th23autolink_encode_start_9hrfrntiW2ltZzo5aHJmcm50aV1odHRwJiM1ODsvL2ltYWdpemVyJiM0NjtpbWFnZXNoYWNrJiM0Njt1cy92Mi8xNTB4MTAwcTkwLzkyMi9qWTk2UFgmIzQ2O2pwZ1svaW1nOjlocmZybnRpXQ==th23autolink_encode_end_9hrfrnti
th23autolink_encode_start_9hrfrntiW2ltZzo5aHJmcm50aV1odHRwJiM1ODsvL2ltYWdpemVyJiM0NjtpbWFnZXNoYWNrJiM0Njt1cy92Mi8xNTB4MTAwcTkwLzkyNC9Yd0NMVksmIzQ2O2pwZ1svaW1nOjlocmZybnRpXQ==th23autolink_encode_end_9hrfrnti
Je suis français c'est pas facile
Estoy Ç'est francés no es fácil
León Mk3 - Actualización infotainment
- Seguidores: 183
- Favoritos: 41
- Vistas: 575.942
Favoritos: BADS, Daruma, ositoerik, dmesanun, YeSL, pocososinos, jasoriab, JaviMarquez, crujipoyo, Arkan7, Cristianibias, pepeiyo69, Angel J, Xaggy, edumachuca, abollao, -alberto-, Rickymax, ferre7, Pedritoleon, Rivesgti, Alleya, davidalba, Xiguito_Corito, craken, JDCLEONFR, nemura, danihd, cenkkaya, Kisszabo, castell_lkpg, pistoleromtb, Raulportela, Martelinko, albert_naga, Adrian Anton, Gravilhas75, chaiser, popez, ruli68, denniisg2000
Seguidores: kenny_fonseca, ncx, Lavadora, juancete, jesusFR, Hysteria, MaximusRoco, Manu1986, Jorge75016, davidbj, bIxu, miyobe, MORKAS, aironsam14, jramis, kimudj, Maikermx, Javizormo, gogua, Melonkid, Kikote8, maxinew, aigort, carlosgzlez, corderazo, Lionxp, jande, Edu1589, msmdraven, Arkan7, jeroc, inamarlo, edumachuca, Josepo79, lead, camamaleon, davidmd, carrasco13, clavelstreet, mikomiko, josele77, car212121, itz18, golf_1990, LeidenSpain, vecnte, Andy_G, csabafr2013, leonfr76, Trimmer, genialsoft, Enerts, leonfrrojito, Horus, paco_22_22, ruben88, Valerofr150, molvi_mabad, Pekee69, Dav2k6, IbiFR, il_munyo, craken, ruben91mad, papo-182, el_padrino, zeratul, kaiserssosse, lytry32.hc, sbarri, ghitus, DesmoSimon, ruli68, Mramos1985, tonielfilas, braulioT, davidalba, JaviMarquez, osjamil, egarense69, fexposru, Pedrost, Illan, chetelopez, juanacho21, cuenka16, pepeiyo69, VapaV, balbu, juan7777, mams69, Helrique, Kike77, volkov, jluis, loeches, Tom70, Dconnect, Trivi83, MilleMiglia, linxes, sergi303, hector37, D83, quiquito30lv, ElFon, DALOFER17, davidap13, kigua, JOTTA, Senuto, jd_zuri, Alvi, damsolu, Leon pucelano, javi_archi, danihd, alcoleazgz, miguel23and, xarlio, jdieztec, mitxuni, Kisszabo, Gendos22, xexpir, canijo82, Brandenor, cenkkaya, kennit0, Chelazo, bertoco, benitogomez, carlosVACA, Peje, NOECUBI1, AAAJDA, trazas, martija, borjiguez, JoseXS, ferbarroso14, Wespa, Cloud_ganora, Berbe15, Valengti, Chrohu, Atajunen, Victorzabal, jrm82, carlo13, iNFeCTeD, paralaxon, ateopoeta, pepo55, ribasxisco, Raulribarroja, ivanti, lopezm0, Rubén Flp, Warelio, Vagabundo, Rekoba, Octacon, matiaso, Alianma, Raulportela, Éugen91, Rivesgti, Mcm90, DaniR86, Gravilhas75, JuanNur78, el_Asturiano, Mr.Chuflas, albert_naga, juanfrancia, Seket, algabe, pistoleromtb, ebcuatro, [GuErRa], Mario Leon, tito68
david06 - Nuev@ por aqui
Re: Actualización infotainment
For 5F (1555 error) read or translate "installation post" (and later comments) on page 41.
Regards!!
Regards!!
- Agradecido: 3575 veces
rojas escribió:Lo que dice @aprietatuercas1974 tiene mas sentido del que parece , vease el ejemplo de las actualizaciones de GPS ... si no es la SD original no funciona ya que lleva unas particiones ocultas que identifican si la SD es original o no .
Si alguien me dice que ha sido capaz de grabar una cartografia en cualquier otra SD y le ha funcionado ... yo me callo
Alguien ???
Informaticamente, si la comprobación es tan solo mediante particiones ocultas, se puede hacer una copia bit a bit de la tarjeta original a otra y ya estaría, porque seria una copia exacta.
A partir de aqui, se podría modificar la tarjeta copiada.
ruben88 - Aun con la L
- Agradecido: 8 veces
Claro que se podria, además para estos casos existen aplicaciones de alto nivel que lo hacen automaticamente.
Con CloneUp yo he clonado tarjetas con particiones ocultas bit a bit quedando perfectamente operativas.
Más jodido que clonar mochilas usb para programas empresariales no va a ser y he clonado unas cuantas con otras aplicaciones innombrables.
