León Mk3 - Actualización infotainment
- Seguidores: 183
- Favoritos: 41
- Vistas: 575.308
Favoritos: BADS, Daruma, ositoerik, dmesanun, YeSL, pocososinos, jasoriab, JaviMarquez, crujipoyo, Arkan7, Cristianibias, pepeiyo69, Angel J, Xaggy, edumachuca, abollao, -alberto-, Rickymax, ferre7, Pedritoleon, Rivesgti, Alleya, davidalba, Xiguito_Corito, craken, JDCLEONFR, nemura, danihd, cenkkaya, Kisszabo, castell_lkpg, pistoleromtb, Raulportela, Martelinko, albert_naga, Adrian Anton, Gravilhas75, chaiser, popez, ruli68, denniisg2000
Seguidores: kenny_fonseca, ncx, Lavadora, juancete, jesusFR, Hysteria, MaximusRoco, Manu1986, Jorge75016, davidbj, bIxu, miyobe, MORKAS, aironsam14, jramis, kimudj, Maikermx, Javizormo, gogua, Melonkid, Kikote8, maxinew, aigort, carlosgzlez, corderazo, Lionxp, jande, Edu1589, msmdraven, Arkan7, jeroc, inamarlo, edumachuca, Josepo79, lead, camamaleon, davidmd, carrasco13, clavelstreet, mikomiko, josele77, car212121, itz18, golf_1990, LeidenSpain, vecnte, Andy_G, csabafr2013, leonfr76, Trimmer, genialsoft, Enerts, leonfrrojito, Horus, paco_22_22, ruben88, Valerofr150, molvi_mabad, Pekee69, Dav2k6, IbiFR, il_munyo, craken, ruben91mad, papo-182, el_padrino, zeratul, kaiserssosse, lytry32.hc, sbarri, ghitus, DesmoSimon, ruli68, Mramos1985, tonielfilas, braulioT, davidalba, JaviMarquez, osjamil, egarense69, fexposru, Pedrost, Illan, chetelopez, juanacho21, cuenka16, pepeiyo69, VapaV, balbu, juan7777, mams69, Helrique, Kike77, volkov, jluis, loeches, Tom70, Dconnect, Trivi83, MilleMiglia, linxes, sergi303, hector37, D83, quiquito30lv, ElFon, DALOFER17, davidap13, kigua, JOTTA, Senuto, jd_zuri, Alvi, damsolu, Leon pucelano, javi_archi, danihd, alcoleazgz, miguel23and, xarlio, jdieztec, mitxuni, Kisszabo, Gendos22, xexpir, canijo82, Brandenor, cenkkaya, kennit0, Chelazo, bertoco, benitogomez, carlosVACA, Peje, NOECUBI1, AAAJDA, trazas, martija, borjiguez, JoseXS, ferbarroso14, Wespa, Cloud_ganora, Berbe15, Valengti, Chrohu, Atajunen, Victorzabal, jrm82, carlo13, iNFeCTeD, paralaxon, ateopoeta, pepo55, ribasxisco, Raulribarroja, ivanti, lopezm0, Rubén Flp, Warelio, Vagabundo, Rekoba, Octacon, matiaso, Alianma, Raulportela, Éugen91, Rivesgti, Mcm90, DaniR86, Gravilhas75, JuanNur78, el_Asturiano, Mr.Chuflas, albert_naga, juanfrancia, Seket, algabe, pistoleromtb, ebcuatro, [GuErRa], Mario Leon, tito68
Re: Actualización infotainment
He encontrado esta página de SEAT Alemania en la que hay algunas versiones para las gen1. http://www.seat.de/kontakt/downloads/se ... dates.html
javigody - Aqui + que con la novi@
- Agradecido: 274 veces
javigody escribió:He encontrado esta página de SEAT Alemania en la que hay algunas versiones para las gen1. http://www.seat.de/kontakt/downloads/se ... dates.html
Ya se han visto antes (creo que en la versión austríaca) y son actualizaciones del módulo de bluetooth.
- Agradecido: 3573 veces
aprietatuercas1974 escribió:stewei escribió:aprietatuercas1974 escribió:siento deciros que no espereis la actualizacion para esas versiones y os explico el motivo
la version de hardware que teneis es la 24 y la version de firmware mas moderna que soporta ese hw es la 0346,y esa precisamente es una version beta no publica para los coches de calle.
