León Mk3 - Actualización infotainment
Seguidores: kenny_fonseca, ncx, Lavadora, juancete, jesusFR, Hysteria, MaximusRoco, Manu1986, Jorge75016, davidbj, bIxu, miyobe, MORKAS, aironsam14, jramis, kimudj, Maikermx, Javizormo, gogua, Melonkid, Kikote8, maxinew, aigort, carlosgzlez, corderazo, Lionxp, jande, Edu1589, msmdraven, Arkan7, jeroc, inamarlo, edumachuca, Josepo79, lead, camamaleon, davidmd, carrasco13, clavelstreet, mikomiko, josele77, car212121, itz18, golf_1990, LeidenSpain, vecnte, Andy_G, csabafr2013, leonfr76, Trimmer, genialsoft, Enerts, leonfrrojito, Horus, paco_22_22, ruben88, Valerofr150, molvi_mabad, Pekee69, Dav2k6, IbiFR, il_munyo, craken, ruben91mad, papo-182, el_padrino, zeratul, kaiserssosse, lytry32.hc, sbarri, ghitus, DesmoSimon, ruli68, Mramos1985, tonielfilas, braulioT, davidalba, JaviMarquez, osjamil, egarense69, fexposru, Pedrost, Illan, chetelopez, juanacho21, cuenka16, pepeiyo69, VapaV, balbu, juan7777, mams69, Helrique, Kike77, volkov, jluis, loeches, Tom70, Dconnect, Trivi83, MilleMiglia, linxes, sergi303, hector37, D83, quiquito30lv, ElFon, DALOFER17, davidap13, kigua, JOTTA, Senuto, jd_zuri, Alvi, damsolu, Leon pucelano, javi_archi, danihd, alcoleazgz, miguel23and, xarlio, jdieztec, mitxuni, Kisszabo, Gendos22, xexpir, canijo82, Brandenor, cenkkaya, kennit0, Chelazo, bertoco, benitogomez, carlosVACA, Peje, NOECUBI1, AAAJDA, trazas, martija, borjiguez, JoseXS, ferbarroso14, Wespa, Cloud_ganora, Berbe15, Valengti, Chrohu, Atajunen, Victorzabal, jrm82, carlo13, iNFeCTeD, paralaxon, ateopoeta, pepo55, ribasxisco, Raulribarroja, ivanti, lopezm0, Rubén Flp, Warelio, Vagabundo, Rekoba, Octacon, matiaso, Alianma, Raulportela, Éugen91, Rivesgti, Mcm90, DaniR86, Gravilhas75, JuanNur78, el_Asturiano, Mr.Chuflas, albert_naga, juanfrancia, Seket, algabe, pistoleromtb, ebcuatro, [GuErRa], Mario Leon, tito68
Re: Actualización infotainment
Notapor artek90 el 27 Nov 2016, 20:09
miceor escribió:En la 5F queda el registro de las ultimas 10 modificaciones nada mas.
Eso lo estuve viendo yo en la propia SEAT.
En el proceso de Actualización, por un lado se hace el chequeo de lo que tienes, lo sobreescribe respetando las modificaciones realizadas con la fecha que se hicieron y aplica la actualización en base a la configuración actual.
Si hay alguna cosa nueva, la implementa (Vease visualización del Ateca),
Una vez actualizado, se reinicia precisamente para volver a releer todas las configuraciones.
El registro de la tarjeta como tu dices no queda en ningún lado registrado por una cuestión principal, porque la tarjeta no lleva ninguna identificación.
La orden principal de instalación así como el listado de cada elemento a actualizar y el orden del mismo se lo indica el archivo Metainfo.txt y si cualquiera que entienda un poquito de esto le echa un vistazo se dará cuenta de que no hay ninguna vinculación de la tarjeta con el sistema de instalación, asi como que es una instalación generalista no unica para cada vehiculo.
Yo he tenido las originales y las propias tarjetas no llevan ni el label.
Unicamente queda registrado en el sistema que se han realizado las actualizaciones de los modulos correspondientes, con la identificación del SW y FW correspondiente y la fecha y además luego en algunos casos que no en todos da el error 1555 que significa simplemente que no se ha validado la instalación de la actualización por el servicio oficial.
Para ello hay que validar el SVM y punto.
O sea, que si dejas pulsado el botón Menú hasta que te sale el segundo menú podrás ir viendo que modulos se han actualizado y cuando. Punto y pelota, no hay nada mas que quede registrado.
Si la tarjeta crease un registro de autentificación logicamente no sería necesaria la validación posterior de instalación.
Así que hablemos con propiedad y no liemos a la gente con cosas que no son.
podemos tener problemas con el tema de garantia o no ? pido que me lo validen cuando cambie aceite o me callo mejor ?
Imagen Leon ST FR 1.8 TSI --->Imagen
artek90
Agradecido: 187 veces
Notapor miceor el 27 Nov 2016, 20:14
Yo no diria nada.
Que te hagan la revisión y si te dicen algo, les pones los ojos saltones y les dices que no tienes ni dea de que te están contando.
