León Mk3 - Actualización infotainment
- Seguidores: 183
- Favoritos: 41
- Vistas: 574.559
Favoritos: BADS, Daruma, ositoerik, dmesanun, YeSL, pocososinos, jasoriab, JaviMarquez, crujipoyo, Arkan7, Cristianibias, pepeiyo69, Angel J, Xaggy, edumachuca, abollao, -alberto-, Rickymax, ferre7, Pedritoleon, Rivesgti, Alleya, davidalba, Xiguito_Corito, craken, JDCLEONFR, nemura, danihd, cenkkaya, Kisszabo, castell_lkpg, pistoleromtb, Raulportela, Martelinko, albert_naga, Adrian Anton, Gravilhas75, chaiser, popez, ruli68, denniisg2000
Seguidores: kenny_fonseca, ncx, Lavadora, juancete, jesusFR, Hysteria, MaximusRoco, Manu1986, Jorge75016, davidbj, bIxu, miyobe, MORKAS, aironsam14, jramis, kimudj, Maikermx, Javizormo, gogua, Melonkid, Kikote8, maxinew, aigort, carlosgzlez, corderazo, Lionxp, jande, Edu1589, msmdraven, Arkan7, jeroc, inamarlo, edumachuca, Josepo79, lead, camamaleon, davidmd, carrasco13, clavelstreet, mikomiko, josele77, car212121, itz18, golf_1990, LeidenSpain, vecnte, Andy_G, csabafr2013, leonfr76, Trimmer, genialsoft, Enerts, leonfrrojito, Horus, paco_22_22, ruben88, Valerofr150, molvi_mabad, Pekee69, Dav2k6, IbiFR, il_munyo, craken, ruben91mad, papo-182, el_padrino, zeratul, kaiserssosse, lytry32.hc, sbarri, ghitus, DesmoSimon, ruli68, Mramos1985, tonielfilas, braulioT, davidalba, JaviMarquez, osjamil, egarense69, fexposru, Pedrost, Illan, chetelopez, juanacho21, cuenka16, pepeiyo69, VapaV, balbu, juan7777, mams69, Helrique, Kike77, volkov, jluis, loeches, Tom70, Dconnect, Trivi83, MilleMiglia, linxes, sergi303, hector37, D83, quiquito30lv, ElFon, DALOFER17, davidap13, kigua, JOTTA, Senuto, jd_zuri, Alvi, damsolu, Leon pucelano, javi_archi, danihd, alcoleazgz, miguel23and, xarlio, jdieztec, mitxuni, Kisszabo, Gendos22, xexpir, canijo82, Brandenor, cenkkaya, kennit0, Chelazo, bertoco, benitogomez, carlosVACA, Peje, NOECUBI1, AAAJDA, trazas, martija, borjiguez, JoseXS, ferbarroso14, Wespa, Cloud_ganora, Berbe15, Valengti, Chrohu, Atajunen, Victorzabal, jrm82, carlo13, iNFeCTeD, paralaxon, ateopoeta, pepo55, ribasxisco, Raulribarroja, ivanti, lopezm0, Rubén Flp, Warelio, Vagabundo, Rekoba, Octacon, matiaso, Alianma, Raulportela, Éugen91, Rivesgti, Mcm90, DaniR86, Gravilhas75, JuanNur78, el_Asturiano, Mr.Chuflas, albert_naga, juanfrancia, Seket, algabe, pistoleromtb, ebcuatro, [GuErRa], Mario Leon, tito68
Re: Actualización infotainment
Post duplicado
Última edición por boixet el 12 Oct 2016, 09:07, editado 1 vez en total
boixet - Asidu@ en la selva
- Agradecido: 15 veces
@Aprietatuercas1974 yo tengo un system high de finales del 2014 con hd. Se puede hacer algo desde aquí (soy de Mallorca)? Lo único que no quisiera perder b la función espejo que me va de lujo, pero si se le puede poner la opción de full link sería un puntazo
Enviado desde mi D6603 mediante Tapatalk
sonxav escribió:Esto aún me da más rabia.... Con los infotaiments de los MY2014 y MY2015 ni una mísera actualización en el tiempo que lleva en el mercado (y ni se la espera) vaya panda de sinverguenzas están hechos!
Bueno, es lo que hay......
Totalmente de acuerdo...
