Seguidores: golf_1990, josusanchez5b, Jastur, r11ourense, MerioE, davidddgt, jose.a.llamas, gato125, Pkt, byChule, Hovig, SorianoFco, jygalvan, CubanPitbull, corderazo, israher, iDavid9669, nyro, pirulo79, Edu1589, ramargo75, javi.ferrer, kikelin, aleejandroogm, Trimmer, car212121, LeoST, Besaygf, kinipc, Rasekfighter, Romera, MartinLeon, camamaleon, Aceroinox1a, jramis, Juanquique, josele77, marlop, Peje, Pedrost, bailyibz, wiki88, teltronik, gogua, sirkez, carlosgzlez, mcecho, genialsoft, aironsam14, JoseCa, Dandy_gsi, vanscampa, Joseibz, trekam, La_jungla, jorgecrackets, aigort, msmdraven, IRO, Jorge75016, alejandro_javier, ivan0909, jmfcoto, viktor_ct_95, maxxg2, olgalberto1, danifusi, Josepo79, er_trompe, miyobe, jande, Petri, itz18, jagman, serguey79, rafapadilla93, Mate, undernok, lead, lead, csabafr2013, jluis, olmeras, LeidenSpain, osjamil, Valerofr150, flope63, Herrdoktor, pocososinos, carrasco13, pichonclv, C.reina, Daner84, inamarlo, aguscalderon, BaZZ, yujakantabro, Fonek, LARABA, juanmaroger, juanmac, Kipu, IvanMc2, garrafa2, Linker89, mihai G, Igor, bronce702, creasy1977, Gsclosada, lebowski, jaro_84, charly425, leonfr76, DBS83, joseanvazquez501, M3rs, borgio, NOCIVOX, FcoJ.M.N., VillaSB, t4alberto, lytry32.hc, david_gz, Kasky, diegol147, jasoriab, jninomo, jmiturbe, chetelopez, utopia95, Dreziel, jonatan1988, xsoldadito, Illan, Fernandoestrada, jd_zuri, Juande667, xjuliox, Bettor, solanomor01, Chinyero, volkov, braulioT, Maikermx, iNowack, D83, MORKAS, dRoXe, JaviMarquez, danitre, Davi_TGI, DiegoR, ertate, cuenka16, nicotzioras, Spok68, urbion, linxes, kukikukarron, Talnoseque, Hyperr, VapaV, jfermar, Moigijon, slyjay73, DuckToy, nachomart, Iosu21, sbarri, sebasresa, Beiró, Llisus, agus_piscis10, Action SVG, Alc16, Trivi83, eyebee, riclanico, Per3zo, Qore, lolorm, abollao, Alvi, sergi303, Xilenos, barret, Gus_Fring, malloc, TomH30, jmofcb, paco_22_22, luigi323, Chelazo, dani10s, victor david, Yeiem93, Luiggi7, Guillen222, yoflipo, nenazojuanma, nitro_g4074, Senuto, gabivvamesia, javichu312, richard_11, Yery, Ivensound, El_pelos44, rvicario76, Mr.Chuflas, subaru_3, eruizm, Gomez89, barubita, Nicoplas, javibmw, el_noi_80, kapi21, satoo, barrosdepor, camaon99, craken, Flow-Rider, Castro87, Kikedecefe, xexpir, Cristian2014mx, _Juansp, jornefra, cucci, Pablitofr, Pablitofr, Rober_SR, kevinhtbs, chocoleitos, RamonLaC, cesarsl, drnrd, conquepoquico, hectordrums, Neuw84, bertoco, dondani96, cupralex, Octacon, pablomus85, josean-opc, davidap13, Raaz, erlanz, canijo82, MarcosRG86, Alianma, SinName, mSx, evomaoleon, BertopenST, a.cuadros71, Lumara, Gendos22, borjayadri2, litllevill, Jandrew, galelir, Josep20, borjiguez, THC77, di360, Juanjocantabria, grijan 2.0, copii92, JDMG, Morales92, nadiia.bcn93, yo_javi89, yurkli, Atajunen, carlo13, Desertcuervo, floppy666, amg129, manjerico, Franr50, iNFeCTeD, Rotemburgero, Link, kivamz, dj_ferrix, manu5, Vagabundo, aaronfdez, Manzi, Perilla, juanaco, pepetgi, pistoleromtb, cp_jj, diepecu2, Freddy169, Welmonk, JaquetónST, alrodri, LuisNM, Rekoba, bizu, ginyu 83, ephreon, rr7mo, Def89, CrisFRST5F, Mohoska, gilen44, ayl, SantiPMI, Jesús Peinado, 05kar, Lata8, Adrián pcg, Warelio, carlosVACA, trazas, barris31, danieleon, enriquevalera, antonioagui95, tito68, Sarge86, victorvOrtiz, bigpicha, ericoperico, JulinM, AlvaroRamlo, josermancol, Davidv, flotter, V de Viana, zainao, LeónST, rubiotuning, RacingSport
Notapor cvillajos el 11 Dic 2016, 13:30
Marianikko escribió:Pues os paso las capturas de lo que me dice el módulo A5
Esta última es para que veáis los módulos que me saca por defecto
En el módulo 55 he visto este valor, supongo que es para la altura pero al intentar modificar me pide codigo del módulo
Lo sabéis?
