No con obdeleven
León Mk3 - Actualización infotainment
- Seguidores: 183
- Favoritos: 41
- Vistas: 574.248
Favoritos: BADS, Daruma, ositoerik, dmesanun, YeSL, pocososinos, jasoriab, JaviMarquez, crujipoyo, Arkan7, Cristianibias, pepeiyo69, Angel J, Xaggy, edumachuca, abollao, -alberto-, Rickymax, ferre7, Pedritoleon, Rivesgti, Alleya, davidalba, Xiguito_Corito, craken, JDCLEONFR, nemura, danihd, cenkkaya, Kisszabo, castell_lkpg, pistoleromtb, Raulportela, Martelinko, albert_naga, Adrian Anton, Gravilhas75, chaiser, popez, ruli68, denniisg2000
Seguidores: kenny_fonseca, ncx, Lavadora, juancete, jesusFR, Hysteria, MaximusRoco, Manu1986, Jorge75016, davidbj, bIxu, miyobe, MORKAS, aironsam14, jramis, kimudj, Maikermx, Javizormo, gogua, Melonkid, Kikote8, maxinew, aigort, carlosgzlez, corderazo, Lionxp, jande, Edu1589, msmdraven, Arkan7, jeroc, inamarlo, edumachuca, Josepo79, lead, camamaleon, davidmd, carrasco13, clavelstreet, mikomiko, josele77, car212121, itz18, golf_1990, LeidenSpain, vecnte, Andy_G, csabafr2013, leonfr76, Trimmer, genialsoft, Enerts, leonfrrojito, Horus, paco_22_22, ruben88, Valerofr150, molvi_mabad, Pekee69, Dav2k6, IbiFR, il_munyo, craken, ruben91mad, papo-182, el_padrino, zeratul, kaiserssosse, lytry32.hc, sbarri, ghitus, DesmoSimon, ruli68, Mramos1985, tonielfilas, braulioT, davidalba, JaviMarquez, osjamil, egarense69, fexposru, Pedrost, Illan, chetelopez, juanacho21, cuenka16, pepeiyo69, VapaV, balbu, juan7777, mams69, Helrique, Kike77, volkov, jluis, loeches, Tom70, Dconnect, Trivi83, MilleMiglia, linxes, sergi303, hector37, D83, quiquito30lv, ElFon, DALOFER17, davidap13, kigua, JOTTA, Senuto, jd_zuri, Alvi, damsolu, Leon pucelano, javi_archi, danihd, alcoleazgz, miguel23and, xarlio, jdieztec, mitxuni, Kisszabo, Gendos22, xexpir, canijo82, Brandenor, cenkkaya, kennit0, Chelazo, bertoco, benitogomez, carlosVACA, Peje, NOECUBI1, AAAJDA, trazas, martija, borjiguez, JoseXS, ferbarroso14, Wespa, Cloud_ganora, Berbe15, Valengti, Chrohu, Atajunen, Victorzabal, jrm82, carlo13, iNFeCTeD, paralaxon, ateopoeta, pepo55, ribasxisco, Raulribarroja, ivanti, lopezm0, Rubén Flp, Warelio, Vagabundo, Rekoba, Octacon, matiaso, Alianma, Raulportela, Éugen91, Rivesgti, Mcm90, DaniR86, Gravilhas75, JuanNur78, el_Asturiano, Mr.Chuflas, albert_naga, juanfrancia, Seket, algabe, pistoleromtb, ebcuatro, [GuErRa], Mario Leon, tito68
csabafr2013 - Asidu@ en la selva
- Agradecido: 13 veces
Re: Actualización infotainment
golf_1990 escribió:
Que valores has modificado exactamente ? Con vag com ?
Mira más arriba lo que dijo miceor lo hice así y funciona perfectamente
miceor escribió:ALROMA87 escribió:cvillajos escribió:ALROMA87 escribió:Buenas a todos!
He actualizado mi 6,5" sin navi a la versión 546 y perfecto, la verdad, muy sencillo de utilizar.
Me salió el error 1555 pero con las indicaciones se ha borrado perfectamente. El único error que me aparece y no soy capaz de cambiar es que me aparece un león Style con llantas de 17 color plata y no he sido capaz cambiando parámetros ya que parece que cambia pero finalmente vuelve a salir el mismo.
Yo tengo un ST FR Blanco con techo, no pido que sea mi color, ni el techo, pero al menos si el modelo y variante. He probado muchas combinaciones, pero ninguna me da resultado.
Alguien me puede orientar que puedo revisar??
Gracias! Feliz Año!
Mírate post anteriores de @nogard y @miceor .
Cambiando parámetros en la 08 y 5F lo consigues.
