León Mk3 - Actualización infotainment
- Seguidores: 183
- Favoritos: 41
- Vistas: 575.922
Favoritos: BADS, Daruma, ositoerik, dmesanun, YeSL, pocososinos, jasoriab, JaviMarquez, crujipoyo, Arkan7, Cristianibias, pepeiyo69, Angel J, Xaggy, edumachuca, abollao, -alberto-, Rickymax, ferre7, Pedritoleon, Rivesgti, Alleya, davidalba, Xiguito_Corito, craken, JDCLEONFR, nemura, danihd, cenkkaya, Kisszabo, castell_lkpg, pistoleromtb, Raulportela, Martelinko, albert_naga, Adrian Anton, Gravilhas75, chaiser, popez, ruli68, denniisg2000
Seguidores: kenny_fonseca, ncx, Lavadora, juancete, jesusFR, Hysteria, MaximusRoco, Manu1986, Jorge75016, davidbj, bIxu, miyobe, MORKAS, aironsam14, jramis, kimudj, Maikermx, Javizormo, gogua, Melonkid, Kikote8, maxinew, aigort, carlosgzlez, corderazo, Lionxp, jande, Edu1589, msmdraven, Arkan7, jeroc, inamarlo, edumachuca, Josepo79, lead, camamaleon, davidmd, carrasco13, clavelstreet, mikomiko, josele77, car212121, itz18, golf_1990, LeidenSpain, vecnte, Andy_G, csabafr2013, leonfr76, Trimmer, genialsoft, Enerts, leonfrrojito, Horus, paco_22_22, ruben88, Valerofr150, molvi_mabad, Pekee69, Dav2k6, IbiFR, il_munyo, craken, ruben91mad, papo-182, el_padrino, zeratul, kaiserssosse, lytry32.hc, sbarri, ghitus, DesmoSimon, ruli68, Mramos1985, tonielfilas, braulioT, davidalba, JaviMarquez, osjamil, egarense69, fexposru, Pedrost, Illan, chetelopez, juanacho21, cuenka16, pepeiyo69, VapaV, balbu, juan7777, mams69, Helrique, Kike77, volkov, jluis, loeches, Tom70, Dconnect, Trivi83, MilleMiglia, linxes, sergi303, hector37, D83, quiquito30lv, ElFon, DALOFER17, davidap13, kigua, JOTTA, Senuto, jd_zuri, Alvi, damsolu, Leon pucelano, javi_archi, danihd, alcoleazgz, miguel23and, xarlio, jdieztec, mitxuni, Kisszabo, Gendos22, xexpir, canijo82, Brandenor, cenkkaya, kennit0, Chelazo, bertoco, benitogomez, carlosVACA, Peje, NOECUBI1, AAAJDA, trazas, martija, borjiguez, JoseXS, ferbarroso14, Wespa, Cloud_ganora, Berbe15, Valengti, Chrohu, Atajunen, Victorzabal, jrm82, carlo13, iNFeCTeD, paralaxon, ateopoeta, pepo55, ribasxisco, Raulribarroja, ivanti, lopezm0, Rubén Flp, Warelio, Vagabundo, Rekoba, Octacon, matiaso, Alianma, Raulportela, Éugen91, Rivesgti, Mcm90, DaniR86, Gravilhas75, JuanNur78, el_Asturiano, Mr.Chuflas, albert_naga, juanfrancia, Seket, algabe, pistoleromtb, ebcuatro, [GuErRa], Mario Leon, tito68
Re: Actualización infotainment
@miceor , no se que le pasa a mi pantalla, h24 con la 346... Ayer por la noche y hoy se pulsa sola la pantalla... Te adjunto vídeo para que lo veas es un coñazo de cuidado , he restaurado, reiniciado y nada. Como dato los dos días tenía la calefacción para desempañar la luna, no se si tiene que ver, pero no sé que hacer...
He limpiado la pantalla varias veces.
golf_1990 - Asidu@ en la selva
- Agradecido: 12 veces
csabafr2013 - Asidu@ en la selva
- Agradecido: 13 veces
miceor escribió:No me acuerdo ahora mismo como lo tengo, cuando lo cambié yo me pasaba eso y estuve investigando en varias unidades y me hice unas tablas.
Unas las puse en el foro, pero creo recordar que yo lo solucioné poniendo :
Bit 0: Skoda
Bit 1: 3
Bit 1: 7
Bit 2: 3
Creo recordar que lo puse así para el León ST. Lo digo de memoria, no tengo los datos a mano.
Mañana lo miro.
Hola, @miceor cuando puedas, a ver si me comentas como solucionaste el problema... Yo si pongo SKODA, no me muestra ningún coche ni en car, ni en el resto de pantallas. Y al volver a SEAT pasa lo que se ve en el vídeo.
En el park pilot también me sale el corto en vez del st/xperience , no se si tendrá algo que ver lo de llevar el OPS.
por otra parte, el android auto no mejora prácticamente nada, y para tener unicamente de mejora los nuevos menús.. No se si merece la pena actualizar para los que no lo hayáis hecho todavía.