@Marianikko , pasate por una Seat y que te revisen la A5.
Sobre el códigos de seguridad de la 55 es '20103'
cvillajos
Agradecido: 3574 veces
Notapor miceor el 11 Dic 2016, 13:43
MORKAS escribió:
miceor escribió:A mi me vibra el volante cuando empieza a corregir el sólo, vuelve a vibrar cuando te avisa de que tomes el volante y casi siempre, estando activo (en verde) te vas a meter a un carril y te vibra e intenta corregir la trayectoria.
Lo del Sound Actor se puede modificar también con el ObDeleven.
Yo no lo tengo y no puedo ver el texto correcto
Pero sería algo asi:
Modulo A9
Adaptación
Lautstärke des Aktuator für Körperschall auswählen (Volumen del Sound Actor)
Cambiar el valor.
Normalmente viene a 100%.
Si lo pones a 0 se desactiva.
Uhmmm..pero es muy poco lo qur vibra...no?.o al menos este mio ..probare..pero..como te comenté...nunca he sido capaz de modificar la vibracion ni los mods rederentes al lane assist...no se...por que .
Si lo tienes para activar en el menu del infotainment, no te deja cambiarlo en Obdeleven.
miceor
Agradecido: 1256 veces
Notapor MORKAS el 11 Dic 2016, 14:00
Modulo A9
Adaptación
Cambiar el valor.
Ahh..ok...pero en el menu...solo hay la opcion de "guiado central en carril" ...si lo quito podria modificar lo demas?.probare...y..como eliminar esa opcion del menu?..investigare..
MORKAS
Agradecido: 368 veces
Notapor miceor el 11 Dic 2016, 14:04
No.
El menú de vibración añadido después.
miceor
Notapor Marianikko el 11 Dic 2016, 14:04
Lo sabéis?
Joder me estás acojonando... Que el coche no tiene ani un año... El tema es como le digo que no funciona el módulo? Por tema garantía y tal no habría problema?
Marianikko
Agradecido: 28 veces
Notapor MORKAS el 11 Dic 2016, 14:07
miceor escribió:No.
Pues no tengo menu de vibracion...luego lo miro y comento....
MORKAS
Notapor er_trompe el 11 Dic 2016, 14:18
@miceor yo estuve en la seat y les pregunte de la vibración del volante, a raiz de que vi que de podía modificar la intensidad de la vibración y a mi no me vibra nunca y la respuesta de ellos fué que el volante no vibra con el asistente de carril, que te centra en el carril y punto... aprovecharé mañana que voy a otra seat diferente y a ver que pasa. Si no saben, que pregunten a fábrica pero que no hablen por hablar. Gracias por la aclaración de que a ti si te vibra
Es de bien nacido ser agradecido. Si te ha resultado útil este mensaje, dale al botoncito de gracias ;)
Antes de preguntar, escribe tu duda aqui, posiblemente ahorres tiempo y nos lo ahorres a los demás.
En este mensaje, er_trompe ha recibido 2 agradecimientos de:
LeidenSpain (14 Dic 2016, 23:59), MORKAS (11 Dic 2016, 14:28)
er_trompe
Coche: Leon MK3 1.5 TGI 130cv
Agradecido: 124 veces
Notapor miceor el 11 Dic 2016, 14:19
@Marianikko
Yo comprobaria la centralita fisicamente.
