El hilo de VAGCOM y opciones/mods para MK3
Seguidores: sarge, dsorribes, Elpuma7788, fonsi008, genialsoft, Mario1307, P.carrizo.leonstfr, trumangs, robereto, rikirpa, champinet, Miguelespino14, Besaygf, El3ndil, gogua, Pitufo_fr, crisFR, hectorcanu, Budoka, janfri, ixorreta, josele887, Jorge75016, jjimene89, cstrol, volkov, easyridergs, jmofcb, crcrodrigo, TeteFR, Dandy_gsi, Marc.22, Youkiler, iMonje, delko, dUeNdEr, Aegnorazo, marlop, pttzarzadilla, Platanot, berserk, Canary_280, La_jungla, davidbj, vigimuertos, Osky1983, chemacrown77, juanmaroger, sadanyac, Lionxp, coxmox, maxinew, nhaxo, Hecson.27, Valerofr150, Arcangel_89, edumachuca, daniel_44, JoseCa, kadettero, pablomus85, Mate, Albino, chuki_gcg, trekam, Ribers, FranGonzalez, Txutxiysilvia, César C., odelot, loeches, LeoST, jmfcoto, msmdraven, antelo85, kurbak, JPeraza, Diegokero, Robert_gti, chichopaco, Unaited, J.COSTA, jbaste, ertate, Javigt, Iosu21, Raul_22_, Daruma, kijute, LuichiFR, TITO CORUÑA, golf_1990, pitc3c14, lazandury_sur, iazofra, khris, Peje, Digon, car212121, Charly24Fr, Rasekfighter, aigort, Vasmurcia, Trivi83, Jeii90, MORKAS, Cantona, picard14, fbmxx, Zenobya, pirulo79, IRO, dookky, alonsodsg, carrasco13, Edu1589, elbirlo.dmm, bailyibz, Aluisdr26, aironsam14, franrx, Joseibz, elluna, hectordrums, chetelopez, llobet112, Kikote8, zenkun, Tomcat7733, djcastle, STFR, Sdocid, jninomo, albertpg, neraka, joke2joke, Miguelpfdez94, Kete32, chisyelamos, molvi_mabad, alejandro_javier, borgio, carlosgzlez, Frekiyo, manupuente92, garrafa2, papo-182, pipaxy, joelsm, morpheusgt, leonfrsaha, joscasaster, bronce702, Dconnect, Agobo, DBS83, Luko, Leon pucelano, davics07, naikon_paul, Juanquique, abollao, Hovig, teltronik, oldaqgonzalez04, ivanmonty, jasoriab, undernok, Mramos1985, braulioT, JoseDel, DiegoR, KoToRRo, Gsclosada, Tunnig, João Ramos, cristian_l.m, ilargiman, Gus_Fring, eyebee, jluis, francisco.gamiz, sisma_eltrigo, VapaV, csabafr2013, guille771, cocorolito, artur.bp, sergi303, portela84, barret, Alba Morales, davidalba, JDCLEONFR, Luiggi7, dukaty, Maikermx, nitro_g4074, Senuto, yoflipo, damsolu, Mobi2004@gmail.com, josutdm, xexpir, cucci, Xabaco, fexposru, DJGrincho, chifli, MartinLeon, sgnwill, trazas, davidap13, ncx, Thor, ivanvidal, LordNelson, David_GT, vicius, javigomezserrano, josemag, iNFeCTeD, sistrax, manu5, galelir, Juanmidv, Chrohu, alex1, davidvilao, yurkli, carlo13, carloslmfr, lopezm0, jose.a.llamas, Gisbigas, Drovniak, diepecu2, JaquetónST, alrodri, ginyu 83, Ivanbustelo, Def89, Fisio, SantiPMI, Lata8, estudiante2003, talanito, wilsugar, perikolu, pedrorossello92, AlvaroRamlo, ebcuatro
Re: El hilo de VAGCOM y opciones/mods para MK3
Notapor tevaadarelsol el 04 May 2016, 07:07
Davido2790 escribió:
tevaadarelsol escribió:Bueno, para los que tengan un MY'16 con pantalla de 6.5 (navegador en mi caso) y no podáis activar el modo carbono en la pantalla de la radio siguiendo el tutorial de la primera página, decir que acabo de conseguirlo con el VagCom, simplemente marcando tanto el bit 0 como el bit 1 del byte 17 del módulo 5F y después reiniciando la radio manteniendo pulsado el botón de power durante 10 segundos.
Perfecto ya lo he echo esta noche y funciona a la perfección, muchas gracias m, ya pensaba que solo podría meterle mano con él VCP, por casualidad de donde lo has sacado?
O lo has descubierto tu?
Pues me puse a trastear, viendo que para el FIS hay varios skins, jugué con los bits para hacer las combinaciones de 0, 1, 2, 3... Hasta que di con él.
Por cierto, lo he hecho con un 15.7.1.
Enviado desde mi Nexus 5 mediante Tapatalk
En este mensaje, tevaadarelsol ha recibido un agradecimiento de:
PacoRuiz3107 (21 Ago 2017, 22:39)
tevaadarelsol
Agradecido: 199 veces
Notapor hectordrums el 04 May 2016, 09:34
cvillajos escribió:
hectordrums escribió:Hola. Llevo con mi León Style Connect Plus ST 10 días y me han dicho en la casa que si manipulo con Vagcom algo ellos lo saben y perdería la garantía. Qué hay de cierto en esto?
