Seguidores: golf_1990, josusanchez5b, Jastur, r11ourense, MerioE, davidddgt, jose.a.llamas, gato125, Pkt, byChule, Hovig, SorianoFco, jygalvan, CubanPitbull, corderazo, israher, iDavid9669, nyro, pirulo79, Edu1589, ramargo75, javi.ferrer, kikelin, aleejandroogm, Trimmer, car212121, LeoST, Besaygf, kinipc, Rasekfighter, Romera, MartinLeon, camamaleon, Aceroinox1a, jramis, Juanquique, josele77, marlop, Peje, Pedrost, bailyibz, wiki88, teltronik, gogua, sirkez, carlosgzlez, mcecho, genialsoft, aironsam14, JoseCa, Dandy_gsi, vanscampa, Joseibz, trekam, La_jungla, jorgecrackets, aigort, msmdraven, IRO, Jorge75016, alejandro_javier, ivan0909, jmfcoto, viktor_ct_95, maxxg2, olgalberto1, danifusi, Josepo79, er_trompe, miyobe, jande, Petri, itz18, jagman, serguey79, rafapadilla93, Mate, undernok, lead, lead, csabafr2013, jluis, olmeras, LeidenSpain, osjamil, Valerofr150, flope63, Herrdoktor, pocososinos, carrasco13, pichonclv, C.reina, Daner84, inamarlo, aguscalderon, BaZZ, yujakantabro, Fonek, LARABA, juanmaroger, juanmac, Kipu, IvanMc2, garrafa2, Linker89, mihai G, Igor, bronce702, creasy1977, Gsclosada, lebowski, jaro_84, charly425, leonfr76, DBS83, joseanvazquez501, M3rs, borgio, NOCIVOX, FcoJ.M.N., VillaSB, t4alberto, lytry32.hc, david_gz, Kasky, diegol147, jasoriab, jninomo, jmiturbe, chetelopez, utopia95, Dreziel, jonatan1988, xsoldadito, Illan, Fernandoestrada, jd_zuri, Juande667, xjuliox, Bettor, solanomor01, Chinyero, volkov, braulioT, Maikermx, iNowack, D83, MORKAS, dRoXe, JaviMarquez, danitre, Davi_TGI, DiegoR, ertate, cuenka16, nicotzioras, Spok68, urbion, linxes, kukikukarron, Talnoseque, Hyperr, VapaV, jfermar, Moigijon, slyjay73, DuckToy, nachomart, Iosu21, sbarri, sebasresa, Beiró, Llisus, agus_piscis10, Action SVG, Alc16, Trivi83, eyebee, riclanico, Per3zo, Qore, lolorm, abollao, Alvi, sergi303, Xilenos, barret, Gus_Fring, malloc, TomH30, jmofcb, paco_22_22, luigi323, Chelazo, dani10s, victor david, Yeiem93, Luiggi7, Guillen222, yoflipo, nenazojuanma, nitro_g4074, Senuto, gabivvamesia, javichu312, richard_11, Yery, Ivensound, El_pelos44, rvicario76, Mr.Chuflas, subaru_3, eruizm, Gomez89, barubita, Nicoplas, javibmw, el_noi_80, kapi21, satoo, barrosdepor, camaon99, craken, Flow-Rider, Castro87, Kikedecefe, xexpir, Cristian2014mx, _Juansp, jornefra, cucci, Pablitofr, Pablitofr, Rober_SR, kevinhtbs, chocoleitos, RamonLaC, cesarsl, drnrd, conquepoquico, hectordrums, Neuw84, bertoco, dondani96, cupralex, Octacon, pablomus85, josean-opc, davidap13, Raaz, erlanz, canijo82, MarcosRG86, Alianma, SinName, mSx, evomaoleon, BertopenST, a.cuadros71, Lumara, Gendos22, borjayadri2, litllevill, Jandrew, galelir, Josep20, borjiguez, THC77, di360, Juanjocantabria, grijan 2.0, copii92, JDMG, Morales92, nadiia.bcn93, yo_javi89, yurkli, Atajunen, carlo13, Desertcuervo, floppy666, amg129, manjerico, Franr50, iNFeCTeD, Rotemburgero, Link, kivamz, dj_ferrix, manu5, Vagabundo, aaronfdez, Manzi, Perilla, juanaco, pepetgi, pistoleromtb, cp_jj, diepecu2, Freddy169, Welmonk, JaquetónST, alrodri, LuisNM, Rekoba, bizu, ginyu 83, ephreon, rr7mo, Def89, CrisFRST5F, Mohoska, gilen44, ayl, SantiPMI, Jesús Peinado, 05kar, Lata8, Adrián pcg, Warelio, carlosVACA, trazas, barris31, danieleon, enriquevalera, antonioagui95, tito68, Sarge86, victorvOrtiz, bigpicha, ericoperico, JulinM, AlvaroRamlo, josermancol, Davidv, flotter, V de Viana, zainao, LeónST, rubiotuning, RacingSport
Notapor clavelstreet el 02 Jun 2016, 20:25
miceor escribió:
clavelstreet escribió:Desmontando la bombilla de marcha atrás de los pilotos leds, he visto que la parte central del piloto del portón lleva en su interior la placa, diodos, leds... de la zona central estrecha que nunca luce, ¿se podría activar con el OBDeleven? Sería un plus estético y de seguridad al frenar. Pongo una foto de la zona a la que me refiero
Lo tienes aqui:
Luz de freno también en la luz de cola (Portón)(Pilotos LED)
Con esta modificación las luces del freno se encienden también en los faros del portón en vez de solamente en los de las aletas traseras.(Para faros LED)
1 - Módulo 09- Centralita electrónica. Code (31347)
2 - Adaptación
3 - Seleccionar - Leuchte23SL HLC10
4 - Submenú - Lichtfunktion C 23
5 - Cambiar valor a Brake light
6 - Submenú - Lichtfunktion CD 23
7 - Cambiar valor a 100
8 - Seleccionar - Leuchte24SL HRA65
9 - Submenú - Lichtfunktion C 24
10 - Cambiar valor a Brake light
11 - Submenú - Lichtfunktion CD 24
12 - Cambiar valor a 100
Siento decir que no es así, se activa al frenar la luz de posición led de la aleta junto con la de freno. Lo he hecho esta mañana y eso me ha sucedido :cry:
Como para el paso 5 en los seleccionables no aparecia Brake light he buscado luz de freno en aleman (Bremslicht) y eso he activado, es lo único diferente que he hecho
clavelstreet
Agradecido: 27 veces
Notapor stewei el 02 Jun 2016, 20:54
Lo tienes aqui:
2 - Adaptación
@clavelstreet Te refieres si vas con las luces apagadas no? porque entiendo que si vas con las luces encendidas entonces no notas ninguna diferencia.
Alguien mas ha hecho este mod?
stewei
Agradecido: 465 veces
Notapor clavelstreet el 02 Jun 2016, 21:00
Lo tienes aqui:
2 - Adaptación
Si, con luces apagadas, no me he fijado si daba más intensidad de luz que cuando está en modo posición
clavelstreet
Notapor stewei el 02 Jun 2016, 21:21
En un adapmap que tengo guardado tengo lo siguiente en esa luz:
Leuchte23SL HLC10 - Lichtfunktion C 23 --> Coming Home oder Leaving Home aktiv
Leuchte24SL HRA65 - Lichtfunktion C 24 --> Coming Home oder Leaving Home aktiv
Por cierto, no encuentro Lichtfunktion CD 23 pero si Dimmwert CD 23
en el caso de Lichtfunktion CD 24, igual.
¿es un error?
stewei
Notapor miceor el 02 Jun 2016, 21:24
Llevais razón lo he estado repasando y hay un error.
Malditas tablas y autocorrectores.
Lo corrijo ahora mismo.
miceor
Agradecido: 1256 veces
Notapor stewei el 02 Jun 2016, 21:27
miceor escribió:Llevais razón lo he estado repasando y hay un error.
@miceor entonces ese mod no se puede activar? el de activar esa franja de leds para que se iluminen al frenar, no la luz led de posicion.
En este mensaje, stewei ha recibido un agradecimiento de:
xa_vie30 (10 Jun 2016, 15:59)
stewei
Notapor miceor el 02 Jun 2016, 21:36
Vaya patinazo, estaban al revés los de led y los de no led.
Ya están cambiados, ahora están bien.
En este mensaje, miceor ha recibido un agradecimiento de:
clavelstreet (02 Jun 2016, 21:42)
miceor
Notapor stewei el 02 Jun 2016, 21:42
miceor escribió:Vaya patinazo, estaban al revés los de led y los de no led.
Perdona @miceor , alomejor soy un pesao..... Solo hay que cambiar una luz?? me refiero a que solo as puesto Leuchte27NSL , y no se si solo es esa o te a faltado poner la del otro lado... Con esto de las leuchte me ago un liazo....
stewei
Notapor clavelstreet el 02 Jun 2016, 21:46
No te preocupes, es normal con la paliza que llevas con tantos mods, traducción del alemán.... Lo bueno es probarlos y el que vea algo que no funcione que lo diga y así se irá mejorando.
Una vez más agradecer tu gran trabajo, sin ti muchos no tendríamos nada activado.
En este mensaje, clavelstreet ha recibido un agradecimiento de:
stewei (02 Jun 2016, 21:49)
clavelstreet
Notapor miceor el 02 Jun 2016, 22:01
Es un bloque, no va por luces separadas.
