León Mk3 - BRICO - Como instalar la cámara de parking
- Seguidores: 136
- Favoritos: 46
- Vistas: 544.923
Favoritos: JaviCG, Vampiro, J@VY, BADS, Daruma, cstrol, JorgeAnteloC, ipenalosa, MONTY DAKA, pirly, josele887, xurox, Nanox23, Carbono79, vallter, norchugo, Efremvidal, @turbina@, blankiblau, jorgee76, jliriz, Vilo, cuenxis, victir, Aras, Korath, Rasekfighter, Carrl, jdieztec, J-Frass, Tarzan, zacarias, Frannisesabe, Xperience, bronce702, sbarri, javieret69, Carlos Chea, Lotar, Alleya, miguelorly, craken, chemazz, xico, eMi1, Maverick.es
Seguidores: Linker89, car212121, franrx, davidalba, TRIBO, danieleon, Panchorin, Hecson.27, jmfcoto, aironsam14, JOTTA, MORKAS, Unaited, trekam, xandis, Jorge75016, Platanot, davidbj, Achehmg, marc.domenech.90, sadanyac, seat leon blanco, Marc.22, Peuero, er_trompe, GTI35, JoseCa, JaviCG, vigimuertos, rabazas, B.Fox, msmdraven, Tomcat7733, Txutxiysilvia, xabidh, cstrol, Carrl, El3ndil, yorky, bolche, LeoST, Diegokero, Rasekfighter, Budoka, IronTor21, marlop, xico, vanscampa, Tarzan, jorgee76, josemag, aigort, LuichiFR, SLon34, clavelstreet, nani_san, nyro, IVANIN9, rober1095, ivan0909, jose.jjg307, csabafr2013, P.carrizo.leonstfr, dookky, Edu1589, Dconnect, D83, Jeii90, inamarlo, Israel-FR, Herrdoktor, el_padrino, Kipu, aguscalderon, lebowski, juanmaroger, bailyibz, naikon_paul, Valerofr150, JAL, kennit0, Mramos1985, bronce702, kijute, juanmik, osjamil, Tonivn, Lotar, Tunnig, JaviMarquez, nitro_g4074, sergi303, ivan2017, Chema_Alvarez, ilargiman, jaumotix, sbarri, javierferriz, alcoleazgz, lecupra280, Colomer, Maikermx, luigi323, rents_80, jdiego75, Pedrost, damsolu, lead, Franr50, Dani2025, Leon pucelano, nachomart, castronight, victor david, bertoco, juan7777, Josep20, jakobitto, rr7mo, a.cuadros71, iNFeCTeD, Gendos22, VapaV, Chrohu, Ganyula, snowpluralism, victor_leon_FR, luaiabou96, Drovniak, Guillen222, leonfrrojito, justics, lopezm0, Romera, pedrorossello92, AlvaroRamlo
Re: BRICO como instalar la Camara de parking en Seat leon MK
Eso me pasa también a mi
Leon st fr 2.0 150cv
Alleya - Asidu@ en la selva
- Agradecido: 12 veces
Estoy utilizando el programa Vag Can Pro.
Alguien lo ha hecho con este programa?
Tarzan - Nuev@ por aqui
miguelorly escribió:cvillajos escribió:miguelorly escribió:
hola,
yo tengo el leon 2.0 tdi 150 cv 2017 (restyling).
esta es la configuración que tendría que poner en mi caso???
Se puede hacer con obdeleven???
y otra cosa, un compañero del foro me podría dejar configurado lo del obdeleven este fin de semana pero la cámara la tengo que pedir y tardaría unas semanas en llegar. hay algún problema por cambiar la configuración y no dejar la cámara puesta??? o eso daría igual.???
estoy leyendo un montón en este hilo pero estoy un poco perdido.
Otra pregunta, he visto esta cámara en aliexpress. Alguien me puede decir si esta en concreto se podría montar o darme una opinión sobre ella???
http://s.aliexpress.com/nAzMvmIn
Yo la 76 no la tengo porque no llevo sensores, pero la 5F la dejé configurada un par de días antes de instalar la cámara, y sin problema... Pantalla negra al engranar marcha atrás y ya. Supongo que con la 76 tampoco habrá problema.