Que se pone la cosa tensa, pues que te quedaste sin bateria estas vacaciones y tuviste que llevarlo a un concesionario en Luxemburgo y estuvieron tocando cosas ellos, que ni idea de lo que hicieron.
Que te dicen que lo tienen que validar.... Pues hagan ustedes lo que tengan que hacer.
Última edición por miceor el 27 Nov 2016, 20:16, editado 1 vez en total
En este mensaje, miceor ha recibido 2 agradecimientos de:
artek90 (27 Nov 2016, 20:29), PacoRuiz3107 (29 Ene 2018, 15:47)
miceor
Agradecido: 1256 veces
Notapor rojas el 27 Nov 2016, 20:14
Lo que dice @aprietatuercas1974 tiene mas sentido del que parece , vease el ejemplo de las actualizaciones de GPS ... si no es la SD original no funciona ya que lleva unas particiones ocultas que identifican si la SD es original o no .
Si alguien me dice que ha sido capaz de grabar una cartografia en cualquier otra SD y le ha funcionado ... yo me callo :si: :si:
Alguien ??? :cejas:
rojas
Coche: Leon MK3 1.5 TGI 130cv
Agradecido: 1884 veces
Notapor miceor el 27 Nov 2016, 20:18
Es totalmente diferente Rojas.
Las del navegador llevan una particion CDFS y en ella una serie de carpetas y archivos ocultos.
Creo que es así, en otros casos para protejer el medio tangible lo que se hace es implementar archivos fantasmas que en realidad no superan 1K de tamaño y se les engorda por ejemplo a 6GB (Mentira), poniendo dos o mas en una tarjeta, no vas a poder duplicarla bajo ningún concepto porque no tendrás espacio disponible para escribir en la nueva.
Luego se mete una linea de comprobación de la existencia de tales archivos y su tamaño y arreando.
Esta técnica era muy común en cd de juegos por ejemplo.
En el caso del navegador. el sistema lo primero que hace en ese caso es comprobar que la SD es la original.
Es logico que protejan un producto que es de pago.
Las SD de las actualizaciones, las he tenido yo y te puedo asegurar que no llevan ninguna partición adicional.
Las he estudiado muy, pero que muy a fondo.
Última edición por miceor el 27 Nov 2016, 20:35, editado 3 veces en total
miceor
Notapor rojas el 27 Nov 2016, 20:30
eso ya lo desconozco , solo se por los antecedentes de la sd de cartografia
rojas
Notapor aprietatuercas1974 el 27 Nov 2016, 20:33
yo hablo con propiedad y segun las cosas que me han explicado en la formacion de vw y de seat,tambien hay cosas que he dicho sobre las actualizaciones y tu has obviado.
Pero bueno parece que cuando uno explica y es correcto no pasa nada y cuando cometemos un error si se nos critica.
Pero bueno viendo el problema poco hablare sobre el tema.
aprietatuercas1974
Coche: Leon MK1 2.8 Cupra 4 V6 204cv
Agradecido: 356 veces
Notapor MORKAS el 27 Nov 2016, 20:38
Cambiando de tema...esa particion CDFS..seria posible clonarla?..y ponerls en otra sd?...[SMILING FACE WITH OPEN MOUTH AND TIGHTLY-CLOSED EYES][SMILING FACE WITH OPEN MOUTH AND TIGHTLY-CLOSED EYES]
MORKAS
Agradecido: 368 veces
Notapor miceor el 27 Nov 2016, 20:43
Que no te lo tomes por las malas Aprietatuercas.
Lo que te he dicho es que tenemos que hablar con propiedad, que tu en el post primero que has puesto sobre el registro de la tarjeta lo has afirmado sin dar un argumento.
Luego dices que es lo que te contaron.
Joderrr, que yo no te critico, Dios me libre.
Tampoco he obviado nada de lo que tu has dicho, ni en este post ni en otros relativos.
Todo lo contrario.
Me parece que tienes unos altisimos conocimientos al respecto de este asunto, pero que hay explicar las cosas bien explicadas porque si no la gente comete errores.
No hay más.
Solo espero que no te lo tomes a mal y continues ilustrandonos con tus conocimientos.
Lo digo sinceramente.
miceor
Notapor aprietatuercas1974 el 27 Nov 2016, 20:50
no me lo tomo a mal,tu tienes conocimiento de este tema y yo tengo de otros,y en este tema me fie de lo que me contaron en la formacion.
Que seguramente es lo que les dijeron a ellos en su formacion.
Yo creo que he avisado en varias ocasiones de los peligros de las actualizaciones del 5f,sobretodo de las de la de 6.5
En este mensaje, aprietatuercas1974 ha recibido un agradecimiento de:
LeidenSpain (05 Dic 2016, 20:08)
aprietatuercas1974
Notapor jony83 el 27 Nov 2016, 20:57
Me estáis dejando acojonado de lo que controláis del tema......