FAROS TRASEROS
Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lasttyp 17-- Intermitente Trasero Interno Izquierdo (Solo Focos LED)
Leuchte16BLK SLB35BLK SL KC9-Lasttyp 16-- Intermitente Trasero Interno Derecho (Solo Focos LED)
Leuchte19BLK HRC31-Lasttyp 19 -- Intermitente Trasero Externo Derecho
Leuchte18BLK HLA60-Lasttyp 18 -- Intermitente Trasero Externo Izquierdo
Leuchte21BR RC8-Lasttyp 21-- Luz de Posición & Freno Exterior Derecho
Leuchte20BR LA71-Lasttyp 20 -- Luz de Posición & Freno Exterior Izquierdo
Leuchte23SL HLC10-Lasttyp 23 -- Luz de Posición Interna Izquierda
Leuchte24SL HRA65-Lasttyp 24 -- Luz de Posición Interna Derecha
Leuchte27NSL RC6-Lasttyp 27 -- Luz Interior (Solo Focos LED)
Leuchte26NSL LA72-Lasttyp 26 -- Luz Antiniebla Trasera Izquierda
Leuchte29RFL RA64-Lasttyp 29 -- Luz Marcha Atrás Izquierda
Leuchte28RFL LC11-Lasttyp 28 -- Luz Marcha Atrás Derecha
FAROS DELANTEROS TODOS LOS TIPOS
Leuchte 0 BLK VL B36-Lasttyp 0 -- Intermitente Delantero Izquierdo (Faro)
Leuchte1BLK VRB20-Lasttyp 1 -- Intermitente Delantero Derecho (Faro)
Leuchte2SL VLB10-Lasttyp 2 -- Luces de Marcha Diurna Izquierda DRL (Faro LED)
Leuchte3SL VRB21-Lasttyp 3 -- Luces de Marcha Diurna Derecha DRL (Faro LED)
Leuchte4TFL LB4-Lasttyp 4 -- Luces de Marcha Diurna Izquierda DRL (Faro)
Leuchte5 TFL RB32-Lasttyp 5 -- Luces de Marcha Diurna Derecha DRL (Faro)
Leuchte6ABL LC5-Lasttyp 6 -- Luz Cruce Izquierda Halógeno / Xenón
Leuchte7ABL RB1-Lasttyp 7 -- Luz Cruce Derecha Halógeno / Xenón
Leuchte8FL LB39-Lasttyp 8 -- Luz Larga Izquierda Halógeno / Punto Izq. Xenón P+
Leuchte9FL RB2-Lasttyp 9 -- Luz Larga Derecha Halógeno / Punto Der. Xenón P+
Leuchte10SHUTTER LB23-Lasttyp 10
Leuchte11SHUTTER RB22-Lasttyp 11
ANTINIEBLAS DELANTEROS
Leuchte12NL LB45-Lasttyp 12 -- Faro Antiniebla Delantero izquierdo
Leuchte13NL RB5-Lasttyp 13 -- Faro Antiniebla Delantero derecho
TERCERA LUZ DE FRENO
Leuchte22BR MA57-Lasttyp 22
LUCES DE LA MATRICULA
Leuchte25KZL HA59-Lasttyp 25
LUCES DE REPOSAPIES
Leuchte30FR LC72-Lasttyp 30
LEDS DE LAS PUERTAS
Leuchte16BLK SLB35BLK SL KC9 B16
En este mensaje, miceor ha recibido 3 agradecimientos de:
clavelstreet (04 Jun 2016, 00:40), MORKAS (02 Jun 2016, 23:10), stewei (02 Jun 2016, 22:05)
miceor
Notapor stewei el 02 Jun 2016, 22:54
A mi me sale que la luz Leuchte28RFL LC11-Lasttyp 28 -- Luz Marcha Atrás Derecha es la "Luz antiniebla trasera" (Nebelschlusslicht).
stewei
Notapor clavelstreet el 02 Jun 2016, 23:17
2 - Adaptación
3 - Seleccionar - Leuchte27NSL RC6
4 - Submenú - Lichtfunktion D 27
6 - Submenú - Dimming direction CD 27
7 - Cambiar valor a Maximize
8 - Submenú - Dimmwert CD 27
9 - Cambiar valor a 100
Siento ser portador de malas noticias, lo acabo de realizar y pasa esto.
Adjuntos
Las luces de posición las tengo apagadas.
En este mensaje, clavelstreet ha recibido 2 agradecimientos de:
MORKAS (02 Jun 2016, 23:21), stewei (02 Jun 2016, 23:24)
clavelstreet
Notapor MORKAS el 02 Jun 2016, 23:21
clavelstreet escribió:Luz de freno también en la luz de cola (Portón)(Pilotos LED)
2 - Adaptación
Faltara algo en el mod?..
MORKAS
Agradecido: 368 veces
Notapor stewei el 02 Jun 2016, 23:27
Pues la verdad es que esta claro que algo no cuadra... He mirado en mi adapmap y hay varias leuchtes que no estan en funcionamiento, o por lo menos yo no las tengo en funcionamiento:
(1)-Leuchte31AMBL 1C61-Lasttyp 31,not active
(1)-Leuchte32AMBL 2C35-Lasttyp 32,not active
(1)-Leuchte33AMBL 3C36-Lasttyp 33,not active
(1)-Leuchte34AMBL 4C37-Lasttyp 34,not active
stewei
Notapor stewei el 02 Jun 2016, 23:30
@clavelstreet entiendo que lo has podido volver a poner bien no??
stewei
