
Qarl escribió:Buenos dias amigos!
@Qarl maravilloso!! :reverencia: Cuando lo subas puedes poner por aqui el enlace al tema que hayas creado?? gracias!!!
stewei
Agradecido: 465 veces
Notapor Qarl el 12 Oct 2015, 17:13
stewei escribió:@Qarl maravilloso!! :reverencia: Cuando lo subas puedes poner por aqui el enlace al tema que hayas creado?? gracias!!!
Sii, por supuesto, dejaré aquí referencia, ya lo estoy terminando.
Qarl
Notapor yoque el 12 Oct 2015, 17:19
ostia que puntazo, no?
yoque
Coche: Leon MK3 1.4 TSI 122cv
Agradecido: 9 veces
