León Mk3 - Actualización infotainment
Favoritos: BADS, Daruma, ositoerik, dmesanun, YeSL, pocososinos, jasoriab, JaviMarquez, crujipoyo, Arkan7, Cristianibias, pepeiyo69, Angel J, Xaggy, edumachuca, abollao, -alberto-, Rickymax, ferre7, Pedritoleon, Rivesgti, Alleya, davidalba, Xiguito_Corito, craken, JDCLEONFR, nemura, danihd, cenkkaya, Kisszabo, castell_lkpg, pistoleromtb, Raulportela, Martelinko, albert_naga, Adrian Anton, Gravilhas75, chaiser, popez, ruli68, denniisg2000, LeonFR80bsv
Seguidores: kenny_fonseca, ncx, Lavadora, barris31, juancete, ivantxe, jesusFR, Hysteria, MaximusRoco, Manu1986, Jorge75016, davidbj, bIxu, miyobe, MORKAS, gorkansr, aironsam14, jramis, kimudj, Maikermx, Javizormo, gogua, Melonkid, Kikote8, danirodrigueze30, maxinew, aigort, carlosgzlez, corderazo, Lionxp, jande, Edu1589, msmdraven, Arkan7, inamarlo, edumachuca, Josepo79, lead, camamaleon, davidmd, carrasco13, clavelstreet, mikomiko, josele77, car212121, itz18, golf_1990, LeidenSpain, vecnte, Andy_G, csabafr2013, leonfr76, Trimmer, genialsoft, Enerts, leonfrrojito, Horus, paco_22_22, ruben88, Valerofr150, molvi_mabad, Pekee69, Dav2k6, IbiFR, il_munyo, craken, ruben91mad, papo-182, el_padrino, zeratul, kaiserssosse, lytry32.hc, sbarri, ghitus, DesmoSimon, ruli68, Mramos1985, tonielfilas, braulioT, davidalba, JaviMarquez, osjamil, egarense69, fexposru, Pedrost, Illan, chetelopez, juanacho21, cuenka16, pepeiyo69, VapaV, AlvaroPM13, balbu, juan7777, mams69, Helrique, Kike77, volkov, jluis, loeches, Tom70, Dconnect, Trivi83, MilleMiglia, linxes, sergi303, hector37, D83, quiquito30lv, ElFon, DALOFER17, davidap13, kigua, JOTTA, Senuto, jd_zuri, Alvi, damsolu, Leon pucelano, javi_archi, danihd, alcoleazgz, miguel23and, xarlio, jdieztec, mitxuni, Kisszabo, Gendos22, xexpir, canijo82, Brandenor, cenkkaya, kennit0, Chelazo, bertoco, benitogomez, carlosVACA, Peje, NOECUBI1, AAAJDA, trazas, martija, borjiguez, JoseXS, ferbarroso14, Wespa, Cloud_ganora, Berbe15, Valengti, Chrohu, Atajunen, Victorzabal, jrm82, carlo13, iNFeCTeD, paralaxon, ateopoeta, pepo55, ribasxisco, Raulribarroja, ivanti, lopezm0, Rubén Flp, Warelio, Vagabundo, Rekoba, Octacon, matiaso, Alianma, Raulportela, Éugen91, Rivesgti, Mcm90, DaniR86, Gravilhas75, JuanNur78, el_Asturiano, Mr.Chuflas, albert_naga, juanfrancia, Seket, algabe, pistoleromtb, ebcuatro, [GuErRa], Mario Leon, tito68
Re: Actualización infotainment
Notapor flotter el 22 Ago 2017, 22:01
cvillajos escribió:
flotter escribió:Al actualizar cabe la posibilidad que funcione el desbloquear el VIM ?? Ya que hasta hora por ser gen2 no se podía hacer nada??? Sería una alegría muy grande
No entiendo tu pregunta (del todo...) El desbloqueo del VIM en las gen2 ha funcionado siempre... Para MirrorLink que es lo que bloqueaba en movimiento...
Pero si te refieres a reproducir archivos de video desde USB o SD eso no tiene nada que ver con el VIM, es una funcionalidad que tienes o no tienes (según el modelo de Infotaiment), y que yo sepa los nuevos firmwares no incorporan la misma en aquellos que no la tenían antes.
Perdón alomejor mis conocimientos eran erróneos yo es lo que me refiere para poder reproducir vídeos desde usb o sd si se podrá después de actualizar a 0346???
Es que el Toledo no tiene conector mitsumi y no puedo poner mirrolink o no tengo los conocimientos correctos
Si me lo podéis aclarar....
Un saludo y gracias
SEAT TOLEDO MK4 1.6 TDI
flotter
Coche: Leon MK2 2.0 16v 140cv
Notapor cvillajos el 22 Ago 2017, 22:20
Un saludo y gracias
Ya te lo comenté aquí: https://www.clubseatleon.net/viewtopic.php?f=9&t=110684&p=1986933&hilit=flotter#p1986933
No puedes poner Mitshumi (todas las investigaciones realizadas por aquí han sido infructuosas, que yo sepa) y no puedes reproducir videos desde USB o SD en una gen2 (salvo que sea el modelo High). Y ninguna actualización de firmware, que recuerde, te va a ofrecer esa nueva funcionalidad.