Diles que si se jode algo relacionado con lo que tu has tocado has tenido mala suerte y aceptarás tu "metedura de pata". Peeeeero si se niegan a aplicar la garantía sobre algo que ni de roce tiene que ver con lo manipulado les verás en los tribunales y que un juez decida. (También les puedes decir que no sean tan listos, pero queda feo...)
Gracias. Eso pensaba yo, que menudo morro tienen. Por otro lado no sé ni por dónde empezar con el Vagcom, ni dónde comprar el cable, ni qué cable, ni na de na. Agradecería que me echaseis una manita. Saludos!
hectordrums
Notapor cvillajos el 04 May 2016, 09:47
Léete este par de hilos para empezar y abrir boca @hectordrums . Todo lo demás vendrá después:
- http://www.clubseatleon.net/viewtopic.php?f=8&t=108591
- http://www.clubseatleon.net/viewtopic.php?f=8&t=113807
Y cuando lo tengas te pones con los MODs de la primera página que quieras (empieza por los sencillitos y luego lo vas complicando).
hectordrums (04 May 2016, 14:33)
cvillajos
Agradecido: 3572 veces
Notapor kossel el 04 May 2016, 09:52
Yo añadiría este hilo a los de lectura obligada también, si te animas.
viewtopic.php?f=8&t=116700
Bienvenido al mundo de los locos que no se pueden estar quietos :comediante: Con las precauciones necesarias no has de tener ningún problema y no "romperás" nada. Pero lee primero antes de lanzarte de cabeza! Yo era muy dado a lo contrario por impaciencia. Jajajaja
En este mensaje, kossel ha recibido un agradecimiento de:
kossel
Coche: Leon MK3 1.2 TSI 86cv
Agradecido: 56 veces
Notapor hectordrums el 04 May 2016, 14:35
Gracias cvillajos y kossel. Iré echándole un ojo a esos hilos poco a poco, que no tengo mucho tiempo. Un saludo!
hectordrums
Notapor LeonCup el 04 May 2016, 16:44
LeonCup escribió:Hay alguna modificación para que el coming y leaving home, sea sólo en la diurnas de leds y no en el faro entero? Yo tengo un cupra y no tiene antinieblas. Ya me diréis.
me cito!
LeonCup
Usuario baneado
Agradecido: 23 veces
Notapor javigody el 04 May 2016, 17:57
me cito!
Página 78 de la biblia de xagico.
javigody
Agradecido: 274 veces
Notapor LeonCup el 04 May 2016, 23:34
javigody escribió:
me cito!
Gracias tío, esque hay tanto y tanto que me pierdo.
LeonCup
Usuario baneado
Notapor Danideloop el 05 May 2016, 22:01
Muy buenas, tengo un st 1.4 del 2015, y con el vag 12.12 he conseguido cambiar los intermitentes de confort, carbono en fis y en media system y activar el reconocimiento de señales. Desde que active las señales me sale
que line assist no está disponible, volví atrás y lo deje como estaba, pero nada, sigue sin estar disponible.
Alguien me puede echar una mano?
Danideloop
Coche: Leon MK3 1.2 TSI 110cv
Notapor Flo-FR el 05 May 2016, 23:50
Una preguntilla, del manual pdf de XaGiCo, ¿Cuales mods valdrían para mi leon de marzo de 2015 con pantalla 5,8 y FIS a color?
Un saludo y gracias :palomitas:
Flo-FR
Agradecido: 15 veces
Notapor cvillajos el 06 May 2016, 00:17
Flo-FR escribió:Una preguntilla, del manual pdf de XaGiCo, ¿Cuales mods valdrían para mi leon de marzo de 2015 con pantalla 5,8 y FIS a color?
Hay ciento y pico MODs en ese PDF @Flo-FR ... Complicao enumerarte los que sí y los que no :cuñao:
Pregunta por el/los que te interese/n y lo vemos...
gogua (06 May 2016, 00:23)
cvillajos
Notapor zenkun el 06 May 2016, 07:03
rojas escribió:Está chulo ... pero atrás no se enciende el intermitente, solo delante por lo que veo en el video
si exacto, aqui en México no es ilegal hasta donde yo se, ando buscando el código sin suerte :(
por cierto rojas, ire a España en agosto, m e encantaría invitarte una cerveza :D
zenkun
Notapor LeonCup el 06 May 2016, 09:34
javigody escribió:
me cito!
Por cierto no funciona, se enciende todo el faro normal.
LeonCup
Usuario baneado
Notapor Flo-FR el 06 May 2016, 09:41
Ups! jejeje. A ver, me interesa el fondo de carbono en el FIS y en la pantalla de 5,8, el test de agujas, litros a repostar, señales de trafico en el FIS (no llevo la cámara ¿seria posible?), intermitentes confort ponerlo a 4 o 5.
En principio me interesa esos mods, he visto que están en la pagina principal, solo que no se si serian compatibles con mi modelo y si estan funcionales de la forma en que vienen puestos en el post 1.
Flo-FR
Notapor rojas el 06 May 2016, 09:48
Si hay que echarla... se echa :rey: jejej
No te olvides una botella de licor típica de allí :si: :si:
Saludoss
rojas
Coche: Leon MK3 1.5 TGI 130cv
Agradecido: 1884 veces
