Lo de los bits es para realizar diferentes mods
Enviado desde mi SM-G900F mediante Tapatalk
León Mk3 - Actualización infotainment
- Seguidores: 183
- Favoritos: 41
- Vistas: 575.752
Favoritos: BADS, Daruma, ositoerik, dmesanun, YeSL, pocososinos, jasoriab, JaviMarquez, crujipoyo, Arkan7, Cristianibias, pepeiyo69, Angel J, Xaggy, edumachuca, abollao, -alberto-, Rickymax, ferre7, Pedritoleon, Rivesgti, Alleya, davidalba, Xiguito_Corito, craken, JDCLEONFR, nemura, danihd, cenkkaya, Kisszabo, castell_lkpg, pistoleromtb, Raulportela, Martelinko, albert_naga, Adrian Anton, Gravilhas75, chaiser, popez, ruli68, denniisg2000
Seguidores: kenny_fonseca, ncx, Lavadora, juancete, jesusFR, Hysteria, MaximusRoco, Manu1986, Jorge75016, davidbj, bIxu, miyobe, MORKAS, aironsam14, jramis, kimudj, Maikermx, Javizormo, gogua, Melonkid, Kikote8, maxinew, aigort, carlosgzlez, corderazo, Lionxp, jande, Edu1589, msmdraven, Arkan7, jeroc, inamarlo, edumachuca, Josepo79, lead, camamaleon, davidmd, carrasco13, clavelstreet, mikomiko, josele77, car212121, itz18, golf_1990, LeidenSpain, vecnte, Andy_G, csabafr2013, leonfr76, Trimmer, genialsoft, Enerts, leonfrrojito, Horus, paco_22_22, ruben88, Valerofr150, molvi_mabad, Pekee69, Dav2k6, IbiFR, il_munyo, craken, ruben91mad, papo-182, el_padrino, zeratul, kaiserssosse, lytry32.hc, sbarri, ghitus, DesmoSimon, ruli68, Mramos1985, tonielfilas, braulioT, davidalba, JaviMarquez, osjamil, egarense69, fexposru, Pedrost, Illan, chetelopez, juanacho21, cuenka16, pepeiyo69, VapaV, balbu, juan7777, mams69, Helrique, Kike77, volkov, jluis, loeches, Tom70, Dconnect, Trivi83, MilleMiglia, linxes, sergi303, hector37, D83, quiquito30lv, ElFon, DALOFER17, davidap13, kigua, JOTTA, Senuto, jd_zuri, Alvi, damsolu, Leon pucelano, javi_archi, danihd, alcoleazgz, miguel23and, xarlio, jdieztec, mitxuni, Kisszabo, Gendos22, xexpir, canijo82, Brandenor, cenkkaya, kennit0, Chelazo, bertoco, benitogomez, carlosVACA, Peje, NOECUBI1, AAAJDA, trazas, martija, borjiguez, JoseXS, ferbarroso14, Wespa, Cloud_ganora, Berbe15, Valengti, Chrohu, Atajunen, Victorzabal, jrm82, carlo13, iNFeCTeD, paralaxon, ateopoeta, pepo55, ribasxisco, Raulribarroja, ivanti, lopezm0, Rubén Flp, Warelio, Vagabundo, Rekoba, Octacon, matiaso, Alianma, Raulportela, Éugen91, Rivesgti, Mcm90, DaniR86, Gravilhas75, JuanNur78, el_Asturiano, Mr.Chuflas, albert_naga, juanfrancia, Seket, algabe, pistoleromtb, ebcuatro, [GuErRa], Mario Leon, tito68
Edu1589 - Asidu@ en la selva
- Agradecido: 9 veces
Re: Actualización infotainment
Edu1589 escribió:Lo de los bits es para realizar diferentes mods
Pero eso no tiene nada que ver con el menú ingeniero, eso es para activar el modo carbono...
(Como decías que lo estabas intentando activarle el menú ingeniero...)
Prueba a introducir el código 20103 en el apartado "Security Access - 16" antes de modificar el LongCoding de la 5F.
- Agradecido: 3575 veces
buenas, pantalla 5,8+navi, alguna actualización y si es así de donde la bajo y como la instalo gracias.
speed_crazy - Aun con la L
speed_crazy escribió:buenas, pantalla 5,8+navi, alguna actualización y si es así de donde la bajo y como la instalo gracias.
Estan por este hilo compañero...para la 5,8"..la versio 0480 o creo..[SMILING FACE WITH OPEN MOUTH AND COLD SWEAT]
- Agradecido: 368 veces
MORKAS escribió:speed_crazy escribió:buenas, pantalla 5,8+navi, alguna actualización y si es así de donde la bajo y como la instalo gracias.
llevo mas de 20 paginas leidas jeje. pero bueno seguire buscando.
speed_crazy escribió:MORKAS escribió:speed_crazy escribió:buenas, pantalla 5,8+navi, alguna actualización y si es así de donde la bajo y como la instalo gracias.
No recuerdo que pagina..te entiendo...