Lo que me tiene intrigado de esa cámara son las líneas de aparcamiento inteligentes... Supongo que se basará en algún sensor de movimiento propio de la cámara, porque no irá conectada al CanBus para "leer" la trayectoria de las ruedas (por lo que he visto en el anuncio). Habría que ver qué tal funciona, y quien sabe... Quizá cambie la mía si va bien...
coño pues si nadie ha probado esa cámara en concreto me da un poco de miedo por si luego algo no va. además veo que tiene ntsc y pal pero lo que viene activado por es ntsc. varios compañeros han escrito que las cámaras SOLO ntsc porque si no dan problemas
cuál es la que está metiendo la gente por aquí??? o me puedes dar alguna recomendación???
en mi coche tengo park assist y navi entonces teniendo eso en cuenta... la configuración de arriba me puede valer o si lo hago así puedo fastidiar alguna cosa??? estoy un poco acojonaete la verdad.
al final me pillé el vag com 17.1.3 porque resulta qeue un amigo lo tiene (versión antigua) y me convenció. me imagino que con este también puedo hacer estos cambios verdad??
Yo la que tengo es esta: http://www.ebay.es/itm/Coche-camara-de-vision-trasera-VW-LUPO-PASSAT-CC-GOLF-4-5-6-MK4-MK5-Seat-Altea-/252093128930?hash=item3ab1ebe0e2:g:nIYAAMXQPW5SDuGn
Es la segunda que monto (a la primera se le fundió el LED a los dos putos meses...) y de momento aguanta bien. Además su luz no es azul, es blanca (no como la primera) así que no tuve que estar jugando con vinilo azul para igualar tonalidades...
Sobre NTCS/PAL ya te han comentado... Mejor solo NTSC o una ya probada.
Sobre la configuración con VagCom y tu equipamiento sí, esa te valdría (es la misma que la indicada en el primer post del hilo).
Por último, el 17.1.3 te valdrá perfectamente... Pero ten en cuenta que a partir de esa versión la centralita 10 es la 76 (que es como siempre debería haber sido).
- Agradecido: 3572 veces
Alleya escribió:Acabo de instalar la cámara de video y me da error
OBDeleven Log de datos
Fecha: 2017-08-15 15:20
Numero de bastidor: VSSZZZ5FZGR240459
Coche: Seat Leon
Año: 2016
Tipo de carrocería: Sports Tourer
Motor: CRLB 110 kW (150 HP) 2 l
Kilometraje: 13707 KM
5F Electrónica de información
Descripción del sistema: MU-S--ER
Número de software: 5QA035824A
Versión de software: 0359
Número de hardware: 5QA035824A
Versión de Hardware: H30
Número de serie: SEZAZ2S0183702
Nombre ODX: EV_MUStd6C1TSAT
Versión ODX: 001015
Codificación extendida: 04730200D70A00001111000100080A002F0201D40120010002
Sub sistemas:
Descripción del sistema: ABTm_Std2
Versión de software: 1031
Versión de Hardware: H44
Número de serie: SEZ8Z9SLL01V0U
Codigos de error:
B106113 - Altavoz de agudos delantero izquierdo Interrupción
Esporádica
B110231 - Cámara de marcha atrás no hay señal
Estática
Date: 2017-08-15 15:09:51
Mileage: 13707 km
Prioridad: 3
Contador de la frecuencia con que se producen las averías: 1
Borrador de averías sin confirmar: 152
Datos ambientales dinámicos: 02867A
Podéis echarme una mano?
Si has probado la cámara de manera aislada en casa y te funciona te diría que revisaras las conexiones del QuadLock de la unidad de la guantera para el segundo error.
El primero es esporádico. Lo borraría y revisaría si vuelve o no a salir.
Gracias lo revisaré mañana
Lo de las interferencias no sabría decirte. Puede que no esté haciendo bien contacto el RCA o no viaje limpia la señal...
Lo del error de ParkPilot es porque has modificado algo de más que no deberías... ¿Qué cosas has cambiado al final?¿Tocaste solo el byte 18 de la 5F o has modificado algo más? (ya te dije que sin sensores el byte 19 no había que tocarlo, ni la centralita 10~76 que, lógicamente, no tendrás...).