Marcos_Colero_Fernandez - Nuev@ por aqui
aprietatuercas1974 escribió:en breve dispondre de sw para actualizar unidades,en principio de mib2 tanto high como std(las normales)
A ver...que quieres decir con eso?..vas a poder subirlas para compartir?..o solo es para ponernos los dientes largos?...si dices que estas haciendo las actualizaciones en tu conce...aun no entiendo porque no puedes pasar las updates a la gente...y nos dices que vayamos a nuestra seat...a que nos lo hagan....sabiendo que como no tengan ganas..nos diran que no existe nada ..
Yo..y muchos mas .que tenemos la 5.8" con navegador ..estamos mosqueados ..ademas..es una update sin riesgos pues es por SD y no se necesita ni ODIS para flasear ni VCP para parametrizar ...
Me podrias enviar la unidad y dejartela preparada si quisieras
aprietatuercas1974 - Aqui + que con la novi@
- Coche: Leon MK1 2.8 Cupra 4 V6 204cv
- Agradecido: 356 veces
@aprietatuercas1974 si para las 6.5 con HDD y Mirrorlink de Q4 2014-Q2 2015 les puedes poner Full Link pero "solo" con Mirrorlink y Android Auto, el módulo USB necesario para Apple CarPlay lo montais si os lo pedimos (y pagamos) o "solo" te encargas de lo del software?
Muchas gracias. Que ansia.
Eluryh - Leoner@ avanzad@
- Agradecido: 107 veces
Pregunta rápida.
Me llega el coche esta semana. Me vendrá con la actualización que se ve como el Ateca?
Grácias
Pregunta rápida.
Grácias
DjTails - Asidu@ en la selva
- Agradecido: 27 veces
Lo que seria interesante (Al menos para los que sabemos de programación) es poder tener algún firmware aunque fuese obsoleto para poderle meter mano a ver como son las tripas del mismo.
No sé si existe la posibilidad de liberar publicamente algún firmware. (O de estrangis)
Aprietatuercas---- Sabes algo al respecto?
Me gustaria destripar alguno que esté obsoleto y ver que más cositas podriamos implementar. (Cambiar aspecto, tiempos de ejecución, nuevos skins, etc, etc)
- Agradecido: 1256 veces
Si fuese posible, sería brutal.
El sistema da para muchísimas posibilidades
Eluryh escribió:@aprietatuercas1974 si para las 6.5 con HDD y Mirrorlink de Q4 2014-Q2 2015 les puedes poner Full Link pero "solo" con Mirrorlink y Android Auto, el módulo USB necesario para Apple CarPlay lo montais si os lo pedimos (y pagamos) o "solo" te encargas de lo del software?
realmente al poner el sistema con full link se instala todo,mirrorlink que ya teneis,android auto y apple car play,todo sera funcional pero el terminal apple no lo reconocera porque el usb no dispone del chip especifico que se necesita para apple.
Eso en cualquier seat se puede comprar y montarlo uno mismo sin problema.
El tema es conseguir que este el full link
aprietatuercas1974 escribió:Me podrias enviar la unidad y dejartela preparada si quisieras
Se te puede enviar la Unidad ?
Yo tengo High con disco duro
Sabes que precio tiene en el conce lo que es la unidad para que sea compatible con android auto , etc
davidmd - Leoner@ habitual
- Agradecido: 16 veces
Pues una sin disco duro son 870€ mas iva,la que tiene disco duro sobre 2000€
aprietatuercas1974 escribió:Pues una sin disco duro son 870€ mas iva,la que tiene disco duro sobre 2000€
La unidad se te puede enviar ? O visitar tu taller jejej ?
Yo haría una lista para los que realmente estamos interesados en el trabajo de @aprietatuercas1974 y que él pueda gestionar nuestras peticiones y luego ya nos entendemos via MP.
Podemos copiar y pegar...
Actualización software (MIB 1GEN 5,8'')
Actualización software (MIB 2GEN 6,5'' SIN HDD)
Actualización software (MIB 2GEN 6,5'' CON HDD y MIRRORLINK)
- Eluryh
Actualización software (MIB 2GEN 6,5'' CON HDD y FULL LINK)
- Eluryh
En este mensaje, Eluryh ha recibido 2 agradecimientos de:
arlot (12 Oct 2016, 21:02), Marcos_Colero_Fernandez (12 Oct 2016, 17:31)
Eluryh escribió:Yo haría una lista para los que realmente estamos interesados en el trabajo de @aprietatuercas1974 y que él pueda gestionar nuestras peticiones y luego ya nos entendemos via MP.
- Eluryh
- Davidmd
León Cupra 290 Foro: Presentaciones Autor: Beet Respuestas: 5 |