Los del concesionario de Seat en zgz dudo q sepan ni la mitad de la mitad de la mitad....
jony83
Agradecido: 20 veces
Notapor artek90 el 27 Nov 2016, 20:58
yo espero que de alguna manera se va poder quitar el fallo 1555 sin tener que pasar por concesionario.
artek90
Notapor miceor el 27 Nov 2016, 21:00
aprietatuercas1974 escribió:no me lo tomo a mal,tu tienes conocimiento de este tema y yo tengo de otros,y en este tema me fie de lo que me contaron en la formacion.
Correctisimo.
No pongo en duda tus conocimientos y tampoco pongo en duda que te lo hayan contado así.
Con respecto a las actualizaciones, creo que del mismo modo que tu adviertes las cosas en cada caso, la gente DEBE leer en todo momento esas advertencias.
Ya las has puesto tu en diversas ocasiones.
¿Cuantas veces habrá que repetirlo?
Las actualizaciones están ahí, ahora que cada cual lea lo que quiera leer, comprenda lo que quiera comprender y desde luego asuma lo que tenga que asumir.
Yo he actualizado la mia a base de leer, leer y leer, siguiendo tus pasos en muchas ocasiones, tus progresos y cuando lo he tenido claro me echado al toro y lo he hecho.
Pero para eso estamos aquí, para aprender, para compartir y para ayudar al que lo necesite.
¿Algunas veces nos equivocamos?
Pues claro que si. Y cuando eso ocurre siempre hay alguien para echar un capote y sacarte del error.
Me alegro que no te hayas enfadado.
Un saludo compañero.
Última edición por miceor el 27 Nov 2016, 21:20, editado 1 vez en total
miceor
Notapor Chimguy el 27 Nov 2016, 21:05
Actualizado MIB 1 5F 5.8" en unos 30 minutos y en principio todo bien aunque no lo he trasteado mucho por falta de tiempo.
No he pasado vagcom por lo que no se si tengo el fallo, aunque si no da problemas no me voy a comer la cabeza con ello. Si tengo que llevarlo en garantia y dicen algo les dire que tuve problemas en un viaje y que me hicieron una actualizacion y punto.
Por cierto, los iconos del menu media me siguen saliendo como siempre ¿en el 5F no cambian?
Chimguy
Agradecido: 76 veces
Notapor Destino el 27 Nov 2016, 21:23
Rebuscando encontre esto:
https://www.youtube.com/watch?v=gWXJI8V9OEc
Y texto de la descripcion:
This video is about software update for Škoda Octavia MIB1 (Amundsen-Bolero) infotainment system.
This video is only for information, learning purpose! I am not responsible if you tray this your self and have any problems!
Update can be done by your Skoda dealer or authorized Skoda service/service partner.
Update instructions:
1) Format your SD card or USB drive to FAT32 (min. 8 GB card needed)
2) Download & unpack the archive to the card (3 folders and the .txt should be in the root directory)
3) Ignition ON (engine not running), insert your SD card or USB
4) Press and hold the MENU button, wait for the service menu to appear
5) Select SW Update, Update
6) Select USB or SD card, select Release
7) Then you can select the components to update, probably all available preselected by default
8) Select Start
9) The update process will start and the HU will restart several times. Don't press anything.
10) When it is finished you will get an update summary message, just close it
11) "Version back documentation" screen appears (final step), this is the moment to connect your VCDS cable
12) Go to module 5F, Adaptations, and select channel "Confirmation of installation change"
13) Check your current "Stored value" and write it down
14) Start Windows Calculator and set it to "Programming" mode (Alt+3)
15) Calculate the following: abcd Xor C9D2 (abcd is your "Stored value", C9D2 is fix). Double check it. :)
16) Enter your new value (in "xx xx" format, using a space character) and click "Do It!" (you may get an "Unknown (0x00)" error, no problem)
17) Your headunit should restart automatically in a few secs.
18) Once your HU works again, turn ignition OFF.
19) Ignition ON again and start VCDS again
20) Start an Autoscan and check for fault codes on different modules (09, 17, 19, 5F, ...) and clear them
21) You are done
In the video I didn't do any VCDS coding or afterwards.
Como se puede ver parece un infotaiment similar al nuestro, y no se si la solucion al error 1555 podria solventarse como dice este chico. Lo dejo aqui para los especialistas :)
Destino
Notapor artek90 el 27 Nov 2016, 21:42
Destino escribió:Rebuscando encontre esto:
8) Select Start
21) You are done
Lo probare
artek90
Nuevo León por Madrid
Foro: Presentaciones
Autor: Pampanilla
Respuestas: 0
Hilo del León mkIV e-hybrid
Foro: General
Autor: vkr84
Respuestas: 610
SEAT Leon 1.0 TSI S&S Style XS 81 kW 110CV
Autor: Waltry
Respuestas: 5
LEON ST Special Edition
Autor: Buils2
Respuestas: 6
León Cupra 290
Autor: Beet
Respuestas: 5
Usuarios navegando por este Foro: amaringo y 9 invitados