Por lo tanto esa actualizacion no os la pondran nunca en concesionario.
a partir de hw 30 ,si os fijais ya son los que salen con la nueva interfaz de mosaico
@aprietatuercas1974 Pues siento discrepar.... pero yo tengo Hw 42 y no me sale la interfaz de mosaico...
P.D.: y Sw 319.
Me extraña bastante,porque incluso con coches nuevos fabricados este mes el hw mas alto en las std es el 30 y el firmware el 0355 o 0358 creo.
Creo que ese debe de ser una high con full link o mirrorlink,y en esas unidades la primera version que tenia el menu de mosaicos es la 0674 o puede que en la 0355,esa no estoy seguro al 100%
Yo tengo la high con hw 50 y sw 355 y sin mosaico
Duplicado
¿Pero para que modelo es?
Porque en el mio no da la versión del. BT por ningún lado (es el que viene el el style connect plus sin GPS)
LeidenSpain - Aqui + que con la novi@
- Agradecido: 59 veces
LeidenSpain escribió:javigody escribió:He encontrado esta página de SEAT Alemania en la que hay algunas versiones para las gen1. http://www.seat.de/kontakt/downloads/se ... dates.html
Para las unidades de primera generacion
javigody escribió:LeidenSpain escribió:javigody escribió:He encontrado esta página de SEAT Alemania en la que hay algunas versiones para las gen1. http://www.seat.de/kontakt/downloads/se ... dates.html
Ok gracias
Entonces me olvido de este tema
A los que ya teneis la apariencia del ateca, os aparecen unos puntitos debajo del reloj en modo espera, que si deslizais aparecen diferentes diseños de ese reloj?
javigody escribió:A los que ya teneis la apariencia del ateca, os aparecen unos puntitos debajo del reloj en modo espera, que si deslizais aparecen diferentes diseños de ese reloj?
A mi si: tres tipos diferentes de relojes.
Yo llevo el primero.
Si queréis le hago fotos
javigody escribió:aprietatuercas1974 escribió:stewei escribió:aprietatuercas1974 escribió:siento deciros que no espereis la actualizacion para esas versiones y os explico el motivo
P.D.: y Sw 319.
en unidades std sin disco duro son hw 30 para poder actualizar las unidades para la apariencia de ateca
std:
hw 24 solo actualizable hasta la version 0346 apariencia de ateca pero no es un firmware publico y tiene algun bug pequeño
hw 30 viene desde la version 0351,0355 y 0358 creo recordar son firmwares publicos y que to sepa salvo algun problema puntual no tienen bugs conocidos
las high no se exactamente el hw que tienen pero por lo que comentais estan con hw 50,y firmware 355 esas son con full link,hay gente que tiene hw menor y firmware 0123 con mirrorlink solo,y han podido actualizar a la version 0674,ese es el primero que llevan con version de mosaico y menu de ateca.
Todas la high se pueden actualizar directamente al firmware que queramos,ahora incluso ha salido uno que no esta aun en ningun vehiculo que es el 0818 y 0897
si quereis saber algo mas os informare encantado
aprietatuercas1974 - Aqui + que con la novi@
- Coche: Leon MK1 2.8 Cupra 4 V6 204cv
- Agradecido: 356 veces
aprietatuercas1974 escribió:javigody escribió:aprietatuercas1974 escribió:stewei escribió:aprietatuercas1974 escribió:siento deciros que no espereis la actualizacion para esas versiones y os explico el motivo
P.D.: y Sw 319.
std:
Sí, por favor, toda la información que aportes será bienvenida. En cuanto a novedades se refiere, aportan algo distinto estas ultimas versiones (818 y 897)?
Yo tengo high con 0123, de donde puedo sacar las actualizaciones? @aprietatuercas1974
Arkan7 - Primeros Pasos
P.D.: y Sw 319.
std:
@aprietatuercas1974, a mí me interesaría saber qué bugs tiene la 0346...
Sent from my Nexus 5 using Tapatalk
- Agradecido: 199 veces
tevaadarelsol escribió:aprietatuercas1974 escribió:javigody escribió:aprietatuercas1974 escribió:stewei escribió:aprietatuercas1974 escribió:siento deciros que no espereis la actualizacion para esas versiones y os explico el motivo
P.D.: y Sw 319.
std:
+1
jony83 - Leoner@ habitual
- Agradecido: 20 veces
de los que se que se lo han instalado elguna vez los modos no responden,es el que se pero vamos en la version 0241 y 0245 se que pasaba tambien alguna vez
En este mensaje, aprietatuercas1974 ha recibido un agradecimiento de:
tevaadarelsol (08 Nov 2016, 16:26)
