León Mk3 - BRICO - Como instalar la cámara de parking
- Seguidores: 136
- Favoritos: 46
- Vistas: 544.863
Favoritos: JaviCG, Vampiro, J@VY, BADS, Daruma, cstrol, JorgeAnteloC, ipenalosa, MONTY DAKA, pirly, josele887, xurox, Nanox23, Carbono79, vallter, norchugo, Efremvidal, @turbina@, blankiblau, jorgee76, jliriz, Vilo, cuenxis, victir, Aras, Korath, Rasekfighter, Carrl, jdieztec, J-Frass, Tarzan, zacarias, Frannisesabe, Xperience, bronce702, sbarri, javieret69, Carlos Chea, Lotar, Alleya, miguelorly, craken, chemazz, xico, eMi1, Maverick.es
Seguidores: Linker89, car212121, franrx, davidalba, TRIBO, danieleon, Panchorin, Hecson.27, jmfcoto, aironsam14, JOTTA, MORKAS, Unaited, trekam, xandis, Jorge75016, Platanot, davidbj, Achehmg, marc.domenech.90, sadanyac, seat leon blanco, Marc.22, Peuero, er_trompe, GTI35, JoseCa, JaviCG, vigimuertos, rabazas, B.Fox, msmdraven, Tomcat7733, Txutxiysilvia, xabidh, cstrol, Carrl, El3ndil, yorky, bolche, LeoST, Diegokero, Rasekfighter, Budoka, IronTor21, marlop, xico, vanscampa, Tarzan, jorgee76, josemag, aigort, LuichiFR, SLon34, clavelstreet, nani_san, nyro, IVANIN9, rober1095, ivan0909, jose.jjg307, csabafr2013, P.carrizo.leonstfr, dookky, Edu1589, Dconnect, D83, Jeii90, inamarlo, Israel-FR, Herrdoktor, el_padrino, Kipu, aguscalderon, lebowski, juanmaroger, bailyibz, naikon_paul, Valerofr150, JAL, kennit0, Mramos1985, bronce702, kijute, juanmik, osjamil, Tonivn, Lotar, Tunnig, JaviMarquez, nitro_g4074, sergi303, ivan2017, Chema_Alvarez, ilargiman, jaumotix, sbarri, javierferriz, alcoleazgz, lecupra280, Colomer, Maikermx, luigi323, rents_80, jdiego75, Pedrost, damsolu, lead, Franr50, Dani2025, Leon pucelano, nachomart, castronight, victor david, bertoco, juan7777, Josep20, jakobitto, rr7mo, a.cuadros71, iNFeCTeD, Gendos22, VapaV, Chrohu, Ganyula, snowpluralism, victor_leon_FR, luaiabou96, Drovniak, Guillen222, leonfrrojito, justics, lopezm0, Romera, pedrorossello92, AlvaroRamlo
Re: BRICO como instalar la Camara de parking en Seat leon MK
Al final se a cojido la alimentación a la luz del maletero i con condensador porque son en fallaba igual
P.carrizo.leonstfr - Asidu@ en la selva
- Agradecido: 6 veces
Caanpulo escribió:P.carrizo.leonstfr escribió:Caanpulo escribió:jony83 escribió:Davido2790 escribió:jony83 escribió:MORKAS escribió:jony83 escribió:Bueno , ya he descubierto otra cosa del mal funcionamiento de la camara.
funciona el 50% de las veces. una vez si, a la siguiente no, y asi sucesivamente, independientemente del tiempo, forma de engranar la marcha atras...etc.
alguna solucion ? intento codificarla con odbeleven ? porque con el vagcom no funciona bien
Has hecho la instalación con el montaje de condensador?..a mi no me falla nunca..de momento
no, ni condensador ni rele...
subi la intensidad de la luz trasera.
De donde eres? Haber si te puedo echar un cable
Enviado desde mi ONE E1003 mediante Tapatalk[/quitar]
De Zaragoza! Pero creo q el problema está en la codificación.
Hoy con el odbeleven he puesto los sensores traseros para q se vean en pantalla, y ahora funciona bien, pero después de quitar la imagen de marcha atrás , me sale el park pilot y se queda unos 8-10 seg
Yo creo que la solucion seria conectarlo directo al fusible de mechero, ami tambien me pasaba eso y una vez conectado directamente me funciona 100%
Hola buenas, me pasa igual se puso la alimentación en la marcha atrás i salta el Park pilot.. Si l alimentas por al fusible del mechero funciona correctamente?? mi león es un st my16 sin sensores ni Park pilot ni nada lleva la radio media system plus 6,5 con full link. Saludos!
El mio tambien lleva pantalla de 6,5 con full link y lo tenia conectada a la luz de marcha atras y solo funcionaba la primera vez que metia la marcha atras desde que arrancaba el coche despue sya me salia lo de park pilot no disponible, lo puse directo al fusible y va perfectamente
Que activaste por el Vagcom? Yo tengo igual que tu y lo tengo con la luz de marcha atrás sin problemas
Davido2790 - Leoner@ avanzad@
- Agradecido: 81 veces
Muy buen brico gracias compañero
Antonio_12812 - Nuev@ por aqui
a mi , la unica manera que funcione bien es activando en pantalla los OPS traseros, pero me sale con la vision de la marcha atras y luego cuando la quito vuelve a salir los OPS , duran 8 seg y se vuelven a ir.
podeis pasar la codificacion que llevais a los que os funciona bien ??
jony83 - Leoner@ habitual
- Agradecido: 20 veces
Tarzan - Nuev@ por aqui
Tengo una pequeña duda, de donde cojo corriente a la camara, del mechero o de la macha atras.
El mio es un leon 2.0tdi 150cv DSG.
Haber si @rojas que es experto me lo sabe decir.
Cógelo del mechero y te ahorras rele y condensador
Enviado desde mi SM-G925F mediante Tapatalk
rojas - Gurú de los leones
- Agradecido: 1885 veces
Yo por llevarle la contra a @rojas de la marcha atrás y le subes la intensidad y ya está. Ni rele necesitas. Porque el rele lo necesitas igual desde el mechero.
Enviado desde mi S6-Edge
- Agradecido: 346 veces
una pregunta para la de 6.5 se codifica tambien con vagcom como las de 5.8?
tokedj1989 - Leoner@ avanzad@
- Agradecido: 25 veces
tokedj1989 escribió:una pregunta para la de 6.5 se codifica tambien con vagcom como las de 5.8?
Si
Davido2790 escribió:tokedj1989 escribió:una pregunta para la de 6.5 se codifica tambien con vagcom como las de 5.8?
Si
pero con el 12.12 vale o tiene que ser el vcp o el vagcom original?gracias
Tarzan escribió:Muy buenas tardes.
Por fin me llego todo el material para instalarla, ahora solo me hace falta tiempo .
Donde has comprado esa cámara? Que tal funciona esa por la resolución y demás?
Isidrito - Nuev@ por aqui
- Agradecido: 10 veces
Isidrito escribió:Tarzan escribió:Muy buenas tardes.
Todabia no la he montado, cuanto este pondre fotos.
Hola soy dookky del club octava os ando siguiendo por aquí con el tema de la cámara k me hace interferencias he leído k se puede subir intensidad podríais poner la codificación para hacerlo ?[THUMBS UP SIGN]
dookky - Nuev@ por aqui
@rojas , te he dejado un mensaje privado con respecto a este tema. te agradecería muchísimo que lo pudieras leer.
zacarias - Leoner@ avanzad@
- Agradecido: 201 veces