Nada, he cambiado mil parámetros y no me sale, me sigue apareciendo todo el rato es style gris 5P que ya le estyo cogiendo hasta manía, jejeje. Tengo el valor en startup creen sticker en 2000, en los bytes todo correcto (y 3, 7, 3 para el ST), he mirado la unidad 08 y está en variant, pero nada, todo sigue igual, no me cambia nada... ya no se que hacer, si intentarlo con el Vagcom a ver...
Gracias!
Prueba como dijo @Nogard:
En la 08:
Derivado del vehiculo de "Variant" a "OFFROAD" y techo lo puse a "Techo panorámico"
Luego en la 5f
car_derivate de 3 a 2
Reseteé ajustes de System y Car, reinicie manteniendo botón.
Y ya me aparece todo correcto, tanto en Car como el OPS, y el setup del clima.
Gracias , lo tengo casi todo solucionado!
Creo q me sale todo bien menos en el estado del coche que me sale un st fr NEGRO.me he cansado de poner modificaciones y no se dnd se pone blanco
Porque el resto de fotos q pongo es blanco o es gris???
jony83 - Leoner@ habitual
- Agradecido: 20 veces
El coche es de color negro en la pantalla porque tienes las puertas abiertas.
Cierra las puertas y lo verás como se tiene que ver.
- Agradecido: 1256 veces
miceor escribió:El coche es de color negro en la pantalla porque tienes las puertas abiertas.
De verdad???? Me dejas asombrado....Más de 30 min cambiando parámetros y nada...Como sea solo eso.
Muchas gracias genio!!
jony83 escribió:miceor escribió:El coche es de color negro en la pantalla porque tienes las puertas abiertas.
En las de 6,5" no sé, pero en las de 5,8" en la pantalla de "estado del vehículo" si hay algún error o problema el coche se vuelve negro y con cierta transparencia sobre el elemento afectado.
- Agradecido: 3572 veces
cvillajos escribió:jony83 escribió:miceor escribió:El coche es de color negro en la pantalla porque tienes las puertas abiertas.
Luego lo probaré con la puerta cerrada..Jeje
Gracias!¡
Hola chicos perdonar que pregunte esto a estas alturas del post pero estoy interesado en hacer la actualización pero tengo algo de lío de como saber que versión tengo yo en mi sistema y de como mirarlo.
Decir que el modelo de coches es un St cupra de mediados del 2016.
Perdonar por esta pregunta que antes de hacer nada tener claro lo que llevo.
Un saludo y gracias
Un saludo y gracias
Daruma - Primeros Pasos
- Agradecido: 5 veces
Daruma escribió:Hola chicos perdonar que pregunte esto a estas alturas del post pero estoy interesado en hacer la actualización pero tengo algo de lío de como saber que versión tengo yo en mi sistema y de como mirarlo.
Un saludo y gracias
Léete la página 61 en Tapatalk la entrada de nuestro compañero miceor que lo explica todo muy bien.
Para saber la versión en el Infotaiment en ajustes información del sistema o algo así lo puedes saber.
- Agradecido: 217 veces
Buenas compis, después de leer todas las páginas tengo una duda, para saber que versión lleva mi coche aprieto la tecla de Menú durante unos segundos y me sale ésto:
kiketo77 - Asidu@ en la selva
- Agradecido: 21 veces
Otra foto
Mi coche es de 30/12 /2015 FR PLUS sin Nav y pantalla de 6,5 ". Entiendo que el SW es 0245, no?. Pero el HW??.
kiketo77 escribió:Mi coche es de 30/12 /2015 FR PLUS sin Nav y pantalla de 6,5 ". Entiendo que el SW es 0245, no?. Pero el HW??.
Creo que es H25, pero para saber eso no tienes que apretar el botón de menú seguido. Con que vayas a Menú/Ajustes/información del sistema te lo dice. Pruebalo
Y que ventajas trae el actualizar? O novedades?
Enviado desde mi XT1635-02 mediante Tapatalk
Frekiyo - Nuev@ por aqui
Frekiyo escribió:Y que ventajas trae el actualizar? O novedades?
Vista cuadrícula ateca, modos de conducción como el ateca, alguna cosilla menor más y algo de fluidez pero poco. Desde que lo tengo instalado no se ha quedado pillado Android auto cuando lleva varias horas funcionando. Saludos
RUIDOS en el Nuevo Leon MK4 Foro: Leon IV - Mecánica / Electricidad / Electrónica Autor: Tik0 Respuestas: 398 |
Despues de 11 años dejo mi leon por un opel Grandland Foro: Presentaciones Autor: Carlolet Respuestas: 0 |
