Seguidores: golf_1990, josusanchez5b, Jastur, r11ourense, MerioE, davidddgt, jose.a.llamas, gato125, Pkt, byChule, Hovig, SorianoFco, jygalvan, CubanPitbull, corderazo, israher, iDavid9669, nyro, pirulo79, Edu1589, ramargo75, javi.ferrer, kikelin, aleejandroogm, Trimmer, car212121, LeoST, Besaygf, kinipc, Rasekfighter, Romera, MartinLeon, camamaleon, Aceroinox1a, jramis, Juanquique, josele77, marlop, Peje, Pedrost, bailyibz, wiki88, teltronik, gogua, sirkez, carlosgzlez, mcecho, genialsoft, aironsam14, JoseCa, Dandy_gsi, vanscampa, Joseibz, trekam, La_jungla, jorgecrackets, aigort, msmdraven, IRO, Jorge75016, alejandro_javier, ivan0909, jmfcoto, viktor_ct_95, maxxg2, olgalberto1, danifusi, Josepo79, er_trompe, miyobe, jande, Petri, itz18, jagman, serguey79, rafapadilla93, Mate, undernok, lead, lead, csabafr2013, jluis, olmeras, LeidenSpain, osjamil, Valerofr150, flope63, Herrdoktor, pocososinos, carrasco13, pichonclv, C.reina, Daner84, inamarlo, aguscalderon, BaZZ, yujakantabro, Fonek, LARABA, juanmaroger, juanmac, Kipu, IvanMc2, garrafa2, Linker89, mihai G, Igor, bronce702, creasy1977, Gsclosada, lebowski, jaro_84, charly425, leonfr76, DBS83, joseanvazquez501, M3rs, borgio, NOCIVOX, FcoJ.M.N., VillaSB, t4alberto, lytry32.hc, david_gz, Kasky, diegol147, jasoriab, jninomo, jmiturbe, chetelopez, utopia95, Dreziel, jonatan1988, xsoldadito, Illan, Fernandoestrada, jd_zuri, Juande667, xjuliox, Bettor, solanomor01, Chinyero, volkov, braulioT, Maikermx, iNowack, D83, MORKAS, dRoXe, JaviMarquez, danitre, Davi_TGI, DiegoR, ertate, cuenka16, nicotzioras, Spok68, urbion, linxes, kukikukarron, Talnoseque, Hyperr, VapaV, jfermar, Moigijon, slyjay73, DuckToy, nachomart, Iosu21, sbarri, sebasresa, Beiró, Llisus, agus_piscis10, Action SVG, Alc16, Trivi83, eyebee, riclanico, Per3zo, Qore, lolorm, abollao, Alvi, sergi303, Xilenos, barret, Gus_Fring, malloc, TomH30, jmofcb, paco_22_22, luigi323, Chelazo, dani10s, victor david, Yeiem93, Luiggi7, Guillen222, yoflipo, nenazojuanma, nitro_g4074, Senuto, gabivvamesia, javichu312, richard_11, Yery, Ivensound, El_pelos44, rvicario76, Mr.Chuflas, subaru_3, eruizm, Gomez89, barubita, Nicoplas, javibmw, el_noi_80, kapi21, satoo, barrosdepor, camaon99, craken, Flow-Rider, Castro87, Kikedecefe, xexpir, Cristian2014mx, _Juansp, jornefra, cucci, Pablitofr, Pablitofr, Rober_SR, kevinhtbs, chocoleitos, RamonLaC, cesarsl, drnrd, conquepoquico, hectordrums, Neuw84, bertoco, dondani96, cupralex, Octacon, pablomus85, josean-opc, davidap13, Raaz, erlanz, canijo82, MarcosRG86, Alianma, SinName, mSx, evomaoleon, BertopenST, a.cuadros71, Lumara, Gendos22, borjayadri2, litllevill, Jandrew, galelir, Josep20, borjiguez, THC77, di360, Juanjocantabria, grijan 2.0, copii92, JDMG, Morales92, nadiia.bcn93, yo_javi89, yurkli, Atajunen, carlo13, Desertcuervo, floppy666, amg129, manjerico, Franr50, iNFeCTeD, Rotemburgero, Link, kivamz, dj_ferrix, manu5, Vagabundo, aaronfdez, Manzi, Perilla, juanaco, pepetgi, pistoleromtb, cp_jj, diepecu2, Freddy169, Welmonk, JaquetónST, alrodri, LuisNM, Rekoba, bizu, ginyu 