Enviado desde mi XT1092 mediante Tapatalk
- Seat Leon MK1 - FR TDI 150cv (2005)
- Seat Leon MK3 - X-Perience TDI 150cv (MY16)
nogard - Asidu@ en la selva
- Agradecido: 34 veces
Mucho rollo para tener 2 cosas nuevas. Me esperaré al concesionario y se lo comentaré.
Cup_Racing - Asidu@ en la selva
- Agradecido: 19 veces
Ya he encontrado donde lo anoté.
En mi caso me salia todo el rato el corto. Después de muchas pruebas que hice, pues ya sabes, cambiar todo lo que tenga relación con ello no me funcionaba nada.
Al final se conoce que entraba en conflicto con otro dato de otro modulo.
Lo cambiaba, aparecia y volvia a quitarse.
Total, yo lo solucioné cambiando esto:
En el modulo 08: (Si, ya sé que puede resultar raro, pero entraba en conflicto con este modulo)
Codificación extendida (Modo texto)
- Derivado del vehiculo -- Opciones : (Variant ) En mi caso es un ST.
Se me habia colocado como Berlina
- Variante carrocería -- Opciones : (A-Plataforma)
No me acuerdo como estaba, pero estaba cambiado.
Mira a ver si te funciona, a mi si que me funcionó.
- Agradecido: 1256 veces
Bueno, pues parece que ya lo tengo correctamente.
Cambié en la 8:
Derivado del vehiculo de "Variant" a "OFFROAD" y techo lo puse a "Techo panorámico"
Luego en la 5f
car_derivate de 3 a 2
Reseteé ajustes de System y Car
reinicie manteniendo botón
Y ya me aparece todo correcto, tanto en Car como el OPS, y el setup del clima.
Es cierto que entre todos esos pasos tuve algún que otro cambio pues al principio aparecía y desaparecía el modelo del coche según la pantalla que seleccionara... pero al final, parece (y crucemos los dedos) que se ha quedado, al menos visualmente correcto.
Siento no poder asegurar el procedimiento exacto que soluciona el problema, ya que como he comentado hubo mucho prueba-fallo e incluso tuve que dejar codificada la 5f de forma distinta a como estaba originalmente.
Gracias a @miceor por darme la pista para poder "solucionarlo".
Cambié en la 8:
Luego en la 5f
Ya te digo, menudo lio me armé yo con todos los cambios que habia hecho.
Al final lo puse como de fabrica y empecé de nuevo.
Me fuí anotando en postit los cambios, pero luego no los pasé a limpio como se suele decir y ya cuando vi que todo era Ok no me estuve a más, tema de bateria con tanto intento. (Bateria baja. Cargue circulando) y como mis notas son un poco raras (Creo que pienso en binario.Para pedir tres cervezas tengo que convertir binarios a hexadecimal. La ultima vez debí pedirlo en binrio y me pusieron 11)pues se me lió la cosa.
Además que es una jodienda que no se vea inmediatamente el tema y tengas que andar reiniciando con cada cambio.
Al final di con el problema de casualidad, ya no habia nada mas que pudiese cambiar en la 5F y dije , a ver si me la está liando otra UC y entra en conflicto?
Y así fué, justo en la 08 que supuestamente no debería interferir, pero si que lo hace.
Me alegro que lo hayas arreglado.
Si al final, poco a poco nos vamos haciendo con ello.
Hola miceor se puede poner todo de fabrica en my León y luego volver hacer todo con el obdeleven gracias
Cuando me he referido a ponerlo de fábrica, queria decir que he vuelto a poner todos los ajustes tal y como lo tenia en mi backup que hice cuando lo compré sin tocar absolutamente nada y que está en la primera pagina de este hilo.
(Sólo lo que necesitaba para partir de cero con esta modificación)
Ok gracias
Enviado desde mi iPad utilizando Tapatalk
Ya voy investigando aver si puedo arreglar lo del coche en el infoteimen Hable con un tío que trabaja en SEAT y me dijo que vendrá un día aver que pasa con esta fallo que tengo
Una pregunta, para que es la barra infrarroja de abajo de la pantalla, yo pensaba que era un sesnor pero no veo.que haga nada
Enviado desde mi XT1635-02 mediante Tapatalk
Frekiyo - Nuev@ por aqui
Frekiyo escribió:Una pregunta, para que es la barra infrarroja de abajo de la pantalla, yo pensaba que era un sesnor pero no veo.que haga nada
Creo recordar que si no tienes navegador no hace nada (ni siquiera tiene los infrarrojos). Al menos en las MIB gen1.
- Agradecido: 3575 veces
cvillajos escribió:Frekiyo escribió:Una pregunta, para que es la barra infrarroja de abajo de la pantalla, yo pensaba que era un sesnor pero no veo.que haga nada
Esa barra es el sensor de aproximacion de la pantalla..
- Agradecido: 368 veces
Usuarios navegando por este Foro: Google [Bot], guindilla01, lucky_38 y 22 invitados