Abrete el capó y mira que no haya nada raro en el conector (Parcialmente desenganchado, que esté flojo, que hay humedades)
Si todo está bién, yo desconectaría el borne negativo de la bateria durante unos 5 minutos.
Lo vuelves a conectar.
Pones la llave en contacto y te saldrán un montón de mensajes de error en el FIS.
Arranca el coche y gira el volante a tope a ambos lados. Se quitarán todos los fallos del FIS.
Conecta el OBDeleven y borra todos los fallos.
Comprueba si te sale la A5.
Ahora que lo pienso, la a5 creo que no va en el motor. No estoy seguro.Luego lo miro en el Elsawin por ubicación.
Lo mismo es un fusible.
miceor
Notapor Marianikko el 11 Dic 2016, 14:31
miceor escribió:@Marianikko
Ok gracias
Marianikko
Notapor Gerni9 el 11 Dic 2016, 16:08
Modulo A9
Adaptación
Cambiar el valor.
Muchísimas gracias @miceor veo que me has entendido. Lo tendré en cuenta y lo intentare cuando me llegue el aparatito, por cierto por vuestra culpa lo acabo de pedir :lol: Espero tenerlo pronto y empezar a hacer los mods, ya os contaré que tal. Muchas gracias por vuestros aportes y videos ayudan mucho ;)
P.D: Se puede trastear con una conexión 4G+??? Esque no tendría posibilidad de usar wifi.
Gerni9
Notapor Marianikko el 11 Dic 2016, 18:33
Modulo A9
Adaptación
Cambiar el valor.
Muchísimas gracias @miceor veo que me has entendido. Lo tendré en cuenta y lo intentare cuando me llegue el aparatito, por cierto por vuestra culpa lo acabo de pedir Espero tenerlo pronto y empezar a hacer los mods, ya os contaré que tal. Muchas gracias por vuestros aportes y videos ayudan mucho ;)
Yo he hecho todo con el 4G sin problemas.
En este mensaje, Marianikko ha recibido un agradecimiento de:
Gerni9 (11 Dic 2016, 19:25)
Marianikko
Notapor ximolink el 11 Dic 2016, 22:34
Buenas a todos,lo primero agradecer a miceor los vídeos y aportes al foro que son muy buenos.
Tengo el obd Eleven unos días y todas las modificación me han salido bien menos la de las luces DRL a contrafase con los intermitentes,despues de hacer todas las modificaciones en el módulo 09 como pone miceor en la página 1 el faro izquierdo no hace nada,el derecho con el intermitente va perfecto,cuando se enciende el intermitente se apaga la luz DRL y al revés pero el izquierdo no hace nada, a alguien le pasa? Me he saltado algún paso?
ximolink
Coche: Leon MK1 1.9 TDI 90cv
Notapor Marianikko el 12 Dic 2016, 12:17
@miceor sabes donde puede estar esa centralita o que debería de mirar? me tiene muy mosca el tema y claro me da que a la seat con el tema no puedo ir. Gracias de antemano ;)
Marianikko
Notapor miceor el 12 Dic 2016, 12:27
No he tenido tiempo de mirarlo.
Miratelo por pasos.
Fusibles, comprueba la conexión de la centralita por si acaso, desconectar bateria, para ir descartando cosas.
Se tarda muy poco en ir mirando esas cosas,una vez descartados posibles fallos miramos a ver que puede ser.
A veces te puedes volver loco con una tonteria, de todas maneras, es que no sé si este problema te ha surgido a raiz de hacer algo o ha sido algo casual, para saber si el problema es derivado de una manipulación o no.
miceor
Notapor Marianikko el 12 Dic 2016, 12:49
miceor escribió:No he tenido tiempo de mirarlo.
Miratelo por pasos.
El problema estaba antes de pasar el OBD ya que no había tocado nada y ya de primeras no tenía acceso al modulo A5 por eso te decía post atrás que a mí no me lo reconocía.
Pues miraré los fusibles y luego intentaré apagar batería como me dices.
Muchisimas gracias
Marianikko
Usuarios navegando por este Foro: Majestic-12 [Bot] y 9 invitados