Solo cambien el byte 19 bit 4. Nada mas, tal y como me dijiste.
Probaré a revisar la instalación por si acaso .
¿Alguien ha probado una de esas cámaras inalámbricas que venden ahora en aliexpress?
gesnazo - Asidu@ en la selva
- Agradecido: 7 veces
Solucionado ya se ve bien había puesto los cables al revés así que los cambie y se ve perfectamente
Gracias cvillajos
Gracias cvillajos
Prueba a cambiar los cables el 6 al 12 y el 12 al 6 yo los puse al revés por error a lo mejor te a pasado lo mismo
Buenas
Pues un día después de conseguír que se vea la imagen de la cámara hago un escaneo y me da todos estos errores
Fecha: 2017-08-17 13:59
Coche: Seat Leon
Año: 2016
Kilometraje: 13866 KM
01 Electrónica del motor
Descripción del sistema: R4 2,0L EDC
Número de software: 04L906026BN
Versión de software: 1197
Número de hardware: 04L907309R
Versión de Hardware: H23
Nombre ODX: EV_ECM20TDI01104L906026BN
Versión ODX: 002002
Codificación extendida: 01190012032401080000
Codigos de error:
No hemos encontrado códigos de error
03 Electrónica de los frenos
Descripción del sistema: ESC
Número de software: 5Q0614517AQ
Versión de software: 0400
Número de hardware: 5Q0614517AF
Versión de Hardware: H62
Número de serie: 63036000001483
Nombre ODX: EV_Brake1UDSContiMK100ESP
Versión ODX: 036010
Codificación extendida: 19EE62922424096C447B060540CC249846249022600224720061F070C022420000000012121212B835351919323200
Codigos de error:
08 Control del aire acondicionado/calefacción
Descripción del sistema: Climatronic
Número de software: 5F0907044AD
Versión de software: 1601
Número de hardware: 5F0907044AD
Versión de Hardware: H05
Nombre ODX: EV_ACClimaBHBVW37X
Versión ODX: 006142
Codificación extendida: 02000124200110011105000000101020
Codigos de error:
09 Centralita electrónica
Descripción del sistema: BCM MQBAB H
Número de software: 5Q0937084CL
Versión de software: 0175
Número de hardware: 5Q0937084AN
Versión de Hardware: H24
Número de serie: 01061628701908
Nombre ODX: EV_BCMMQB
Versión ODX: 015001
Codificación extendida: 08500B42424102FB43E0400041040328100E000000000000000000000000
Sub sistemas:
Descripción del sistema: WWS370 161005
Versión de software: 0574
Versión de Hardware: 041
Número de serie: 161018031929
Codificación extendida: 0BC5FD
Descripción del sistema: RLHS
Versión de software: 0105
Versión de Hardware: 042
Número de serie: S2Y16M10D21H07M26S23
Codificación extendida: 06095D
Codigos de error:
15 Airbag
Descripción del sistema: Airbag VW20
Número de software: 3Q0959655AS
Versión de software: 0200
Número de hardware: 3Q0959655AS
Versión de Hardware: 013
Número de serie: 003SQPN43LMQ
Nombre ODX: EV_AirbaVW20TS6VW48X
Versión ODX: 001116
Codificación extendida: 98CCC000000000005C0000CC000800000065
Sub sistemas:
Descripción del sistema: SideSensor_Df
Versión de software: 0887
Versión de Hardware: 008
Número de serie: 3576U000000A6044DE1H
Codificación extendida: 2D2D2D
Descripción del sistema: SideSensor_Pf