MORKAS escribió:speed_crazy escribió:MORKAS escribió:speed_crazy escribió:buenas, pantalla 5,8+navi, alguna actualización y si es así de donde la bajo y como la instalo gracias.
Pagina 41
Página 61 de Tapatalk
- Agradecido: 217 veces
Lo se,lo se. ...probé a meterle el código y lo acepta.....por eso pido ayuda. ..no creas que estoy tan confundido lo que pasa es que pruebo varias cosas y mods cuando uno me falla pues paso a otra cosa no sin antes quemar cartuchos antes de pedir ayuda...je je. Vamos haber si me explico mejor. ..en el caso de lo del menú ingeniero cuando entro en la 5f,en 16 security acces pongo el código y lo acepta.....entonces entro en 10 adaptation elijo el canal,lo modifico y le doy al do it! Y es cuando me dice eso de fuera de rango. por otra parte en los diferentes mods que estoy intentando hacer entre hueco y hueco de tiempo libre, ademas que estoy instalando la cámara de marcha atrás, pues me pasa eso de los bits que aparentemente los acepta pero que va tío. ..cuando vuelvo a entrar para verificar el cambio pues están como de origen.
He de decir que esto del Vagcom es nuevo para mi, y bueno recordar que llevo el sound System plus sin nav.de Julio del 2014 por si dentro de mi ignorancia e inexperiencia puedo aportar algo a este blog que me parece cojonudo y les doy las gracias a todos los cómpis que aportan tanto xq sin ellos nuestros fieras no serían únicos, serian otro coche más sobre el asfalto. GRACIAS CHAVALES GRACIAS.
Edu1589 escribió:Lo se,lo se. ...probé a meterle el código y lo acepta.....por eso pido ayuda. ..no creas que estoy tan confundido lo que pasa es que pruebo varias cosas y mods cuando uno me falla pues paso a otra cosa no sin antes quemar cartuchos antes de pedir ayuda...je je. Vamos haber si me explico mejor. ..en el caso de lo del menú ingeniero cuando entro en la 5f,en 16 security acces pongo el código y lo acepta.....entonces entro en 10 adaptation elijo el canal,lo modifico y le doy al do it! Y es cuando me dice eso de fuera de rango. por otra parte en los diferentes mods que estoy intentando hacer entre hueco y hueco de tiempo libre, ademas que estoy instalando la cámara de marcha atrás, pues me pasa eso de los bits que aparentemente los acepta pero que va tío. ..cuando vuelvo a entrar para verificar el cambio pues están como de origen.
Si consigues activar el menú de ingeniero puedes cambiar el fondo de carbono desde ahí mejor que desde bits de la 5F (que a varias personas no les ha funcionado).
Lo del menú oculto de desarrollador está probado con VCP, OBDeleven, y un "pajarito" (tú) me ha chivado se puede pero con VagCom mínimo versión 16.5.0 (yo eso no lo he visto todavía).
Edu1589 escribió:Yo he intentado activarle el menú ingeniero y me dice que fuera de rango o algo así. Y además no me deja modificar bits...bueno si me deja pero cuando le doy al éxit aún dando el mensaje de ok no se modifican xq al volver a entrar están como de origen.
Hay que cambiar la sesion de diagnostico a la de desarrollo, en el menu de obdeleven de la centralita, en la parte de abajo esta reinicia etc y ahi esta cambiar sesion
javigody - Aqui + que con la novi@
- Agradecido: 274 veces
Buenas me he descargado la actualizacion en la SD tal y como habeis dicho en el tutorial, para pantalla 5,8.
Bien este paso todo bien.. podria poner la SD y actulizarlo, pero aqui mi duda, no se si me saldrian fallos, y no podria corregirlos ya que no dispongo de vag com ni conocimientos ,,,
La pregunta es instalando la targeta sd con su archivo y actualizando mi pantalla de 5'8 serviria de algo? o necesito corregir errores si o si..?
gracias
gracias
speed_crazy escribió:Buenas me he descargado la actualizacion en la SD tal y como habeis dicho en el tutorial, para pantalla 5,8.
gracias
Puedes actualizar y el software sería 100% funcional. El error solo sale si se le pasa una diagnosis al coche (por ejemplo en la Seat). Pero si no te preocupa o no vas a pasar nada en garantía de la radio puedes dejar el error ahí perenne.
hakanFR - Nuev@ por aqui
Buenos días!
Tuve el problema que tuvimos varios al actualizar de que me aparecía en la pantalla continuamente un Style 5P y el mio es un ST FR.
Siguiendo las instrucciones de varios compañeros me metí en la 08 y cambie el vehículo a Offroad y ahora ya me funciona todo bien y ya me aparece el ST en pantalla en el acabado que le quiera poner, asique no se porque, pero esa centralita estaba en conflicto con la 5F, lo digo por si a alguno os pasa no os desesperéis que al final se consigue!
Saludos y muchas gracias!
Seat Leon ST FR 1.4 TSI ACT
ALROMA87 - Aun con la L
- Agradecido: 12 veces