83, ephreon, rr7mo, Def89, CrisFRST5F, Mohoska, gilen44, ayl, SantiPMI, Jesús Peinado, 05kar, Lata8, Adrián pcg, Warelio, carlosVACA, trazas, barris31, danieleon, enriquevalera, antonioagui95, tito68, Sarge86, victorvOrtiz, bigpicha, ericoperico, JulinM, AlvaroRamlo, josermancol, Davidv, flotter, V de Viana, zainao, LeónST, rubiotuning, RacingSport
Notapor Gerni9 el 12 Ene 2017, 20:13
Sen escribió:
Gerni9 escribió:Buenas. Activando el mod de los cornering cuando funcionarían? Con las luces de cruce o cuando vamos con las luces DRL solamente.
me funcionan cuando llevo encendido cruce, con los intermitentes y la marcha atras
Yo las he activado desde las aplicaciones de la app y funcionan solo hasta 35km/h
¿Sabéis si hay forma de variar el parámetro de la función para aumentar la velocidad?
Ok. Gracias. Hay un mod que puedes variar la velocidad en la que se encienden. Lo tienes al principio en los mods.
Última edición por Gerni9 el 12 Ene 2017, 20:17, editado 1 vez en total
Gerni9
Notapor mikomiko el 12 Ene 2017, 20:14
Hola a todos, tengo una pregunta para @miceor o si alguien ha activado Mas de un usb, si le ha funcionado con algun hub en concreto o si tiene que tener alguna característica determinada, yo lo he activado y no me detecta Mas de 1 usb, lo he probado con 2 pen, uno 2.0 y otro 3.0 , y si connecto uno solo funcionan bien, si conecto 2 so detecta uno, sabeis que puede pasar para que no funcione??
Enviado via Tapatalk
mikomiko
Agradecido: 16 veces
Notapor XaGiCo el 12 Ene 2017, 21:03
cvillajos escribió:Creo que dando de alta la centralita de remolque en el Gateway (módulo 19) y no sé si hará falta codificarla, pero desconozco el procedimiento por completo...
No sé si alguien de por aquí la tiene y puede indicarte qué dar de alta en el "Instalation List" de la 19 (¿La "69-Trailer" puede ser?) y/o si hay que poner alguna codificación/adaptación en la misma, aunque si dices que ya te la configuraron y dejaron funcional, quizá con dar de alta es suficiente.
Mi coche venía de serie!
Pero alguien me facilitó el documento oem!
En el PDF 1.4 páginas 178 y 179
En el PDF buscar que también está el documento OEM
En este mensaje, XaGiCo ha recibido 2 agradecimientos de:
cvillajos (12 Ene 2017, 22:03), miyobe (12 Ene 2017, 21:16)
XaGiCo
Agradecido: 163 veces
Notapor lafu1988 el 12 Ene 2017, 21:06
mikomiko escribió:Hola a todos, tengo una pregunta para @miceor o si alguien ha activado Mas de un usb, si le ha funcionado con algun hub en concreto o si tiene que tener alguna característica determinada, yo lo he activado y no me detecta Mas de 1 usb, lo he probado con 2 pen, uno 2.0 y otro 3.0 , y si connecto uno solo funcionan bien, si conecto 2 so detecta uno, sabeis que puede pasar para que no funcione??