Número de serie: 3586U00000087435DE1L
Descripción del sistema: SideSensor_Dr
Versión de software: 0148
Versión de Hardware: 301
Número de serie: 3516RFF29EF0C000000
Descripción del sistema: SideSensor_Pr
Número de serie: 3526RBAC02E0D000000J
Descripción del sistema: FrontSensor_D
Versión de software: 0149
Versión de Hardware: 304
Número de serie: 3556VE5C64D0D000000V
Codigos de error:
16 Electrónica de la columna de dirección
Descripción del sistema: Lenks. Modul
Número de software: 5Q0953507GT
Versión de software: 0140
Número de hardware: 5Q0953549E
Versión de Hardware: 003
Número de serie: 23101604221380
Nombre ODX: EV_SMLSKLOMQB
Versión ODX: 020002
Codificación extendida: 2C00
Codigos de error:
17 Cuadro de instrumentos
Descripción del sistema: KOMBI
Número de software: 5F0920741D
Versión de software: 8311
Número de hardware: 5F0920741D
Versión de Hardware: 206
Nombre ODX: EV_DashBoardVDDMQBAB
Versión ODX: 009051
Codificación extendida: 07AD120069840008000832021000000000000000
Codigos de error:
U111000 - Funcionamiento parcial por fallo en la comunicación
Esporádica
Date: 2017-08-16 12:47:26
Mileage: 13769 km
Prioridad: 6
Borrador de averías sin confirmar: 194
Esporádica
Date: 2017-08-16 12:47:27
Mileage: 13769 km
Prioridad: 6
19 Interfaz de diagnóstico de datos
Descripción del sistema: GW MQB High
Número de software: 5Q0907530AM
Versión de software: 2265
Número de hardware: 5Q0907530M
Versión de Hardware: 212
Número de serie: 15101610522892
Nombre ODX: EV_GatewConti
Versión ODX: 013020
Codificación extendida: 030100F40F087300FB0002C8080F00010001050000000000000000000000
Sub sistemas:
Descripción del sistema: J367-BDMConti
Versión de software: 1050
Versión de Hardware: H03
Número de serie: 75410803001610206006
Descripción del sistema: E221__MFL-PR6
Versión de software: 0130
Versión de Hardware: H04
Número de serie: 000000000A1269300916
Codificación extendida: 002000
Codigos de error:
U006500 - CAN del infotenimiento no hay comunicación
Esporádica
Date: 2017-08-16 12:47:24
Mileage: 13769 km
Prioridad: 2
Tensión de alimentación borne 30: 12.4 V
Borne 15: on
Datos ambientales desconocidos:
42 Electrónica puerta del conductor
Descripción del sistema: TSG FS
Número de software: 5Q4959593E
Versión de software: 0031
Número de hardware: 5Q4959593B
Versión de Hardware: 010
Número de serie: 0000224656235
Nombre ODX: EV_DCUDriveSideEWMAXCONT
Versión ODX: 006001
Codificación extendida: 00100320DC00040000001000
Sub sistemas:
Descripción del sistema: FOND_FHSG_DRV
Versión de software: 0005
Versión de Hardware: 005
Número de serie: 00000000000011998110
Codificación extendida: 310000
Codigos de error:
44 Dirección asistida
Descripción del sistema: EPS_MQB_ZFLS
Número de software: 5Q0909144T
Versión de software: 1072
Número de hardware: 5Q0909144R
Versión de Hardware: 129
Nombre ODX: EV_SteerAssisMQB
Versión ODX: 013144
Codificación extendida: 9103
Codigos de error:
52 Electrónica puertas pasajeros.
Descripción del sistema: TSG BFS
Número de software: 5Q4959592E
Número de hardware: 5Q4959592B
Número de serie: 0000223312976
Nombre ODX: EV_DCUPasseSideEWMAXCONT
Versión ODX: 006001
Codificación extendida: 00100320DE00040000001000
Sub sistemas:
Descripción del sistema: FOND_FHSG_PSG
Número de serie: 00000000000012028112
Codificación extendida: 290000
Codigos de error:
55 Nivelación de los faros
Descripción del sistema: LWR-ECU
Número de software: 5Q0907357
Versión de software: 0080
Número de hardware: 6R0907357A
Número de serie: --------------
Nombre ODX: EV_HeadlRegulVWLWRMQB
Versión ODX: 001110
Codificación extendida: 038A000009000000
Codigos de error:
Versión ODX: 001015
Sub sistemas:
Codigos de error:
Esporádica
Date: 2017-08-16 12:45:29
Mileage: 13769 km
Prioridad: 3
Datos ambientales dinámicos: 02867C
76 Aparcamiento asistido
Descripción del sistema: PARKHILFE 8K
Número de software: 5Q0919294K
Versión de software: 0054
Número de hardware: 5Q0919294A
Número de serie: 39331630211848
Nombre ODX: EV_EPHVA18AU3700000
Versión ODX: 002026
Codificación extendida: 0031051001
Codigos de error:
A5 Sensores frontales sistema asistencia al conductor
Descripción del sistema: MQB_MFK
Número de software: 5Q0980653G
Versión de software: 0060
Número de hardware: 5Q0980653
Versión de Hardware: H07
Número de serie: 10000612952
Nombre ODX: EV_MFKBoschAU370
Versión ODX: 001001
Codificación extendida: 0101010001020300000500000000000100
Codigos de error:
U112100 - Falta el mensaje del bus de datos
Esporádica
Date: 2017-08-16 12:47:28
Mileage: 13769 km
Prioridad: 6
: 54 °C
: 28.0 °C
: 0.00 km/h
: 12.3 V
Borne 15 ON: 486.0 s
Coche: Seat Leon
Año: 2016
Versión ODX: 002002
Codigos de error:
Versión ODX: 036010
Codigos de error:
Versión ODX: 006142
Codigos de error:
Versión ODX: 015001
Sub sistemas:
Codigos de error:
15 Airbag
Versión ODX: 001116
Sub sistemas:
Codigos de error:
Versión ODX: 020002
Codigos de error:
Versión ODX: 009051
Codigos de error:
Esporádica
Mileage: 13769 km
Prioridad: 6
Esporádica
Mileage: 13769 km
Prioridad: 6
Versión ODX: 013020
Sub sistemas:
Codigos de error:
Esporádica
Mileage: 13769 km
Prioridad: 2
Borne 15: on
Versión ODX: 006001
Sub sistemas:
Codigos de error:
Versión ODX: 013144
Codigos de error:
Versión ODX: 006001
Sub sistemas:
Codigos de error:
Versión ODX: 001110
Codigos de error:
Versión ODX: 001015
Sub sistemas:
Codigos de error:
Esporádica
Mileage: 13769 km
Prioridad: 3
Versión ODX: 002026
Codigos de error:
Versión ODX: 001001
Codigos de error:
Esporádica
Mileage: 13769 km
Prioridad: 6
: 54 °C
: 28.0 °C
: 0.00 km/h
: 12.3 V
@Alleya , Son todos esporádicos y a la misma hora "2017-08-16 12:47:26" salvo el de la 5F por comunicación con la cámara de marcha atrás dos minutos antes.
Esto pasa por dar el contacto con la unidad de la guantera sin conectar (A mí me salieron 9 tras la instalación por este motivo...)
Bórralos, no tienen mayor importancia.
cvillajos escribió:@Alleya , Son todos esporádicos y a la misma hora "2017-08-16 12:47:26" salvo el de la 5F por comunicación con la cámara de marcha atrás dos minutos antes.
Vale gracias lo seguiré vigilando de todos modos
Hoy a vuelto a dar error
Fecha: 2017-08-18 13:56
Coche: Seat Leon
Año: 2016
Kilometraje: 13946 KM
Versión ODX: 001015
Sub sistemas:
Codigos de error:
Esporádica
Date: 2017-08-17 22:51:27
Mileage: 13910 km
Prioridad: 3
Borrador de averías sin confirmar: 199
Datos ambientales dinámicos: 028691
Coche: Seat Leon
Año: 2016
Versión ODX: 001015
Sub sistemas:
Codigos de error:
Esporádica
Mileage: 13910 km
Prioridad: 3
Alleya escribió:Hoy a vuelto a dar error
Coche: Seat Leon
Año: 2016
Versión ODX: 001015
Sub sistemas:
Codigos de error:
Esporádica
Mileage: 13910 km
Prioridad: 3
Puede que éste tenga que ver con la instalación (los otros ya no aparecen)... ¿Cómo alimentas la cámara? ¿Dónde tomas tierra? ¿Qué has hecho con los cables RCA (central y maya)?