Tu única opción para ver videos en movimiento es comprarte un móvil compatible con MirrorLink ™ y hacer espejo 1:1 siguiendo el tutorial publicado o desbloquando VIM.
cvillajos
Agradecido: 3610 veces
Notapor flotter el 22 Ago 2017, 22:25
Un saludo y gracias
Tu única opción para ver videos en movimiento es comprarte un móvil compatible con MirrorLink y hacer espejo 1:1 siguiendo el tutorial publicado o desbloquando VIM.
Muchas gracias rezaremos para que dentro de un tiempo se pueda hacer algo jaja
flotter
Notapor davidalba el 22 Ago 2017, 23:40
El mío está actualizado a la ultima? Imagen
davidalba
Agradecido: 19 veces
Notapor flotter el 23 Ago 2017, 08:08
Buenas
Que diferencia tienen cuando unos son H24 y otros H41????
flotter
Notapor jasoriab el 23 Ago 2017, 10:19
davidalba escribió:El mío está actualizado a la ultima? [ Imagen ]
El mapa al menos sí, la 820 es la última versión que hay en la web para descargar en nuestros navegadores.
Respecto al HW, tengo exactamente la misma versión, y no me suena haber visto firmware más actualizado para él.
jasoriab
Agradecido: 2046 veces
Notapor stewei el 23 Ago 2017, 10:26
@davidalba ¿Qué tipo de navegador llevas, el nav plus con full link y hdd?
stewei
Agradecido: 465 veces
Notapor stewei el 23 Ago 2017, 10:30
Mantaray escribió:y para la H42 software 0319 hay algo? tambien tengo el sistem plus
@Mantaray Justo llevamos lo mismo, mismo HW y mismo SW... :lol:
stewei
Notapor jasoriab el 23 Ago 2017, 10:35
stewei escribió:@davidalba ¿Qué tipo de navegador llevas, el nav plus con full link y hdd?
Es un Navi System (no plus) ya que la referencia empieza por 6P0
http://www.navigation.com/is-bin/INTERS ... rope-Site&
jasoriab
Notapor gabri78 el 23 Ago 2017, 11:45
Hola
Por si alguno puede respondorme (hice la pregunta hace unos días pero quedó en el inicio de vacaciones).
1) para actualizar el firmware del león con pantalla 5.8, ¿es necesario hacer los pasos finales que se indican de conectar el elemento de diagnosis y borrar los errores?
2) modo milagro: y si finalmente actualizo el firmware, ¿podré actualizar los mapas aun no teniendo el mapcare? (león mk3 del 2013)
Gracias de antemano!
Gabriel
gabri78
Coche: Leon MK3 1.4 TSI 122cv
Notapor davidalba el 23 Ago 2017, 12:31
Exactamente. No es plus. Pero como no entiendo pregunto por si se tiene que actualizar
davidalba
Notapor MilleMiglia el 23 Ago 2017, 12:46
aprietatuercas1974 escribió:Creo que lo puedes hacer directamente,si encuentras los archivos claro
¿Esos de los que todo el mundo habla y nadie parece tener para compartir? Son un verdadero misterio... :cafe:
Exprimir las marchas cortas es un placer, exprimir las largas, un delito.
MilleMiglia
Notapor stewei el 23 Ago 2017, 13:02
Según leo, para las High esta la versión 0674, 0818 y 0897.....
stewei
Notapor flotter el 23 Ago 2017, 16:30
Buenas Tardes
despues de actualizar a la 330 he borrado los fallos y tal con obdeleven y luego se me quedaba el error ese que viene he cogido mi codigo y lo puesto en el calculador en el medio he puesto el codigo que pone ahi y se ha generado otro codigo lo he metido y he dado a guardar y me ha puesto funcion no disponible, he salido y he ido a borrar el fallo y me ha dejado sin problema, pues he seguido el procedimiento a la 346 he actualizado y tal pero me ha vuelto a salir el error del codigo otra vez?? que debo hacer??
he tenido un pequeño contratiempo, en la pantalla cuando salian en el menu el sensor de parking la foto del coche pues yo tenia un toledo en la imagen y ahora se me a cambiado a leon :( :( :( como solucionar eso??
luego cuando pueda subo el error para que lo venias
flotter
Notapor jeroc el 23 Ago 2017, 16:57
gabri78 escribió:Hola
Gabriel
1) no es imprescindible, todo funcionara correctamente, yo no lo hice hasta unos 2 meses despues de actualizar... Pero quedara un error grabado en la centralita que saldra al conectar al ordenador de la seat
2) No, continuaras sin poder actualizar
jeroc
Coche: Cupra Leon 1.5 TSI 150cv