A mi me pasa lo mismo lo active el otro día y probé con un hub que tengo y no los detectaba. En el Infotaiment si salen pero sombreado como que no hay nada conectado.
lafu1988
Agradecido: 217 veces
Notapor lafu1988 el 12 Ene 2017, 21:08
Desde la misma aplicación has probado a desactivarlo?se queda como antes?
Lo de la velocidad del corning se hace así.Imagen
En este mensaje, lafu1988 ha recibido un agradecimiento de:
LeidenSpain (16 Ene 2017, 19:51)
lafu1988
Notapor Sen el 12 Ene 2017, 22:03
No he probado a desactivarlo pero debería quedarse como estaba, ahora me pregunto si hay algún límite para la velocidad de funcionamiento de las cornering, como veo que en el mod que has enviado pone cambiar a 60
Sen
Coche: Leon MK3 1.5 TGI 130cv
Notapor lafu1988 el 12 Ene 2017, 22:17
Yo es que estoy pensando si activarlo por la aplicación o manual. Me decanto por la manual porque así se lo que hace pero la automática te da la opción de activar y desactivar rápidamente para pasar la ITV y también desconozco si es compatible activar manual y desactivar con la aplicación o viceversa. Y si hacen exactamente lo mismo una o la otra.
Supongo que se podrá poner la velocidad que uno quiera pero no creo que sea muy legal a altas velocidades el corning.
lafu1988
Notapor mikomiko el 12 Ene 2017, 22:18
pues a mi no llega ni a salir en el infotaiment, solo un usb , no se que debo hacer mal :enfurecido:
mikomiko
Notapor lafu1988 el 12 Ene 2017, 22:28
Yo seguí los pasos del vídeo de Youtube y perfecto.
lafu1988
Notapor Sen el 12 Ene 2017, 22:36
A ver si alguien me puede ayudar, llevo una semana el aparato, lo recibí con un código de 200 créditos y realize el video que hay en Internet para obtener más créditos, el caso es que ahora llevo como 5 días que me pone hoy no hay mas créditos disponibles, pero así llevo 5días
Sen
Notapor txato70 el 12 Ene 2017, 22:46
hola.una pregunta para @miceor o @cvillajos o quien sepa,se puede activar con obd que al abrir y cerrar el coche se enciendan las luces?.es para un amiguete que no lleva sensor de luces.gracias de antemano.
txato70
Agradecido: 56 veces
Notapor lafu1988 el 12 Ene 2017, 22:50
txato70 escribió:hola.una pregunta para @miceor o @cvillajos o quien sepa,se puede activar con obd que al abrir y cerrar el coche se enciendan las luces?.es para un amiguete que no lleva sensor de luces.gracias de antemano.
En la página 1 de este hilo en el apartado de luces exteriores creo que está como activar el leaving home con y sin sensor. Revisalo
cvillajos (12 Ene 2017, 22:53)
lafu1988
Notapor lafu1988 el 12 Ene 2017, 22:52
Sen escribió:A ver si alguien me puede ayudar, llevo una semana el aparato, lo recibí con un código de 200 créditos y realize el video que hay en Internet para obtener más créditos, el caso es que ahora llevo como 5 días que me pone hoy no hay mas créditos disponibles, pero así llevo 5días
No te recomiendo que consigas créditos gratis con métodos raros porque el desarrollador puede saberlo. Es preferible entrar todos los días y ver algunos anuncios o hacer los mods a mano que son gratis sin créditos con la info que tienes en este hilo.
De todas formas yo forzaría detención de la app y borraría datos y volvería a empezar de nuevo para ver si así se soluciona. Saludos
lafu1988
Notapor txato70 el 12 Ene 2017, 23:04
ok.gracias le hechare un vistazo.
txato70
Notapor Cristianibias el 12 Ene 2017, 23:13
Bueno yo he solucionado el problema que tenia gracias a los videos del compi @miceor un saludo
Cristianibias
Usuarios navegando por este Foro: Chako y 10 invitados