- Agradecido: 1256 veces
cvillajos escribió:For 5F (1555 error) read or translate "installation post" (and later comments) on page 41.
Regards!!
th23autolink_encode_start_97mjxd15W2ltZzo5N21qeGQxNV1odHRwJiM1ODsvL2ltYWdpemVyJiM0NjtpbWFnZXNoYWNrJiM0Njt1cy92Mi8xNTB4MTAwcTkwLzkyMS81bkZuM3EmIzQ2O2pwZ1svaW1nOjk3bWp4ZDE1XQ==th23autolink_encode_end_97mjxd15
Le code ne va pas
el código no lo hará
Intentatando actualizar mi media system plus...durente la instalacion me salio estos errores y el aparato yo no funciona mas..sigue dandose restarts y sigue asi con el contacto quitado durante horas...
Sabeis si puedo hacerle un reset de fabrica con obd?
O como poder hacerlo como antes?
aqui son las fotos
Un Saludo
aqui son las fotos
Un Saludo
Última edición por phantome el 01 Mar 2017, 08:21, editado 1 vez en total
phantome - Nuev@ por aqui
david06 escribió:cvillajos escribió:For 5F (1555 error) read or translate "installation post" (and later comments) on page 41.
Regards!!
Le code ne va pas
Insert a white space between 'F3' and 'B9'. Just like this "F3 B9" with VagCom interface.
Regards!!
phantome escribió:Intentatando actualizar mi media system plus...durente la instalacion me salio estos errores y el aparato yo no funciona mas..sigue dandose restarts y sigue asi con el contacto quitado durante horas...
aqui son las fotos
Formatea y graba de nuevo la actualización en la SD. Puede que algún archivo se haya quedado corrupto y no lo pueda leer correctamente.
Vuelve a empezar el proceso de actualización a ver si reacciona.
No hay manera de dejarlo "como antes" (o downgrade) sin el firmware original disponible, que creo que no está publicado por ningún sitio, al menos por aquí...
No se ven muy bien las imágenes pero parece que te paso como a mi, el problema es que algún archivo no se copio bien.
Vuelve a copiarlo y ten pulsado el botón de apagado hasta que se reinicie así conseguí yo que continuará la instalación.
- Agradecido: 354 veces
Muchas gracias para los consejos,he vuelto a grabar un otro usb con los ficheros y al conectarlo al coche ya funciono,parece que la problema era del pen que no grabava bien los ficheros y aparecian como coruptos.
Muchisima Gracias para ayuda.
cvillajos escribió:david06 escribió:cvillajos escribió:For 5F (1555 error) read or translate "installation post" (and later comments) on page 41.
Regards!!
Le code ne va pas
Regards!!
th23autolink_encode_start_lwxuooknW2ltZzpsd3h1b29rbl1odHRwJiM1ODsvL2ltYWdpemVyJiM0NjtpbWFnZXNoYWNrJiM0Njt1cy92Mi8xNTB4MTAwcTkwLzkyMy9pRDF1YzEmIzQ2O2pwZ1svaW1nOmx3eHVvb2tuXQ==th23autolink_encode_end_lwxuookn
th23autolink_encode_start_lwxuooknW2ltZzpsd3h1b29rbl1odHRwJiM1ODsvL2ltYWdpemVyJiM0NjtpbWFnZXNoYWNrJiM0Njt1cy92Mi8xNTB4MTAwcTkwLzkyMy8wc2lRSGsmIzQ2O2pwZ1svaW1nOmx3eHVvb2tuXQ==th23autolink_encode_end_lwxuookn
Creo que el código se pasa, pero la pantalla permanece en negro un poco de luz
la bomba de la batería
je pense que le code est passé mais mon ecran reste noir un peu allumer
sa pompe sur la batterie
Adresse 5F: Electr. d'informat. (J794) Labels: Aucun
No. pièce Log: 5F0 035 846 A Mat: 5F0 035 846
Pièce: MU-S-N-ER 039 0480
No. de série: E1F03101130092
Codage: 04730001D70A000021110001000900002F0306040100010046
No. Atelier: WSC 02391 785 00200
Jeu de données ASAM: EV_MUStd4CPASE 002039
ROD: EV_MUStd4CPASE_SE37.rod
VCID: 2643A74459F2900E07-8072
Media Player 1:
Sous-système 1 - No. pièce Log: 5F0 919 603 A Mat: 5F0 919 603 A
Pièce: ABTmin_Std_Nv H45 0022
No. de série: SEZ8Z9M56008N6
es ce que c"est bon comme ça
son lo que es bueno como esto
Media Player 1:
Buenos dias, hace como dos semanas hice la actualización, todo ok, pero creo que ahora el volumen ha bajado ligeramente, tanto radio, como USB y fullink, alguien a percibido lo mismo o es cosa de la edad y perdida de audición por mi parte jajajajaja, no se si habrá forma de subir la ganancia de alguna manera con obd
Enviado desde mi Aquaris E5 mediante Tapatalk
davidz800e - Aun con la L
- Agradecido: 9 veces
davidz800e escribió:Buenos dias, hace como dos semanas hice la actualización, todo ok, pero creo que ahora el volumen ha bajado ligeramente, tanto radio, como USB y fullink, alguien a percibido lo mismo o es cosa de la edad y perdida de audición por mi parte jajajajaja, no se si habrá forma de subir la ganancia de alguna manera con obd
Activa el menú del desarrollador. Luego te vas al green menú y allí tienes una opción de "gain" creo que dentro de "Audiomgt".
Duda León mk3 DSG7 1.5TSI Foro: Leon III - Mecánica / Electricidad / Electrónica Autor: Alort Respuestas: 0 |
Usuarios navegando por este Foro: markinnen y 4 invitados
